EDID Override Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #271 of 3482 Old 01-02-2009, 04:05 PM
mrchiefs2005's Avatar
Hi Kemac, you are right, it does work with the original file in the first post... now what did I do wrong...
here is what moninfo gives me when connected directly in my TV:
Monitor
Model name............... Panasonic-TV
Windows description...... Generic PnP Monitor
Manufacturer............. Panasonic
Plug and Play ID......... MEIA07C
Serial number............ n/a
Manufacture date......... 2008, ISO week 0
Filter driver............ monitor
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.345
Green chromaticity....... Gx 0.291 - Gy 0.635
Blue chromaticity........ Bx 0.163 - By 0.093
White point (default).... Wx 0.288 - Wy 0.296
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (4:3)
Detailed timing #4....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #5....... 1440x480i at 60Hz (4:3)
CE video data (timings supported)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 190MHz
Report information
Date generated........... 1/1/2009
Software revision........ 2.20.0.779
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,34,A9,7C,A0,01,01,01,01,00,12,01,03, 80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
......................... 17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
......................... 45,00,BA,88,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, BA,88,21,00,00,9E,00,00,00,FC,00,50,
......................... 61,6E,61,73,6F,6E,69,63,2D,54,56,0A,00,00,00,FD,00,17,3D,0F, 44,0F,00,0A,20,20,20,20,20,20,01,FF,
......................... 02,03,1E,71,49,90,05,20,04,03,02,07,06,01,23,09,07,01,67,03, 0C,00,10,00,B8,26,E3,05,03,01,01,1D,
......................... 00,72,51,D0,1E,20,6E,28,55,00,BA,88,21,00,00,1E,8C,0A,D0,8A, 20,E0,2D,10,10,3E,96,00,BA,88,21,00,
......................... 00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,0B,88,21,00,00,18, 8C,0A,A0,14,51,F0,16,00,26,7C,43,00,
......................... BA,88,21,00,00,98,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,0B,88, 21,00,00,98,00,00,00,00,00,00,00,BC
and here is what I get when plugged directly to the yamaha rx-v863:
Monitor
Model name............... RX-V863
Manufacturer............. Yamaha
Plug and Play ID......... YMH312B
Extension blocs.......... 1 (Reserved - 0x00)
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Horizontal scan range.... 15-91kHz
Vertical scan range...... 23-121Hz
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Report information
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,65,A8,2B,31,00,00,00,00,00,12,01,03, 80,00,00,78,0A,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80, C4,8E,21,00,00,9E,00,00,00,FC,00,52,
......................... 58,2D,56,38,36,33,0A,20,20,20,20,20,00,00,00,FD,00,17,79,0F, 5B,0F,00,0A,20,20,20,20,20,20,01,60
mrchiefs2005 is offline
post #272 of 3482 Old 01-02-2009, 04:09 PM
kemac's Avatar
Quoted: 92 Post(s)
Liked: 74
If your like me you messed up one or more things in your inf file.
Can you attach your inf file or at least post your two override lines from your inf.
kemac is offline
post #273 of 3482 Old 01-02-2009, 04:09 PM
Panasonic TH-50PZ80U
Yamaha RX-V863
Thanks for the help !
EDIDOverride New File.txt 2.638671875k . file
post #274 of 3482 Old 01-02-2009, 04:35 PM
skidoo1's Avatar
Hi,
your EDIDs start like this
HKR,EDID_OVERRIDE,"0",0x01,0x00,
HKR,EDID_OVERRIDE,"1",0x01,0x00,
but should start like this
HKR,EDID_OVERRIDE,"1",0x01,0x02,
I'm not sure of anything else
skidoo1 is offline
post #275 of 3482 Old 01-02-2009, 04:43 PM
kemac's Avatar
Quoted: 92 Post(s)
Liked: 74
Yamaha RX-V863
Your EDID data that you posted for your 863 doesn't contain the extension block, it is only 4 lines in length when it should be 8 lines. Its the missing 4 lines that should be in your second override line. Can you update your inf to use the last 4 lines from this EDID? I could do it for you but I am in the middle of making diner.
