EDID Override Thread - Page 107 - AVS Forum
 2Likes
post #3181 of 3199 Old 07-22-2014, 07:36 PM
votum's Avatar
Here is my moninfo readout
Code:
Monitor
  Windows description...... Generic PnP Monitor
  Manufacturer............. SDC
  Plug and Play ID......... SDC4852
  Data string.............. LTN156FL02L01
  Serial number............ n/a
  Manufacture date......... 2013, ISO week 0
  Filter driver............ None
  EDID revision............ 1.3
  Input signal type........ Digital (DisplayPort)
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. 340 x 190 mm (15.3 in)
  Power management......... Standby, Suspend, Active off/sleep
  Extension blocs.......... None
  DDC/CI................... n/a
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2.20
  Red chromaticity......... Rx 0.620 - Ry 0.355
  Green chromaticity....... Gx 0.300 - Gy 0.580
  Blue chromaticity........ Bx 0.150 - By 0.090
  White point (default).... Wx 0.313 - Wy 0.329
  Additional descriptors... None
Timing characteristics
  Range limits............. Not available
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 3840x2160p at 48Hz
    Modeline............... "3840x2160" 415.850 3840 3888 3920 3956 2160 2162 2168 2190 -hsync -vsync
Standard timings supported
Report information
  Date generated........... 7/22/2014
  Software revision........ 2.60.0.972
  Data source.............. Registry-Active - NB: improperly installed
  Operating system......... 6.2.9200.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,83,52,48,00,00,00,00,00,17,01,03,95,22,13,78,EA,CE,85,9E,5B,4C,94,26,
  17,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,71,A2,00,74,F0,70,1E,80,30,20,
  26,00,58,C2,10,00,00,18,00,00,00,0F,00,00,00,00,00,00,00,00,00,37,82,05,46,00,00,00,00,FE,00,53,
  41,4D,53,55,4E,47,0A,20,4C,83,46,4C,00,00,00,FE,00,4C,54,4E,31,35,36,46,4C,30,32,4C,30,31,00,19
votum is offline
post #3182 of 3199 Old 08-12-2014, 07:20 PM
kache's Avatar
Hello.
Is there any way to read whether the GPU is outputting 4:4:4 or 4:2:0 to the screen? There have been a few changes in the latest Nvidia drivers that point out to the Maxwell 750ti card being (possibly) able to output HDMI2.0, but we're not sure how to test that precisely, since there doesn't appear to be a technical info screen on the AX800 to show the input, and we can't find a way to read exactly what is the GPU outputting.
I tried using MonInfo, but it only says Non-sRGB.
Ipsa scientia potestas est
kache is offline
post #3183 of 3199 Old 08-12-2014, 09:02 PM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
That depends on whether a monitor or a TV is detected by the graphic driver. There are ways to fool the driver into detecting a monitor even over a HDMI connection by editing the EDID (removing the extension block used to work with Nvidia, and years ago a EDID specific hack worked with AMD). Even using a DVI-HDMI cable has worked some times (surely with AMD).
IIRC the AMD driver explicitly shows in Catalyst when a DVI connection has been detected. Not sure about Nvidia or Intel.
Anyway, AFAIK the detection is in the graphic driver, not the EDID itself.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #3184 of 3199 Old 09-27-2014, 10:42 AM
Liked: 0
I have read all thread and grats to all . I need some help please. The edid overide works for me when i have one monitor only working BUT
I have 3 monitors all (LG FHD 1080P) in multiple display setup
No 1 and no3 monitors are direct at pc no1 and no3 HDMI outputs
The no2 pc HDMI output goes to a splitter 1in x4 out
From splitter 3 outputs im going to the:
a. no2 Lg monitor to
b.a SONY TV (2 audio) and to
c.Yamaha AVR (9.1 audio) input
From Yamaha output im going to a SONY TV and to a SONY vpl 40 es projector
When i boot all then i have 7.1 sound and all formats available till i change input source or switch off the Yamaha avr then im loosing the ability to 7.1 if i switch on again the Yamaha or change input and the result is 2 channels audio till i restart pc
I used the edid overide and all monitors have the same setup of SONY TV and Yamaha AVR
Monfo though see an LG monitor in real time all time when all my monitors in device manager are EDID overide as driver described
Somehow my pc must see all time all devices as "on" and emulated of 7.1
How can i solve this and have the pc see all time the setup as 7.1?
tyvm
sirdiman is offline
post #3185 of 3199 Old 09-27-2014, 10:58 AM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
When multichannel is not detected after switching, try reapplying the EDID Override on the current monitor driver (should be a GenericPnp driver). Reboot and test again.
