EDID Override Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #721 of 3494 Old 04-08-2010, 09:26 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
The Marantz SR5003 EDID is fine with no TrueHD or DTS HD SAD issues, so you shoud bitstream just fine.
My guess is that you need to uninstall/install the ATI drivers but by cleaning old traces with DriverCleaner or DriverSweeper. This should deal with your DVI issue with your PC monitor.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #722 of 3494 Old 04-09-2010, 09:15 AM
ottelo's Avatar
@Trulli
THX, Now it works perfectly !!!!!! I think the the issue with the order was the problem (or Detailed Timing Offset). Now my NVIDIA Driver accept DTS/Dolby Digital !!!!!!
ottelo is offline
post #723 of 3494 Old 04-10-2010, 04:41 AM
p750mmx's Avatar
I have the same issues as user Ottelo with a Asus EB1501 ION 330 system. Only 2 canal sound true HDMI on Windows 7 32b, no matter what I try. I assumed that my Asus could only give 2 channel sound by HDMI.
My setup is a Yamaha RX-V465 AV receiver and my TV is a Samsung Plasma PS50B650. The connection goes from HTPC > Receiver > TV by HDMI (1.3)
I've included the output file from Moninfo.
Hope you can help me with this one...
Code:
Monitor Asset Manager Report, generated 4/10/2010 (6.1.7600)
Copyright (c) 1995-2010, EnTech Taiwan.
Hardware data
  BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI00018.PCI0001C
  00000000 = 0A8210DE.00A00006.060000B1.00800000.00000000.00000000.00000000.00000000
  00000001 = 0A8810DE.00A00004.050000B1.00800000.00000000.00000000.00000000.00000000
  00000018 = 0AAD10DE.00A0000F.060100B2.00800000.00002F01.00000000.00000000.00000000
  00000019 = 0AA410DE.00A00400.050000B1.00800000.00000000.00000000.00000000.00000000
  0000001A = 0AA210DE.00B00001.0C0500B1.00800000.00002901.00000000.00000000.00000000
  0000001B = 0A8910DE.00200000.050000B1.00800000.00000000.00000000.00000000.00000000
  0000001D = 0AA310DE.00A00006.0B4000B1.00800000.F9F80000.00000000.00000000.00000000
  00000020 = 0AA510DE.00B00006.0C0310B1.00800000.F9F7E000.00000000.00000000.00000000
  00000021 = 0AA610DE.00B00006.0C0320B1.00800000.F9F7FC00.00000000.00000000.00000000
  00000030 = 0AA710DE.00B00006.0C0310B1.00800000.F9F7D000.00000000.00000000.00000000
  00000031 = 0AA910DE.00B00006.0C0320B1.00800000.F9F7F800.00000000.00000000.00000000
  00000040 = 0AC010DE.00B00006.040300B1.00000000.F9F78000.00000000.00000000.00000000
  00000048 = 0AAB10DE.00B00407.060401B1.00010000.00000000.00000000.40010100.228000F0
  00000058 = 0AB810DE.00B00007.010601B1.00000000.0000C081.0000C001.0000BC01.0000B881
  00000080 = 0AA010DE.00100407.060400B1.00010000.00000000.00000000.00020200.2000D1D1
  000000A8 = 0AC610DE.00100007.060400B1.00010010.00000000.00000000.00030300.0000E1E1
  000000B0 = 0AC710DE.00100006.060400B1.00010010.00000000.00000000.00040400.000001F1
  000000B8 = 0AC710DE.00100004.060400B1.00010010.00000000.00000000.00050500.000001F1
  00000200 = 087D10DE.00100107.030000B1.00000010.FA000000.E000000C.00000000.F600000C
  00000300 = 816810EC.00100407.02000003.00000010.0000EF01.00000000.FBEFF004.00000000
  00000400 = 002B168C.00100400.02800001.00000010.FBFF0004.00000000.00000000.00000000
  01040000 = 00FFFFFF.FFFFFF00.4C2D1C05.01000000.30120103.80100978.0AEE91A3.544C9926
  00000020 = 0F5054BD.EF80714F.81008140.81809500.950FB300.0101023A.80187138.2D40582C
  00000040 = 4500A05A.0000001E.011D0072.51D01E20.6E285500.A05A0000.001E0000.00FD0018
  00000060 = 4B1A5117.000A2020.20202020.000000FC.0053414D.53554E47.0A202020.2020018B
  01040100 = 020325F5.49901F04.13051403.12202309.07078301.0000E200.0FE30503.0167030C
  00000020 = 001400B8.2D011D00.BC52D01E.20B82855.40A05A00.00001E01.1D801871.1C162058