Someone else posted their EDID from their 863 that has all 8 lines, below:
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,1E,6D,01,01,01,01,01,01,23,0F,01,03, 80,6E,3E,78,0A,31,30,A5,58,3B,B8,26,
......................... 0F,4B,52,2F,CE,00,31,CA,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,8C,0A,D0,8A,20,E0,2D,10,10,3E,
......................... 96,00,C4,8E,21,00,00,18,01,1D,80,18,71,1C,16,20,58,2C,25,00, 4C,6C,42,00,00,9E,00,00,00,FD,00,37,
......................... 4E,19,3E,08,00,00,00,00,00,00,00,00,00,00,00,FC,00,4C,47,20, 54,56,0A,20,20,20,20,20,20,20,01,ED,
......................... 02,03,36,76,4B,01,03,05,04,12,13,94,0F,1E,24,26,38,09,7F,07, 0F,7F,07,15,07,50,3E,1F,C0,4D,02,00,
......................... 57,06,00,67,54,00,5F,54,01,83,5F,00,00,68,03,0C,00,13,00,80, 21,00,01,1D,00,72,51,D0,1E,20,6E,28,
......................... 55,00,4C,6C,42,00,00,1E,8C,0A,D0,90,20,40,31,20,0C,40,55,00, 4C,6C,42,00,00,18,01,1D,00,BC,52,D0,
......................... 1E,20,B8,28,55,40,4C,6C,42,00,00,1E,01,1D,80,D0,72,1C,16,20, 10,2C,25,80,4C,6C,42,00,00,9E,00,FC
Then your second override line will start with 0x02, as skidoo pointed out because you will be using the second block of 128 instead of the first block of 128.
kemac is offline
post #276 of 3482 Old 01-02-2009, 05:00 PM
Wouhou, thanks Kemac, I cannot beleive that after days of searching you finally got it to work !!! Millions thanks !!!
Now let's see if I can get my Yamaha to play 5.1 blu-ray ripped movies !!!
post #277 of 3482 Old 01-02-2009, 05:13 PM
kemac's Avatar
Quoted: 92 Post(s)
Liked: 74
Great! You got it to work!!
Just keep in mind that since you have a 3XXX series ATI card that you have to make sure you send your AVR the raw AC3 for 5.1.. If anything in your playback chain is converting AC3 or any other codecs to PCM you will only get 2 channel audio.
kemac is offline
post #278 of 3482 Old 01-02-2009, 05:34 PM
Kemac your the best, I actually had to set the audio stream in Power DVD to AC3/DTS Pass-through, is this right ??
Sound seems to be perfect and working in 5.1 mode !!
Thanks again !
post #279 of 3482 Old 01-02-2009, 05:37 PM
kemac's Avatar
Quoted: 92 Post(s)
Liked: 74
Awe shucks
You got it nailed, thats it!
Enjoy!
kemac is offline
post #280 of 3482 Old 01-03-2009, 03:46 PM
PCKid's Avatar
Finally got it working thanks to everyone here. LG 50" Plasma, Radeon EAH4550 with HDMI and RX-V863 Amp. All works fine 5.1. But am having troubles with a jerky wireless mouse. Everytime I reinstall the bluetooth drivers I lose the sound setting. Have to reinstall my EDID Override and then re install Realtek 2.09 drivers to get it back. Anyone else had this problem? Is there a work around. I thought of locating the files that it uses and making them read only but where to start.
PCKid is offline
post #281 of 3482 Old 01-03-2009, 04:06 PM
skidoo1's Avatar
even better, looks like the newest version 2.20 of moninfo will actually create the .inf for you, very useful.
under File-> Create inf
creates it from the real time (live) EDID read
thank you EnTech
skidoo1 is offline
post #282 of 3482 Old 01-04-2009, 12:20 PM
Ashley Saldanha's Avatar
Just to clarify, it will create an INF from the user selected EDID, which is always a live EDID by default but can be any EDID of record - even one loaded from a file.
And you can then merge the extension bloc from a second EDID - e.g., from a receiver - into an existing INF (File > Merge extension...).
The resulting INF will contain the model ID, serial number, range limits and native/preferred DTD of *your* display, rather than someone else's, and the audio information from your receiver rather than some other unit.
