Hauppauge HDPVR-1212 Owner's Thread - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3901 of 3911 Old 04-17-2015, 09:21 AM
bpratt's Avatar
Originally Posted by AllenDB View Post
From the dark ages of rctvcap and rcgraphbuilder. My HTPC bit the dust in a major way a month ago. Its resurrection seemed a difficult task so I opted for the DVR option from DirecTV. While impressed with its capabilities I need to get the HTPC back up and running. I use rctvcap to record off two DTV boxes. To get rctvcap to run in the past I used rcgraphbuilder.
Now when I run rcgraphbuilder I get the dreaded "can't find filter: File Dump". Having grown a bit older since the early 2000 I can't remember how to get around this problem.
Somebody out there remember????
Please and thank you.
I haven't used rctvcap and rcgraphbuilder for many years now, but when I did, I used instructions from the following post:
http://blog.arogan.com/2008/06/haupp...odel-1212.html
good luck. I don't remember any more than you do on setting up this stuff.
bpratt is offline
post #3902 of 3911 Old 04-17-2015, 11:15 AM
AllenDB's Avatar
Quoted: 14 Post(s)
I've got the site but there is no help for rcgraphbuilder. Just says click the Build button. I might have to try the graphedit thingy.
AllenDB is offline
post #3903 of 3911 Old 05-25-2015, 02:25 PM
pmbtv's Avatar
Originally Posted by tightrope View Post
<div class="quote-container" data-huddler-embed="/t/1055232/hauppauge-hdpvr-1212-owners-thread/3720#post_23818759" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Hyrax</strong> <a href="/t/1055232/hauppauge-hdpvr-1212-owners-thread/3720#post_23818759"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
My Tivo has filled up its fairly small hard drive with stuff that I want to watch, but have not had the time to do so. Therefore, I've just started using the 1212 to move older recording s off my Tivo. Doing this manually, and one show at a time, works - but I wonder if there might be a way to automate the process. Has anyone got any ideas on how to make this easier?<br><br>
Thanks in advance.</div>
</div>
<br>
I use kmttg to copy shows from my Tivo to my PC, it works really well (as long as the shows are not copy-protected, obviously) and has a batch mode.<br>
It is free and can be downloaded from this link:<br>
<a href="http://sourceforge.net/projects/kmttg/" target="_blank">http://sourceforge.net/projects/kmttg/</a>
The Tivo Desktop, originally free but now costs $15 or $16, will easily move just about anything off your Tivo and into your Desktop. If you are capturing free programming off the antenna, it will come out as a Tivo file and the bitrate will be rather large. Unless that's the way you want it to be, youll have to use VideoRedo to edit (to delete commercials etc and then another software (plenty of free ones out there such as Handbrake) to make the total file smaller than the original. Even if you reduce by 50 percent or more, it still will look very good.
pmbtv is offline
post #3904 of 3911 Old 06-24-2015, 07:17 PM
MoonLaf's Avatar
Hi Allen,
Check my post here:
http://forum.videohelp.com/threads/3...=1#post2241647
I think it might help you.
Kind Regards,
Mouna.
MoonLaf is offline
post #3905 of 3911 Old 06-25-2015, 06:05 AM
AllenDB's Avatar
Quoted: 14 Post(s)
I finally got it working again. Went back and did some more reading.
AllenDB is offline
post #3906 of 3911 Old 06-25-2015, 06:45 AM
DigitalfreakNYC's Avatar
Quoted: 12 Post(s)
I seem to have a problem with all of my recorded files created with my Hauppauge 1212.
After recording, I edit using VideoReDo and then use MultiAVCHD to author a disc. All files that are authored come out with a jump at the beginning, with the files themselves losing 3 frames.
Now, the odd thing is that the files are still ok. If I wanted to re-encode all of them, I could and the problem would disappear so it's not as if something has been re-encoded or cut. It's a playback issue and it only happens after the editing from VRD. For example, if I took the raw file from the Hauppauge and authored that, it wouldn't be a problem.
However, I'd rather figure out what TSmuxer (by way of Multiavchd) is doing to the files. For some reason, whenever it gets a hold of them to change from ts to M2TS (or even just from .ts to .ts), they come out with this problem.
After asking people about this issue on videohelp, I was told that smartcutters sometimes screw around with the information in the header and that is most likely causing this problem. Does anyone have any experience with this type of issue or know how I could correct the header so that I don't have to re-encode all of my files?
I should also note that this is a problem with ALL Hauppauge files. It's not just the 1212 that's a problem. I've had people record things for me with other devices and they all have the same problem.
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #3907 of 3911 Old 07-19-2015, 06:38 PM
100Watt Warlock's Avatar
I tried looking through the threads, but, can I have both the HDPVR-1212 for cab/sat and a 2255 PCI-e card for ATSC from Hauphaugge?
Both work perfectly fine on their own. I found using a VERY short USB2.0 cable (12" with isolators) and a rear fan to the HT rack elminated 99% of jitters and stops.
Any suggestions? I still use Windows 7 MCE for my HTPC and aside from the HDPVR not working with the other card, its a pleasure to use.
100Watt Warlock is offline
post #3908 of 3911 Old 07-19-2015, 06:51 PM
SHS
SHS's Avatar
Quoted: 24 Post(s)
No, You need look at 3rdparty apps if want that work.
SHS is offline
post #3909 of 3911 Old 07-19-2015, 07:21 PM
IS that the DVBlink that you are describing or something other than MCE? I'd prefer to use MCE as wife/kids know it well now.
post #3910 of 3911 Old 07-19-2015, 08:59 PM
SHS
SHS's Avatar
Quoted: 24 Post(s)
Last I heard DVBlink was or stop support the HD-PVR and Colossus you need ask on there forum about it.
For now there are two option NextPVR or wait SageTV to go Open Source or buy used copy of SageTV.
As sait now you go all analog video input or all atsc tuner you can't mix them as far I know of the hauppauge mce plugin is use less any way
SHS is offline
post #3911 of 3911 Old 07-20-2015, 02:30 AM
Super Moderator
DrDon's Avatar
Quoted: 277 Post(s)
Liked: 487
FWIW, this is exactly my setup. Well, I have two 2250s for QAM and analog cable and one 1212 for D*running under Win7 WMC. Never misses a beat. The only issue I have is that the 1212 won't change channels on the DirecTV box quickly enough. So, I just set the reminder timers on the D* box to correspond to recording times.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Reply Home Theater Computers
Hauppauge 1212 Hd Pvr High Definition Personal Video Recorder
