EDID Override Thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #3481 of 3494 Old 08-18-2016, 05:49 PM
yj5
Liked: 0
Hi Tulli,
is it possible to ask kindly for an Edid override?
This is my setup:
Grundig 32 VLC 6110 C
Sony STR-DB780
AMD Radeon HD 7700 Series
Thanks in advance!
yj5 is offline
post #3482 of 3494 Old 09-19-2016, 05:13 PM
Liked: 0
Hello Guys,
I'm trying to get this configuration working:
GTX 970 --HDMI--> Philips 55PUK7100 --HDMI-ARC--> Onkyo TX SR-308
I took the line for the AVR from a file in this thread and it worked fine BUT I can't choose resolutions above 1080p anymore. I think the issue is that MonInfo can't handle higher resolutions it shows that 1080p would be the max. resolution for my TV, which is false, it's 2160p. Does anybody have a hint for me to get this working with higher resolutions? Is there maybe an alternative approach, via registry or so? Another program to export the INF?
Thank You in advance
Gerrit507 is offline
post #3483 of 3494 Old 10-19-2016, 12:30 AM
Liked: 0
Hello, does anyone have EDID's for any of these TVs:
Sony KDL-60R520A
Sony KDL-55W900A
Sony XBR-65HX950 (2012)
Toshiba 32C120U (2012)
Toshiba 65LS9300
Vizio E500i-A1
Thank yoU!
Pete 2 is offline
post #3484 of 3494 Old 10-28-2016, 02:50 AM
SweetLow's Avatar
How to override monitor EDID on intel gfx using registry
http://www.codeground.net/howto/over...sing-registry/
Translation of Theory About Intel's HDMI Quantization Range Setting (Full 0-255) finally available
SweetLow is offline
post #3485 of 3494 Old 10-30-2016, 07:02 AM
Quoted: 17 Post(s)
Liked: 3
nvidia downsampling @ 1080p @ 120hz somehow possible?
if i turn on downsampling, its starting from UHD x 1,2, x 1,5, x 2 etc.
but i want to use downsampling for 1080p on this TV, to stay @ 120hz and low input-lag.
is this possible by tweaking the EDID settings?
TV: sony x8505c via HDMI to GPU.
Lors is offline
post #3486 of 3494 Old 11-22-2016, 08:35 AM
ludespeedny's Avatar
Quoted: 28 Post(s)
Can anyone help me with an inf file for the edid override? I just need the inf file to contain the audio info for my receiver, ex 5.1 formats etc...
ludespeedny is offline
post #3487 of 3494 Old 11-25-2016, 11:03 AM
Liked: 0
Hello, Only stereo is available in my setting, is it EDID related?
This is my setup: Gtx 780 to Onkyo TX-RZ710 receiver to Tv Sony kd55x8505c.
Please help.
Sorry, for my bad english.
ID:	1789057   Click image for larger version
Andréa Yin is offline
post #3488 of 3494 Old 01-30-2017, 04:27 PM
Yawny's Avatar
Hello! Is this thread still open? Tulli still around? Thought I'd post here first rather than both threads... A little late to the party and wanted to request an override for my setup. nVidia GTX650 HDMI out to Sony Bravia TV. Optical out to Yamaha sound bar that supports DTS 5.1. TV reports only 2ch Stereo and DD/5.1 AC3. Would like TV to support DTS 5.1 as well. If so please reply. Can post Moninfo if so. Thanks!
Yawny is offline
post #3489 of 3494 Old 02-17-2017, 07:46 AM
Liked: 0
How about headless setups (VNC)?
Hello. Thank you all for your research on this topic!
I'm looking to emulate an EDID on a PC for which there is no monitor attached. I know this is an HTPC forum, but I have a situation at work where we VNC (remote desktop control) into PCs that have no monitor attached. Unfortunately, this defaults the resolution to 1366x768. I'm accessing the PC on a 1920x1080 monitor, so I'd like to make use of all that screen real estate.
