EDID Override Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 02-20-2009, 08:29 PM
jaemius's Avatar
Thanks for all of the great information in this thread. I got it up and running on my first try. This is definitely a great resource for everyone!
Setup
Windows Vista Ultimate
PowerColor HD4830
Arcsoft TMT (.126 for BluRay Playback)
MyMovies
Display: Panasonic PT-AE3000U Projector
Receiver: Sony STR-DG820
EDIDOverride.zip 3.1923828125k . file
jaemius is offline
Old 02-28-2009, 07:03 AM
AVR1909's Avatar
I have the following configuration:
HTPC with Radeon 4650 graphics card --> Denon AVR-1909 --> Samsung LE32M5 LCD TV.
I have catalyst 9.2 drivers and the EDID override installed.
My problem is that if I switch off the denon receiver and AFTERWARDS (or at the same time) send the PC into standby, then the TV will display "no signal" after resuming the PC from standby. If I send the PC first into standby, wait a few seconds and then swtch off the denon, there is no problem after resume.
I use a harmony remote to switch off everything together and therefore run into this issue 100%. If the system is up and running and I switch off the denon receiver and afterwards back on, there is problem.
Any ideas howto fix that?
AVR1909 is offline
Old 02-28-2009, 03:27 PM
mikezos's Avatar
Hey Everyone,
I tired the EDID override as documented but Vista says that the driver I have installed is more current or something like that.
Have I created the INF file correctly? Have I understood the instructions properly? I take the first 4 lines of raw output from Monitor Asset Manger for the TV and then the last 4 lines from the denon?
Ive attached the INF and raw data if anyone is interested in looking at them.
I have the following hardware:
HTPC with Radeon 4670 graphics card --> Denon AVR-3808 --> Samsung LN46A850 LCD TV.
When is an EDID override needed? I currently have DD and DTS 5.1 getting to the receiver. Is EDID override needed to achieve 7.1 LPCM?
Im new to the HTPC setup, so a curious mind needed to ask this question.
Thanks for your help
Cheers
EDIDOverride.txt 2.625k . file
EDID Raw Data.txt 1.6787109375k . file
mikezos is offline
Old 03-02-2009, 07:37 AM
Saibling's Avatar
Hi Folks,
I tried to get my stuff working for nearly two weeks now. But somehow Windows tells me there would be a mistake in my creted .ini-File for my Receiver and TV. So now I'd like you to look over my "Driver" and correct it. I got my driver by reading everything out via MonInfo and with the Realtime-thing there I let it create this .ini-File. Could you please take a look at the current file? Unfortunately I'm at work now, so I can post it for you just a little later. This would be SOOO nice...!
On my PC there's Windows XP Home, my TV is a 37LG5000 and my Receiver's name is Yamaha RX-V663. I hope at least you can help me... I'm so desperate at the moment!
Saibling is offline
Old 03-02-2009, 08:13 AM
kemac's Avatar
Quoted: 49 Post(s)
Liked: 47
Saibling, the EDID override method in this thread only works with Vista. The ATI CCC 9.1 drivers and newer corrected the ATI EDID issue for most.
kemac is online now
Old 03-02-2009, 09:02 AM
Saibling's Avatar
What options does a normal XP user have to get these things working then?
Saibling is offline
Old 03-02-2009, 09:14 AM
kemac's Avatar
Quoted: 49 Post(s)
Liked: 47
you never stated what card your using and whats not working for you? Have you tried the latest ATI drivers? The ATI CCC 9.1 drivers and newer corrected the ATI EDID issue.
kemac is online now
Old 03-02-2009, 09:29 AM
Saibling's Avatar
You're not completely right. I have sound on my Receiver, but just stereo-sound. How can I get 7.1-surround-sound? Aaaaaah! HELP ME! In my sound settings i have chosen the hdmi-output and set it do 7.1 surround system but there's just stereo sound! How can I get it changed?
