ATI's magic DVI to HDMI Dongle - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 10-31-2008, 09:36 PM - Thread Starter
BoostGTR's Avatar
Hey guys, i'm just tidying up my first HTPC build and with my current cabinet setup i had been looking at using a DVI to HDMI cable to connect my Sapphire 4670 to my Sony HSS1300 Speakers as I dont have alot of space so needed a compact solution.
Obvioulsy just jumping straight in I bought a 1.3 spec DVI to HDMI cable and swapped out my current DVI Dongle to HDMI cable and thats when I realised i was getting no sound.
I've done a bit of trawling round the t'internet and found out that the supplied dongle is actually special in a sense that it specifically enables the sound to be passed out and without using it a standard DVI to HDMI cable will not work.
I was just wondering if anyone knew exaclt what the dongle did and would it be possible to adapt a standard DVI to HDMI cable or is there some special hardware in the Dongle? I'm hopng its just a cross wiring of one of the pins.
Cheers!
BoostGTR is offline
post #2 of 28 Old 11-01-2008, 08:28 AM
mslide's Avatar
Short answer: You have to use ATI's dongle. It's not just a simple re-wiring of the pins. In fact, the wiring the dongle does is exactly the same as a standard dongle.
Long answer: This is what I've gathered from my curious research on that stupid little thing. It's no magic at all. Actually, it's very simple and quite clever. ATI does not use a proprietary DVI connector on their cards, contrary to what most people say on internet forums and articles. There are no dedicated audio pins on a standard DVI or HDMI connector, nor does ATI employee any on their connector. DVI and HDMI connectors contain 3 sets of data signals that are used to transmit video data. The manner in which the video data is sent is basically the same for DVI and HDMI (thus why it is so easy to convert one to the other). For HDMI, audio is interleaved between the video data, on the same pins. This is how ATI transmits audio over their DVI port and is also the reason why you don't loose the audio when you use their dongle and convert is back to DVI to HDMI to DVI to HDMI, etc.
So, what does the dongle do? It simply tells the ATI card that it is plugged in and to start sending the audio (again, not over dedicated audio pins but over the 3 sets of data signals). Basically, when the dongle is plugged in, ATI pretends the DVI connector is an HDMI one and electrically treats it like that.
How does it detect that the dongle is plugged in? The DVI and HDMI specs include a 2 wire serial bus called I2C ("I squared See") that is widely used in electronics (including motherboards). This bus is used to transfer the EDID information. The ATI dongle includes a small memory chip, either an EPROM or some other non volatile RAM device, on that bus. Any time an adapter is plugged in, the ATI card tries to probe for that eprom and read the data from it. If it's a real ATI dongle, it then turns on the audio.
This is all just my theory but I'm 95% certain I'm right. I would love to crack open one of these to make sure, but I'm not THAT curious. I also once saw a schematic of that dongle somewhere that described this also.
mslide is offline
post #3 of 28 Old 11-01-2008, 11:35 AM
Smitty2k1's Avatar
Great work! I feel like this should go somewhere in "Guide to building an HD HTPC" that is at the top of this forum...
Smitty2k1 is offline
post #4 of 28 Old 11-01-2008, 02:31 PM
dondu's Avatar
And of course, this means that ATI could easily have a setting in their driver to override the dongle, and force HDMI audio always on (or off).
So... Why do they have the custom dongle at all? If it could just be controlled by software?
--Don
dondu is offline
post #5 of 28 Old 11-01-2008, 03:40 PM - Thread Starter
BoostGTR's Avatar
mslide your a legend, cheers for the info that has certainly raised my interest in the matter.
It certainly raises the question as to why ATi have designed the card like this. When you think that if someone isnt interested in getting Video and Audio from the card then by using a standard DVI to VGA cable works without a problem as does DVI to HDMI.
Like dondu said why not just add an option in the Catalyst Control Center for the option of sending decoding Audio if ATi were specifically after reducing overheads in the cards performance when users aren't looking for Audio.
