Hauppauge HDPVR-1212 Owner's Thread - Page 132 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #3931 of 3947 Old 01-07-2016, 01:24 PM
DigitalfreakNYC's Avatar
Quoted: 24 Post(s)
Does anyone know how long HC has been generating temp files? I now have both a 1212 and a 1498 and I've been trying to capture things from both my cable box and my Roku. I've been having hiccups in the resulting main file every single time it creates a new temp .ts file. I've been trying to work with Hauppauge on it to no avail. Now I am starting to have problems with the 1212. It's not my computer because it happens on recordings from both my laptop and my desktop. And it doesn't happen in the exact same place every time either. I just don't remember having any problems before they started generating those stupid temp files. Any ideas?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #3932 of 3947 Old 01-07-2016, 01:42 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
Just wondering what app are you using ? and what OS, SSD or req hard drive?.
SHS is offline
post #3933 of 3947 Old 01-07-2016, 02:45 PM
nikknightt's Avatar
Quoted: 45 Post(s)
Liked: 26
I noticed the temp files when they introduced the skipback feature. I have older versions of HC if you need them.. I save the install file for each.
nikknightt is offline
post #3934 of 3947 Old 01-07-2016, 04:50 PM
Quoted: 24 Post(s)
App? Like I said...HC. 33313. It's happened on two different OS - Windows 7 and 10. Two different hard drives - 1 is SSD and other is regular.
That would be fantastic!!! THANK YOU!! When was it?
post #3935 of 3947 Old 01-07-2016, 05:33 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
Then you mean Hauppauge Capture as for skipback that was add some time go rigth after 1.0.33156
Just turn off skipback if giving it you problem.
There be a reg perview temp file.
What the rest of your system spec.
SHS is offline
post #3936 of 3947 Old 01-07-2016, 05:40 PM
Quoted: 24 Post(s)
Skipback isn't on. It still creates the temp files regardless of whether it's on or off.
Laptop is:
i7-3610QM CPU 2.30
16 gigs of RAM
Windows 10 64 bit
post #3937 of 3947 Old 01-07-2016, 07:02 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
Laptop is:
i7-3610QM CPU 2.30
16 gigs of RAM
Windows 10 64 bit
I see what you ref to, Dran Hauppauge you goof, I pass this on to them
It the Perview make a bunch temps file as you leave it run it make new buffer that grow with new number
SHS is offline
post #3938 of 3947 Old 01-07-2016, 07:06 PM
Quoted: 24 Post(s)
Skipback is not disable it self that why you end up with a bunch temps file as the long you leave it run the buffer which base mins counter
Sorry. I didn't understand any of that.
post #3939 of 3947 Old 01-07-2016, 07:22 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
I edited my other post above
Your ref to this right in below screenshot ?.
SHS is offline
post #3940 of 3947 Old 01-07-2016, 07:37 PM
Quoted: 24 Post(s)
Yup. They're always there.
Granted, my problems have always been there but, now, they're there pretty consistently.
post #3941 of 3947 Old 01-07-2016, 07:52 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
That being cuase by perview buffer which just loop over and over ever few mins see if you can disable preview mode it in the setting tab.
I know there bug in the ver I have which is 33352 I not sure older ver as my capture card is most likely not support as I have latest model HD-PVR 60
SHS is offline
post #3942 of 3947 Old 01-13-2016, 09:03 PM
leroybrown's Avatar
Any 1212 owners use it with the Pace X1 DVR? I have the green light Pace and two companion boxes. Th companions work perfectly with the PVR, but the DVR works for a little bit then I get "input resolution 0x0 0fps"
Hauppauge support thinks is a hardware problem with the PVR, but why would it work with the companion boxes? I had a GE Plus and it worked with the Pace DVR with no resolution errors.
I tried two different Pace boxes with the 1212 and had the same problem with both. Comcast in my area does not have the Pace with the blue light, if that one would work with the PVR.
leroybrown is offline
post #3943 of 3947 Old 01-14-2016, 09:22 AM
SHS
SHS's Avatar
Quoted: 42 Post(s)
So the HD-PVR GE Plus as in HD-PVR 2 Gaming Edition Plus model 1504 works but not the HD-PVR model 1212 1st gen rigth?
The must common with the 1st/2nd gen HD-PVR is power supply going bad that could cuase the problem
Which output are you using with HD-PVR and have try any of analog signal ?.
Another possable is could be the Pace X1 DVR is output some forum of copyright protection like Macrovision or CGMS which common on Component, Composite, S/Video and even RF Tuners the other one is know HDCP found on HDMI ourput and with the rigth HDMI Splitter you can work around that problem or just output an off wall signal that in starderd.
I try borrow Xbox 360 or even PS3 to check the HD-PVR model 1212 and what happing.
SHS is offline
post #3944 of 3947 Old 01-14-2016, 02:14 PM
leroybrown's Avatar
Yes Gaming Edition worked fine.The composite connection with the 1212 will work. Sometimes switching back and forth from that to component will get it working again. It's very weird, it will work for a one hour recording, then a few minutes after the recording stops I get the 0x0 0fps again. But the then it will work again for a little
I will try to borrow a friends PS3 to check. I also ordered a Colossus just to see if it has the same problem.
post #3945 of 3947 Old 01-14-2016, 06:33 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
It could just some hardware problem as Hauppage said i was wondering is the box get hot on button and top ?.
SHS is offline
post #3946 of 3947 Old 01-14-2016, 08:23 PM
leroybrown's Avatar
It does get hot on top, last few days I have been sitting it on its side and has not been getting as hot
It's still not working properly though
post #3947 of 3947 Old 01-14-2016, 08:50 PM
SHS
SHS's Avatar
Quoted: 42 Post(s)
More like you could have is what know as trace brake some where on board or possable bad solder joints come know as terminal crack some where.
SHS is offline
Reply Home Theater Computers
Hauppauge 1212 Hd Pvr High Definition Personal Video Recorder