Saibling is offline
Old 03-02-2009, 09:38 AM
kemac's Avatar
Quoted: 49 Post(s)
Liked: 47
What ATI card are you using? What are you setting hdmi output in? Have you tried setting it to 7.1 instead of hdmi? The more details you can provide about your setup the easier for someone to help...
kemac is online now
Old 03-02-2009, 09:47 AM
Saibling's Avatar
Sorry man, could have posted this much earlier: my graphics card is a radeon hd 4650 from palit, and I've got two sound drivers: the realtek high definition audio driver and the realtek hdmi audio driver. as I have installed both of them I could chose the HDMI output and make settings, but whether I chose stereo, 5.1 or 7.1 my Receiver always says, that there ist just stereo sound coming out of my soundchip via HDMI!
what other details do you need to help me, I'll give them to you...
Saibling is offline
Old 03-02-2009, 10:02 AM
kemac's Avatar
Quoted: 49 Post(s)
Liked: 47
What are you playing as a source? You are playing something with more than 2 channels of audio correct?
Just some suggestion based on what I have read.
Some users have reported having an issue if they have on-board audio enabled and the ATI aduio controller so I would make sure any motherboard audio is diabled in the BIOS and associted drivers uninstalled.
My understanding (Could be wrong) is that the ATI CCC install package includes the ATI realtek drivers needed for XP. Vista users have to install the Realtek ATI HDMI drivers seperatly. It might not hurt to unstill all the realtek and ATI software and reinstall just the CCC drivers and see what happens.
Hope that helps!
kemac is online now
Old 03-02-2009, 10:05 AM
Saibling's Avatar
Thanx I'll try...
Aaaaah. Didn't work again. I uninstalled everything and installed it again. Now I still have stereo sound via HDMI, but no 5.1 or 7.1 surround. Also my monitors don't play together anymore. When I start my TV, then it goes with 1280x1024 (Acer-Monitor) and the Acer monitor goes with 1920x1080, but reports an error, because it can't understand such a huge resolution! If I change it in CCC, after the next restart it's the same agein!
Saibling is offline
Old 03-03-2009, 01:11 AM
Saibling's Avatar
Another hint??
Saibling is offline
Old 03-03-2009, 10:15 PM
elvin's Avatar
What I had to do to get my setup to get pass the 2 channel was on my reciever change the audio out to pcm and I would get the output depending on what movie I played and the setting I did on the audio part.Hope this helps some.
elvin is offline
Old 03-04-2009, 02:17 PM
topdogzero's Avatar
Hello everyone, I posted this in other thread on here, but since it may have something to do with this thread I'll post it here too, can someone have a look at there HDMI dongle for me. Thanks.
I have a 4850 from Palit that came without the dongle, Palit has since sent me one but I still can’t get audio over HDMI, the dongle that Palit sent me is black. Did Palit send me the wrong dongle because my HDTV is detected as a DVI device in CCC.
Hdmi is selected in audio properties, using 9.2 drives and also tried realtek ATI audio driver since they made the audio codec chip on the card, when I use this driver it says cable not plugged in. Dongle I received has marking HDMI on it and a circle with a arrow going through it. No ATI makings and no rev numbers or letters.
topdogzero is offline
Old 03-05-2009, 12:08 PM
Alexander01's Avatar
Hello, I want my Sony TV to be detected as DVI device in CCC so i can use external analog audio (because if the TV is detected as HDMI device, the tv doesnt accept external analog audio).
What do i need to change in the EDID to get the TV detected as DVI device?
