*Official* Asus Xonar HDAV1.3 thread - Page 101 - AVS Forum | Home Theater Discussions And Reviews
post #3001 of 9588 Old 12-13-2008, 01:54 AM
kbil69's Avatar
Originally Posted by Rathbone View Post
The Boom issue is a known problem. It's not the disc, it's your receiver. I had the exact same problem with my Onkyo 605 with bitstream HDMI. After firmware update no more Boom.
Yes, it's solved with a firmware on the onkyo.
kbil69 is offline
post #3002 of 9588 Old 12-13-2008, 08:01 AM
ymarker's Avatar
Quoted: 30 Post(s)
Another finding: Playing .ISO vs playing blu-ray from folder.
There appears to be a significant difference in quality playing a blu-ray movie from ISO(or disc) VS playing it from a folder, the latter being much worse. It appears to be associated with blu-ray and not individual file play (i.e. non-m2ts files like MKV are fine).
End finding: use .ISO to playback blu-ray movies. Most of us have already converted due to powerdvd8 so probably a moot issue.
ymarker is offline
post #3003 of 9588 Old 12-13-2008, 08:04 AM
Emig5m's Avatar
What exactly is the Boom issue for you? What me and mpgxsvcd is experiencing seems directly related to only the latest Asus .125 version of TMT. Care to try at low volume HDMI 5.1 48KHz/TMT 5.1 (with the use audio mixer check box unchecked) and try to play a movie, press pause, then play, and see if you get a static noise that's nearly twice as loud as the normal playback volume? (since you claim firmware fixed it.)
Emig5m is offline
post #3004 of 9588 Old 12-13-2008, 08:24 AM
hlkc's Avatar
I have Onkyo 998 and I do not have such problem with TMT .125.
hlkc is offline
post #3005 of 9588 Old 12-13-2008, 08:58 AM
Kingpimp's Avatar
Hi, I have a problem with my Xonar HDAV 1.3 and bitstreaming. Maybe someone here can help, I read about similar problems earlier in this thread but found no solutions that worked.
While PCM output has always worked fine, I am now trying to get HDMI bitsreaming on Vista. However, when I switch TMT to "HDMI" output and I am playing any kind of track except for LPCM, there is a) no sound at all and b) a strong image stuttering/freezing effect (main feature finally freezing completely). The receiver display still reads Multichannel PCM, while TMT information box reports "passthrough" as it should be. I tested that with TrueHD, DTS HD MA, and even normal DTS. Only LPCM tracks play like normal.
Drivers and TMT are the latest beta drivers for Vista 32-bit SP1 (6.12.8.1757 and 2.1.13.125 respectively). I did what I consider a clean re-install (removed previous TMT and driver first in that order and rebooting after each step). My HDMI Cables are all 1.3a compliant and the receiver (Marantz SR7002) should be able to decode the streams. My mainboard is Asus P5B-Deluxe Wifi, and graphics card is an nVidia GeForce 7900 GTX. I have a projector connected an its native 720p resolution is set when playing movies.
I tested with and without Splendid installed; did not make a difference. It also did not (and obviously should not for bitstreaming) make any difference what speakers/sampling rate I selected in the HDAV control panel. I was also looking for a bitstreaming/HDMI setting in HDAV control panel that I have to select, but there was none. I assume that's ok?
Any ideas? Does anyone else experience this problem?
Kingpimp is offline
post #3006 of 9588 Old 12-13-2008, 09:25 AM
bsselp's Avatar
So is it worth it to go ahead and purchase the Xonar 1.3 for TrueHD and MasterDTS at this point? I have an Onkyo 805 and a 4850 ATI card right now that can't do the TrueHD etc. Or is there another version coming out soon that would be better to wait for?
Thanks, this board is very informative!
bsselp is offline
post #3007 of 9588 Old 12-13-2008, 10:11 AM
Emig5m's Avatar
Interesting. Me and mpgxsvcd have the same receiver and we're both effected. In a way I find it hard to believe it's the receivers fault since it doesn't do it with the 7.1 setting or older versions of TMT. If it was the receiver one could assume it would do it with the 7.1 setting and also on previous versions of TMT. Could it be OS specific? I'm running in WinXP SP3 32bit. Are you XP/Vista? If I can get this "DTS-Bomb" as mpgxsvcd calls it problem fixed, I'd be pretty much 100% happy with the card even though bitstreaming works, it monkeys with my image quality and prefer to just use PCM out and bypass and run my videocard directly to the display.