Ashley Saldanha is offline
post #283 of 3482 Old 01-04-2009, 09:56 PM
oakie45's Avatar
I have read through the majority of this thread and find it awesome that there are people out there who like to help.
I'm using:
vista 64
Powercolor 4830
yamaha v863
and an older samsung plasma that only has a dvi input. (using a dvi/hdmi cable from tv to 863)
I've installed the realtek driver, shut off onboard audio and when I used the .inf file from the zip on the first page there was audio but no video when windows loaded. I thought that it was just because the edid for the monitor in the zip was just not working. I downloaded moninfo and changed the raw data for the tv to what moninfo gave me for my tv. I then restarted and i have video but alas no audio once again. I've uploaded the inf file I created so hopefully somebody could take a look at it. I would really like to get this working, I have the Dark Knight on BR waiting for me if I do, I haven't seen it yet. Thanks in advance for any and all help.
EDIDOverride1.zip 0.970703125k . file
File Type: zip EDIDOverride1.zip (994 Bytes, 61 views)
oakie45 is offline
post #284 of 3482 Old 01-04-2009, 11:06 PM
archibael's Avatar
Couple things: you need an extra 0x01 at the start of the first block:
HKR,EDID_OVERRIDE,"0",0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4C,0x2D ...
to
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4C,0x2D ...
Next, your initial block gives no indication there is a second block. Instead of
... 0x50,0x44,0x50,0x0A,0x20,0x00,0x12
the last section of the first block should be
... 0x50,0x44,0x50,0x0A,0x20,0x01,0x12
I may have gotten the checksum wrong-- might have to do 0x11 instead of 0x12 as the last digit.
Hope that helps.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
post #285 of 3482 Old 01-05-2009, 11:04 AM
oakie45's Avatar
to
Hope that helps.
Unfortunately this did not work. I've uploaded the moninfo file for my tv and just intend to use the data from the randomfoes zip for my avr. There has to be a way for this to work I just cant seem to figure this out. Any help and or advice would be greatly appreciated.
samsung.zip 1.12109375k . file
oakie45 is offline
post #286 of 3482 Old 01-05-2009, 05:25 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1285 Post(s)
Liked: 1347
This is one of the best threads I've stumbled upon in quite a while. The information is very timely as I've been working through 2 problems getting my HTPC to play nicely with my surround sound processor and TV.
The first problem was getting the HDMI audio to work - I was getting the dreaded "your HDMI cable is unplugged" message despite the fact that it was indeed plugged in and the video was clearly working .
The 2nd problem was that 720P resolutions weren't working from Catalyst Control Center which was forcing me to use PowerStrip to get them working which meant I coulnd't use the simpler Catalyst Control Center Custom HDTV Format feature.
It took me all of 10 minutes to grab the EDID info from the TV and surround sound processor and then create my own customized version of the EDIDOverride.inf posted in the first post.
Here are my values:
Mitsubishi WD-65835 DLP:
Code:
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x34,0xAC,0xC3,0x31,0x01,0x01,0x01,0x01,0x0D,0x12,0x01,0x03,0x80,0xA2,0x5B,0x78,0x2A,0x24,0x71,0xAE,0x4C,0x47,0xAA,0x26,0x10,0x50,0x54,0x21,0x08,0x00,0xD1,0xC0,0x8B,0xC0,0x81,0x80,0x81,0xC0,0x66,0xC0,0x4B,0xC0,0x01,0x00,0x01,0x00,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x50,0x8D,0x63,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x50,0x8D,0x63,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x3B,0x3D,0x0F,0x44,0x11,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x4D,0x45,0x55,0x53,0x50,0x54,0x56,0x31,0x30,0x0A,0x20,0x20,0x20,0x01,0x75
Denon AVP-A1HDCI Surround Sound Processor:
Code:
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x45,0x71,0x5C,0x85,0x14,0x04,0x13,0x02,0x03,0x11,0x12,0x10,0x1F,0x20,0x06,0x07,0x15,0x16,0x01,0x0E,0x23,0x0F,0x24,0x1D,0x25,0x1E,0x26,0x0A,0x0B,0x19,0x1A,0x38,0x0F,0x7F,0x07,0x3D,0x1E,0xC0,0x15,0x07,0x50,0x5F,0x7E,0x01,0x57,0x06,0x00,0x65,0x7E,0x00,0x67,0x1E,0x00,0x4D,0x02,0x00,0x83,0x5F,0x00,0x00,0x66,0x03,0x0C,0x00,0x40,0x00,0x80,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xC4,0x8E,0x21,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0xB3
I now have HDMI audio and the 720P resolutions work with no need for PowerStrip. Since my video card is a 3870, my audio options are more limited than if I upgrade to a 4xxx series card. So the next step is to find a 4xxx series card that's a single slot wide, has a native HDMI port, and is powerful enough for HTPC use (no gaming).