  00000040 = 2C2500A0.5A000000.9E011D80.D0721C16.20102C25.80A05A00.00009E00.00000000
  00000060 = 00000000.00000000.00000000.00000000.00000000.00000000.00000000.0000004E
Monitor #1 [Real-time 0x0041]
  Model name............... SAMSUNG
  Manufacturer............. Samsung
  Plug and Play ID......... SAM051C
  Serial number............ 1
  Manufacture date......... 2008, ISO week 48
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. 160 x 90 mm (7.2 in)
  Power management......... Not supported
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2.20
  Red chromaticity......... Rx 0.640 - Ry 0.330
  Green chromaticity....... Gx 0.300 - Gy 0.600
  Blue chromaticity........ Bx 0.150 - By 0.060
  White point (default).... Wx 0.313 - Wy 0.329
  Additional descriptors... None
Timing characteristics
  Horizontal scan range.... 26-81kHz
  Vertical scan range...... 24-75Hz
  Video bandwidth.......... 230MHz
  CVT standard............. Not supported
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #1....... 1280x720p at 60Hz (16:9)
    Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
     720 x  400p at  70Hz - IBM VGA
     640 x  480p at  60Hz - IBM VGA
     640 x  480p at  67Hz - Apple Mac II
     640 x  480p at  72Hz - VESA
     640 x  480p at  75Hz - VESA
     800 x  600p at  60Hz - VESA
     800 x  600p at  72Hz - VESA
     800 x  600p at  75Hz - VESA
     832 x  624p at  75Hz - Apple Mac II
    1024 x  768p at  60Hz - VESA
    1024 x  768p at  70Hz - VESA
    1024 x  768p at  75Hz - VESA
    1280 x 1024p at  75Hz - VESA
    1152 x  870p at  75Hz - Apple Mac II
    1152 x  864p at  75Hz - VESA STD
    1280 x  800p at  60Hz - VESA STD
    1280 x  960p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1440 x  900p at  60Hz - VESA STD
    1440 x  900p at  75Hz - VESA STD
    1680 x 1050p at  60Hz - VESA STD
EIA/CEA-861 Information
  Revision number.......... 3
  DTV underscan............ Supported
  Basic audio.............. Supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 5
  Detailed timing #1....... 1280x720p at 50Hz (16:9)
    Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
  Detailed timing #2....... 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
  Detailed timing #3....... 1920x1080i at 50Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
CE video data (timings supported)
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
    1920 x 1080p at  24Hz - HDTV (16:9, 1:1)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
  Channel configuration.... 2.0
  Front left/right......... Yes
  Front LFE................ No
  Front center............. No
  Rear left/right.......... No
  Rear center.............. No
  Front left/right center.. No
  Rear left/right center... No
  Rear LFE................. No
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 4.1.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... Yes
  Supports 30bpp........... Yes
  Supports YCbCr 4:4:4..... Yes
  Supports dual-link DVI... No
  Maximum TMDS clock....... 225MHz
Report information
  Date generated........... 4/10/2010
  Software revision........ 2.50.0.849
  Operating system......... 6.1.7600.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,2D,1C,05,01,00,00,00,30,12,01,03,80,10,09,78,0A,EE,91,A3,54,4C,99,26,
  0F,50,54,BD,EF,80,71,4F,81,00,81,40,81,80,95,00,95,0F,B3,00,01,01,02,3A,80,18,71,38,2D,40,58,2C,
  45,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,00,00,00,FD,00,18,
  4B,1A,51,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,8B,
  02,03,25,F5,49,90,1F,04,13,05,14,03,12,20,23,09,07,07,83,01,00,00,E2,00,0F,E3,05,03,01,67,03,0C,
  00,14,00,B8,2D,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,A0,5A,00,00,00,1E,01,1D,80,18,71,1C,16,20,58,