This is the EDID:
Monitor
Model name............... SONY TV
Windows description...... Algemeen PnP-beeldscherm
Manufacturer............. Sony
Plug and Play ID......... SNYFE00
Serial number............ n/a
Manufacture date......... 2007, ISO week 1
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1600 x 900 mm (72,3 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,625 - Ry 0,340
Green chromaticity....... Gx 0,280 - Gy 0,595
Blue chromaticity........ Bx 0,155 - By 0,070
White point (default).... Wx 0,283 - Wy 0,298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 14-68kHz
Vertical scan range...... 48-62Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 85,500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 -hsync -vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 0
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace -hsync -vsync
Detailed timing #3....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Detailed timing #4....... 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2448 2492 2640 1080 1116 1121 1125 +hsync +vsync
Detailed timing #5....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
CE video data (timings supported)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.2.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 5-3-2009
Software revision........ 2.30.0.793
Operating system......... 6.0.6001.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,00,FE,01,01,01,01,01,11,01,03, 80,A0,5A,78,0A,0D,C9,A0,57,47,98,27,
12,48,4C,21,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,66,21,50,B0,51,00,1B,30,40,70,
36,00,40,84,63,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00, 40,84,63,00,00,18,00,00,00,FC,00,53,
4F,4E,59,20,54,56,0A,20,20,20,20,20,00,00,00,FD,00,30,3E,0E, 44,0F,00,0A,20,20,20,20,20,20,01,63,
02,03,24,70,50,1F,14,13,12,11,16,15,10,05,04,03,02,07,06,01, 20,23,09,07,07,83,01,00,00,66,03,0C,
00,20,00,80,01,1D,80,D0,72,1C,16,20,10,2C,25,80,40,84,63,00, 00,9E,01,1D,80,18,71,1C,16,20,58,2C,
25,00,40,84,63,00,00,98,01,1D,00,BC,52,D0,1E,20,B8,28,55,40, 40,84,63,00,00,1E,02,3A,80,D0,72,38,
2D,40,10,2C,45,80,40,84,63,00,00,1E,02,3A,80,18,71,38,2D,40, 58,2C,45,00,40,84,63,00,00,1E,00,D6
I already tryed to remove the second EDID block but after updating the .inf and rebooting the TV is still detected as HDMI.
So i need to change something else in the first EDID block. But i don't know what needs to be changed
Alexander01 is offline
Old 03-05-2009, 01:09 PM
Mikl1984's Avatar
You should change
Extension blocs.......... to 0 and control sum
Mikl1984 is offline
Old 03-05-2009, 01:43 PM
Originally Posted by Mikl1984 View Post
You should change
With what program can i find and change those values in the RAW data? I was already thinking that the extension blocs needed to set to 0, but were is the control sum value located?
Old 03-05-2009, 04:24 PM
I tryed some tools. Non of them are able to see to what hex value the "Extension blocs.......... 1 (CEA-EXT)" is mapped. Is it not possible to read and edit specific hex values in the edid? Please help!
Old 03-05-2009, 10:25 PM
Mikl1984's Avatar
Any EDID or even text/Hex editor http://en.wikipedia.org/wiki/Extende...ification_data
In your case your should change two last bytes of first 128byte block
from 01,63 to 00,64
Mikl1984 is offline
Old 03-06-2009, 04:35 PM
Thanks. It's detected as DVI now
Old 03-09-2009, 02:46 PM
archibael's Avatar
Any word on this working for Nvidia cards? My TV (falsely) fails to include Dolby Digital/DTS in its HDMI EDID. While I can probably use AC3Filter to get around this I'd rather just have the HDMI port transmitting properly without an assist.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
Old 03-23-2009, 09:54 PM
eennaampje's Avatar
Hi,
I've decided to set up a htpc and everything works except for sound.
tv: samsung 32r81
receiver: Sony str dg820
video: Sapphire HD3470 with catalyst 9.3
The strange thing is that the sound over hdmi does work with every resolution except for 1360x678@60hz, which is the native resolution of my tv.