I would attach the full inf file, but it's obviously somewhat specific to my combination of TV and surround sound processor - I assume the EDID override values for each device are more useful to people.
Thanks RandomFoe for figuring this out and starting the thread.
Here's the full EDID info for the Mitsubishi WD-65835:
Code:
Monitor
  Model name............... MEUSPTV10
  Manufacturer............. Mitsubishi
  Plug and Play ID......... MEL31C3
  Manufacture date......... 2008, ISO week 13
  Screen size.............. 1620 x 910 mm (73.2 in)
  Power management......... Active off/sleep
  DDC/CI................... Not supported
  Red chromaticity......... Rx 0.680 - Ry 0.299
  Green chromaticity....... Gx 0.278 - Gy 0.664
  Blue chromaticity........ Bx 0.149 - By 0.065
  White point (default).... Wx 0.313 - Wy 0.329
  Vertical scan range...... 59-61Hz
  Video bandwidth.......... 170MHz
  Detailed timing #1....... 1920x1080p at 30Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
     640 x  480p at  60Hz - IBM VGA
     800 x  600p at  60Hz - VESA
    1024 x  768p at  60Hz - VESA
    1920 x 1080p at  60Hz - VESA STD
    1360 x  765p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1280 x  720p at  60Hz - VESA STD
    1064 x  594p at  60Hz - VESA STD
     848 x  477p at  60Hz - VESA STD
  DTV underscan............ Supported
  Detailed timing #1....... 1920x1080p at 24Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2558 2602 2750 1080 1116 1121 1125 +hsync +vsync
  Detailed timing #2....... 1920x1080i at 60Hz (16:9)
  Detailed timing #3....... 1280x720p at 60Hz (16:9)
  Detailed timing #4....... 720x480p at 60Hz (16:9)
    1920 x 1080p at  30Hz - HDTV (16:9, 1:1)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
  Channel configuration.... 2.0
  Front left/right......... Yes
  Front LFE................ No
  Front center............. No
  Rear left/right.......... No
  Rear center.............. No
  Front left/right center.. No
  Rear left/right center... No
  Rear LFE................. No
  CEC physical address..... 0.2.0.0
  Maximum TMDS clock....... 225MHz
  Data payload............. 0000000000
Report information
  Date generated........... 1/5/2009
  Raw data................. 00,FF,FF,FF,FF,FF,FF,00,34,AC,C3,31,01,01,01,01,0D,12,01,03,80,A2,5B,78,2A,24,71,AE,4C,47,AA,26,
  ......................... 10,50,54,21,08,00,D1,C0,8B,C0,81,80,81,C0,66,C0,4B,C0,01,00,01,00,02,3A,80,18,71,38,2D,40,58,2C,
  ......................... 45,00,50,8D,63,00,00,1E,01,1D,80,18,71,38,2D,40,58,2C,45,00,50,8D,63,00,00,1E,00,00,00,FD,00,3B,
  ......................... 3D,0F,44,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4D,45,55,53,50,54,56,31,30,0A,20,20,20,01,75,
  ......................... 02,03,28,F1,47,90,22,20,05,04,03,01,23,09,07,07,83,01,00,00,6C,03,0C,00,20,00,B8,2D,00,00,00,00,
  ......................... 00,E3,05,03,01,E2,00,7F,01,1D,80,3E,73,38,2D,40,7E,2C,45,80,50,8D,63,00,00,1E,01,1D,80,18,71,1C,
  ......................... 16,20,58,2C,25,00,50,8D,63,00,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,50,8D,63,00,00,1E,8C,0A,
  ......................... D0,8A,20,E0,2D,10,10,3E,96,00,50,8D,63,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,CF
and for the Denon AVP-A1HDCI:
Code:
Monitor
  Model name............... DENON-AVAMP
  Manufacturer............. DON
  Plug and Play ID......... DON0009
  Manufacture date......... 2007, ISO week 0
