HTPC & PVR: QAM Tuner for Recording HD Shows from DVR to PC? - AVS | Home Theater Discussions And Reviews
post #1 of 9 Old 10-09-2008, 01:02 PM - Thread Starter
moonstar's Avatar
I have a QAM tuner installed on my Windows XP PC (Pinnacle HD PCI to be exact). I also have subscription with a cable company and a STB plus DVR in one (SA8300HD).
My question is is it possible for me record onto my computer through the QAM tuner HD shows that are stored in my DVR if those channels are NOT encrypted (basic channels like CBS, NBC, ABC, etc. no premium /cable channels) just like the way I can record ATSC signals, even if my video card or computer monitor is not HDCP compliant? I don't care about watching those shows in HD on my computer screen, but I would like to be able to STORE on a data DVD in HD qualities. By the way, I do not have a Cable CARD slot anywhere around my computer and I could not get clear QAM when I hooked up a coax cable from a wall directly to the QAM tuner. Or is an ATSC tuner or PC like this with an OEM tuner the only option if I'd like to record unencrypted HD shows in HD qulaities from a DVR using my PC? Thank you.
moonstar is offline
post #2 of 9 Old 10-09-2008, 03:23 PM
ilovejedd's Avatar
Quoted: 65 Post(s)
Liked: 62
From your cableco-issued DVR to clear QAM tuner, no. You'd have to use something like the Hauppauge HD PVR to capture in high definition from the DVR. If you just want a copy of the show for archival, you can capture to standard definition using the analog input (S-Video or composite) on your card. Whether your monitor is HDCP compliant or not has no bearing with this.
If you mean to store HD recordings straight to DVD (no re-encoding, etc), then that might prove impractical. I'm not sure if you can even write a 4+GB file to DVD without splitting.
What program did you use for recording clear QAM? I've had no problems getting the basic channels with GB-PVR + HDHomeRun.
ilovejedd is offline
post #3 of 9 Old 10-09-2008, 09:53 PM - Thread Starter
moonstar's Avatar
Thank you for your reply. I guess my purpose of saving HD videos is rather unusual. Most of the HD stuff I'd like to store is 20 second to 5 minute clips. I could either split >4GB clips with an mpeg splitte or store in my external HDDs.
I used Pinnacle PCTV Pro (the latest version) that came with the ATSC/QAM tuner trying to pick up clear QAM channels. I wonder if it has to do with the way things were set up, and any thoughts and suggestions on this are greatly apprecicated.
First of all, here are tuners on my computer and connections I had when I attempted the scan for QAM signals.
1st Tuner (I had this and the soft already installed before adding the 2nd tuner):
USB tuner for ATSC and NTSC but no QAM
An OTA antenna was connected.
2nd Tuner:
PCI card for ATSC, QAM and NTSC.
A coax from a wall and S video from a STB.
I had hooked up my OTA antenna to both and recorded a couple of stuff before. I unplugged the OTA antenna from the PCI card, hooked up a coax cable instead, opened the soft, PCTV Pro, and then began a channel scan specifically for QAM signals through the PCI card. The software shows a list of available devices and allows you to choose which one you want to scan.
Here's a list of available devices for scanning:
Internet Radio
PCTV HD Pro Stick (USB) Analog
PCTV HD Pro Stick (USB) Digital Antenna (ATSC)
PCTV HD PCI Analog
PCTV HD PCI (FM) Radio
PCTV HD PCI Digital Antenna (ATSC)
PCTV HD PCI Digital Cable (ClearQAM)
Each of the listings has a box next to it, and I only had the Clear QAM checked for scanning as I already had scanned for ATSC and saved the channels after installing the PCI card.
Any idea? I think I read somewhere that most of the cable companies don't send free clear QAM. They want you to rend their cable cards, though I may be mixing it up with something else.
moonstar is offline
post #4 of 9 Old 10-09-2008, 11:31 PM
ilovejedd's Avatar
Quoted: 65 Post(s)
Liked: 62
Maybe you could try using different software? I think GB-PVR should be compatible with your card. You could check http://www.silicondust.com/hdhomerun/channels to get an idea what channels you'll likely be able to receive.
post #5 of 9 Old 10-10-2008, 07:10 AM - Thread Starter
moonstar's Avatar
This is the BEST site for QAM listings! anyways, yes, this site WAS the reason I got the 2ndary tuner (PCI) to try QAM... I'm beginning to suspect that my cable provider (TMC) may have a role in this. I'll inquire and post here what they say. thanx for the recommendation, I'm always looking for better programs! You mean GB-PVR posted here?
moonstar is offline
post #6 of 9 Old 10-10-2008, 07:27 AM
steven975's Avatar
unfortunately, that site has many channels listed that definitely are not ClearQAM in my ZIP code.
steven975 is offline
post #7 of 9 Old 10-10-2008, 07:39 AM - Thread Starter
moonstar's Avatar
Bomberrrr!
moonstar is offline
post #8 of 9 Old 10-10-2008, 07:50 AM
ilovejedd's Avatar
Quoted: 65 Post(s)
Liked: 62
Yep. That GB-PVR. The SiliconDust site's been pretty accurate for me. Anyway, it's still worth a try.
post #9 of 9 Old 10-11-2008, 03:46 PM - Thread Starter
moonstar's Avatar
Yup! You guessed it right. There are QAM channels. The only thing I had to do was reintall the PC Center Pro software AFTER I swap the OTA antenna with coax. I had to choose the right kind of input when I installed the soft. I am very excited I can now pick up QAM! I have been having a headach for months beacuase of multipath signals with the OTA antenna. Now that I could confirm the availability of QAM in my area, I'm considering the new dual digital tuner model from Hauppauge (WinTV-HVR-2250).
moonstar is offline
Reply Home Theater Computers
