HD4650: few deinterlacing options/fan control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 156 Old 11-05-2008, 02:15 AM - Thread Starter
topcaser's Avatar
Hi,
i have installed this HD 4650.
After installing latest Hotfix drivers (CCC 8.10 Hotfix) i can only select Bob or Weave as deinterlacing option. Nothing changed after deinstallation of 8.10 and installatiion of 8.11RC1.
Then i applied those regtweaks:
Code:
REGEDIT4
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Video\\{FAC79B42-7125-47A3-B8B4-B9B2875AE150}\\0000]
"UseBT601CSC"="1"
"vforcedeint"="6"
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Video\\{FAC79B42-7125-47A3-B8B4-B9B2875AE150}\\0001]
"UseBT601CSC"="1"
"vforcedeint"="6"
i have double checked if the regtweaks are really in there where they have to be. Reboot: Nothing changed.
Is there any more regtweak available to get the missing deinterlacing options?
Furthermore the fan control works well. Nevertheless, the minimum value, which i am able to adjust in CCC, is 20%. I cant find those fan settings in the registry - did a search for fan in the entire registry. Any hints? Is there a chance to go beyond 20% or is it really the minimum value?
topcaser is offline
post #2 of 156 Old 11-05-2008, 04:39 AM
Rigby Reardon's Avatar
I have the same card and also only see Bob and Weave deinterlacing modes. Haven't checked the fan control, since the card is virtually silent as it is (which is the main reason why I got this particular card, as there is no passive solution on the market that fits in my HTPC case).
Also, as I already wrote in the other 4600/4800 thread, the controls for denoising and sharpening are disabled under advanced settings. Is this the case for you as well?
Rigby Reardon is offline
post #3 of 156 Old 11-05-2008, 04:57 AM - Thread Starter
topcaser's Avatar
Have you already posted the problem in another thread? Have you got a link for me?
Here, the deinterlacing options are also disabled. Did you had a look in the registry? There you can adjust the values manually. Maybe there is a trick, that you get it enabled in CCC.
topcaser is offline
post #4 of 156 Old 11-05-2008, 05:54 AM
http://www.avsforum.com/avs-vb/showt...1#post15005211
Just to clarify: The deinterlacing slider in CCC works, but I can only select between Bob and Weave (but not the advanced adaptive modes). On the other hand, the sliders for Denoise and Sharpening under "Advanced Quality" are simply greyed out and cannot be operated at all. I would specifically like to turn off Denoise (which is activated with a value of 64 by default), but it's apparently not possible.
Whether there are any registry hacks to adjust the parameters, I don't know. I would rather have the possibility to adjust them in the user interface.
post #5 of 156 Old 11-05-2008, 06:05 AM - Thread Starter
topcaser's Avatar
Some stuff can only be adjusted in the registry for a long long time. I used to it anyway.
If you want to switch off denoise: open the registry editor, HKLM/System/CurrentControlSet/Control/Video//0000 and 0001/UMD/DXVA
Find there the denoise option and set in both 0000 and 0001 the min value to 0. Thats it.
Maybe there is also an entry which brings back the option to do it in CCC direcly. Ask Arfster, he is best known with this stuff.
Hope that helps.
topcaser is offline
post #6 of 156 Old 11-05-2008, 06:33 AM
Thanks for the registry tip!
Anyway, it's good to know that it's not just me. Hopefully it's just a bug in the Hotfix driver that causes these features to be disabled. The hardware of a 4650 should support them.
post #7 of 156 Old 11-05-2008, 06:49 AM - Thread Starter
topcaser's Avatar
Did you opened a ticket @ATI for the deinterlacing stuff?
Which card do you have?
topcaser is offline
post #8 of 156 Old 11-05-2008, 06:52 AM
No. It doesn't bother me so much because I mostly use the HTPC for Blu-ray and HD-DVD playback where interlaced content is very rare. The forced denoising concerns me more, because I suspect it impacts picture quality.
Exactly the same that you linked to in the first post.
post #9 of 156 Old 11-05-2008, 07:05 AM
lstepnio's Avatar
This is just perfect. I have a HD4650 on it's way to replace my 7950GT due to unresolvable issues with 1080i playback with DXVA enabled. You guys running XP or Vista? I'll be installing the card on my XP based HTPC over the weekend.
lstepnio is offline
post #10 of 156 Old 11-05-2008, 07:31 AM
arfster's Avatar
Use dxva checker to set reg options, that way it's always in the right place.
arfster is offline
post #11 of 156 Old 11-05-2008, 07:58 AM - Thread Starter
topcaser's Avatar
Arfster, dont know, what you mean. Do you mean, that the lost deinterlacing options will come back by using dxva checker?
Some german guys reported no problems at all with deinterlacing options, but they have another vendor (HIS). That you have the same problems as me points to a VGA BIOS problem
topcaser is offline
post #12 of 156 Old 11-05-2008, 08:21 AM
arfster's Avatar
Dunno - depends if you're putting the reg keys in the right place :-) DXVA checker is just useful for doing that.
arfster is offline
post #13 of 156 Old 11-05-2008, 08:41 AM - Thread Starter
topcaser's Avatar
Arfster, can you advice me what to do?