I think there's a newer firmware revision for the RX-663 than the one mine shipped with, I could try it, what the hell do I have to lose?
Emig5m is offline
post #3008 of 9588 Old 12-13-2008, 10:12 AM
Emig5m's Avatar
Newer revisions coming out. Just wait a bit.
Emig5m is offline
post #3009 of 9588 Old 12-13-2008, 10:14 AM
cybrsage's Avatar
Liked: 154
If they put the VMC plugin and HD-DVD back in, then I will consider it.
I feel saddened that they have come so close to creating exactly what I want, and then they purposeefully gimp it.
cybrsage is offline
post #3010 of 9588 Old 12-13-2008, 10:14 AM
Emig5m's Avatar
You're right, settings in the Xonar control panel doesn't matter when bitstreaming as long as you do have it set to HDMI output. Then the only other setting is HDMI in TMT and you're set.
Emig5m is offline
post #3011 of 9588 Old 12-13-2008, 10:16 AM
Emig5m's Avatar
HD-DVD works here same as it always did... Or are you talking about bitstreaming support?
Emig5m is offline
post #3012 of 9588 Old 12-13-2008, 10:21 AM
cybrsage's Avatar
Liked: 154
I read (in this thread somewhere) that they removed HD-DVD support from their version of TMT.
Is this not true?
I don't really care if they add bitstreaming support for HD-DVD, since it is a dead format after all. As long as they do not mess up the LPCM output of the HD-DVDs.
cybrsage is offline
post #3013 of 9588 Old 12-13-2008, 10:49 AM
Davinleeds's Avatar
Yes, works with spdif setting in .125
The moderators' statement:
The decision of not including HDDVD is to reduce loading of testing and the chances of causing troubles to BD passthrough. Plus also becuase now BD is the only standard. We'll discuss necessity with our partners to see the possibilities of adding HDDVD support back.
Seems like it was left in but they didn't work on HDDVD bitstream. That's my guess.
PS; Retail 126 works great with the Xonar except no bitstream.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #3014 of 9588 Old 12-13-2008, 11:13 AM
Emig5m's Avatar
Ya, PCM on HD-DVD bluescreens for me. Spdif setting in TMT works for bitstreaming the DD+ track with either using the digital optical out or HDMI output of the card.
I'm still trying to find out what the latest revision of firmware for the RX-663 is. I bought mine fairly recently and assume is already has the newest firmware.
Emig5m is offline
post #3015 of 9588 Old 12-13-2008, 11:23 AM
kbil69's Avatar
I've vot a problem, i can watch a film only with THT
I try with PowerDVD or MPC and my PC boot
Why only THT can play a movie ?
THX
kbil69 is offline
post #3016 of 9588 Old 12-13-2008, 11:27 AM
cybrsage's Avatar
Liked: 154
So I would have to manually change the player each time I inserted a HD-DVD and then manually change it back when I play a BR? The simple fix is to have it autodetect and change the settings for me, then they can claim it simply works when you insert a disc.
cybrsage is offline
post #3017 of 9588 Old 12-13-2008, 11:29 AM
cybrsage's Avatar
Liked: 154
Ah, so I actually lose capabilities with regards to HD-DVDs if I use the ASUS version of TMT.
With the Arcsoft version, I can LPCM the HD-DVD sound. With the ASUS version, I have to go to the crappy (relatively speaking) compressed sound.
That is a loss of functionality, imo. Not good.
cybrsage is offline
post #3018 of 9588 Old 12-13-2008, 11:35 AM
Davinleeds's Avatar
THX
Did PDVD and MPC work before Xonar?
Sometimes too many codecs/different players can be the problem.
post #3019 of 9588 Old 12-13-2008, 11:39 AM
Davinleeds's Avatar
That's why, if you think you might want this, post @ ASUS to complain:
http://vip.asus.com/forum/view.aspx?...Language=en-us
Posting about 24playback got their attention.
post #3020 of 9588 Old 12-13-2008, 11:49 AM
nephster's Avatar
Hi guys,
I've discovered that if you are purely using hdmi, it makes a difference to disable s/pdif in your Vista sound panel. This allows you to use s/pdif or digital output (actually hdmi) in other programs like PDVD and XBMC and get audio. Otherwise it was trying to send through this non connected output.
nephster is offline
post #3021 of 9588 Old 12-13-2008, 12:11 PM
Davinleeds's Avatar
If you have speaker testing correct, I would remove TMT and reinstall. Look in registry also.
From Arcsoft forum:
Uninstall.
Restart.
