Do RAID drives typically show up as Removable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-21-2008, 09:36 AM - Thread Starter
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 55
I installed three 1TB drives in a RAID 5 and have a separate drive for the OS. Everything is working properly and shows up as expected in the BIOS boot screen, however in windows (Vista 32) I now have an icon near the clock/taskbar that lists the three RAID drives as "removable". It is the same icon that is used when you plug in a USB drive to allow "the device to be safely removed".
I did a google search which turned up a similar question where the answer was to uncheck "removable drive" in the drives properties box. I don't have that check box in my drives' property box.
I'm not too concerned about this, but it doesn't seem right as these drives are not removable. Is this normal for a RAID setup? This is the first time I have used RAID.
CountryBumkin is offline
post #2 of 3 Old 08-21-2008, 09:45 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
It depends on how the drives are plugged in, whether SATA or IDE, plugged into a motherboard or a RAID card, whether the motherboard/card supports hot plug or not, is the system identifying it as a "SCSI device" (assuming you have AHCI enabled), storport drivers..and what not.
Don't worry about it, it doesn't cause any issues.
kapone is offline
post #3 of 3 Old 08-21-2008, 04:21 PM - Thread Starter
Quoted: 214 Post(s)
Liked: 55
Thanks for your reply.
In case anyone else has this question too, the drives are Seagate Barracuda ES.2 ST31000340NS (SATA II), they are plugged into the on-board RAID on my Gigabyte GA-EG45M-DS2H board (ICH10R). I don't see anything identifying the drives as a SCSI device if this matters (AHCI is enabled).
No need to reply again. I just wanted the assurance that everything is okay.
Thanks again
Reply Home Theater Computers