  Screen size.............. 800 x 450 mm (36.1 in)
  Vertical scan range...... 49-61Hz
  Detailed timing #2....... 1280x720p at 50Hz (16:9)
    Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
  Detailed timing #3....... 720x480p at 60Hz (16:9)
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
     720 x  576p at  50Hz - EDTV (4:3, 16:15)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
     720 x  576i at  50Hz - Doublescan (4:3, 16:15)
     720 x  576i at  50Hz - Doublescan (16:9, 64:45)
    1440 x  480p at  60Hz - DVD (4:3, 4:9)
    2880 x  480p at  60Hz - Console (4:3, 2:9)
    1440 x  480p at  60Hz - DVD (16:9, 16:27)
    2880 x  480p at  60Hz - Console (16:9, 8:27)
    1440 x  576p at  50Hz - DVD (4:3, 8:15)
    2880 x  576p at  50Hz - Console (4:3, 4:15)
    1440 x  576p at  50Hz - DVD (16:9, 32:45)
    2880 x  576p at  50Hz - Console (16:9, 16:45)
    2880 x  480i at  60Hz - Console (4:3, 2:9-20:9)
    2880 x  480i at  60Hz - Console (16:9, 8:27-80:27)
    2880 x  576i at  50Hz - Console (4:3, 2:15-20:15)
    2880 x  576i at  50Hz - Console (16:9, 16:45-160:45)
  LPCM    8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
  DTS     6-channel, 1536k max. bit rate at 44/48/88/96 kHz
  AC-3    6-channel,  640k max. bit rate at 32/44/48 kHz
  DTS-HD  8-channel, 16-bit              at 44/48/88/96/176/192 kHz
  DD+     8-channel                      at 44/48 kHz
  DVD-A   6-channel                      at 44/48/88/96/176/192 kHz
  DVD-A   8-channel                      at 44/48/88/96 kHz
  SACD    6-channel                      at 44 kHz
  Channel configuration.... 7.1
  Front LFE................ Yes
  Front center............. Yes
  Rear left/right.......... Yes
  Rear center.............. Yes
  Rear left/right center... Yes
  CEC physical address..... 0.4.0.0
  Supports 36bpp........... No
  Supports 30bpp........... No
  Supports YCbCr 4:4:4..... No
  Maximum TMDS clock....... 165MHz
Report information
  Raw data................. 00,FF,FF,FF,FF,FF,FF,00,11,EE,09,00,01,01,01,01,00,11,01,03,80,50,2D,78,0A,0D,C9,A0,57,47,98,27,
  ......................... 12,48,4C,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
  ......................... 25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E,21,00,00,9E,00,00,00,FC,00,44,
  ......................... 45,4E,4F,4E,2D,41,56,41,4D,50,0A,20,00,00,00,FD,00,31,3D,0F,44,0F,00,0A,20,20,20,20,20,20,01,92,
  ......................... 02,03,45,71,5C,85,14,04,13,02,03,11,12,10,1F,20,06,07,15,16,01,0E,23,0F,24,1D,25,1E,26,0A,0B,19,
  ......................... 1A,38,0F,7F,07,3D,1E,C0,15,07,50,5F,7E,01,57,06,00,65,7E,00,67,1E,00,4D,02,00,83,5F,00,00,66,03,
  ......................... 0C,00,40,00,80,01,1D,00,72,51,D0,1E,20,6E,28,55,00,C4,8E,21,00,00,1E,01,1D,00,BC,52,D0,1E,20,B8,
  ......................... 28,55,40,C4,8E,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18,00,00,00,00,B3
gsr is offline
post #287 of 3482 Old 01-05-2009, 09:48 PM
javadave74's Avatar
Thank God for AVS Forum. This EDID thread save my sanity. Finally got this sucker to work....audio and video through my HDMI. Stick with it and it will work. I have a Yammy 663 and Panny th-50pz700u. my mod is attached
Dave
EDIDOverride-yammy-panny.txt 2.638671875k . file
javadave74 is offline
post #288 of 3482 Old 01-06-2009, 11:55 AM
KillMeManJaro's Avatar
My sanity is still at risk here, Im sorry to say.
