Assembling HTPC in Origen S16V and S14V cases - AVS Forum | Home Theater Discussions And Reviews
post #1 of 190 Old 07-24-2008, 11:08 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
I built several HTPCs on Origen S16V and S14V cases and I think that some information and pictures may be helpful for other guys.
I planned to put all pictures here but they are to big so I provided link to my page only.
Zygmunt
Perfect Home Theater
Zygmunt is offline
post #2 of 190 Old 07-24-2008, 03:28 PM
SKaustin's Avatar
Thanks Zygmunt! I am planning to get a S14V to go with the new DG45ID motherboard.
I have a kind of stupid question that you prob know the answer to. When you buy the Origen from PCalchemy, it comes with VF210 VFD/IR Module included and Philips RC197 Vista remote included. But the IR221 is optional. I don't really understand what the IR221 offers. Wouldn't the included remote work with Vista through the IR receiver in the VF210? I don't know why I can't wrap my head around this.
SKaustin is offline
post #3 of 190 Old 07-24-2008, 03:31 PM
SKaustin's Avatar
Also, since you have built so many, can you confirm if the LG Blueray/HD-DVD long optical drive will fit?
SKaustin is offline
post #4 of 190 Old 07-24-2008, 05:33 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
There are no stupid questions. Sometimes there are stupid answers.
IR221 is for someone who needs blasters. RC197 will control your HTPC and can turn on/of TV/projector. If you have remote with macros you can program it to control all your equipment. (I use Universal Remote MX-3000 and control everything from it.)
If you need blasters you can add IR221 at any time. You will get two blasters with IR221 so turning ON/OFF your HTPC should turn on your TV/PJ and receiver/amplifier.
Zygmunt
Zygmunt is offline
post #5 of 190 Old 07-24-2008, 05:40 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
I didn't use this drive but it should fit. This drive is 185 mm long so it shouldn't interfere with memory. However if you use memory with high radiators like Patriot or Corsair it may, depends of your motherboard.
Optical drive sits 3/4" higher in 16V than 14V.
Zygmunt
Zygmunt is offline
post #6 of 190 Old 07-24-2008, 05:41 PM
carrera1's Avatar
I built a system using the S14V and the LG drive fit.
carrera1 is offline
post #7 of 190 Old 07-24-2008, 07:58 PM
SKaustin's Avatar
Thanks Zygmunt and Carrera1! Appreciate the help.
OK, this makes sense now. Since I have a Harmony 880 I can use it to do normal remote operations in Vista through the already-included IR. I only need the add-in board if I want to change channels on my cable box, etc. I have an external IR sensor with blasters hooked up to USB now and it works great. I will wait n see how it goes with the Origin box before deciding which direction to go.
Next question... how does the VF210's wake-up from off feature work for you? Does it work with all motherboards?
SKaustin is offline
post #8 of 190 Old 07-24-2008, 08:09 PM
ixion's Avatar
There are no stupid questions. Sometimes there are stupid answers.IR221 is for someone who needs blasters. RC197 will control your HTPC and can turn on/of TV/projector. If you have remote with macros you can program it to control all your equipment. (I use Universal Remote MX-3000 and control everything from it.)
Hi Zygmunt,
I need help... I've asked this in several threads with no responses...
I own a Universal Remote MX-900 which is RF with the MRF-300 basestation:
http://www.universalremote.com/produ...l.php?model=42
The whole thing will be hidden in a cabinet with the HTPC that I'm building based on the S14V or S16V.
What is the best way to get this to control an HTPC?
The basestation has mono-mini-jack serial outputs for emitters. Is there any way to connect the output to an HTPC without converting back to IR? Is there something out there that would allow the RF basestation output to be connected to a USB port or to the motherboard IR header?
ixion is offline
post #9 of 190 Old 07-24-2008, 08:20 PM
SKaustin's Avatar
Would an RF receiver do it? This one connects via serial port, and can use a USB-to-serial adaptor. ??? Here is another...
The W800RF32 family of RF receivers are designed to receive X10 RF signals generated from X10 products: Palm Pad remotes, key chain remotes, Hawkeye motion detectors, and many, many other X10 RF devices.
