*Official* Gigabyte GA-E7AUM-DS2H Thread (NVIDIA 9400 mATX HDMI 8 channel LPCM) - Page 95 - AVS Forum | Home Theater Discussions And Reviews
First ... 93  94  95
Home Theater Computers > *Official* Gigabyte GA-E7AUM-DS2H Thread (NVIDIA 9400 mATX HDMI 8 channel LPCM)
TimA's Avatar TimA 05:57 AM 03-03-2012
Originally Posted by pizzaman79 View Post
Thanks. I swapped the Scythe shuriken on my cpu for a Scythe big shuriken and the Antec NSK1380 case is now replaced by a Lian Li PC-V351B. This alone brought the temperature down to around 60', without an active fan.
Gigabyte had a great tech support and confirmed that these are quite normal temperatures, so i'm gonna accept them for now. I'll probably replace the internals for ivy bridge as soon as gigabyte brings out a nice htpc/server uatx mobo. Already bought my DDR3 memory, as prices are about to rise :-)
My chipset runs at about 39 degC using one of these:
http://www.newegg.com/Product/Produc...82E16835200034
The fan pulls air down and then out over the components around the CPU including the chipset heatsink. If your CPU fan doesn't direct air over your chipset heatsink, you will have a hot chipset. I started with a passive CPU cooler, but found out quickly that it didn't cut it for this chipset. There was a lot of hot chipset discussions in this thread when this board was released. Take a look.
Tim
elloco07's Avatar elloco07 08:09 AM 12-27-2012
I just installed Windows 8 PRO on my HTPC and now my PC randomly goes to sleep or hibernate. Windows 8 installed fine, it found all the drivers except for the coprocessor driver which I had to manually point to the windows 7 64bit chipset downloaded folder I got from gigabyte website. So the computer boots up fine, I have it connected to HDMI to my receiver-->tv and a touchscreen VGA monitor. Now I try to do something and it randomly will make my tv and monitor go blank (I get no signal on tv). The PC is still on, then shuts off but it either goes into sleep or hibernate because when I turn it back on, the login screen comes up. Even before I can logon if I press a key to logon and enter my password it shuts down again.
Has anyone installed Windows 8 and what drivers did you use? I am sure it is a driver issue but in Gigabytes website there is no windows 8 drivers.
I hope there is a fix if not I will go back to windows 7.
Maverick0984's Avatar Maverick0984 01:38 PM 12-27-2012
I haven't tried Windows 8 on my HTPC with this motherboard but it always had issues with the Nvidia graphics card and its drivers. Always seemed to be very temperamental. I would look towards those as a first line of troubleshooting. Either make sure you have the most recent and/or rollback a few versions and see if you have better luck with them. I seem to remember it being so bad I thought about getting a dedicated graphics card even though the very reason I choose this motherboard was because of the integrated solution. It eventually started working and I have made sure I haven't taken any automatic updates since to those drivers since then. Eventually, I'll swap out the motherboard for something better as there are much better options available nowadays.
ForestMajors's Avatar ForestMajors 01:21 PM 01-25-2013
I have had problems running windows 8 Pro on this board too. Runs fine on another computer with a later motherboard including WMC but not his board. Have tried several different drivers including a later nvidia drivers. I have also run into another problem that is not mentions - extraordinarily slow copy process to my windows home server 2011 - Painful
bryansj's Avatar bryansj 07:06 PM 02-19-2013
An update on this motherboard, which I retired from HTPC use to Server use. I just added an IBM MegaRAID M1015 controller. First I was concerned it might not be compatible due to the nvidia chipset usage. Well, it worked fine.
Then there is the whole process of flashing these cards with an LSI firmware. Again, this too worked fine. I just disabled the onboard SATA, IDE, and LAN in the BIOS prior to flashing. Up until I received the card I could never find info that it would work on this board.
rts's Avatar rts 06:09 PM 03-04-2013
Any other experiences on running it with Windows 8? Mine has been running Windows 8 for last month. I'm so disappointed. It reboots at random at least once a day. I've made some basic tweaks mentioned for Windows 8 to avoid reboot issue, but no success yet. Since I use it as a Media center, I don't think there is any advantage of running 8 - seems like it's a mistake. Will probably be going back to 7 over the weekend.
ForestMajors's Avatar ForestMajors 12:09 PM 03-05-2013
I discover that the cause of my windows 8 problems and file access was the lan drivers. After I replace the motherboard drivers with standard lan drivers the file access problems and other related problems went away. Windows 8 now performs well on this board and there are no problems accessing files over my network and server. I almost gave up and went back to windows 7 but am glad that I did not as I like the on-line interactive interface of windows 8 and the clean music app...
laurentluberon's Avatar laurentluberon 12:09 AM 04-14-2013
hello
my htpc is running on windows xp 32 with 2 Go RAM.
I would like to change (Windows seven 32).
Could you clearly tell me if Gigabyte GA-E7AUM-DS2H works well with seven ? all functions are available ?
Do i need 4 Go ?
sincerely
CountryBumkin's Avatar CountryBumkin 05:25 AM 04-14-2013
The MB works great with Win7. Win7 is a major improvement over XP. You will be glad you upgraded.
Regarding HTPC use, the on-board graphics is too weak for running MadVR (at its highest settings) but a cheap NVidia GT440 or GTS450 add-on card is all it takes to handle that.