Thanx again for help.
topcaser is offline
post #14 of 156 Old 11-05-2008, 09:07 AM
It's possible. But it could also be a bug in the driver that causes it not to recognize the card correctly. E.g., I also noticed that CCC reports 1GB video memory even though the card only has 512MB. I guess Hotfix in this case means that support for the 46xx/45xx cards was "mit heisser Nadel gestrickt". The 8.11 should be out soon; if it isn't fixed then, I will open a ticket with ATI.
post #15 of 156 Old 11-05-2008, 10:17 AM - Thread Starter
topcaser's Avatar
Rigby,
the Palit site hosts a driver, which has RC2 in its name. Maybe it is the 8.11RC2 driver and supports the graphics card.
I just download it...
topcaser is offline
post #16 of 156 Old 11-05-2008, 11:27 AM - Thread Starter
topcaser's Avatar
This did the trick. All deinterlacing options are available now. Also you can enable denoise and that stuff.
Be happy with this graphics :-)
topcaser is offline
post #17 of 156 Old 11-05-2008, 11:43 AM
lstepnio's Avatar
Thanks for reporting back! I ordered the "VGA HIS H465P512P HD4650 512M RT" version which is passive cooled. I'll give the drivers you suggested a try if the official ATI drivers don't do the trick right out of the box.
Can you confirm it's actually working too?
lstepnio is offline
post #18 of 156 Old 11-05-2008, 11:53 AM - Thread Starter
topcaser's Avatar
Works great here. Nevertheless in a few days new 8.11 (official) will be released. Furthermore german guys, who ´have exactly this passive HS version, said, that there is no problem with 8.10 Hotfix drivers.
Now there is only one problem left: where can i modify percentage of the fan? It is not in the registry. Arfster, have you any ideas?
topcaser is offline
post #19 of 156 Old 11-05-2008, 11:57 AM
Good news. Are you referring to the 8.54-RC2 driver? That's actually older than the current Hotfix on the AMD site.
post #20 of 156 Old 11-05-2008, 12:20 PM - Thread Starter
topcaser's Avatar
The driver from the Palit site, which has RC2 in its filename, has version number: 2008.0910.2138.36940
can you post yours - i havent it available any more.
topcaser is offline
post #21 of 156 Old 11-05-2008, 12:36 PM
The CCC version number of the Hotfix driver is 2008.1003.1759.30358. The driver package is version 8.542-081003a-070928E. So this driver is dated Oct. 3rd, whereas yours is from Sept. 10th. But who cares if it works. Anyway, since the problem is not very severe for me I will wait for the official 8.11 which should be out soon.
post #22 of 156 Old 11-05-2008, 12:43 PM - Thread Starter
topcaser's Avatar
IMO that is a very bad Software development. i hope, that all features from this older version will find their way in the new 8.11 release. Sometimes i want to have a view in this software development.....
topcaser is offline
post #23 of 156 Old 11-05-2008, 01:58 PM
Bignickfly's Avatar
I believe only Vista had supported enhanced AVIVO options. I did notice my hd2400pro now has new options with Cat 8.10 and XP sp3
Bignickfly is offline
post #24 of 156 Old 11-05-2008, 02:00 PM - Thread Starter
topcaser's Avatar
What are enhanced AVIVO options?
topcaser is offline
post #25 of 156 Old 11-05-2008, 05:42 PM
Bignickfly's Avatar
Denoise, Edge Enhancement, Dynamic Contrast and Colour Vibrancy.
Check to see these options are in Advanced AVIVO section of Catalyst control center
post #26 of 156 Old 11-05-2008, 06:55 PM
lstepnio's Avatar
I'm awaiting my card to arrive and new to the ATI cards for HTPC. What exactly does one loose running XP with these cards? Please tell me this doesn't include any of the deinterlacing features does it?
lstepnio is offline
post #27 of 156 Old 11-05-2008, 10:18 PM - Thread Starter
topcaser's Avatar
No worries,
all of the features are there in XP, too.
Dunno why Bignickfly thinks, it is not available. Nevertheless, you will switch off those "enhancer" anyway.
The only thing you need is: Vector adaptive deinterlacing and PDVD codec.
topcaser is offline
post #28 of 156 Old 11-07-2008, 05:09 AM
nemrod95's Avatar
Hi,
I have a Gainward ATI Radeon HD 4650 and i have same problem with deinterlacing/denoise options. All are disabled
This happend with 8.10 Catalyst hotfix II and with 8.11 beta.
I have tried the 8.10 catalyst from Palit but same problem...
I hope this will be solve in the final 8.11 Catalyst......
nemrod95 is offline
post #29 of 156 Old 11-13-2008, 01:54 AM
Update: The Catalyst 8.11 drivers are now available on the AMD site. Unfortunately they do *not* solve the problems with the missing deinterlacing modes and greyed out advanced options for me (Xpertvision 4650 "Super" as linked in the first post).
post #30 of 156 Old 11-13-2008, 03:10 AM - Thread Starter
topcaser's Avatar
Rigby,
i have not tried it and wont try it if you say that it dont work.
Nevertheless, please open a ticket with ATI and write an Email to technical support of Palit.
The more people tell them the earlier they fix this issue. That is the plan
topcaser is offline
Reply Home Theater Computers
