Vista Codec Packs - Shark 007 - K-Lite - Good or Bad? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 10-29-2008, 05:09 PM - Thread Starter
T^2
T^2's Avatar
So are Codec Packs a good idea or not? Should you stay away from them or go for it? Why or why not? Should you just go with the How-to for FFDShow in this forum or what?
T^2 is offline
post #2 of 20 Old 10-29-2008, 05:33 PM
GooberedUp's Avatar
People seem to be overall rabidly against codec packs. For me, I installed CCCP and everything worked and continues to work as smooth as silk. I suppose YMMV.
I suppose I could have just installed Ffdshow, Haali and whatever else on their own, but the codec pack was easier and worked well. I was prepared to redo my entire system if something went wrong. It didn't.
GooberedUp is offline
post #3 of 20 Old 10-29-2008, 05:40 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
I have used CCCP, with no real issues, but it does have alot on it, more than most need. I now use K-lite, which I am very happy with, and was very easy to set-up.
jdcrox is offline
post #4 of 20 Old 10-29-2008, 07:27 PM
voranand's Avatar
K-Lite here too but installed CoreAVC seperately. Silky smooth from the beginning plus I can play MKV file in VMC without having to hack Windows registry.
voranand is offline
post #5 of 20 Old 10-29-2008, 07:48 PM
sh1ft3rDtCom's Avatar
I feel that a CLEAN install with a SINGLE codec pack is fine. I have had great results with KLite, including the x64 version.
sh1ft3rDtCom is offline
post #6 of 20 Old 10-29-2008, 08:11 PM
arfster's Avatar
Arrgh, codec packs, arrrrrrrgh *fume* *explode*
DO NOT TOUCH.
arfster is offline
post #7 of 20 Old 10-29-2008, 08:26 PM
leonowski's Avatar
DO NOT TOUCH.
Agreed. It's best to always know what is being used in the filter chain while something is playing. It will save you headaches down the road.
leonowski is offline
post #8 of 20 Old 10-29-2008, 08:31 PM
nm88's Avatar
DO NOT TOUCH.
Exactly.
These people mess up their systems with codec packs then wonder why things don't work right or why PQ isn't as good as it should be.
If you care about quality and reliability, don't install codec packs!
nm88 is offline
post #9 of 20 Old 10-29-2008, 08:51 PM
leiff's Avatar
Quoted: 83 Post(s)
I was pleasantly surprised to discover after installing vista 64 bit, that 64 bit and 32 bit version of wmp11 played mpeg2 nativly as well as out put DTS to my receiver (though that may have been thanks to my p5q-em MB). It seemed to me mpeg2 playback PQ looked better on 64 bit version. Anyways, I installed 32/64 bit vista codecs from shark for my mkv's, avi's ect. but then decided against it and uninstalled both. I opened Graphedit x64 and played a mpeg2 but the path seems a little more convoluted now. Can someone tell me the default or simplest way the path should look? Or tell me how to post here my Graphedit path results? Is there a step I should take to assure no undesirable codec parts remain?
leiff is offline
post #10 of 20 Old 10-29-2008, 09:01 PM
nm88's Avatar
Reformat, and don't make the same mistake again.
These codec packs can mess with the system settings in unpredictable ways which cannot be easily undone. That is one reason why you never install them if you care about your system.
nm88 is offline
post #11 of 20 Old 10-29-2008, 10:17 PM
leonowski's Avatar
If you can find out the names of the .dll or .ax files for the filters, just unregister them with regsvr32 /u. There are some tools out there that can help you. In fact, I just found this:
http://www.free-codecs.com/download/DXMan.htm
It lists all the filters and lets you remove them. Just find out the names of the codecs installed by these packs (I'm sure there is a list of what they install somewhere) and use the utility to remove them.
Be careful - don't delete anything that you may need. To play it safe, you can simply unregister the file and not delete it. I'm not sure what this DXMan app does - unregister and delete or just unregister.
post #12 of 20 Old 10-30-2008, 12:11 AM
jayntguru's Avatar
Shark007's is awesome. I can't imagine *not* using something like that. It has them all stripped down with config in one place, ffdshow, the works. Installing individual codecs and managing all that with every single one? Bleh.
-Jay
jayntguru is offline
post #13 of 20 Old 10-30-2008, 02:19 AM
pacemaker's Avatar
Quoted: 30 Post(s)
you got me worried now i need codecs for avi support so i used vista codec pack and just installed the xvid codec
pacemaker is offline
post #14 of 20 Old 10-30-2008, 03:25 AM
rhysevans's Avatar
I never install codec packs, all I install are the following, and i've never come across a file i could not play fine in WMP (or any other direct show app):
ffdshow
haali splitter
real alternative
quicktime alternative
might have missed one (not on the pc now) but i think thats it!
rhysevans is offline
post #15 of 20 Old 10-30-2008, 06:46 AM
arfster's Avatar
Why install a codec pack? What's the point? Install only what you need.
arfster is offline
post #16 of 20 Old 10-30-2008, 07:20 AM
GooberedUp's Avatar
Well, since I'm one of "these people" using a codec pack, I'll disagree. You don't see me on here complaining or asking for help.
Codec packs work and work well for a lot of people.
post #17 of 20 Old 10-30-2008, 07:28 AM
GooberedUp's Avatar
For me, simple 1-click trouble free installation and operation.
Then again, I may not be the kind of genius that frequents these forums. I attribute my success to the following:
I don't know any better--ignorance is bliss
I have no idea what good quality picture/audio is like
beginner's luck
So, for the ignorant like me, codec packs work. That's my story and I'm sticking to it.
post #18 of 20 Old 10-30-2008, 11:54 AM
pixelation's Avatar
I once installed a KLite codec pack years ago on my XP and I regret it. Don't do it.
The only time you install codec pack is when you don't know what you are doing.
You will end up replacing some perfectly fine codecs in your OS and adding 3 or more flavors of codecs capable of decoding the same media.
If you still want to do it, at least setup a restore point using System Restore.
pixelation is offline
post #19 of 20 Old 10-30-2008, 12:08 PM
GooberedUp's Avatar
Or, like me when you do know what you're doing and want ease of setup. In all three recent instances, I installed the codec packs on brand new builds. I didn't have to fart around with anything other than getting the MPC-HT drivers for hardware acceleration. I'm sure there are a lot of people on here that would kill to have the same "problematic" experience that I did with the codec pack.
Although, I do agree that being prepared to undo the install is a good precaution.
post #20 of 20 Old 10-31-2008, 09:21 PM
skrubol's Avatar
This often takes less time than figuring out which friggin' codec I need.
I've been haphazardly installing the K-lite codec pack on every PC I've needed to play a weird video on and haven't had a major problem yet (other than some filter I uninstalled randomly popping up when I manipulated video files.)
skrubol is offline
Reply Home Theater Computers
