Auzentech Home Theater 7.1 HDMI thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 1939 Old 12-30-2008, 04:45 AM
xtrips's Avatar
Originally Posted by eggman51 View Post
I believe it has been confirmed that this card replaces the HDMI daughter card for the Prelude that is no longer going to ship.
I have read there will be an upgrade program of sorts for owners of the Prelude to purchase these cards.
As an owner of the Prelude who bought it for no reason other than to have the HDMI daughter card in May of this year (when it was supposed to ship) I will not be purchasing this card nor any other product from Auzentech in the future.
egg
Well I can tell you as a Prelude owner that bought it for the same reasons as you and who just wrestled for 4 days with a Asus HDAV 1.3 Deluxe card that was supposed to replace the Prelude that:
- the Asus card is, to say the least, still in Beta
- its drivers are subpar
- it doesn't support 24fps and it is a hardware problem!!!
- it seems to be unable to conect to my AVR at 192Khz
- it needs a specific *beta* version of TMT to be able to play the new sound formats from HDMI. This version crashes.
So, as disapointed as I can be of Auzentech's daughter card trick, I think I might give it a try with the HD. After all, unlike Asus, Auzentech is dedicated to Audio cards.
xtrips is offline
post #272 of 1939 Old 12-30-2008, 07:27 AM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
ASUS will be releasing a digital only half-height card. That helps my friend.
Is the Auzentech half-height?
I am not likely to pay $200 for a sound card with analog when the point is to bit-stream.
I expect announcements at CES, perhaps the best solution is a motherboard or video card that can do protected path.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #273 of 1939 Old 12-30-2008, 08:37 AM
Please don't go around spreading lies about the Asus card. Just because you are having issues with your specific setup does not mean the problems exist with all owners of the card. You are correct it is not supporting 24fps, but that is about all. I have no issue with any of the other statements you made.
- 192Khs is working fine for me
- specific version of TMT for the new sound formats has had zero problems so far (reportedly the Asus and Arcsoft versions are merging at some point)
- obviously all the HD formats are being bitstreamed as specified
Sorry you are having problems with your setup, or perhaps your specific card needs to be replaced.
jdubbs23 is offline
post #274 of 1939 Old 12-30-2008, 10:00 AM - Thread Starter
ROBSCIX's Avatar
- Rich
To many, the point is Full resolution audio for the newer media. Bitstream,LPCM is only relavent for those with external HDMI receviers. For those without them, analog is the point and give them all the audio goodness without the external receiver.
ROBSCIX is offline
post #275 of 1939 Old 12-30-2008, 11:37 AM
mpgxsvcd's Avatar
Quoted: 2473 Post(s)
Liked: 2221
That is what the ASUS HDAV 1.3 DELUXE is for. It has analog outputs that provide upto 7.1 192 Khz undownsampled audio. It is currently available(I have it) and works perfectly in XP and Vista.
How long till we see a solution from Auzentech now? 1 month or will it be longer?
mpgxsvcd is offline
post #276 of 1939 Old 12-30-2008, 02:27 PM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
Right and the point of Bitstream support and analog outputs is?
- Rich
RichB is offline
post #277 of 1939 Old 12-30-2008, 03:27 PM
sensui's Avatar
He's saying the sound card will (may) have the support of outputting non-downsampled (lossless) sound via analog channels. So there is a point for people that don't have receivers that decode the new high def codecs.
sensui is offline
post #278 of 1939 Old 01-01-2009, 07:23 AM
RamGuy's Avatar
Quoted: 21 Post(s)
Does it support Dolby IIX? Which Prelude for some reason doesn't?
Wouldn't that be a rather huge advantage for me with 7.1 analogue speakers?
RamGuy is offline
post #279 of 1939 Old 01-08-2009, 04:29 PM
sensui's Avatar
We have any new info with CES going on?
sensui is offline
post #280 of 1939 Old 01-09-2009, 10:01 AM
hceuterpe's Avatar
My thought is, if it's at CES 2009 then it'll be ready, if it's not at CES 2009, it's probably and will be vaporware (for months to come)..
hceuterpe is offline
post #281 of 1939 Old 01-11-2009, 05:29 AM
xtrips's Avatar
Hello,
CES is over and still no news from Auzentech?
That's bad news.
BTW, about the Asus HDAV, maybe I had issues with 192khz input, and also I have found out that the problem with TMT was in fact with the powerlib.dll file, but about the 24fps I was right and there is a hardware problem.
That's why I returned the card.
Options are opened now.
Either I get the new Auzentech or the corrected hardware version of the Asus, what comes first.
xtrips is offline
post #282 of 1939 Old 01-11-2009, 09:45 AM
jimwhite's Avatar
My bet's on the Asus cards...
Jim White
St. Petersburg, FL
jimwhite is offline
post #283 of 1939 Old 01-11-2009, 11:55 AM
Hogweed75's Avatar
I think your right. Asus has pretty much worked through most things now (almost) and we haven't heard a thing out of Auzentech. I also only needed the HDMI outs like the new Asus Slim Card will offer but I prefer using PowerDVD for the upconversion of SD disc's. That's one reason I was hoping the Auzentech card would be out and working soon. It's nice to just use one program for all disc's.
Cary Cinema 12 Pre/Pro, XPA-3 & UPA-2 Amps.
