Front End that FULLY supports HVR-1600 Standard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-04-2008, 05:51 PM - Thread Starter
Squeeky's Avatar
Well I'm new to the HTPC and attempted several methods in order to connect my standard HVR-1600 to ASTC and STB. The only issue is I do not have a "Microsoft" USB IR, just the one that came with the 1600. Although I might have to bite the bullet and shell out another $40+ dollars for a new remove and receiver I'm attempting not too.
Is there a program that will allow me to use the standard HVR-1600 hardware. I have attempted MediaPortal 0.2.3 and Vista MCE, both need the additional receiver. I have tried the newest version on MP RC1 does not support the card at all.
I would like to be able to use one remote as well as the IR blaster that came with the 1600. If anyone has any input or workaround please let me know.
Squeeky
Squeeky is offline
post #2 of 8 Old 09-04-2008, 06:15 PM
pixelation's Avatar
I can use the stock remote from my HVR-1250 (the one with IR receiver plugged in to the card) to control Media Center. I can also modify remote.ini to control other applications including SlingPlayer and VLC. Is that what you are looking for?
pixelation is offline
post #3 of 8 Old 09-04-2008, 07:13 PM - Thread Starter
Squeeky's Avatar
Not exactly, in order for me to tune the channels coming from s-video STB, it states I need the connect MCE receiver.
Squeeky is offline
post #4 of 8 Old 09-05-2008, 07:51 AM
walford's Avatar
How well does the Hauppauge WinTV6 application work for your requirements?
walford is offline
post #5 of 8 Old 09-05-2008, 08:48 AM
Widman's Avatar
Have you looked at GB-PVR? I'm not 100% sure it supports the IR blaster but it is a free download, so it would be easy to try it out.
pete
Widman is offline
post #6 of 8 Old 09-05-2008, 08:52 AM
daMaster's Avatar
MediaPortal. 'Nuff said.
daMaster is offline
post #7 of 8 Old 09-07-2008, 09:38 PM - Thread Starter
Squeeky's Avatar
I'm having major issues with MP and 1600, I can't seem to pull anything off svideo just stays black
Squeeky is offline
post #8 of 8 Old 09-08-2008, 07:39 AM
walford's Avatar
An S-video connection will downgrade to B&W if the sending device does not sense the proper impedence over the Chroma(color) pin connection. Check your S-video cable to be sure you don't have any bent pins and/or try a different S-video cable.
walford is offline
Reply Home Theater Computers