I have exported the EDID from a compatible monitor, and I have the hex code to manipulate in whatever way necessary.
Is there a way to emulate or force the EDID information that I have into Windows7's "no monitor" profile? I only need the resolution, for what it's worth.
I don't have a "Generic PnP Monitor" in device manager, probably because there's no monitor attached. I can attach a monitor if need be... but I can't keep it there permanently.
In short.. How can I get this to make the EDID information STICK after the monitor is removed?
Any help would be GREATLY appreciated!
DrPhant0m is offline
post #3490 of 3494 Old 03-17-2017, 05:46 AM
Liked: 0
Hi. I just tried the Acer4k EDID override on a LG C6OLED with passive 3d. Unfortunately, it doesn't seem to be stable. The screen starts to flicker black more and more until it crashes Windows 10.
Is there a trick to this I'm missing? Do I need to install the Nvidia 3D Vision controller driver?
Right now I'm trying to get Quantum Break to run in 3D. Tridef has it running at 4K/60Hz but has several broken shaders. Nvidia 3D has a mod that fixes these and runs great--but only up to 1080p/24Hz. I was hoping that gaming would be the place where we wouldn't have to choose between 3D and 4K.
I'd really appreciate some help if you can.
edwardsean is offline
post #3491 of 3494 Old 03-17-2017, 05:58 AM
Liked: 0
Forgot to mention: I'm going out of the HDMI port of a EVGA GTX1060 6Gb.
post #3492 of 3494 Old 03-26-2017, 01:14 PM
Liked: 0
Hi,
I have a LG 50UH5530 4k tv. the manual states that it has up to 7.1 passthrough over HDMI (ARC). When I hook my pc >HDMI>TV>receiver the audio option only shows 2 channel stereo with DD and DTS compatability. I know this tv is capable of acception 7.1 sources and passing though Dolby true hd and dts HD. and 7 channel PCM. How do I override my EDID to show this.
Thank you for the help.
mlprice is offline
post #3493 of 3494 Old 04-08-2017, 06:51 AM
Jeroen1000's Avatar
Quoted: 37 Post(s)
Just a general anouncement:
EDID-override is now working with Intel HD Graphics GPU's 4th generation and up. I have tested this with a Dell and Toshiba laptop with an 4600 IGP. IRIS pro should also work. You just need a 4th generation CPU (or later).
for more information, send me a PM and I'll walk you through.
papanik likes this.
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer
Jeroen1000 is offline
post #3494 of 3494 Old 07-24-2017, 07:12 AM
calvin940's Avatar
Originally Posted by Tulli View Post
Check this and the other EDID override thread (see my sig.). It's been already thoroughly discussed. Windows test tones use uncompressed audio (LPCM), which can be at best 2 channels with the bandwidth available over the HDMI link through the TV. OTOH multichannel is possible only with compressed audio (DD or DTS). Bottom-line: stream DD or DTS audio from the application and it will work. For games audio must be live-encoded to AC3 to DTS (there's a hack for Realttek drivers - search for link in the threads).
Hi there,
I know this post was from some time ago, but I am looking to solve my gaming sound problem and as much as I have searched around here for it, I seem to be going in circles. If you wouldn't mind pointing me in the right direction, I would appreciate it.
HTPC (NVidia 780TI) --HDMI--> Vizio P65-C1 --Optical--> Vizio SB-4551
(I have other devices connected to the TV as well - PS4, Xbox 360, Bell receiver) so that's why I am not connecting HTPC optical directly to the Soundbar.
Here is my issue. From Plex, my sound is what it should be - DD5.1, AC3, whatever, but from my games, all are CDDA 2.0. Now after reading the threads and trying EDID route, I finally understood why. Question is:
How do I do that Live-encoding you mentioned above? Do I need other sound hardware? If so, how do I get that sound output going through the NVIDIA HDMI connector going to the TV? Or is this is software live encoding option.
Appreciate any help.
Calvin
calvin940 is offline
Reply Home Theater Computers
