Hauppauge HDPVR-1212 Owner's Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #811 of 3973 Old 03-24-2009, 12:23 PM
JonW747's Avatar
Quoted: 108 Post(s)
Liked: 53
Originally Posted by AllenDB View Post
I'm running fine with two HDPVRs. I use Record_This, rcTVCap and a small command line program to do the channel changing on the two DirecTV sat boxes. All I do is record tho and record from both at the same time if need be.
That's cool, but will the software that comes with the HDPVR work too? Or will it only control one? Or worse does it choke and not work?
Does rctvcap require less resources from the PC? Is this because it doesn't try to display what's being recorded while the standard software does?
My main goal is to get shows that are on my DirecTv HR20 DVRs off it, so channel changing isn't necessary a concern, and preview isn't necessary either.
JonW747 is offline
post #812 of 3973 Old 03-24-2009, 01:35 PM
Nosferax's Avatar
If only somebody would write a simple howto or guide for rctvcap... I spent the weekend trying to make this work to know avail. Not that I'm lazy or dumb or anything but I just don't get how to create the graph and all. Also how do you schedule your recording with it?
Nosferax is offline
post #813 of 3973 Old 03-24-2009, 02:40 PM
jebo_4jc's Avatar
Thanks for all the valuable info here.
What I want to do though, hasn't really been addressed from what I can see, surprisingly.
What's the easist way to get recorded TV files to play in Vista Media Center?
Is there any way to get recorded movies to show up in My Movies, or My DVD Library?
jebo_4jc is offline
post #814 of 3973 Old 03-24-2009, 02:42 PM
AllenDB's Avatar
I struggled with rcTVCap too. But there is also a graph builder (rcGraphBuilder) that makes things infinitely easier. I don't know how to build a graph either and don't want to know. And to some degree believe me if I can do it so can near anybody else.
AllenDB is offline
post #815 of 3973 Old 03-24-2009, 04:10 PM
Nosferax's Avatar
I struggled with rcTVCap too. But there is also a graph builder (rcGrapgBuilder) that makes things infinitely easier. I don't know how to build a graph either and don't want to know. And to some degree believe me if I can do it so can near anybody else.
Do you have a list of the apps that are needed? Beside rctvcap, rcgraphbuilder and graphedit what else is needed. Maybe i'm missing something and that's why I can't make it work.
Nosferax is offline
post #816 of 3973 Old 03-24-2009, 04:38 PM
DigitalfreakNYC's Avatar
Quoted: 52 Post(s)
At this point, I don't know what's going on with my Hauppauge. After fiddling last night and making a couple of very short recordings (less than 5 minutes), i kept getting the BSOD. It got to the point where i'd hear a click and then it was done. My entire computer would completely freeze and then I'd get the BSOD.
I re-installed and updated my ATI drivers and now the computer won't recognize the Hauppauge at all. I'm going to re-install everything. Any other suggestions?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #817 of 3973 Old 03-24-2009, 04:51 PM
AllenDB's Avatar
Just rcgraphbuilder and rcTVCap. Record_This schedules a bat file which has this line in it:
rcTVCap hdpvrcap.GRF "File Dump" %1 %2
"hdpvrcap.grf is the graph built by rcgraphbuilder. Parameter 1 is the number of seconds to record and param 2 is the file name to create. Get everything setup in some folder and your off,,,,,, I think
AllenDB is offline
post #818 of 3973 Old 03-24-2009, 04:57 PM
Quoted: 52 Post(s)
My computer completely refuses to acknowledge the device. It says it is not recognized. I can't even re-install drivers.
post #819 of 3973 Old 03-24-2009, 06:22 PM
Nosferax's Avatar
I've gotten farther now but I get this error message now:
Couldn't find dump filter in filter graph: filedump
Nosferax is offline
post #820 of 3973 Old 03-24-2009, 06:24 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
The name has to be exact "File Dump", I think it's even case sensitive, from that error it looks like you put in filedump as the filter.
rebkell is offline
post #821 of 3973 Old 03-24-2009, 07:05 PM
AllenDB's Avatar
And there were two rcGraphFilter programs. The one I use has a date of 11/27/2008. It helped in solving the "File Dump" problem.
AllenDB is offline
post #822 of 3973 Old 03-24-2009, 08:52 PM
Rico66's Avatar
And as mentioned (I think it was in the other thread a couple of days ago), this "File Dump" (filedump.ax) stems from Arcsoft TME. So you need to either keep Arcsoft installed, or (if you plan to uninstall TME) make a copy of this file and re-register it afterwards via regsvr32.exe filedump.ax.
Rico66 is offline
post #823 of 3973 Old 03-25-2009, 04:19 AM
Nosferax's Avatar
Hey, it works! Thank you all :-)
Nosferax is offline
post #824 of 3973 Old 03-25-2009, 04:29 AM
Nosferax's Avatar
Oh one more thing (there's always one more thing). What is the syntax for record_this? Or if somebody could paste a sample command line entry for it or a sample xml file that I could adapt to my need it would be appreciated.
Nosferax is offline
post #825 of 3973 Old 03-25-2009, 09:47 AM
Quoted: 52 Post(s)
Just talked to customer support.
The unit is dead. I have to send it back.
Jeez...
If it got 1 hour's use, that would be pushing it.
I am NOT pleased.
post #826 of 3973 Old 03-25-2009, 09:50 AM
jebo_4jc's Avatar
Jeez...
I am NOT pleased.
While I understand your frustration (we've all been there through the RMA process) the unfortunate reality of electronics, and life, in general, is sometimes, things just don't work like they should, even if the company performed appropriate quality checks
jebo_4jc is offline
post #827 of 3973 Old 03-25-2009, 09:58 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
I'm a HD PVR 1212 newbie. Trying to follow you guys about rcTVCap. I haven't installed anything yet as I want to understand this first. So, is this the right sequence from beginning to end?