Tulli is offline
post #3186 of 3199 Old 09-27-2014, 12:58 PM
Liked: 0
Thank you very much for your fast response.
I think my problem is to keep the edid live all time - i mean even if i switch input in receiver or close him the output display that the pc sees must be always on.
I think dr hdmi may solve this but i thought that maybe there is a software around to use .
Something like a trick to the output to seems active all time no matter what i do in the inputs etc.
If you have any ideas im open
tyvm
sirdiman is offline
post #3187 of 3199 Old 09-28-2014, 06:07 AM
Liked: 0
Hey,
I have a Samsung 3D LED TV 40" F6100 being used as a monitor,I play in 3D via Nvidia 3DTV play and I'd like to "get rid of" the 1080p@24hz,720p@60hz limit of HDMI using an EDID override.I have a GTX 770, I mention this to clearify that I'm not that guy who tries to play an Nvidia software with an Ati card
I know I can't do nothing about those limits, so I'd like to downsample to 720p (The games render at 1080p, but the resolution would be 720p). As you can only downsample to your native resolution which is 1080p currently, I'd like to set the native resolution to 720p via a 720p monitor EDID override, or any other way if there's any.So the main question is how can I do this? Can I just simply edit my EDID somehow to think 720p is my native res.? Thanks guys.
spongebobble is offline
post #3188 of 3199 Old 09-28-2014, 07:54 AM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
The 720p video descriptor should be in the EDID. It would be just a matter of using it to replace the main 1080p descriptor (or just swap them), and try.
Tulli is offline
post #3189 of 3199 Old 09-28-2014, 08:14 AM
Liked: 0
Thanks for the quick reply. Can you explain that? I'm not really into EDID stuff. I suppose I should use a program like Phoenix, but I really don't know how do I do what you said. You don't have to write a step by step for noobs, but I could use some details.
post #3190 of 3199 Old 09-28-2014, 08:22 AM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
Capture the real-time EDID of your TV (and AVR, if you're using one in the chain ... see instructions in my sig.) and I'll mod it.
Tulli is offline
post #3191 of 3199 Old 09-28-2014, 08:29 AM
Liked: 0
Thank you, I really appreciate it. I was trying to mess around with Moninfo but It didn't work out for me. I attached the .inf file.
post #3192 of 3199 Old 09-28-2014, 08:43 AM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
I set the 1080p descriptor as secondary and replaced the main one with a 720p descriptor from the extended block.
Tulli is offline
post #3193 of 3199 Old 09-28-2014, 09:10 AM
Liked: 0
Thanks, now it does recognize 720p as native resolution, but do you think it's possible to make it the highest resolution? I mean windows/nvidia would detect 720p as the maximum resolution, then I add 1080p later as a custom resolution, because I guess it's the only way to get downsampling working, correct me if you know anything about it.
post #3194 of 3199 Old 09-28-2014, 10:31 AM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
I removed the 1080p resolution from the basic block.
Tulli is offline
post #3195 of 3199 Old 09-28-2014, 06:35 PM
Liked: 0
The number of channels just means the max bandwidth for uncompressed audio for s/pdif. But this shouldn't be a problem as long as a multichannel compressed audio is streamed over the HDMI link Are you sure TMT6 audio is correctly set up? Just set it to not decode the audio stream and it should work (there should be an option for that in the "Mixing Mode" pull-down menu).
Hi Tulli,
I don't know if I have an issue or not based on your statement above. The HDMI on my HTPC is running on Nvidia Geforce 425M, and is only showing 2 channels possible in HDMI audio. The setup is:
HTPC --> (HDMI) --> Samsung UE55D8005 --> (S/PDIF) --> AVR
I am in the process of changes my AVR setup, and wants to be prepared when it arrives.