I have:
An Ati HD4670 hdmi out to---4x2 hdmi switch, one hdmi to my Benq PE8720 projector, and one hdmi to my Yamaha RX-V663.
Direct connection: No hdmi-sound. Then via switch, only 2 channels.
I have 7.1 system, tested working.
Then I install: Catal. 8.12, still nothing, then Realtek 2.13, still nothing, then the EDID-override from this site, dont know if that is correct for my 663 and Benq, but THEN reinstalled Realtek 2.13 and could finally choose between 2, 5.1, and 7.1 system.
Still, the Yamaha shows PCM 2CH. By testing, yes only 2.
I change output from 16bit/48Hz to 24bit/192Hz, as both my card, my switch, and my Yamaha supports this. Sound disappears, and PCM is blinking on the Yamaha. I change it back, and no sound at all, untill restart, and 2 ch ok.
What now? I am LOST.
KillMeManJaro is offline
post #289 of 3482 Old 01-06-2009, 01:22 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2524
Are you running Vista?
Stereodude is offline
post #290 of 3482 Old 01-06-2009, 04:33 PM
DetectiveConan's Avatar
Sony TV KDL-40W4000
Yamaha RX-V663
Gigabyte MA78GM-S2H (780g)
Onboard ATi 3200
vista 32bit
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x65,0xA8,0x27 ,0x31,0x00,0x00,0x00,0x00,0x00,0x12,0x01,0x03,0x80,0x00,0x00 ,0x78,0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,0x12,0x48,0x4C ,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x80,0x18,0x71 ,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xC4,0x8E,0x21,0x00,0x00 ,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25 ,0x80,0xC4,0x8E,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0xFC,0x00 ,0x52,0x58,0x2D,0x56,0x36,0x36,0x33,0x0A,0x20,0x20,0x20,0x20 ,0x20,0x00,0x00,0x00,0xFD,0x00,0x17,0x79,0x0F,0x5B,0x0F,0x00 ,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x66
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x3A,0x74,0x4F,0x10,0x04,0x05,0x03,0x02,0x07 ,0x06,0x20,0x01,0x0E,0x0F,0x0A,0x0B,0x23,0x24,0x38,0x09,0x7F ,0x07,0x0F,0x7F,0x07,0x15,0x07,0x50,0x3E,0x1F,0xC0,0x4D,0x02 ,0x00,0x57,0x06,0x00,0x67,0x54,0x00,0x5F,0x54,0x01,0x83,0x5F ,0x00,0x00,0x68,0x03,0x0C,0x00,0x41,0x00,0x80,0x21,0x00,0x8C ,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0x40 ,0x84,0x63,0x00,0x00,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D ,0x10,0x10,0x3E,0x96,0x00,0xB0,0x84,0x43,0x00,0x00,0x18,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E
ATI HDMI Audio output is stereo. Signal audio info is 2ch pcm. No output is multi ch.
(Ati ccc, dd is ver. 8.12 . Realtek HD Audio driver version is R2.13)
DetectiveConan is offline
post #291 of 3482 Old 01-07-2009, 12:51 AM
I am running Vista and I solved it!!!!
I followed the instructions given here, used the edid override as a driver for the display.
Then finally my brain started working. I changed the connection and put the hdmi-switch AFTER my receiver. So it is HTPC- hdmi to Yamaha 663, hdmi out to switch, hdmi from switch to Benq 8720. I now have 7.1 PCM at 24/192. Eureka!
You, the override guy, are a Saint!
post #292 of 3482 Old 01-07-2009, 12:10 PM
the-pred's Avatar
My set up is DISPLAY-Pioneer Pro 141FD RECEIVER-Yamaha RX V3800 HTPC Graphics- Asus P5E VM HDMI. I have HDMI out to the receiver, and then HDMI to the Display. My problem is everything works great until change input on the receiver. When I go back to the HTPC I get a black screen. I am taking it that the motherboard is dropping the EDID of the display. I have upgraded all the drivers, and still no luck. Anyone have a work around for this?
the-pred is offline
post #293 of 3482 Old 01-07-2009, 01:48 PM
pappers's Avatar
Has anyone been able to get a TV with a DVI-D input (HDCP enabled) to work using the override? I pasted below the moninfo from my Westy LTV-32w1 and it only shows computer resolutions (eg 1024x768) and not any HDTV resolutions (eg 1280x720) EVEN THOUGH it is HDTV compatible (480i, 480p, 720p, 1080i). This is in combination with a 4350 and SR605.