1. Install latest Hauppauge driver
2. Plug in HD PVR via USB; let Windows recognize/install automatically
3. Install TME off CD-ROM (or is there a newer version somewhere?)
4. Download rcTVCap from http://www.arogan.com/rcTVCap.zip
5. Download rcGraphBuilder from http://www.arogan.com/rcGraphBuilder.zip (says v.1.02)
6. Unzip contents of both above in a folder like C:\\Program Files\
cTVCap
7. Play content on HD PVR
8. Start capture as follows via Windows command prompt...
"C:\\Program Files\
cTVCap\
cTVCap.exe" "C:\\Program Files\
cTVCap\\hdpvrcap.grf" "File Dump" 60 "D:\\Capture\\Test.ts" HQ
The above command line would presumably capture a 60-second file named Test.ts. I'm guessing HQ means at highest bitrate?
Also, I forget where I read this, but can KLToolBox be used as a GUI for rcTVCap? Instructions I've got saved are...
Put KLToolBox in the same directory as rcTVCap. It also needs the DirectShowLib-2005.dll to be in the same directory as the .exe file. Register the proppage.dll as described on arogan's blog. If the DirectShowLib-2005.dll isn't in the same directory as KLToolBox, you can copy it from the directory where rctvcap is to the KLToolBox directory or move KLToolBox to the same directory as rctvcap. Make sure config.xml goes with KLToolBox if you have to move it, so you don't lose all your settings.
I think I follow everything except for what "Register the proppage.dll" means. Guess I need to read Arogan's blog (which I find a little confusing to follow).
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #828 of 3973 Old 03-25-2009, 10:56 AM
Nosferax's Avatar
cTVCap
"C:\\Program Files\
cTVCap\
+1 on the confusion with the blog.
It's as if the cr/lf where removed or something. Also the info is mixed in with his modding project.
Nosferax is offline
post #829 of 3973 Old 03-25-2009, 11:10 AM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
You may not have to register proppage.dll, it needs to be installed to tweak the encoder settings, but with the profiles(HQ is a profile) in the newer rctvcap, you can set most of those without actually calling up the encoder property page. Try it first and don't worry about the proppage.dll, if you have troubles, then it may need to be found on the links on arogan's blog, but it may not even be necessary.
rebkell is offline
post #830 of 3973 Old 03-25-2009, 11:24 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
So the steps I've listed above are correct?
Brajesh is offline
post #831 of 3973 Old 03-25-2009, 11:46 AM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
I think so, I'm not sure I'd recommend the latest drivers, just from some of the comments on here, many of us are using the first beta drivers that came out that supported AC3, but the drivers seem to be to find what best works for you, but somebody needs to try it and see what happens. I think that should work pretty well, seems like there is are little tweaks that people have to make here and there, but that would probably be better in a FAQ section.
Step by step, I think it looks fine.
rebkell is offline
post #832 of 3973 Old 03-25-2009, 12:09 PM
wildboys's Avatar
All of the captures i make with the
hauppage hf pvr.Have lip synch problems
once i make them into blu ray disk.
I do not have the lip sync problem
when capturing the file.but when i mux
the file into blue ray structure.and burn
with nero the disc always playback in
my blue ray player with liop sync problems.
All the files open in tsmuxer show a -99ms delay in the
box.I don't know if this is the problem.I have the D2 version of the unit.
Any suggestions.
wildboys is offline
post #833 of 3973 Old 03-25-2009, 01:33 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Which version would this be? Also, you said "drivers" ... is there more than one or are you talking about the files that come with the zipped driver package?
Brajesh is offline
post #834 of 3973 Old 03-25-2009, 01:46 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
Singular as in one zip file, the set of files. I'm currently using 1.0.3.53, which I'm pretty sure was the first set of drivers that came out with support for AC3. SHS or some of the others could probably reconstruct a list of the drivers that have come out, and various problems solved/created with each update. I had pretty good luck with the first AC3 beta set and haven't fooled around with any of the others.
rebkell is offline
post #835 of 3973 Old 03-25-2009, 02:14 PM
Quoted: 52 Post(s)
It broke after less than hours use.
That might be a record even for hauppauge.
post #836 of 3973 Old 03-25-2009, 02:23 PM
xsrsmithx's Avatar
Mine broke exactly the same as yours after two weeks. Mine was rev. E1. Waiting for replacement from NewEgg. Let hope the replacement last a lot longer...
Steve
xsrsmithx is offline
post #837 of 3973 Old 03-25-2009, 02:24 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Stupid question: Can CapDVHS be used to capture? I used this to capture via Firewire from HD camcorders, DVHS & hi-def STBs. It's an easy-to-use, lightweight tool, but maybe only supports MPEG2; don't know.
Brajesh is offline
post #838 of 3973 Old 03-25-2009, 02:53 PM
Quoted: 52 Post(s)
Steve
Ugh. Mine was D1.
You had the same issue? That it wouldn't recognize the USB device?
Maybe by T1, they'll have a unit that lasts 2 months.
post #839 of 3973 Old 03-25-2009, 03:27 PM
xsrsmithx's Avatar
Ugh. Mine was D1.
That's right, it wouldn't recognize the USB devise. It worked all day the day before without a hitch and next morning the computer could not recognize it. Tried it on several computers, two Dish receivers and re-installed the software and drivers. Pretty much useless after that...
Steve
post #840 of 3973 Old 03-25-2009, 06:46 PM
nikknightt's Avatar
Quoted: 59 Post(s)
Liked: 27
Where can I find Record_This?
nikknightt is offline
Reply Home Theater Computers
Hauppauge 1212 Hd Pvr High Definition Personal Video Recorder