My new AVR will be the Sonos Playbar, which only has one S/PDIF input connector. Therefore I want every device to connect to the TV and then from the TV to the Sonos Playbar.
Do you suspect this will work if my HTPC is just sending compressed DD5.1 to the TV or will I need a EDID override driver for the Samsung TV?
Rav3nDK is offline
post #3196 of 3199 Old 09-28-2014, 08:52 PM
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
You'll need a EDID override just to enable AC3.
Tulli is offline
post #3197 of 3199 Old 10-03-2014, 09:06 AM
Spawn182's Avatar
Just finished my new Windows 8.1 Haswell HTPC build (ASUS Z97I-Plus / i7-4790K) replacing my old (N54L / AMD HD 6450) build. When I have turned on my amp and TV, I don't get DTS-MA HD audio formats. Never had this problems with the old build.
Tried building an EDID override and test-signed it, to get it working in Windows 8.1. Still no DTS-MA when my TV is turned on. Bios, drivers, amp firmware everything is up to date. Strange thing, the TV EDID seems to have all the formats. (Using PowerDVD 14 I only can chose non-decoded HD audio when my TV is off, windows audio device shows just the standard digital formats when the TV is on)
Maybe I missed something else?
Thanks for your help.
Signal chain
PC -> HDMI -> Yamaha RX-V3067 (fw3.43) -> HDMI -> LG 60PX950N (sw03.02.13)
MonInfo [RT] Yamaha RX-V3067
Code:
Monitor
  Model name............... RX-V3067
  Manufacturer............. Yamaha
  Plug and Play ID......... YMH3153
  Manufacture date......... 2010, ISO week 0
  Screen size.............. Undefined or variable
  Power management......... Not supported
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
  Display gamma............ 2,20
  Red chromaticity......... Rx 0,625 - Ry 0,340
  Green chromaticity....... Gx 0,280 - Gy 0,595
  Blue chromaticity........ Bx 0,155 - By 0,070
  White point (default).... Wx 0,283 - Wy 0,298
  Horizontal scan range.... 15-91kHz
  Vertical scan range...... 23-121Hz
  Video bandwidth.......... 150MHz
  CVT standard............. Not supported
  Native/preferred timing.. 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
  Detailed timing #1....... 1920x1080i at 50Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
EIA/CEA-861 Information
  Revision number.......... 3
  IT underscan............. Not supported
  Basic audio.............. Supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 4
  Detailed timing #1....... 720x480p at 60Hz (4:3)
    Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
  Detailed timing #2....... 720x576p at 50Hz (4:3)
    Modeline............... "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1) [Native]
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (4:3, 8:9)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  480i at  60Hz - Doublescan (4:3, 8:9)
     720 x  480i at  60Hz - Doublescan (16:9, 32:27)
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1)
    1440 x  480p at  60Hz - DVD (4:3, 4:9)
    1440 x  480p at  60Hz - DVD (16:9, 16:27)
    2880 x  480i at  60Hz - Console (4:3, 2:9-20:9)
    2880 x  480i at  60Hz - Console (16:9, 8:27-80:27)
    2880 x  480p at  60Hz - Console (4:3, 2:9)
    2880 x  480p at  60Hz - Console (16:9, 8:27)
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
     720 x  576p at  50Hz - EDTV (4:3, 16:15)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
     720 x  576i at  50Hz - Doublescan (4:3, 16:15)
     720 x  576i at  50Hz - Doublescan (16:9, 64:45)
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
    1440 x  576p at  50Hz - DVD (4:3, 8:15)
    1440 x  576p at  50Hz - DVD (16:9, 32:45)
    2880 x  576i at  50Hz - Console (4:3, 2:15-20:15)