ForestMajors's Avatar ForestMajors 09:02 AM 04-15-2013
The board will run either windows 8 or 7 - personally, I would recommend the 64 bit version.
laurentluberon's Avatar laurentluberon 04:07 AM 05-01-2013
hello.
I installed seven 32bits. Everything seems to work correctly.
But windows tells me that the driver for multimedia video controller (PCI\VEN_109E&DEV_0350) is missing.
I don t know if it is important.
Have you seen this problem ?
Sincerely.
bryansj's Avatar bryansj 06:24 AM 05-01-2013
Originally Posted by laurentluberon View Post
hello.
Sincerely.
http://lmgtfy.com/?q=PCI%5CVEN_109E%26DEV_0350
Google tells me that it is your AVerMedia Capture Card.
bLKPANTHR's Avatar bLKPANTHR 10:28 AM 05-23-2013
Nice to see people still using thiese boards
I have 2 of them running stong with cablecard tuners and win7 32bit
not a single issue with either of them.
magusat999's Avatar magusat999 10:29 AM 06-06-2013
Today, after having zero problems with this board for a few years now, I turned on my PC and it sits at POST for a long time (10+ minutes). When it finally tries to boot to Windows (7 x86) it has an onld system and one of my current ones listed. I have Windows 7 / Windows 8 dual boot - but it shows Windows 7 / Windows XP instead. I'm rying to figure out why its taking forever to boot to post, and secondly why my systems are not coming up correctly. There is also an error related to winload, and Windows 7 will not load.
Update: I found the Windows problem - after updating the BIOS the SATA drives were running in IDE mode instead of AHCI. I switched that and WIndows now loads - but the long waiting period at POST is still there.
bLKPANTHR's Avatar bLKPANTHR 01:49 PM 06-25-2013
try EasyBCD, should fix your boot issues.
markabuckley's Avatar markabuckley 02:35 PM 06-25-2013
my boot times are very very very long on this board too
although it depends on my FSB speed .... some lower speeds and it takes forever, some higher speeds the same, some inbetween much quicker ...
"quick" is prob 20 seconds (to initial boot), slow is 40+ seconds
seemed to be when I added the discrete graphics card
never had a PC take so long to boot to bios
markabuckley's Avatar markabuckley 09:16 AM 07-20-2013
ouch - just tried (as was lent one) a IR temperature detector
measured the northbridge heatsink on my 9400 .... 79.4C - ouch
hifiaudio2's Avatar hifiaudio2 09:53 AM 07-31-2014
I am considering finally retiring / selling this MB that I have combined with an Intel Core2 duo 8400. Any idea how the CPU and graphics of this setup would compare to what is in the i5 Intel NUC? (i5-4250U and HD graphics 5000)
TripleFun's Avatar TripleFun 12:04 PM 07-31-2014
The CPU are much the same - see http://cpuboss.com/cpus/Intel-Core2-...-Core-i5-4250U.
The HD 5000 is a significant improvement on the 9400 - see http://www.game-debate.com/gpu/index...eforce-9400m-g.
WhitePC 06:41 PM 08-14-2015
GA-E7AUM-DS2H, How can I get 64 Bit? I have tried almost everything to get it to install 64 bit but drivers on boot install will not acknowledge a 64 bit environment. This was extracting the driver and pointing it to "it" during install. I wish it would fault on install if the actual OS 32/64 bit was all that could be installed, that way I could T/S the install.
kcdaemon's Avatar kcdaemon 10:13 AM 08-16-2015
Which CPU are you using? 64bit or not will depend on that in most cases...
CountryBumkin's Avatar CountryBumkin 01:34 PM 08-18-2015
I'm trying to reply but AVS forum keeps telling me I need to type more than 2 characters.
Okay, I'm back in.
I wanted to post to confirm that the GA-E7AUM board will support Win10 x64. I have been running it since it came out for Insider testing without any issues. Check that you have latest BIOS (F4), and that CPU multi-threading is enabled in BIOS.
Ironically my Gigabyte mb failed about week ago - so now I have an Intel "Core2 Duo 8400"" cpu for sale - and I have an Intel "Core 2 Quad 9500" cpu for sale. Both will work on your board. So if you end up needing to buy a CPU, PM me.
hifiaudio2's Avatar hifiaudio2 03:47 PM 09-14-2015
I have a custom HTPC based off this board that I will want to sell soon... just seeing if there is interest before I price out the components to see what I want for it. Cant remember what CPU I put in it offhand...core2 8400 or 9300 probably.
bryansj's Avatar bryansj 05:07 PM 09-14-2015
I gave mine away. Lack of HD audio from the onboard GPU limits its use around here.
hifiaudio2's Avatar hifiaudio2 07:00 AM 09-15-2015
Ah good point. I have had it connected to just a TV for WMC use for so long that I forgot it doesnt do HD audio.
bryansj's Avatar bryansj 07:26 AM 09-15-2015
I upgraded to the first Intel CPU with HD audio and a new motherboard. The build with this board was used on my first WHS build. I then switched to an ESXi server and gave this one away to a friend. As far as I know it is still running.
hifiaudio2's Avatar hifiaudio2 07:33 AM 09-15-2015
Yeah I put this thing together in early 2009 and it hasn't skipped a beat.
First ... 93  94  95
Up