And yes I'm surprised this "feature" is not more widely documented in discussions.
All in all a very strange design!
Come on ATi please let us use 3rd party cables, my HTPC looks stupid sticking out 2 inches of my cabinet!!!
BoostGTR is offline
post #6 of 28 Old 11-01-2008, 10:23 PM
Bastian74's Avatar
The ATI DVI-HDMI adapter uses a lot more pins on the DVI interface than you usually see. I would think that it uses these extra pins for hdmi
Bastian74 is offline
post #7 of 28 Old 11-02-2008, 01:28 AM
dondu's Avatar
No, those extra pins are not used for HDMI.
The DVI connector has several options: One option is to include VGA output, and that adds pins If you can connect a DVI-to-VGA dongle and have it work, then the DVI out has the VGA pins. Also, lots of video cards these days are dual-link DVI, and that adds pins too.
So the "extra" pins you are seeing are the pins to support VGA, and the pins to support dual-link DVI.
--Don
dondu is offline
post #8 of 28 Old 11-02-2008, 04:00 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
It is interesting that the DVI port of Radeon HD 3200 (AMD 780G chipset IGP) carries audio with any generic DVI-HDMI adapter (confirmed by a couple of people including me).
renethx is offline
post #9 of 28 Old 11-02-2008, 06:20 AM
bokis's Avatar
I´m gona try this to my Onkyo 576, I have a HD3850 dongle that should work
Edit Yes their is audio, but put in the Onkyo in the mix no go it´s still a dvi device
bokis is offline
post #10 of 28 Old 11-02-2008, 06:51 AM
mslide's Avatar
Oh, I'm certainly no legend. I'm just an electrical engineer by day who's very curious about things like this.
Well, DVI to VGA is never an issue as there are dedicated pins on a DVI connector for the analog video signals. For DVI to HDMI, read on...
Honestly, I only read enough of the DVI and HDMI specs to satisfy my curiosity of this dongle. I've often wondered why not just have a soft-switch in the drivers somewhere, as you and dondu are suggesting and let someone use an ordinary DVI to HDMI cable. I'm guessing that they do it this way just to cover their butts and to make sure they are 100% in compliance with the DVI spec. I'd bet almost anything that having the audio turned on all the time, or accidentally, wouldn't hurt a DVI device (i.e. connect the ati card to a monitor via a DVI cable, but have the audio turned on by accident), but they probably don't want to take the chance.
There are no spare pins on a DVI connector. Every single one of them has a function, whether it be for transmitting the analog VGA signals, or dual-link DVI support. Even if they did steal pins just for the audio, it wouldn't be possible to interleave it back into the HDMI data stream using a connector like that. There would have to be a processor inside the dongle that could process the stream and insert the audio in. Why do it that way when the processor on the actual graphics card can do that? They also can't start mucking around with the dvi pinout, and reassigning (say the VGA pins) to something else, because then that could make them non-compliant with some DVI devices. DVI and HDMI are actually very similar when you take away the physical connector differences.
I'm guessing that maybe they finally realized that it's no big deal to just send out the audio all the time. Things like this dongle sometimes come about out of ignorance. I can see the meeting now:
"Can we just send the audio out all the time so that anyone can use a standard DVI-HDMI connector?"
"Huh? No one here really knows? Okay, well lets just make a dongle that only causes the audio to turn on when it's plugged in then. Now we're 100% compliant with the DVI spec."
So, again, I bet they did it this way just to cover their asses.
