*Official* Asus Xonar HDAV1.3 thread - Page 314 - AVS Forum | Home Theater Discussions And Reviews
post #9391 of 9582 Old 03-18-2012, 09:56 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by Davinleeds View Post
use 1920x1080
Right, or separate connections.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #9392 of 9582 Old 03-18-2012, 12:09 PM
Perocat's Avatar
It works!!! On TMT with BluRay Discs...
Now, with mkv and MPC-HC? Nothing has changed, no HD Bitstreamed audio...
Perocat is offline
post #9393 of 9582 Old 03-18-2012, 12:31 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I'm not sure but maybe TMT and mpc-hc don't support HD audio in an mkv container via hdav? Try demuxing the mkv to an avchd format and see what happens.
audit13 is offline
post #9394 of 9582 Old 03-18-2012, 01:53 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
MPC-HC works. Last time I tried was with asaudiorenderer.dll from TMT5 .185.
Tulli is offline
post #9395 of 9582 Old 03-18-2012, 04:01 PM
Davinleeds's Avatar
Through the HDAV?
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #9396 of 9582 Old 03-18-2012, 05:29 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Through the HDAV?
Yes.
Tulli is offline
post #9397 of 9582 Old 03-18-2012, 05:46 PM
Davinleeds's Avatar
Originally Posted by Tulli View Post
Yes.
I should have added bitstreaming? I can see lpcm. If so, first I've heard. Thanks
post #9398 of 9582 Old 03-18-2012, 05:54 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Yes, bitstreaming (MPC-HC). But like I said, up to TMT5 .185 asaudiorenderer.dll. Right now I don't have the HDAV1.3 installed to test with latest versions.
Tulli is offline
post #9399 of 9582 Old 03-19-2012, 12:14 PM
Perocat's Avatar
Nothing... all it's right setted (seems to...) but I get HD bitstreaming only with TMT and BD... .mkv and MPC-HC nothing, only normal DD and DTS
Perocat is offline
post #9400 of 9582 Old 03-19-2012, 01:54 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Can you please post screen captures of MPC-HC output and external filters window and of the active filters during playback (right-click on MPC-HC window and select "Filters")?
Tulli is offline
post #9401 of 9582 Old 03-19-2012, 04:26 PM
Perocat's Avatar
Of course System Default Audio Device is 2: Altoparlanti (Xonar HDAV 1.3 etc.)
Perocat is offline
post #9402 of 9582 Old 03-19-2012, 04:39 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Ok, that looks perfect. The problem is, now that I remember well (I don't have my HDAV1.3 installed right now), that you definitely require ffdshow audio decoder which must be configured according to my previous post in this thread.
Only use ffdshow audio decoder instead of LAV audio decoder and it should work now ...
Tulli is offline
post #9403 of 9582 Old 03-19-2012, 04:46 PM
Perocat's Avatar
Thank you! I try now and let you know
Perocat is offline
post #9404 of 9582 Old 03-19-2012, 05:03 PM
Perocat's Avatar
nothing...
EDIT: DTS-HD from an mkv... now try other things
EDIT2: If I get DTS-HD audio the video is blocket, if the video runs audio is blocket
Perocat is offline
post #9405 of 9582 Old 03-19-2012, 05:08 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
If it still doesn't work try using MPC-HC native splitter (Gabest) instead of LAV Splitter.
Tulli is offline
post #9406 of 9582 Old 03-19-2012, 05:15 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
nothing...
hmm ... maybe using ffdshow video decoder instead will fix it. In fact this is the formula that used to work (mpc native splitter, ffdshow video + audio decoders & asaudiorenderer.dll).
Tulli is offline
post #9407 of 9582 Old 03-19-2012, 05:20 PM
Perocat's Avatar
MPC Crash...
so sad...
Perocat is offline
post #9408 of 9582 Old 03-19-2012, 05:23 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
MPC Crash...
so sad...
Use latest versions of MPC-HC & ffdshow from www.xvidvideo.ru or from here.
Tulli is offline
post #9409 of 9582 Old 03-19-2012, 05:25 PM
Perocat's Avatar
done...
Perocat is offline
post #9410 of 9582 Old 04-02-2012, 01:34 PM
Chris Albert's Avatar
Quoted: 17 Post(s)
Need some help from the Xonar gurus.
Looking at buying a Denon 5805 receiver for a good price but it won't pass through 1080p
Can I feed the receiver audio out of the zonar hdav and feed my projector separately out of my video card or use a hdmi splitter to go to both?
Or can I simply come out of the video card's hdmi to receiver and the hdmi to the projector?
Cheers.
Chris Albert is offline
post #9411 of 9582 Old 04-02-2012, 04:38 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Cheers.
If you're using Win 7 and the hdav comes with a short dvi-to-hdmi cable, connect your video card's dvi output to the hdav's hdmi input. Connect the hdav's hdmi output to your Denon. Connect the video card's hdmi output to your projector. Make the projector display 1 and extend your desktop to display 2 which would be the Denon.
audit13 is offline
post #9412 of 9582 Old 04-02-2012, 04:57 PM
Quoted: 17 Post(s)
I'm still on Vista, there's an advantage to 7?
post #9413 of 9582 Old 04-02-2012, 05:06 PM
Fastslappy's Avatar
Liked: 749
how I do it with my Onkyo's is using a small 19" monitor as 2nd display out of the HTPC DVI & then run outta the HDAV into my Onkyo then on to my display if your Denon has 2 HDMI outputs the you could also have a PJ & display as well .
make sure that the Denon is the primary monitor in windows .
the real benefit from this set-up is being able to switch to other video & still see the desk top on the 19" as when I switch to another source on the Onkyo the 19" then changes to the primary desk top on the HTPC ,, IE; watching DirecTV & still have the HTPC desktop on the small 19" . then when I switch back to the PC selection on the Onkyo boom windows 7 then adjusts agin & brings back the desktop to the large display , with the 19" going to 2nd extended monitor
It's all very cool as when watching streaming Vid's on the main display I still can use the 19" to surf for more content . change my mind to watch TV agin boom automatically goes desktop to 19" as primary .
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #9414 of 9582 Old 04-02-2012, 05:22 PM
Davinleeds's Avatar
I'd say all around.
post #9415 of 9582 Old 04-02-2012, 05:26 PM
Fastslappy's Avatar
Liked: 749
I'd say all around.
+1100
uses less resources , less buggy, WAY better home networking , easy to use ,FAST
Mike
post #9416 of 9582 Old 04-02-2012, 09:10 PM
Quoted: 17 Post(s)
Damn! More upgrading.
Home premium ok?
post #9417 of 9582 Old 04-03-2012, 12:18 AM
Fastslappy's Avatar
Liked: 749
Home premium ok?
Yeah , go with NewEgg to purchase it's on sale all the time
back everything up & do a complete new install not an overlay .W7 will ask which one that you want .
Mike
post #9418 of 9582 Old 04-06-2012, 01:41 PM
Quoted: 17 Post(s)
Cheers.
post #9419 of 9582 Old 04-08-2012, 05:36 PM
Quoted: 17 Post(s)
Another quick Q if anyone knows, will the HDAV 1.3 Slim work with the H6 analog daughter card?
post #9420 of 9582 Old 04-08-2012, 06:00 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
No, you'll need a standard HDAV1.3.
Tulli is offline
Reply Home Theater Computers
Asus , Nvidia