I tried swapping hdmi cables, installing realtek drivers (ati hdmi device), installing windows 7, reinstalling vista, disabling onboard sound in the bios, but it all didn't help
This got me to try the resolution given by RandomFoe:
putting together the raw data of the samsung 32r81:
00,FF,FF,FF,FF,FF,FF,00,4C,2D,9D,02,00,00,00,00,2D,10,01,03, 80,10,09,8C,0A,E2,BD,A1,5B,4A,98,24,15,47,4A,A1,08,00,01,01, 01,01,01,01,01,01,01,01,01,01,01,01,01,01,66,21,50,B0,51,00, 1B,30,40,70,36,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20, 6E,28,55,00,A0,5A,00,00,00,1E,00,00,00,FD,00,31,47,0F,32,09, 00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47, 0A,20,20,20,20,20,01,1D,02,03,1A,F1,46,84,13,05,14,03,12,23, 09,07,07,83,01,00,00,66,03,0C,00,20,00,80,01,1D,00,BC,52,D0, 1E,20,B8,28,55,40,A0,5A,00,00,00,1E,01,1D,80,18,71,1C,16,20, 58,2C,25,00,A0,5A,00,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C, 25,80,A0,5A,00,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00, A0,5A,00,00,00,18,8C,0A,D0,90,20,40,31,20,0C,40,55,00,A0,5A, 00,00,00,18,00,00,00,00,00,00,00,00,00,00,00,69
and the sony str dg820
00,FF,FF,FF,FF,FF,FF,00,4D,D9,01,4C,01,01,01,01,0A,12,01,03, 80,50,2D,78,0A,0D,C9,A0,57,47,98,27,12,48,4C,20,00,00,01,01, 01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,00,72,51,D0, 1E,20,6E,28,55,00,C4,8E,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10, 10,3E,96,00,C4,8E,21,00,00,18,00,00,00,FC,00,53,4F,4E,59,20, 41,56,41,4D,50,0A,20,20,00,00,00,FD,00,31,3D,0F,2E,08,00,0A, 20,20,20,20,20,20,01,A1,02,03,44,71,4D,83,04,05,0E,0F,10,12, 13,14,1D,1E,1F,20,32,61,7E,00,65,7E,00,67,1E,00,59,7E,01,5D, 7E,01,5F,1E,01,32,09,7F,07,0D,7F,07,0F,7F,07,15,07,55,3D,1F, C0,57,06,00,83,5F,00,00,67,03,0C,00,21,00,B8,2D,8C,0A,D0,90, 20,40,31,20,0C,40,55,00,C4,8E,21,00,00,18,01,1D,00,BC,52,D0, 1E,20,B8,28,55,40,C4,8E,21,00,00,1E,00,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,9E,80,D0,72,1C, 16,20,10,2C,25,80,A0,5A,00,00,00,9E,8C,0A,D0,8A,20,E0,2D,10, 10,3E,96,00,A0,5A,00,00,00,18,8C,0A,D0,90,20,40,31,20,0C,40, 55,00,A0,5A,00,00,00,18,00,00,00,00,00,00,00,00,00,00,00,69
gives:
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4C,0x2D,0x9D ,0x02,0x00,0x00,0x00,0x00,0x2D,0x10,0x01,0x03,0x80,0x10,0x09 ,0x8C,0x0A,0xE2,0xBD,0xA1,0x5B,0x4A,0x98,0x24,0x15,0x47,0x4A ,0xA1,0x08,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x66,0x21,0x50,0xB0,0x51 ,0x00,0x1B,0x30,0x40,0x70,0x36,0x00,0xA0,0x5A,0x00,0x00,0x00 ,0x1E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00 ,0x31,0x47,0x0F,0x32,0x09,0x00,0x0A,0x20,0x20,0x20,0x20,0x20 ,0x20,0x00,0x00,0x00,0xFC,0x00,0x53,0x41,0x4D,0x53,0x55,0x4E ,0x47,0x0A,0x20,0x20,0x20,0x20,0x20,0x01,0x1D
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x44,0x71,0x4D,0x83,0x04,0x05,0x0E,0x0F,0x10 ,0x12,0x13,0x14,0x1D,0x1E,0x1F,0x20,0x32,0x61,0x7E,0x00,0x65 ,0x7E,0x00,0x67,0x1E,0x00,0x59,0x7E,0x01,0x5D,0x7E,0x01,0x5F ,0x1E,0x01,0x32,0x09,0x7F,0x07,0x0D,0x7F,0x07,0x0F,0x7F,0x07 ,0x15,0x07,0x55,0x3D,0x1F,0xC0,0x57,0x06,0x00,0x83,0x5F,0x00 ,0x00,0x67,0x03,0x0C,0x00,0x21,0x00,0xB8,0x2D,0x8C,0x0A,0xD0 ,0x90,0x20,0x40,0x31,0x20,0x0C,0x40,0x55,0x00,0xC4,0x8E,0x21 ,0x00,0x00,0x18,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8 ,0x28,0x55,0x40,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9E
But this also didn't work.
I doubt if this is not the solution or did I do something wrong in the process of creating the edid data?
eennaampje is offline
Old 03-30-2009, 01:25 PM
curtis104's Avatar
I was wondering if this EDID override will resolve my HTPC problems. I am using a Radeon 4850 video card through an Onkyo 606 A/V receiver. Everything displays perfectly and the sound through HDMI is great. My problem is if I use my Harmony remote to switch to another the device on my A/V receiver and then try to switch back to HTPC I do not get any picture. It almost as if the PC is turned off. Now if I hook the DVI Doctor up this totally resolves the problem. BUT I can not get any sound when using the DVI Doctor. It disables the sound coming through the ATI card. Will EDID resolve this problem for me and give an always on signal coming from my HTPC?