Disclaimer: I don't work for ATI, not do I have any sources that can back up my theories on how this works. The way to prove my theory would be to use an ohm-meter to see if the pinouts of the dongle match that of a standard dongle or DVI-HDMI cable. Then, crack it open to see if there is a small eprom connected to pins 6 & 7 of the DVI connector. I would do this myself, but I don't own one of those dongles, nor am I THAT curious to spend money on one just to destroy it in the process.
mslide is offline
post #11 of 28 Old 12-30-2008, 10:22 AM
dorian11's Avatar
I like your theory about the I2C bus being at the root of the special ATI dongle. I'm trying to figure a way around it 'cause I just bought a 50 foot DVI to HDMI cable and it doesn't send the audio as is... and I don't want to go and buy a new 50 foot HDMI to HDMI cable. I was hoping it would be an easy mod -- like figuring out which pins they repurpose for for the I2C bus and hooking them up. I'm hoping there isn't an I2C EEPROM in the dongle... ideally, there is just something (like a pulled up or pulled down pin) that tells the card that the dongle is there an then it turns on the audio.
I had suspected that the I2C bus needed to be there so the downstream device could be told how to decode the audio or to even look for the audio, but peoples experience (renethx) with generic adapters suggest it is just a mater of enabling the interleaved audio data in software...
I'll buzz out my adapter and see if I can figure it out.
dorian11 is offline
post #12 of 28 Old 12-30-2008, 12:10 PM
walford's Avatar
First you have to have the special ATI DVI-HDMI adapter for your card in order to tell caard to multiplex the audio of the same pins as the video in accordance with the HDMI spec.
Then if use an HDMI(male)-DVI(female) adapter to connect the HDMI out of the special ATI adapter to the DVI end of your long DVI-HDMI cable you will be all set.
The reason that ATI uses a special is to insure that your are not sending out audio out of its DVI connector since that could damage the unit on the other end when just using a DVI-DVI connection.
walford is offline
post #13 of 28 Old 12-30-2008, 12:47 PM
mslide's Avatar
Originally Posted by dorian11 View Post
I like your theory about the I2C bus being at the root of the special ATI dongle. I'm trying to figure a way around it 'cause I just bought a 50 foot DVI to HDMI cable and it doesn't send the audio as is... and I don't want to go and buy a new 50 foot HDMI to HDMI cable. I was hoping it would be an easy mod --...
I'm still hoping that someone will crack open one of those dongles and either prove or disprove my theory. You can try to buzz out the connector, but it won't prove whether or not an EEPROM is inside it. If it is there, it just hangs off of the I2C bus, which would be passed through anyways as that I2C bus is part of the DVI and HDMI standard. That's how the EDID info is sent. I'd be surprised if they simply used a pull-up resistor to tell if it's plugged in.
I agree that it could just be done in software. I don't really know why some would require the dongle where as some other cards, or IGP mobos, can use a generic adapter. Maybe ATI initially wanted to cover their butts, so they came up with the dongle so there was no possibility of damaging a DVI monitor and then later realized it wasn't a big deal?
Disclaimer: I don't own one of these cards, so take what I say with a grain of salt. I really wish an engineer, who worked at ATI, would speak up
edit: I had more written, but Walford's post contains the same solution I was going to suggest (hdmi male to dvi female adapter in between the ati dongle and your cable).
mslide is offline
post #14 of 28 Old 12-30-2008, 11:31 PM
dorian11's Avatar
I thought at first the I2C wasn't part of the DVI interface... But I buzzed it out and it looks like it is -- DDC clock and DDC data are SCL and SDA respectively.
I also found that there is about 500k between 5V and ground on the ATI adapter where as a generic adapter is open, which fits with the idea of there being an active circuit that uses 5V.
I'm able to get EDID info from my Panasonic TV without the dongle... I'm starting to think that maybe there is an EEPROM in there, but as some have suggested, the ATI card just uses it to verify that the dongle is there before sending audio data so as not to screw up a standard monitor (I guess the monitor, not knowing anything about HDMI, would attempt to decode the extra data as image data).
Anyway, I'll probably never find out for sure -- I'll just get the extra adapter as you both mention
thanks
dorian11 is offline
post #15 of 28 Old 12-31-2008, 09:14 AM
walford's Avatar
I have seen references to an an eprom in the dongle and I beleive it is used to modify the EDID data coming from the destination and going to the graphics card so that the card knows it can also send audio that the card can generate.
