Review my HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-26-2008, 01:23 PM - Thread Starter
amonteiro's Avatar
Here's my initial build, any advice would be greatly appreciated.
Motherboard: P5K-VM
Processor E7200
RAM OCZ 6400 4GB
HDD: Caviar GP 1TB IntelliPower Serial ATA-300 Hard Drive OEM
I'm still looking for a case and video card and would just use the S/PDIF out for audio. Eventually I would add a blu-ray drive and a tuner card to the setup.
amonteiro is offline
post #2 of 8 Old 05-26-2008, 06:12 PM
sunny5011's Avatar
it seems good but why would you use laptop memory??
sunny5011 is offline
post #3 of 8 Old 05-26-2008, 08:16 PM - Thread Starter
amonteiro's Avatar
Good catch
I didn't realize it was laptop memory.
How about this Corsair 6400 instead.
post #4 of 8 Old 05-28-2008, 01:33 PM - Thread Starter
amonteiro's Avatar
After a lot of research today, I made some changes. Hopefully this is final.
Case - Antec New Solution NSK2480 Black/Silver 0.8mm cold-rolled steel MicroATX Desktop Computer Case 380W Power Supply
http://www.newegg.com/Product/Produc...tec-_-11129034
~ 89.99
Motherboard - ASUS P5E-VM HDMI LGA 775 Intel G35 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131237
~ 129.99
Processor - Intel Core 2 Duo E7200 Wolfdale 2.53GHz 3MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Produc...5052&Tpk=E7200
~ 131.99
HDD 1 (For Data) - Caviar GP 1TB IntelliPower Serial ATA-300 Hard Drive OEM
http://www.microcenter.com/single_pr...uct_id=0266876
~ 179.99
HDD 2 (For OS)- Western Digital Caviar SE WD800JD 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Produc...822135106#spec
~ 39.99
RAM - Kingston 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory
http://www.newegg.com/Product/Produc...82E16820134636
~ 83.98
Total - 655.93
post #5 of 8 Old 05-28-2008, 01:48 PM
sunny5011's Avatar
you might want to make your terabyte hard drive the second hdd because if anything happens then you wont have to format that hard drive
post #6 of 8 Old 05-28-2008, 01:57 PM
lakaw's Avatar
You could also create a 50GB partition on the TB HD and ditch the 80 GB HD.
lakaw is offline
post #7 of 8 Old 05-28-2008, 02:01 PM
Fredrik Rasmussen's Avatar
Yes, why put in a 80GB HDD today? It will just generate additional heat and noise.
Fredrik Rasmussen is offline
post #8 of 8 Old 05-29-2008, 08:30 AM - Thread Starter
amonteiro's Avatar
I was thinking of putting in the 80GB for the OS as HD1 (not HD2), with the assumption that it will speed up the computer since the OS and media are separated. The 80GB seems to be a lot faster too. Is this not the case?
Reply Home Theater Computers