    2880 x  576i at  50Hz - Console (16:9, 16:45-160:45)
    2880 x  576p at  50Hz - Console (4:3, 4:15)
    2880 x  576p at  50Hz - Console (16:9, 16:45)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
  LPCM    8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
  AC-3    6-channel,  640k max. bit rate at 32/44/48 kHz
  DTS     7-channel, 1536k max. bit rate at 32/44/48/88/96 kHz
  SACD    6-channel                      at 44 kHz
  DD+     8-channel                      at 44/48 kHz
  DVD-A   8-channel                      at 48/96/192 kHz
  DTS-HD  8-channel, 16-bit              at 48/96/192 kHz
CE speaker allocation data
  Channel configuration.... 7.1
  Front left/right......... Yes
  Front LFE................ Yes
  Front center............. Yes
  Rear left/right.......... Yes
  Rear center.............. Yes
  Front left/right center.. No
  Rear left/right center... Yes
  Rear LFE................. No
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 1.1.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... No
  Supports 30bpp........... No
  Supports YCbCr 4:4:4..... No
  Supports dual-link DVI... No
  Maximum TMDS clock....... 165MHz
  Audio/video latency (p).. n/a
  Audio/video latency (i).. n/a
  HDMI video capabilities.. No
  Data payload............. 030C001100802100
Report information
  Date generated........... 03.10.2014
  Software revision........ 2.90.0.1000
  Data source.............. Real-time 0x0061
Raw data
  00,FF,FF,FF,FF,FF,FF,00,65,A8,53,31,00,00,00,00,00,14,01,03,80,00,00,78,0A,0D,C9,A0,57,47,98,27,
  12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
  25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E,21,00,00,9E,00,00,00,FC,00,52,
  58,2D,56,33,30,36,37,0A,20,20,20,20,00,00,00,FD,00,17,79,0F,5B,0F,00,0A,20,20,20,20,20,20,01,27,
  02,03,45,74,5A,85,04,02,03,06,07,10,0E,0F,0A,0B,23,24,14,13,11,12,15,16,1F,1D,1E,19,1A,25,26,38,
  09,7F,07,0F,7F,07,15,07,50,3E,1F,C0,4D,02,00,57,06,00,67,54,00,5F,54,01,83,5F,00,00,68,03,0C,00,
  11,00,80,21,00,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,13,8E,21,00,00,18,8C,0A,D0,90,20,40,31,20,0C,
  40,55,00,13,8E,21,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,5F
MonInfo [RT] LG 60PX950N (via Amp)
Code:
Monitor
  Model name............... LG TV
  Manufacturer............. LGE
  Plug and Play ID......... GSM0001
  Manufacture date......... 2010, ISO week 1
  Screen size.............. 1600 x 900 mm (72,3 in)
  Red chromaticity......... Rx 0,640 - Ry 0,330
  Green chromaticity....... Gx 0,300 - Gy 0,600
  Blue chromaticity........ Bx 0,150 - By 0,060
  White point (default).... Wx 0,313 - Wy 0,329
  Horizontal scan range.... 30-83kHz
  Vertical scan range...... 58-62Hz
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 138,500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
  Detailed timing #1....... 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
     720 x  400p at  70Hz - IBM VGA
     640 x  480p at  60Hz - IBM VGA
     800 x  600p at  60Hz - VESA
    1024 x  768p at  60Hz - VESA
     640 x  480p at  60Hz - VESA STD
     800 x  600p at  60Hz - VESA STD
    1024 x  768p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1920 x 1080p at  60Hz - VESA STD
  IT underscan............. Supported
  Detailed timing #1....... 1920x1080i at 60Hz (16:9)
  Detailed timing #2....... 1280x720p at 60Hz (16:9)
    Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
    1920 x 1080p at  30Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  24Hz - HDTV (16:9, 1:1)
  Supports 36bpp........... Yes
  Supports 30bpp........... Yes
  Supports YCbCr 4:4:4..... Yes
  Maximum TMDS clock....... 225MHz
  HDMI video capabilities.. Yes
  EDID screen size......... No additional info