Remove anything that remains in [PROGRAMFILES]\\ArcSoft\\TotalMedia Theatre
Remove anything that remains in [COMMONFILES]\\ArcSoft\\
(assuming no other ArcSoft apps.)
Remove the userdata stored in [USERNAME]App Data\\Roaming\\ArcSoft
Reinstall.
Restart.
post #3022 of 9588 Old 12-13-2008, 12:27 PM
Emig5m's Avatar
Well I updated the Yamaha 663's firmware from Ver: D054E to Ver: E057E and still get the same result with the DTS Bomb and only with only the 5.1 PCM setting - 7.1 still not effected. Nothing changed there. I'm still pretty confident this is TMT's fault and not the receivers since it didn't do it in the previous version and not with the 7.1 setting in TMT (which honestly sounds the same as the 5.1 setting - I assume each setting is irrelevant when decoding and outputting PCM and would only be relevant when using the 'enable sound mixer'). EDIT: Take back this statement, 7.1/5.1 settings do sound different in Transformers which is a 5.1 track.
Can we get someone with a different receiver/pre-pro than the Yamaha 663 to try 5.1 PCM output of Dolby True-HD and press pause then play see if you get the digital static noise? You also hear it for a split second when seeking/skipping. Don't worry about blowing anything up, just keep the volume set low and/or use headphones. That would be bizarre if only the Yamaha was effected and if so, you would assume it would also do it with the 7.1 TMT setting.
Emig5m is offline
post #3023 of 9588 Old 12-13-2008, 12:59 PM
ymarker's Avatar
Quoted: 30 Post(s)
Originally Posted by nephster View Post
Hi guys,
Under controlpanel>sound I only have Speakers and Digitial Output. Where are you seeing SPDIF?
ymarker is offline
post #3024 of 9588 Old 12-13-2008, 01:06 PM
nephster's Avatar
Hmm, I guess it's to do with my onboard, though I deliberately didn't install any drivers for my onboard audio/video chipset (Intel G35) when I did a fresh install so I don't have the motherboard hdmi showing up. Device says Digital Output Device (SPDIF). Driver says Microsoft.
nephster is offline
post #3025 of 9588 Old 12-13-2008, 01:12 PM
Davinleeds's Avatar
Are you showing disabled and disconnected devices?
post #3026 of 9588 Old 12-13-2008, 01:15 PM
kbil69's Avatar
you can be more precise? thank you
I tested to play MPC without external filter.
I use with MPC:
CoreAVC
AC3Filter
FFDSHOW
Haali media splitter
Nvidia Video Decoder
kbil69 is offline
post #3027 of 9588 Old 12-13-2008, 01:36 PM
nephster's Avatar
I was - but the SPDIF wasn't disabled anyway. Now it is disabled and all working better, although PDVD 7.3 will only pass 2.0 from say 5.1 TrueHD (i.e. it is not reading the core DD that is supposed to be embedded in TrueHD). Set to normal DD/DTS in a film with that as another soundtrack it will pass the full 5.1.
nephster is offline
post #3028 of 9588 Old 12-13-2008, 01:42 PM
hlkc's Avatar
I thought mpgxsvcd have different Onkyo receiver but not 998.
I have Vista 32 bit.
I am using latest DSP and firmware updated in my 998.
I have prefect bitstream TrueHD and DTS MA BD playback and DD, DTS TMT .125 using HDMI output and ES DTS for DVD playback using TMT .125 SPDIF output.
hlkc is offline
post #3029 of 9588 Old 12-13-2008, 01:43 PM
nephster's Avatar
Just tried playing Dark Knight with TMT set to 5.1 and pausing multiple times. Occasionally heard a tiny crackle but no bomb, even when turned up loads. Onkyo 875, latest TMT and driver, Vista SP1.
However, I *did* encounter this before I think (I assume this is a horrible loud white noise like a dead tv channel?) when playing a PCM soundtrack in the previous version of TMT on XP. Didn't happen when I switched to the DTS or DD track. Only happened when I hit pause. IIRC correctly it went away on the 2.0 PCM soundtrack when I unpaused but not on the 5.1 PCM track.
nephster is offline
post #3030 of 9588 Old 12-13-2008, 01:44 PM
Davinleeds's Avatar
I use with MPC:
CoreAVC
AC3Filter
FFDSHOW
ArcSoft TMT and ^ above sometimes don't work well together
Did they work before Xonar HDAV 1.3 and ASUS TMT?
Reply Home Theater Computers
Asus , Nvidia
