no ac3 or DTS in Vista x64 WMC via 3650 & HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-30-2008, 12:00 PM - Thread Starter
RobertStern's Avatar
Hi everyone,
I just got a new Vista machine. It's running Vista x64 digital cable edition.
I am using the hdmi out on a radeon 3650. in Vlc everything works perfect.
When using WMC i can play the files and get sound, just not in digital, whether it's ac3 or DTS. Same files in WMP 11 i get the same thing as WMC
, except DTS. DTS actually send through the hdmi in WMP.
I am using the codec pack from shark007.com and SPdifer (which i dont think helps me through HDMI)
any suggestions??
thanks in advance
Emotiva XMC-1 | Pioneer BDP-52FD | Roku 3 | XBOX ONE | Custom HTPC | B&O BeoGram 8002 | APC J25 | Front L/R JBL LSR12+LSR6328P, Center JBL LSR6328P, Surround JBL LSR6325P | Subwoofer 2 X Boston Acoustics 595X + Monster MPA 5150 SS | 120" EliteScreen CineGrey 3D | Sony VPL-HW40ES
RobertStern is offline
post #2 of 11 Old 10-30-2008, 12:06 PM
720p's Avatar
disable vmc sounds
720p is offline
post #3 of 11 Old 10-30-2008, 12:14 PM - Thread Starter
Originally Posted by 720p View Post
disable vmc sounds
I just tried that with no luck. I went to Tasks, then Settings, then Visual and sounds. Unchecked the enable sounds in WMC box.
Restarted and same deal. Did I miss something?
post #4 of 11 Old 10-30-2008, 01:11 PM
720p's Avatar
No that's correct.
You must check dd/dts under audio in control panel if unchecked.
Check also enable & prefer exclusive mode again under audio in control panel.
720p is offline
post #5 of 11 Old 10-30-2008, 01:16 PM - Thread Starter
No that's correct.
All of that is set correctly as well.... Still same issue.
post #6 of 11 Old 10-30-2008, 03:18 PM
720p's Avatar
look at the ffdshow audio decoder settings under the x64 codec pack
do you have ac3 & dts set to spdif instead of liba something codec?
set speakers to stereo instead of 5.1/7.1 in control panels (just for testing, dd/dts will use all channels available anyway)
720p is offline
post #7 of 11 Old 10-31-2008, 12:43 AM - Thread Starter
That was it!..
Thanks alot 720P, that was driving me crazy.. Now to just get the ATI DCT up and running. Just waiting for Tine-Warner to actually come when they have an appointment. ( Waited all day and they never showed ) So, they are coming back Saturday.
Other than that WMC has been pretty good so far. I am liking it. I just sold my Mac Mini that I was using for a Media Center Computer on OSX.
post #8 of 11 Old 10-31-2008, 07:41 AM
720p's Avatar
Good because my next suggestions would involve uninstalling stuff.
720p is offline
post #9 of 11 Old 11-03-2008, 01:51 AM - Thread Starter
Ok,
I thought everything was good. I now get the correct decoded sound (AC3 or DTS). But the sound is not synced to the picture.
Have you had this issue?
post #10 of 11 Old 11-03-2008, 02:22 AM
720p's Avatar
No, I'm only aware of this issue under TMT with Ati but only at 24Hz. Never seen this under vmc.
720p is offline
post #11 of 11 Old 01-26-2009, 04:15 AM
fraggermcg's Avatar
Digging up a slightly old thread, but is there any way to keep Vista Media Centre sounds and get spdif working? Could turning off exclusive mode have anything to do with this - thinking being that media centre with exclusive mode on is not releasing the sound card hence breaking spdif passthrough?
fraggermcg is offline
Reply Home Theater Computers