An I beleive that this is why not all DVI-HDMI audio capable use the same version of the dongle
walford is offline
post #16 of 28 Old 12-31-2008, 09:28 AM
nalawod's Avatar
Isn't it also true that you need to use the ATI provided dongle in order to properly detect your HDTV and the colorspace's available? I know that the "pixel format" option was NOT available in CCC until I used their dongle. So, yet another reason to use theirs and not a generic.
nalawod is offline
post #17 of 28 Old 12-31-2008, 12:28 PM
vkristof's Avatar
This is a function of AMD/ATI's lack of public documenation. Intel, blesss their profit-making souls, puts a LARGE amount of their documentation online. That's how you can find out the reason behind some of Intel GMCH oddities (IGP defeated when add-in PEG card used, etc.)
AMD/ATI does NOT. I've complained to various AMD Apps engineers who appear at trade shows and they typically act chagrined.
Note that ATI used to peddel that DVI to component dongle, so the new dongle might be a corporate philosophy carryover. Companies can do many dumb things becasue of institutional reasons.
Note that the EDID in HDMI monitors also contains the audio configuration information, so the graphics chips SHOULD know whether the far-end end point really can accept audio embedded in the TMDS signal.
vkristof is offline
post #18 of 28 Old 03-03-2009, 07:12 PM
topdogzero's Avatar
I have a 4850 from Palit that came without the dongle, Palit has since sent me one but I still can't get audio over HDMI, the dongle that Palit sent me has no makings on it and the colour is light gray. Did Palit send me the wrong dongle because my HDTV is detected as a DVI device in CCC.
topdogzero is offline
post #19 of 28 Old 03-03-2009, 07:23 PM
RADCOMj1's Avatar
you may need to enable Audio over HDMI in the sound config.properties. Also helps if you use the latest drivers.
RADCOMj1 is offline
post #20 of 28 Old 03-03-2009, 07:48 PM
topdogzero's Avatar
Sorry the colour of the dongle is black, and I should give more info. Hdmi is selected in audio properties, using 9.2 drives and also tried realtek ATI audio driver since they made the audio codec chip on the card, when I use this driver it says cable not plugged in. Dongle I received has marking HDMI on it and a circle with a arrow going through it. No ATI makings and no rev numbers or letters.
post #21 of 28 Old 05-13-2009, 09:50 PM
So I have a weird problem where if I use the ATI HDMI dongle, then I can set my pixel format to limited and get correct 16-235 grayscale (with clipping of BTB/WTW), but if I use the Asus Xonar HDAV supplied DVI-HDMI cable, then I cannot even get to the Pixel Format in CCC, and I get double compression of the video grayscale (something like 32-219). This is all wiht 9.4 drivers.
Now I can set the pixel format to limited in CCC (when using the dongle) so that I get correct greyscale levels, and then switch to the DVI-HDMI cable, and retain those levels, however I lose this upon a restart.
I would really like to use the DVI-HDMI cable due to space constraints in my TV cabinet (the HDMI dongle plus an HDMI cable is like 4 inches from the back of my case which is just too much). I would hate to have to pull my HTPC out of the cabinet and run through the procedure above to get correct grayscale every time I restart my PC.
Is there anything I can do? Besides wait around for another driver release from ATI?
jdubbs23 is offline
post #22 of 28 Old 09-28-2010, 03:14 PM
Mandor6's Avatar
Hi folks,
Sorry for the *holy thread revival* but I stumbled upon this on a google search and it describes my problem exactly.
I have a 25 foot DVI to HDMI cable that used to work with my Nvidia GTX260 for video and audio, but now I have a new 5970 and I get no audio.
Has anyone found a way to enable audio over the DVI port without the dongle?
Cheers!
Jerome
Mandor6 is offline
post #23 of 28 Old 10-06-2010, 04:46 PM
Mandor6's Avatar
bump! got reply from AMD tech support and it was extremely unuseful ....