The W800RF32 then sends these commands directly to your computer's serial(RS232)port. This allows your computer to receive X10 RF commands from remotes and motion detectors directly, without having to broadcast any power line commands, thus minimizing power line clutter and improving home automation response times by bypassing the usual power line delay.
SKaustin is offline
post #10 of 190 Old 07-24-2008, 08:38 PM
ixion's Avatar
Thanks for your response.
That won't work because the RF of my remote is 418MHz narrowband. I guess what I'm looking for is either:
1) something that can take the output of the RF basestation and convert it to USB with a driver that recognizes everything as an MCE remote
OR
2) an 418MHz RF to USB receiver that I can plug directly into the HTPC, again with a driver that recognizes it as a MCE remote
Now I have seen these:
http://www.newegg.com/Product/Produc...82E16833998030
but they are 433MHz.
I can't be the only one in the world wanting to control an HTPC with my URC RF remote?? I Googled everywhere and cannot find a solution for this other than using IR emitters connected via a flasher to the IR eye on the HTPC.
What do people with automation like Crestron control systems do? Do they use emitters?
ixion is offline
post #11 of 190 Old 07-24-2008, 09:56 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Right.
If you can create long enough macro in your 880 you are all set. 880 will do everything if you copy commands from RC197 to 880.
I am sure that it does. I have no problem with any of them. VF210 sends command (received from remote) to motherboard to turn on and off.
Zygmunt
Zygmunt is offline
post #12 of 190 Old 07-24-2008, 10:11 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Hi Zygmunt,
I don't think so. I think that emitter is the only option with MRF-300 You can also use front blaster if you are short of emitters.
I don't know anything like that. If I have more complicated installation with a lot of equipment I use MSC-400 and serial ports together with flashers. (depend of equipment) In your case I would use emitter.
Zygmunt
Zygmunt is offline
post #13 of 190 Old 07-24-2008, 10:19 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Depends of equipment. Some devices take IR commands only.
Less expensive option than Crestron is URC system with MSC-400, the best receiver from URC with IR, RF, RS232, USB and trigger outputs.
Zygmunt
Zygmunt is offline
post #14 of 190 Old 07-25-2008, 07:10 AM
zyren's Avatar
I was thinking of getting the s14 but then i saw the pricetag of $379. After power supply, i'll be spending $300 more than i wanted to (vs antec fusion). Is the s14 really worth the extra price? Im not sure if i can justify that when i could spend the $300 on hardware components.
zyren is offline
post #15 of 190 Old 07-25-2008, 07:59 AM
Botero's Avatar
Part of the reason to buy these cases is because they are beautiful. Besides being really well put together and the layout being awesome, the reason you spend the extra cash is for the looks. Honestly it is like spending $4000 on a Knoll Barcelona chair... you can get a chair for $50, the extra $3950 is just because it looks amazing.
If you are going to sacrifice elsewhere to get this case, then it is not the case for you. Most of us buy these because the price isn't really an issue.
Botero is offline
post #16 of 190 Old 07-25-2008, 08:17 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
It depends what you are looking for. Origen S series are the best cases I worked on. Top quality, thick aluminum, perfect fit, quiet fans, nice remote and look good with other components.
If you have inexpensive equipment, go with something matching it.
If you spent many, many thousand dollars for amplifier, speakers projector and screen than
Zygmunt
Zygmunt is offline
post #17 of 190 Old 07-25-2008, 10:12 AM
hhb97ba's Avatar
Hi
Do you use IR221 in any of the builds? if so does it work well, because I have read somewhere that there has been problems with it. What software(girder, eventghost) do you use with IR210 and IR221
hhb97ba is offline
post #18 of 190 Old 07-25-2008, 10:48 AM
ixion's Avatar
Ok thanks Zygmunt. Emitters it is then.
ixion is offline
post #19 of 190 Old 08-14-2008, 08:37 PM
aslg's Avatar
I am planning to buy an OrigenAE S14V case and I have two questions:
1) I had a bad experience in the past with loud 60mm fans. Are the rear 60mm fans in the S14V quiet?
2) I noticed the horizontal placement of the PSU. I have a very quiet Corsair HX620 with a side 12cm fan I could recycle from another PC but I am worried that it will gasp for air in the S14V. Which type of PSU did the S14V owners install in the case? Anyone with a success story with a PSU with a side fan?
aslg is offline
post #20 of 190 Old 08-15-2008, 06:12 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Yes, they are.
