htpc - wish list (let me know your thoughts) - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What is the best Tv Turner Manu
Hauppauge 0 0%
ASUS 0 0%
AVerMedia 0 0%
Other 0 0%
Voters: 0. You may not vote on this poll
post #1 of 20 Old 11-23-2008, 09:46 PM - Thread Starter
nalij's Avatar
Hey thanks for stopping by....
I am thinking about building an HTPC and it needs to be able to do the following: i) HDMI out to my Samsung LCD, ii) optical out to my home receiver, iii) massive storage, iv) quiet, v) network access (not in any particular order) Also, am not sure if I should make the system Blue-ray capable since I have a PS3 and don't own or plan on buying any Blue-Ray movies in the near future. Nor, have I been able to decide on a tv-tuner - any advice would be appreciated!
I would appreciate any feedback if you have past experience with any of these components or recommendations for alternative gear. Thanks.
Wish List
- CPU: AMD Athlon X2 4850e 2.5 GHz 2x512KB L2 Cache Socket AM2 45W Dual Core Processor ($59.99)
http://www.newegg.com/Product/Produc...82E16819103255
- Mobo: Gigabyte GA-M578LI-S4 AM2 NvIDA nforce 570 SLI MCP ATX AMD ($79.99)
http://www.newegg.com/Product/Produc...82E16813128014
- Case: Silverstone Grandia GDOIMX Black HTPC ATX Case Built-in LCD Display, Front USB, Firewire, & Audio Ports ($249.99)
http://www.tigerdirect.com/applicati...IN#detailspecs
- PSU: Corsair CMPSU-550VX 550W ATX12V V2.2 SLI Ready 80+ Certified ($97.99)
- Fan: Thermaltake CL-PO464 80"mm ($64.99)
http://www.newegg.com/Product/Produc...82E16835106114
- Video Card: Sapphire 100265L Radeon HD 4830 512 MB 256-bit GDDR3 ($109.99)
http://www.newegg.com/Product/Produc...on%20HD%204830
- RAM: 2 - Kingston HyperX 2GB 240 Pin DDR SDRAM DDR2 800 (PC2 6400) ($28.99 each)
http://www.newegg.com/Product/Produc...82E16820104030
- HDD: 2 - WD Caviar Green WD10EACS 1TB SATA 3.0 Gb/s ($99.99 each)
http://www.newegg.com/Product/Produc...82E16822136151
-Optical: Samsung SH-5223Q/BEBN 22x DVD+/-RW SATA OEM Internal Drive Black ($34.99)
http://www.tigerdirect.com/applicati...396&CatId=1624
- Sound Card: Diamond XtermeSound X571DDL 7.1 Channel 24 bit 96 HKz PCI-interface ($49.99)
http://www.newegg.com/Product/Produc...82E16829111002
Total System Cost: ~$1,005.84 plus Uncle Sam's cut and shipping.....
nalij is offline
post #2 of 20 Old 11-25-2008, 02:48 PM - Thread Starter
nalij's Avatar
bump for feedback
Christmas is coming soon.....need to get the wishlist out
Any comments are greatly appreciated!
nalij is offline
post #3 of 20 Old 11-25-2008, 03:38 PM
mr007's Avatar
I am thinking about building an HTPC and it needs to be able to do the following: i) HDMI out to my Samsung LCD, ii) optical out to my home receiver, iii) massive storage, iv) quiet, v) network access (not in any particular order) Also, am not sure if I sure make the system Blue-ray capable since I have a PS3 and don't own or plan on buying any Blue-Ray movies in the near future. Nor, have I been able to decide on a tv-tuner - any advice would be appreciated!
Wish List
newegg doesnt charge tax so uncle sam can go screw himself
mr007 is offline
post #4 of 20 Old 11-25-2008, 03:39 PM
redtyler1's Avatar
I've always had good success with Hauppague tuners.
The 4830 card is overkill unless you are planning on gaming. If you're not a hardcore gamer, get a 4650 which will pass 7.1 LPCM audio to your receiver over HDMI. Thus, rendering unnecessary your sound card choice.
You can get a cheaper micro ATX board, or at least similarly priced (780G) that will use less power, if thats a concern. But, it looks good.
redtyler1 is offline
post #5 of 20 Old 11-25-2008, 03:41 PM
mr007's Avatar
u dont really need a soundcard the onboard stuff is good
mr007 is offline
post #6 of 20 Old 11-25-2008, 04:49 PM - Thread Starter
nalij's Avatar
Everyone thanks for the advice!
mr007 - thanks for pointing that out....def a nice to know.....also thanks for the advice on the sound card....now i can spend that $$$ at the bar
redtyler1 - Hauppage was definitely my top consideration, thanks for confirming.....I am not a gamer and thus i will def. look into the 4650 as an option (thanks for the suggestion)....and less power -> less heat -> less noise, more smiles so again thanks....also i looked into a micro ATX board, my concern is the size of the board for future additions
nalij is offline
post #7 of 20 Old 11-25-2008, 07:06 PM
HappyFunBoater's Avatar
Is the ability to screw oneself a good thing or a bad thing? And how is that an acceptible substitute for taxation?
I couldn't find a reference to your OS choice and whether you want the TV tuner to support ATSC (OTA) or QAM (cable). The AVerMedia m780 supports native QAM with Vista Media Center's TV Pack 2008 (Fiji). I don't believe Hauppauge has this support. Setting up QAM manually is a huge pain in the butt.
HappyFunBoater is offline
post #8 of 20 Old 11-25-2008, 07:38 PM
JJ
JJ's Avatar
Total of 12
Avermedia A180s so far, one dead at 2years another has gone partially funky (only tunes up to RF25) but the rest are going realy strong. For a specialized situation I'm using a HDHomerun too, but the A180 is my lasting love and it does cable QAM with TV Pack 2008. I'm certain that another tuner will someday tempt me but I'm loyal (but not quite monogamous) for now...