Mandor6 is offline
post #24 of 28 Old 10-06-2010, 05:11 PM
Davinleeds's Avatar
For info, I have the ATI dvi/hdmi adapter connected to a 450GTS DVI cause I dislike the mini hdmi adapter. Hdmi audio passes and is recognized in playback devices.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #25 of 28 Old 10-06-2010, 08:49 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You *must* use ATI's own dongle if you want to use the DVI port of the card for audio.
Why not use a HDMI male to DVI-D female adapter and connect it to the HDMI port of the card?
renethx is offline
post #26 of 28 Old 10-07-2010, 07:16 AM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
Cheers!
Jerome
You can't do it, did you read through all the responses and the mention of the probable EEPROM in the adapter? It's funny you said the thread describes your exact problem which may be true, but, it also describes the solution
There's really no reason for the use of the adapter at all, it's just to force you to use that DVI-HDMI adapter, but that's the way it is. The card knows when you've used a [generic] DVI-HDMI cable because the driver gives you a popup message telling you so when you do use one. So if the card knows what you've connected, why doesn't it just throw audio out the DVI port when it's detected an HDMI device is connected? I wish I knew that answer, I'm sure a lot of people do. Probably some engineer at ATi had some "bright idea" and thought it had to be implemented that way when it certainly did not.
It doubt it's really to make money on parts sales to consumers because a lot of cards started coming with the adapters in the HD 3xxx generation (though some companies like XFX weren't doing this on their mainstream cards). I can't imagine there is any huge revenue for them from these adapters, it's just stupidness.
It can't be solved with a driver hack either (i.e. at the software level) because I'm sure if it were possible someone would have done it by now as this has been going on for years (since ATI started HDMI audio in the HD 2xxx).
The only thing I'd imagine you could do is hard mod the card. You'd have to find out what they use in the adapter to tell the card to output HDMI audio and solder it in permanently. And nobody really knows for sure and if it is an EEPROM you'd be buying the adapter anyway to get it LOL. Plus doing that (even if you could) would totally void the warranty and prevent the DVI port from ever being used as a DVI port proper, which is really not something you want to get into on a card as pricey as the 5970.
Nowadays the problem is largely gone in the 5xxx series, not because AMD did away with the adapter, but because most cards now have actual HDMI ports on them. Which of course begs the question...why don't you use the HDMI port?
ES_Revenge is offline
post #27 of 28 Old 10-07-2013, 01:22 AM
Zajec's Avatar
I feel a bit bad posting in this old thread, but I think this is the only place in the Internet explaining ATI's dongle magic!
I totally agree with mslide's theory, it makes sense to me.
I guess you're guys mostly Windows users, so let me shortly explain Linux situation here.
In Linux world you have a choice between two drivers for ATI/AMD GPUs:
1) Catalyst AKA fglrx - close source driver, provided by AMD, it is pretty similar to the Window's one
2) radeon - open source driver included in the kernel by default
So as you can guess, when using Catalyst / fglrx driver, we can't play audio when using generic DVI ←→HDMI adapter. This totally matches your experience.
*However* when using open source "radeon" driver, there is no such problem. Using *exactly* the same hardware, adapter and TV, I just play audio totally fine. It includes LPCM, DD and DTS.
So there must be some extra validation in the "fglrx" driver checking for the adapter type. If "fglrx" doesn't detect ATI adapter, it refuses to setup HDMI audio mode.
Open source "radeon" driver doesn't have any validation like that, so you can use any adapter.
There aren't any extra pins, it's just a matter of extra I2C identification of the adapter.
Zajec is offline
post #28 of 28 Old 10-27-2013, 06:03 PM
resqguy's Avatar
I found a bunch of the adapters on Ebay. The prices range from about $4 to $15. I have a HIS card and was wondering if the generic ATI adapter would work or if I should order the (more expensive) HIS version.
resqguy is offline
Reply Home Theater Computers