  3D structures supported.. Top-and-bottom
  3D formats supported..... Mandatory formats plus some primary VICs
  Data payload............. 030C001100B82D20C01200403F304810581088109810A810B810D810
CE colorimetry data
  xvYCC709 support......... Yes
  xvYCC601 support......... Yes
  sYCC601 support.......... No
  AdobeYCC601 support...... No
  AdobeRGB support......... No
  Metadata profile flags... 0x01
Report information
Raw data
  00,FF,FF,FF,FF,FF,FF,00,1E,6D,01,00,01,01,01,01,01,14,01,03,80,A0,5A,78,0A,EE,91,A3,54,4C,99,26,
  0F,50,54,A1,08,00,31,40,45,40,61,40,81,80,D1,C0,01,01,01,01,01,01,1A,36,80,A0,70,38,1F,40,30,20,
  35,00,40,84,63,00,00,1A,02,3A,80,18,71,38,2D,40,58,2C,45,00,40,84,63,00,00,1E,00,00,00,FD,00,3A,
  3E,1E,53,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,47,20,54,56,0A,20,20,20,20,20,20,20,01,1D,
  02,03,5B,F4,58,02,03,11,12,13,04,15,16,05,14,10,1F,22,20,0E,23,0F,24,19,1A,1D,25,1E,26,38,09,7F,
  07,0F,7F,07,15,07,50,3E,1F,C0,4D,02,00,57,06,00,67,54,00,5F,54,01,7C,03,0C,00,11,00,B8,2D,20,C0,
  12,00,40,3F,30,48,10,58,10,88,10,98,10,A8,10,B8,10,D8,10,E3,05,03,01,83,5F,00,00,01,1D,80,18,71,
  1C,16,20,58,2C,25,00,40,84,63,00,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,40,84,63,00,00,1E,E5
MonInfo [RT] LG 60PX950N (directly connected to PC)
Code:
Monitor
  Video bandwidth.......... 160MHz
  Detailed timing #1....... 1360x768p at 60Hz (16:9)
    Modeline............... "1360x768" 85,500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
  Native formats........... 1
  Detailed timing #2....... 1920x1080i at 60Hz (16:9)
  Detailed timing #3....... 1280x720p at 60Hz (16:9)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48/96/192 kHz
  CEC physical address..... 1.0.0.0
  3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
  Data payload............. 030C001000B82D20C00E01403F30D8109810881048105810
CE colorimetry data
Report information
Raw data
  35,00,40,84,63,00,00,1A,66,21,50,B0,51,00,1B,30,40,70,36,00,40,84,63,00,00,1E,00,00,00,FD,00,3A,
  3E,1E,53,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,47,20,54,56,0A,20,20,20,20,20,20,20,01,C6,
  02,03,37,F1,4E,02,03,11,12,13,04,15,16,05,14,10,1F,22,20,26,15,07,50,09,57,07,78,03,0C,00,10,00,
  B8,2D,20,C0,0E,01,40,3F,30,D8,10,98,10,88,10,48,10,58,10,E3,05,03,01,02,3A,80,18,71,38,2D,40,58,
  2C,45,00,40,84,63,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,84,63,00,00,9E,01,1D,00,72,51,
  D0,1E,20,6E,28,55,00,40,84,63,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,AC
Spawn182 is offline
post #3198 of 3199 Old 10-10-2014, 07:59 AM
Liked: 0
Looks like this thread isn't as active anymore...
Sirs2k is offline
post #3199 of 3199 Old 11-12-2014, 06:16 AM
Thrakier's Avatar
Hello there,
could anyone help me with the following problem?
I got this problem with my Monitor => DVI => PC => HDMI => AVR => TV setup. With my Onkyo 604 and my Pio 529 it's like that:
- I'm working on my PC monitor. Turning on the Onkyo/Pio, my picture goes to TV instead ONLY if I set the coressponding output on the AVR. For example, it's possible to watch chromecast via AVR on my TV while working on my PC monitor.
With the Sony it's like that:
- it grabs away my PC signal as soon as the HDMI cable is connected, even when the PC output AVR => TV is NOT selected
- my DVI monitor blanks
- I have to manually go into windows settings to set my Nr. 1 monitor every time if I want to have the picture back on my DVI monitor
- with this setup, it's NOT possible to watch chromecast via AVR and work on my monitor at the same time - I need to plug the HDMI cable from the Sony AVR so that I get the picture back on my TV
Any ideas?
Thrakier is offline
Reply Home Theater Computers