JJ
The Original Technology Wrangler
JJ is offline
post #9 of 20 Old 11-25-2008, 07:39 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
GA-M578LI-S4 is a two year old model (Socket AM2, released in May 2006) and there is no CPU upgrade path (for the upcoming 45 nm AM3 processors that will last through 2010). GA-MA78G-DS3H or the upcoming GA-MA78G-DS3HP is a better choice. Or GA-MA78GM-S2HP for mATX.
renethx is offline
post #10 of 20 Old 11-27-2008, 09:53 AM - Thread Starter
nalij's Avatar
Happyfunboater - my current provider is Optimum so I would need a QAM set up - particularly one that supports a cable card so I can record those HD channels...my plan is to initialize the set up with MCE and not Vista....i've read a few forums about the pain to get QAM going right, thanks for the heads up
JJ - Thanks for the confirmation that Avermedia turners are not the way to go...as you have had 12 in two years....i think ill go with a Hauppage model when i find out that suits all my needs
renethx - some of the BEST advice yet...exactly the type of info i was looking for....i will certainly look into your two suggested ATX boards
Thanks again everyone....Happy Thanksgiving
nalij is offline
post #11 of 20 Old 11-27-2008, 10:03 AM - Thread Starter
nalij's Avatar
Also, forgot to mention that I would like to format my HDD in RAID 1...if that has any influence on the future recommendations
nalij is offline
post #12 of 20 Old 11-27-2008, 11:15 AM
I think JJ was actually saying the opposite. He's got 12 units, and only two have failed. He loves the AVerMedia cards.
post #13 of 20 Old 11-27-2008, 11:20 AM
Given what you're read about the pain of getting QAM going, are you really sure you want to use MCE instead of Vista? TV Pack 2008 (Fiji), which automates QAM support, is only available for Vista. You also mentioned that you were leaning towards Hauppauge. Are you sure they support QAM under MCE or VMC?
post #14 of 20 Old 11-27-2008, 01:04 PM - Thread Starter
nalij's Avatar
I already own a copy of MCE and am not a big fan of Vista...so unless i get it free i dont see myself going to get a copy anytime soon...i'd rather wait to see what windows 7 has to offer....
And no I am not sure that Hauppuage supports QAM for MCE, which is why I havent selected a tv card yet
If you know of a solid card for MCE preferably made by Hauppuage that supports QAM and potentially a cable card - let me know....
appreciate the feedback
nalij is offline
post #15 of 20 Old 11-27-2008, 01:08 PM - Thread Starter
nalij's Avatar
Got it....thanks on the clarification....
what's your opinion on either manufacturer?
nalij is offline
post #16 of 20 Old 11-27-2008, 01:34 PM
I don't know too much more than what I've already mentioned, but here it all is:
I installed a Hauppauge card about a year ago in a Vista x64 system with 4GB of RAM and never got it working. There was a known issue with 4GB systems (not x64, surprisingly). I don't know if they ever fixed the problem, but I'd like to assume that they did. I switched to the AVerMedia M780 (with a free Media Center remote and IR hub) and haven't had a problem since day one.
I always got the impression that Hauppauge was the "king of the hill" for TV tuners, but with QAM support under Media Center AVerMedia seems to have surged ahead. Just from reading various forums, I "think" that Hauppauge only supports QAM under their own application, not Media Center. I could be wrong. And I am also pretty sure (again, just from reading forums, not first hand experience) that only AVerMedia supports TV Pack 2008. But if you're stuck with MCE then TV Pack 2008 is out of the question.
Given how hard it is to set up QAM, are you sure you really want it? On my local cable the QAM stations are barely more than I can pick up via antenna. I think I get a few extra PBS stations. You won't get any of the encrypted QAM channels. I'm lucky enough that I can use a cheap indoor antenna and pick up the local stations with almost 100% signal level. This might not be an option for you.
Good luck!
post #17 of 20 Old 11-29-2008, 02:50 PM - Thread Starter
nalij's Avatar
Wish List
Update -
Per the advice of renethx I will now be purchasing the upgraded Gigabyte mobo
GIGABYTE GA-MA78G-DS3H AM2+/AM2 AMD 780G HDMI ATX AMD Motherboard (86.99)
http://www.newegg.com/Product/Produc...=GA-MA78G-DS3H
I also found an old DVD +/- RW drive in my closet so that will cut some $ off the final bill...but...have yet to find a tv turner
And since I am saving rougly 30 bucks on not purchasing a DVD drive, I changed the case I am going to get....
Thermaltake VF7001BNS DH101 HTPC Computer Case - Front LCD Display, Remote (269.99)
http://www.tigerdirect.com/applicati...776&CatId=3429
nalij is offline
post #18 of 20 Old 11-29-2008, 04:48 PM
Teeps's Avatar
Quoted: 18 Post(s)
The heck they don't; Newegg collected $29 in tax on my recent order.
Cheers, Tp
"No lawsuit ever fixed a moron."
Teeps is offline
post #19 of 20 Old 11-30-2008, 11:50 AM
PhillipH's Avatar
Of course it depends on which state you live in. I've never been charged sales tax by Newegg. They don't ship from my state.
SageTV v7 WHS + 2 HD200s
Windows Home Server PP3 - Dual Xeon 2.8ghz
23 Drives - 26 Terabytes
Blu-ray Titles 251
HD-DVD Titles 166
DVD Titles - Too Many To Count..
PhillipH is offline
post #20 of 20 Old 11-30-2008, 12:22 PM
Rico66's Avatar
They're located in California, so you obviously pay tax, if you live in the same state.
Rico66 is offline
Reply Home Theater Computers