My displays are a Samsung SlimFit 50" DLP and a Mitsubushi HD1000 Front Projector.
Curtis
Xbox Live ID: Blaze104
MSI Media Live DIVA 5.1
Ahanix MCE701 case
LG Blu-ray/HD-DVD
3 Cable Card
1 HDHomerun
Windows 7 32bit
42" HP MediaSmart
WHS Norco 4020 case w/ WHS 2011
curtis104 is offline
Old 04-02-2009, 11:20 AM
PanamaMike's Avatar
Originally Posted by RandomFoe View Post
Ok so I have found a way to get around the problem of not recieving sound from the ATI card and would like to share it.
First a disclamer This will change your generic pnp monitor to a edid override device using a INF. file changing the driver, if you start getting into trouble roll back your driver back to generic pnp monitor using device manager. I take no responisblity for your computer skills.
I'm not the best on computers so I guess this can be improved on.
1st- Get the attached file and place in on your desktop or where it wont get lost then unzip the file you should end up with an .inf setupfile.
2nd- Veiw the file with notepad, the part we are interested in are the two fields below with a long string of text.
"HKR,EDID_OVERRIDE,"0",0x01" followed by EDID data (change this to suit or tv/monitor)
"HKR,EDID_OVERRIDE,"1",0x01" followed by EDID data (change this to suit your reciever)
This the EDID your computer will use, existing non generic pnp monitors will not be changed, I'm not sure about monitors being installed later.
In "01" everything after 0x01, starting with 00,ff,ff,ff,ff,ff,ff,00 is the first block of EDID data for you monitor that you want to use. Mine was set for Samsung LA46F81BD HDTV.
In "02" everything after 0x01, is regarding to the extention block use the second half of EDID data for your reciever here. Mine was set for Yamaha RX-V663 Reciever.
The registry puts the two together and into action.
3rd- Once you are happy with the two parts of data save and exit the file. Have all your equipment connected and running. To install open device manager, find generic pnp monitor and right click go into options. ensure the current driver is for generic pnp monitor (roll back driver if required). In properties click the driver tab and choose update driver, choose browse computer, pick from a list of device drivers, have disk and find the EDID override file with the information you want and install, note you will get a warning because it is modified.
4th- Reboot your computer if the EDID information you supplied is correct you will now have 7.1 ability.
Just a note I think a dvi detective is a better solution if you have the money... I had more time then cents while recovering from a knee op.
I need to do EDID override of my Sharp 46D64U LCD VGA input. It won't allow for 1080p from VGA but does work from HDMI. I know it's possible to force 1080p on the VGA, but I don't know how to do it via Win7.
I'd like to leave the SHARP HDMI EDID settings in tact, just change the SHARP LCD EDID settings.
I've tried powerstrip no luck.
Mike
PanamaMike is offline
Old 04-03-2009, 03:15 PM
zerbino's Avatar
Hello all! Very well, that this topic exists. I read many information, but could not solve my problem.
Config:
1. Bly-ray player BDP-51FD ==> HDMI 1m ==> AV Receiver TX-NR906 ("HDMI in 1" connect)==> HDMI 1m ==> TV Pioneer PDP LX508D.
2. ATI 2600HD (Drivers + CCC v.9.3) ==> DVI-HDMI Conv. ==> 8 meters Supra HDMI Cable v.1.3.support ==> AV Receiver TX-NR906 ("HDMI in 2" connect)==> HDMI 1m ==> TV Pioneer PDP LX508D.
At the first variant any problems not exists. All perfectly works.
At 2-nd - from the beginning, at the first connection, all displayed well, but with one exception - there was fields in width nearby 1 centimeter around of picture at 1920х1080 (at 1280x1024 fields wasn't present, but it was not pixel-to-pixel picture).
I tried to use others resolutions such as 1776x1000, freq 24, 25, 50, 60 but there wasn't any positive changes. EDIDOverride.inf installed wia mouse right click and as driver for 2-nd display.