Yes you can do it, because fan is up.
There is another problem with S14. You can't use high memory modules like OCZ Reaper HPC 4GB or G.SKILL 4GB (2 x 2GB). This memory will NOT fit under DVD drive in S14V.
I use this one for S14V.
Go with S16V. Only $20.00 more and it's one inch (25mm) taller. Advantage: No collision with tall memory DIMMs (unless very tall with huge radiators), 80 mm fans and vertical placement of PS - better cable management.
Zygmunt
Zygmunt is offline
post #21 of 190 Old 08-16-2008, 03:22 PM
aslg's Avatar
Thanks Zygmunt. I liked the skinnier look of the S14V but I agree with you that I lose too much in terms of flexibility inside the case.
I ended up preordering a silver S16V.
aslg is offline
post #22 of 190 Old 08-16-2008, 04:25 PM
aslg's Avatar
I ordered a OrigenAE IR221 module that I plan to use in place of the S16V built in IRTrans IR module. Can I completely avoid to install the IRTrans software or do I need to install the IRTrans "MCE Display Driver" feature?
aslg is offline
post #23 of 190 Old 08-17-2008, 06:38 AM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
I didn't install any IR software (from Origen). I used the built-in Vista IR driver and it works fine so far. The case dispay also works. the only issue I'm working on now is the remote jumps two selections at a time for every button press (in Media Center) so I have to use the mouse to go from Movies to Shutdown while in the VMC. I'm sure it is not a big deal to fix. Right now I'm copying movies to HD and reading this forum - so I'll get to that issue later.
CountryBumkin is offline
post #24 of 190 Old 08-17-2008, 08:11 AM
aslg's Avatar
CountryBumkin,
thanks!
Does this happen with the remote shipped with the S16V case?
I had that problem once with a logitech harmony remote and I fixed it decreasing the number of repeats.
aslg is offline
post #25 of 190 Old 08-17-2008, 08:44 AM
Quoted: 214 Post(s)
Liked: 54
CountryBumkin,
thanks!
yes. Both the Origen (Media Center) remote and my Harmony 550 do the same thing. I think it is just a matter of spending some time on the configuartion/setup.
I've got 85 DVD movies copied - about 100 more to go. Then I'll start fine tuning everything. Right now the HTPC is in my office hooked up to my LCD and I'm using the mouse and keyboard, so I can't really test/adjust/troubleshoot the remote.
post #26 of 190 Old 08-18-2008, 05:00 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
IR221 is not replacement but extension to Origen system. I prefer IRTrans over Vista driver.
No double jumping in Vista MC (Unless I press button for too long)
Zygmunt
Zygmunt is offline
post #27 of 190 Old 08-28-2008, 04:58 PM
Steve Young's Avatar
Can anyone tell me what kind of height a HSF can be in the S16V?
Steve Young is offline
post #28 of 190 Old 09-04-2008, 02:18 PM
helldiver667's Avatar
Hello!
I have assembled my HTPC with the Origen S16V today, but I don't run any operating system yet.
There is one thing I don't understand. How do I connect the VFD/IR-module to the mainboard. There is no USB cable included except the one for the two front-USB ports to get a connection.
Do I need the IR221-module to use the remote control?
I studied the pictures from Zygmunt, but I also didn't find any cable to connect the IR/VFD to the mainboard on that pictures.
Thanks for help!
Dennis
helldiver667 is offline
post #29 of 190 Old 09-05-2008, 11:49 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
You just connect USB to MB and power connector to PS and you are all set.
You have to download and install IRTrans software of course.
You don"t need IR221.
Zygmunt
Zygmunt is offline
post #30 of 190 Old 09-06-2008, 01:10 PM
mattsoft's Avatar
How are you guys connecting the fans for the S16V?
I have my CPU fan connected to the CPU header, the single intake fan connected to the motherboard SYSFAN header, and then I got a fan power splitter from my power supply to connect the dual outtake fans. Those outtake fans are SLOW, but quiet. Is that really enough airflow in there?
mattsoft is offline
Reply Home Theater Computers