Monitor #1 [Real-time 0x0011]
Model name............... LTV-32w1
Manufacturer............. Westinghouse
Plug and Play ID......... WDE3201
Data string.............. Westinghouse
Manufacture date......... 2005, ISO week 43
Screen size.............. 710 x 400 mm (32.1 in)
Extension blocs.......... None
Red chromaticity......... Rx 0.648 - Ry 0.332
Green chromaticity....... Gx 0.272 - Gy 0.606
Blue chromaticity........ Bx 0.142 - By 0.074
White point (default).... Wx 0.285 - Wy 0.293
Horizontal scan range.... 30-80kHz
Vertical scan range...... 50-75Hz
Video bandwidth.......... 140MHz
Native/preferred timing.. 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 84.750 1360 1432 1568 1776 768 771 776
798 -hsync +vsync
720 x 400p at 70Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
Report information
Date generated........... 1/7/2009
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,5C,85,01,32,01,01,01,01,2B,0F,01,03, 80,47,28,78,2A,0D,40,A6,55,45,9B,24,
......................... 13,49,4B,BF,EF,80,71,4F,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,1B,21,50,A0,51,00,1E,30,48,88,
......................... 35,00,C6,90,21,00,00,1C,00,00,00,FE,00,57,65,73,74,69,6E,67, 68,6F,75,73,65,0A,00,00,00,FD,00,32,
......................... 4B,1E,50,0E,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,54,56, 2D,33,32,77,31,0A,20,20,20,20,00,4A
pappers is offline
post #294 of 3482 Old 01-07-2009, 04:51 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1347
Try disabling the "Ati External Event Utility" in Services (Control Panel -> System and Maintenance -> Administrative Tools -> Services, double click on Ati External Event Utility and change the Startup type option to Disabled, then reboot). It turns out that I needed to do this on my system after I applied the EDID override in order to survive changing inputs and/or power cycling my surround sound processor.
gsr is offline
post #295 of 3482 Old 01-08-2009, 06:57 AM
the-pred's Avatar
It is not an ATI chipset, it is an Intel
the-pred is offline
post #296 of 3482 Old 01-08-2009, 07:18 AM
Wo0zy's Avatar
Don't know if this has been suggested (been away) but disabling "igfxpers.exe" should sort it out.
Check out the Intel threads for details or PM me. Bit OT to discuss here.
Wo0zy
Wo0zy is offline
post #297 of 3482 Old 01-08-2009, 08:20 PM
pappers's Avatar
I take it no one has used a DVI-D input? Anyone??
In that case, can someone PLEASE post their moninfo for a 32" HDMI LCD? Preferably, a 720p and not a 1080p (I don't think there are too many, if any, 32" with 1080p). I'm hoping I can substitute my LCD info with yours in combination with my Onkyo 605 so that I can "fool" Vista.
pappers is offline
post #298 of 3482 Old 01-08-2009, 11:52 PM
Mikl1984's Avatar
Quoted: 18 Post(s)
My moninfo reports collection you may find here
http://forum.ixbt.com/topic.cgi?id=62:14612#1
Mikl1984 is offline
post #299 of 3482 Old 01-09-2009, 08:43 AM
pappers's Avatar
Thank you SO much! I can't wait to try out the Vizio L32 with my 605 EDID tonight.
pappers is offline
post #300 of 3482 Old 01-09-2009, 09:17 AM
ajamils's Avatar
To do the EDID override, I need to connect both receiver and TV to the computer separately or I can just read the receivers EDID and update the "Generic PnP Monitor" with its inf ?
[color=Blue]
psn id: hunter4life
Live Gamertag: huntre4life (notice "re" not "er" in hunter)
ajamils is offline
Reply Home Theater Computers