There are 2 reports attached (Receiver and TV) and my EDIDOverride that used.
Please tell me, where was mistake and what possible to try?
p.s. There is no sound through PC HDMI connection. Creative X-Fi spdif-out used
(sorry for my poor english, i know language badly )
onkyo 906.txt 5.390625k . file
pioneer pdp-lx508d.txt 5.1640625k . file
EDIDOverride.txt 2.62890625k . file
zerbino is offline
Old 04-04-2009, 06:40 PM
dmkbox's Avatar
HI!
I have system with HD4350 + DG820 + ACER PROJECTOR.
Using EDID OVERRIDE from this thread, I get 7channel LPCM, but not DD-DTS ever. I use AC3 filter with SPDIF passtrough but with no success. In HDMI DEVICE properties DD-DTS test can`t pass. I use latest drivers ATI/REALTEK. What's wrong?
MonINFO with HD4350 + DG820 + ACER PROJECTOR linked
Model name............... SONY AVAMP
Plug and Play ID......... SNY4C01
Manufacture date......... 2008, ISO week 10
Screen size.............. Undefined or variable
DDC/CI................... Not supported
Red chromaticity......... Rx 0,647 - Ry 0,342
Green chromaticity....... Gx 0,323 - Gy 0,616
Blue chromaticity........ Bx 0,143 - By 0,088
White point (default).... Wx 0,290 - Wy 0,347
Horizontal scan range.... 31-100kHz
Vertical scan range...... 43-85Hz
Video bandwidth.......... 170MHz
Native/preferred timing.. 720x480p at 60Hz
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #1....... 1280x720p at 50Hz
Modeline............... "1280x720" 74,250 1280 1464 1504 1980 720 725 730 750 +hsync +vsync
Native formats........... 5
Detailed timing #1....... 1920x1080i at 60Hz
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 720x576p at 50Hz
Modeline............... "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #3....... 1280x720p at 60Hz
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
DVD-A 2-channel at 44/48/88/96/176/192 kHz
DVD-A 6-channel at 44/48/88/96/176/192 kHz
DVD-A 8-channel at 44/48/88/96 kHz
DTS-HD 2-channel, 16-bit at 44/48/88/96/176/192 kHz
DTS-HD 6-channel, 16-bit at 44/48/88/96/176/192 kHz
DTS-HD 8-channel, 16-bit at 44/48/88/96 kHz
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 6-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 6-channel, 680k max. bit rate at 32/44/48 kHz
DTS 6-channel, 1536k max. bit rate at 32/44/48/88/96 kHz
DD+ 8-channel at 44/48 kHz
Channel configuration.... 7.1
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. Yes
Rear left/right center... Yes
CEC physical address..... 2.1.0.0
Report information
Date generated........... 05.04.2009
Software revision........ 2.30.0.797
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,01,4C,01,01,01,01,0A,12,01,03, 80,00,00,78,0A,EF,A7,A5,57,52,9D,24,
16,4A,58,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,8C,0A,D0,8A,20,E0,2D,10,10,3E,
96,00,00,00,00,00,00,18,01,1D,00,BC,52,D0,1E,20,B8,28,55,00, 00,00,00,00,00,1E,00,00,00,FC,00,53,
4F,4E,59,20,41,56,41,4D,50,0A,20,20,00,00,00,FD,00,2B,55,1F, 64,11,00,0A,20,20,20,20,20,20,01,2A,
02,03,3D,75,47,02,0E,11,1D,84,13,05,32,61,7E,00,65,7E,00,67, 1E,00,59,7E,01,5D,7E,01,5F,1E,01,32,
09,7F,07,0D,7F,07,0F,7F,07,15,07,55,3D,1F,C0,57,06,00,83,5F, 00,00,66,03,0C,00,12,00,80,01,1D,80,
18,71,1C,16,20,58,2C,25,00,00,00,00,00,00,9E,8C,0A,D0,90,20, 40,31,20,0C,40,55,00,00,00,00,00,00,
18,01,1D,00,72,51,D0,1E,20,6E,28,55,00,00,00,00,00,00,1E,00, 00,00,00,00,00,00,00,00,00,00,00,A9
dmkbox is offline
Old 04-18-2009, 06:32 AM
Jaguare's Avatar
My system is: HD4870 connected with Onkyo SX605 by HDMI 1.5 Qed then to the Philips TV 37PF9731D
I would like to ask to check my EDID info and tell me what's wrong. Same time I get DD and DTS-ES sound but never DTS-HD. I use MPC without any codeck HDMI passtrough and offcourse I use latest drivers ATI HDMI REALTEK.
