QAM Patch for Saber DA-1N1 (I/E) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-12-2008, 04:06 PM - Thread Starter
Shimon Hirschorn's Avatar
Hello,
I just wanted to let people know that we have released a patch that allows QAM tuning on computers running TV Pack 2008. It can be found on the download section of the Vista View web site ( VistaView.tv) under Saber DA-1N1/Drivers.
Simply install the patch, reboot and go into setup to set the QAM channels.
I have at least 1 satisfied user. He had trouble initially, but they did a freash install of Vista. Now it works fine.
Shimon
Shimon Hirschorn is offline
post #2 of 4 Old 08-12-2008, 05:22 PM
charlesj123's Avatar
Thanks Shimon for this update.
You're posting into the right forum
BTW, great product you have.
Charles
charlesj123 is offline
post #3 of 4 Old 08-13-2008, 05:38 PM
pixelation's Avatar
Originally Posted by Shimon Hirschorn View Post
Hello,
Shimon
Sounds like you work on the product. Can you tell us why it is so difficult to come up with a QAM driver that works with Vista without the TV Pack? All you need to do is keep a mapping between the QAM channels to ATSC numbers, right?
pixelation is offline
post #4 of 4 Old 04-08-2009, 04:23 PM
denyart's Avatar
Hey, I was wondering if anyone is till watching this. I have tried to use a VistaView DA-1N1-E with QAM and I couldn't get it to work. I have 3 other Avermedia M780 PCIe combo tuners which do work, but the Saber does not. I have inserted the registry patch (twice), but it still doesn't see the Saber as QAM capable. If I can't get it to work, or it won't work due to some limitation I will just have to go back to ATSC. Any help would be appreciated.
Win7Ult x64:P8Z77V Deluxe, 8GB DDR3, ATI 6670, i5-3570k, 3 Ceton InfiniTV4 PCIe, Hauppauge 2250, Fractal Arc Midi SSP
denyart is offline
Reply Home Theater Computers
