RGB (vga) or DVI? Radeon 4850 - Dual screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-15-2008, 08:27 AM - Thread Starter
Pyret's Avatar
So to my problem,
I am about to run dual screen from my new htpc build to use it both as a htpc aswell as a gaming/surfing computer.
So on one end I have a Philips 42" full hd lcd tv connected via DVI-HDMI cable from my radeon hd4850 and on the other end I have an acer 22" lcd monitor. The problem here is that the distance is ~7meters so I would need a 10 meter cable to the monitor (which have both vga and DVI-D input).
Today I ran to a numerous stores looking for a 10m DVI cable but with no luck, and I live in an eastern europe coutry where language is a problem for me.
Will I experience bad signal by using a vga cable for this distance (which is way easier for me to find in shops) instead of DVI? Mainly when gaming?
Thank you in advance!
Pyret is offline
post #2 of 8 Old 08-15-2008, 09:00 AM - Thread Starter
Pyret's Avatar
Forgot to mention that I will run the Acer 22" monitor at the native resolution of 1680x1050...
Pyret is offline
post #3 of 8 Old 08-15-2008, 09:31 AM
umdivx's Avatar
32 feet might be a little long for vga, also the larger the rez you run the longer cables have issues supporting it.
With that said though I am running a 720p projector with a 25 foot VGA cable for my xbox 360 and I don't have any issues or picture degradation or anything along those lines.
umdivx is offline
post #4 of 8 Old 08-15-2008, 09:42 AM - Thread Starter
Pyret's Avatar
umdivx,
Yes that is what I thought... :/
However it looks like I've found the shop I am looking for, according to their website they have a few 10m dvi cables so I will head there tomorrow...
Thank you for your reply!
Pyret is offline
post #5 of 8 Old 08-15-2008, 11:18 AM
nijel8's Avatar
Look here:
http://www.lindy-usa.com/audio-video/cables/dvi/
Their DVI-D cables are very good. I'm running one 10m @1024x768 with no any issues.
nijel8 is offline
post #6 of 8 Old 08-15-2008, 12:40 PM
ahlinspcs's Avatar
Dvi
ahlinspcs is offline
post #7 of 8 Old 08-16-2008, 02:53 AM - Thread Starter
Pyret's Avatar
Hmm,
The store I thought had my solution only had hdmi cables up to 10m, would that
work or will the dvi-hdmi, hdmi-dvi adaptors reduce the signal anything?
Could this be an option for me or should I keep looking for a 10m dvi cable?
Pyret is offline
post #8 of 8 Old 08-16-2008, 09:02 AM
umdivx's Avatar
yea since dvi and hdmi are technically the same thing on the video side, simple dvi to hdmi adapters will work just fine.
- Josh
umdivx is offline
Reply Home Theater Computers