2 DIY Vifa 12" Subs, HTPC-3D, Moncaso 301P, Svr: Norco RPC-4020-24TB WHS.
Ctr:ML Motif, Rrs:ML Fresco i w/Abyss sub.
Hogweed75 is offline
post #284 of 1939 Old 01-11-2009, 03:41 PM
iansilv's Avatar
I think azurntech should think about chiming in on this thread. I have been holding out for this card for some time. I like the idea of the nvidia internal connector, the 24p output, and the in molested audio stream. Not hearing anything at ces is certainly disheartening.
iansilv is offline
post #285 of 1939 Old 01-14-2009, 07:23 AM
Super XP's Avatar
Auzen X-Fi HomeTheater HD
HDMI v1.3a Compliant, 24p Compatible, Non-Downsampling, Native PCI Express Soundcard
http://www.auzentech.com/site/produc...theater_hd.php
HWC Exclusive: Auzentech X-fi Home Theater HD 7.1 Specs & Pics
http://www.hardwarecanucks.com/forum...pecs-pics.html
Super XP is offline
post #286 of 1939 Old 01-14-2009, 08:20 AM
AngelEyes's Avatar
I didn't read anything new here, why the post?
Adam
AngelEyes is offline
post #287 of 1939 Old 01-14-2009, 11:13 AM
mpgxsvcd's Avatar
Liked: 2221
Adam
In an attempt to keep people interested in the product. That is kind of hard to do while enjoying Bitstream Bliss with the Asus HDAV though!
mpgxsvcd is offline
post #288 of 1939 Old 01-14-2009, 11:20 AM
ymarker's Avatar
Quoted: 27 Post(s)
passes the salt shaker
ymarker is offline
post #289 of 1939 Old 01-14-2009, 11:53 AM
benbell's Avatar
Does this card require Vista to bitsteam DTS-MA and DD-TrueHD?
The website certainly strongly suggests it.
benbell is offline
post #290 of 1939 Old 01-14-2009, 10:42 PM
GoodToGo1's Avatar
Man I got all excited thinking that they released the card finally.
GoodToGo1 is offline
post #291 of 1939 Old 01-16-2009, 12:20 AM
Super XP's Avatar
If you read just bellow that line, it says XP support will be coming out when the card is released.
To me this info was new, sorry if I made you guys all exited.
Note: The current operating system supported by Cyberlink PowerDVD for Blu-ray HD audio playback are Windows VISTA 32/64. Additional information coming soon regarding Windows XP support.
Super XP is offline
post #292 of 1939 Old 01-17-2009, 10:21 AM
robert9674's Avatar
Quoted: 938 Post(s)
Liked: 548
so its almost the end of the month and still no word!! What is Auzentech doing?
robert9674 is offline
post #293 of 1939 Old 01-17-2009, 11:30 AM
phaselocd's Avatar
It's a matter of patience. These products WILL come. I just took delivery last week of the first batch of new HTPC parts for BD playback. I waited till now since all previous hardware just had too many issues. It's tough being on the leading edge and expensive...only two more weeks folks
If it's not UNIX, what is it ?
phaselocd is offline
post #294 of 1939 Old 01-17-2009, 12:53 PM
jimwhite's Avatar
Preparing the postponment announcement....
Jim White
St. Petersburg, FL
jimwhite is offline
post #295 of 1939 Old 01-17-2009, 01:47 PM
rcoleman's Avatar
The last press release stated it would be released in the last week of January. We're barely halfway through.
rcoleman is offline
post #296 of 1939 Old 01-17-2009, 02:43 PM
lifespeed's Avatar
Quoted: 25 Post(s)
I think it is important that our Lord and Master Microsoft establish some standard for this PAP nonsense. Otherwise we're saddled with the proprietary whims of ASUS/Auzentech/Arcsoft/Cyberlink.
I think I'm just going to stick with my Xonar D2X until windows 7 and aforementioned standard is ready. It is trivial to rip to MKV if I have a BD to watch with excellent audio.
It does seem the HTPC stuff lags consumer electronics by a few years. So much more flexible, tho.
Lifespeed
lifespeed is offline
post #297 of 1939 Old 01-18-2009, 09:52 PM
Super XP's Avatar
I agree. Now we have from the 25th to the 31st of January to see if Auzentech HDMI card becomes a reality. I've already spoken to the retail outlet in my area about this card and if they can get in on order, all I got was they are expecting some new products from Creative, Asus and Auzentech sometime in Feb 09, but no mention about the HDMI theatre card?
Don't know what to think, either way I am going to wait for reviews before making a purchase on either card (Asus or Auzentech). Both have a lot of work to do anyway, to make sure these new sound cards are working 100%.
Super XP is offline
post #298 of 1939 Old 01-18-2009, 11:47 PM
GoodToGo1's Avatar
End of January = February always
1-2 weeks delay is always to be expected. However, if they come out and say that there is a delay of 2 or more months, its curtains for Auzentech at least as far as I go.
post #299 of 1939 Old 01-19-2009, 01:13 AM
XaNe's Avatar
i just found out about this card it is my dream ive been looking for something that would do multichannel pcm through hdmi to my receiver! please come out soon
XaNe is offline
post #300 of 1939 Old 01-19-2009, 05:09 AM
Super XP's Avatar
I just hope it doesn't suffer the original quirks as the Asus HDMI card when it was first released.
Super XP is offline
Reply Home Theater Computers
