What does ffdshow really do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-24-2008, 09:04 AM - Thread Starter
mjfink's Avatar
I've finally broken down and installed ffdshow on my HTPC, which, just about instantly, resovled all my media playback problems. It's a great program, it really does fix just about any format problem that you might be having.
That said, I'm not sure that I understand exactly what it does. I'm going to use audio as an example, but I'm curious for video as well. Here's how I see the "stack" in audio with ffdshow:
File -> media player -> ffdshow -> output device
My question is, when I play a file with; let's say, DTS-HD (which my reciever natively decodes), does ffdshow decode it and then re-encode it? And, if it does, do I lose quality (or it is just a translation).
I had a BD rip that had some audio problems in it, ffdshow fixed them, but, I just want to make sure that by running my data through that program I'm not degrading the sound quality (any more then I would by finding the right codec to install).
Is it superior to find the right codec and do away with the translations? Or do I have the wrong impression of ffdshow entirely?
Thanks for the help; I'll just say, for my files, ffdshow is like a mircle, after installing it, there's just about nothing that the system won't play. Great app!
_____________________________________
My Onkyo 3008 (non-professional) review
http://www.avsforum.com/avs-vb/showt...php?p=19539055
mjfink is offline
post #2 of 3 Old 08-24-2008, 09:17 AM
Ben_Tech's Avatar
A computer cannot output a DTS-HD bitstream at this time. Maybe in the future.
My advice to you would be, if it works, don't worry about it.
My Blog - Ask Toy Tech
Ben_Tech is offline
post #3 of 3 Old 08-24-2008, 10:04 AM - Thread Starter
mjfink's Avatar
LOL. That would be very good advice, I just can't stop messing with it, and, of course, I will probably wind up breaking it.
One follow-up question, where does seesaw2 come from? I can't seem to find it on the threads, although there is plenty of mention to it.
A better example would have been AC3, my reciever decodes that; does ffdshow deode it, and then reencode it back into AC3 for output to reciever? And if so, does this result in any loss of quality. CPU is not a concern, my HTPC has plenty of processor, I just don't want to lose quality in the encode/re-encode process.
Thx.
mjfink is offline
Reply Home Theater Computers
