vhdc300 problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-20-2008, 05:54 PM - Thread Starter
Dot50Cal's Avatar
Hello, I just bought a vhdc300, which converts VGA to Component. I tried using this on my Dreamcast home console, but the left side of the picture is cut off. I adjusted the horizontal pot, but it doesn't go far enough before losing signal. I'm missing about 29 pixels from the left side of the screen. I don't mind if its not centered, but as long as I can see everything on the screen, its fine.
Is there any way I can correct this? Any help is appreciated.
Dot50Cal is offline
Reply Home Theater Computers
