Music too loud, voices too quiet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-08-2008, 04:09 AM - Thread Starter
gomjabar's Avatar
I live in an apartment so I cant be too loud at all hours. Ive noticed with DVD movies that the music and sound effects are really loud compared to the voices. I find myself turning the volume up and down to compensate. Is there a software fix for this that would adjust these automatically?
gomjabar is offline
post #2 of 7 Old 07-08-2008, 04:58 AM
undermined's Avatar
yeah it is know as "dynamic range control" it is normally a option in the dvd playback software.
FYI it is not a bug or something it is on purpose that loud noises are loud in a movie because it better conveys a sence of realism when you listen at reference levels that are around 75db.
http://www.howstuffworks.com/question124.htm
This site has more info about sound levels
http://www.avforums.com/forums/archi...p/t-63165.html
and here is more talk of how that works in a home theater context
The basic idea is to have a dialoge be the same loudness as a person talking to you at a normal level so a explosion will be much louder.
The dynamic range control limits the range between how load and how quiet a given dvd will sound so quiet sounds are louder and loud sounds are softer for a given volume setting.
undermined is offline
post #3 of 7 Old 07-08-2008, 09:10 AM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
AC3filter has dynamic range control (DRC), and many AV receivers have a 'night mode' or something similar which is basically DRC too. The new Yamahas have a similar thing that kicks in at low volumes (you get DRC), and is off at high volumes (no DRC).
fitbrit is offline
post #4 of 7 Old 07-08-2008, 12:05 PM
spectrumbx's Avatar
Quoted: 31 Post(s)
Liked: 37
I think you just need to boost the center speaker level, reduce the sub-woofer level, and then fall back a tad bit on the volume.
spectrumbx is offline
post #5 of 7 Old 07-08-2008, 09:35 PM - Thread Starter
gomjabar's Avatar
The AC3 filter worked well. It even has a setting to increase Voice volume independently. Thanks for the tip
gomjabar is offline
post #6 of 7 Old 07-08-2008, 10:57 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Thanks for mentioning the voice volume thing... I think I'll look for it and use it myelf.
fitbrit is offline
post #7 of 7 Old 07-08-2008, 11:10 PM
pastishe's Avatar
I hate this as well, even if it is intentional, heh.
I use quiet mode on my av reciever and much prefer that over ****ting it everytime a plane takes off or someone drops a glass.
pastishe is offline
Reply Home Theater Computers