Monitor
Model name............... TX-SR605
Manufacturer............. Onkyo
Plug and Play ID......... ONK0761
Manufacture date......... 2007, ISO week 0
Screen size.............. 640 x 360 mm (28.9 in)
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.290 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.289 - Wy 0.299
Horizontal scan range.... 15-50kHz
Video bandwidth.......... 90MHz
Native/preferred timing.. 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Detailed timing #1....... 1024x768p at 60Hz (4:3)
Modeline............... "1024x768" 65.000 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
DTV underscan............ Supported
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
MPEG1 2-channel, 1072k max. bit rate at 32/44/48 kHz
Report information
Date generated........... 18.Apr.09
Operating system......... 6.1.7077.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,3D,CB,61,07,00,00,00,00,00,11,01,03, 80,40,24,78,0A,E6,92,A3,54,4A,99,26,
0F,4A,4C,21,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,D0,72,1C,16,20,10,2C,
25,80,80,68,21,00,00,9E,64,19,00,40,41,00,26,30,18,88,36,00, 90,2C,11,00,00,18,00,00,00,FC,00,54,
58,2D,53,52,36,30,35,0A,20,20,20,20,00,00,00,FD,00,30,3E,0F, 32,09,00,0A,20,20,20,20,20,20,01,DD,
02,03,25,F0,4B,01,03,04,05,06,07,12,13,14,15,16,29,09,1F,07, 15,07,50,19,07,86,83,01,00,00,66,03,
0C,00,12,00,80,01,1D,80,18,71,1C,16,20,58,2C,25,00,80,68,21, 00,00,9E,01,1D,00,BC,52,D0,1E,20,B8,
28,55,40,80,68,21,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55, 00,80,68,21,00,00,1E,8C,0A,D0,90,20,
40,31,20,0C,40,55,00,80,68,21,00,00,18,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,1F
Jaguare is offline
Old 04-27-2009, 09:46 AM
Plasticlizard's Avatar
I got the method in post 1 to work, but only after a slight modification.
First my specs:
HIS ATI Radeon 4850
Yamaha RX-V661 reciever
Gigabyte EX58-UD4P motherboard
Westinghouse LVM47 LCD TV
Samsung 24" monitor.
Windows 7 Beta, 64 bit edition.
The procedure:
1. I unplugged everything but the samsung flatscreen.
2. I used Moninfo to create an .inf file for the monitor and saved it.
3. I plugged in just the yamaha reciever via HDMI and not the westinghouse, then rebooted. Moninfo showed the RX-V661 as a monitor.
4. I used Moninfo to create an .ini file for the Yamaha reciever and saved it.
5. I then connected the Westinghouse LCD and used moninfo to create an .ini file for it.
6. Then I used wordpad to cut and paste the Yamaha data string into BOTH the Westinghouse and Samsung *.inf files after the data that was already in there.
7. I am using Catalyst 9.4 and the ATI HD audio drivers...not the realtek one, but the one from game.amd.com
I have tried for weeks to get the system to output 7.1 to the reciever, but could only get 2 channel stereo. Only by putting the reciever information in BOTH monitors, including the desktop LCD, was I able to finally get sound as 7.1
I still have to manually click on the "choose sound device" and set the ATI HD to default, and I still have to retest the 7.1 speakers everytime I boot up. But at least that is an option now, before I could only see the 2 speakers. I'll work on making that permanent tonight.
best of luck to the rest of you.
Plasticlizard is offline
Old 04-27-2009, 09:49 AM
Oh, one more comment,
I am using the BD edition of PowerDVD 7 that came with my Blueray drive. I also downloaded and have a few days left on PDVD 9 trial.
In that software I can select to have the audio output straight to the reciever, or have the software decode it. Which sounds better/delivers better 7.1?
thanks