  2C,25,00,A0,5A,00,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,A0,5A,00,00,00,9E,00,00,00,00,00,
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,4E
Monitor #2 [Real-time 0x0100]
  Extension blocs.......... 1 (Reserved - 0x00)
  Detailed timing #1....... 1360x768p at 60Hz (16:9)
    Modeline............... "1360x768" 85.500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Report information
Raw data
  45,00,A0,5A,00,00,00,1E,66,21,50,B0,51,00,1B,30,40,70,36,00,A0,5A,00,00,00,1E,00,00,00,FD,00,18,
  4B,1A,51,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,5C
moninfo.txt 10.7197265625k . file
p750mmx is offline
post #724 of 3494 Old 04-10-2010, 10:18 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
That capture is only 128-byte so no audio data. Anyway, have you checked that the Yamaha is set to NOT repeat the TV EDID audio specs? That's a typical problem. This is an HDMI setting (in my DENON is "AMP").
Tulli is offline
post #725 of 3494 Old 04-10-2010, 10:58 AM
p750mmx's Avatar
Ok, now with media running on the background.
Do you get more usable info from the txt file?
ps50b650-hd-dts-moninfo.txt 10.001953125k . file
p750mmx is offline
post #726 of 3494 Old 04-10-2010, 11:10 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Oh, that one is fine, and of course it shows only one Audio SAD for 2-LPCM.
But, did you check the Yamaha HDMI setting that I mentioned? Or, can you set your HDMI audio to 5.1 or 7.1 in Windows?
I really doubt that the problem is EDID related, but if the Yamaha HDMI is set to pass-through the TV audio (or to repeat the TV EDID specs) the HTPC will only be enabled for 2-LPCM.
Tulli is offline
post #727 of 3494 Old 04-10-2010, 11:27 AM
p750mmx's Avatar
The HDMI trough light is off so I assume that is not the case.
The HDMI info under Windows 7 shows only 2 channel and can't be changed but my computer hardware and OS is almost equal to that of user ottelo and he had the same issues with the HDMI sound.
p750mmx is offline
post #728 of 3494 Old 04-10-2010, 11:47 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
No, you must enter the Yamaha HDMI setup and check for the HDMI value that specifies for TV audio passthrough.
If the issue is not there we can try the EDID override route (it seems the Nvidia ION chipset can be EDID overriden? I'm not sure) for which I would need the full 256-byte Yamaha EDID too.
Tulli is offline
post #729 of 3494 Old 04-10-2010, 12:03 PM
p750mmx's Avatar
Ok, I think I understand what you mean now.
I've disabled the HDMI Audio AMP+TV and set it to AMP only. Now sound volume can only be controlled by the amp not by my DVB-tuner anymore.
I've also disabled the HDMI video/audio signal will still be active when the receiver is set to standby, that's the pass trough I assume, I earlier saw the pass light come on and that stays off right now.
But now my wife is watching TV and she is the boss when she's not asleep so I will call back later with (I hope) the correct info regarding the amp.
No matter how this ends, your effort is being appreciated.
p750mmx is offline
post #730 of 3494 Old 04-10-2010, 01:00 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
That's it! It should work now.
Tulli is offline
post #731 of 3494 Old 04-10-2010, 04:42 PM
p750mmx's Avatar
p750mmx is offline
post #732 of 3494 Old 04-10-2010, 05:26 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Ok, new output generated.
Chacked the Yamaha EDID and it's repeating the Samsung base block perfectly, and the audio block is complete, with all available audio modes (meaning that the real-time EDID is being detected fine), so you don't need an EDID override (the HDMI audio driver should allow 5.1 and 7.1 now). Set the Yamaha HDMI to "AMP" and it's done.
Tulli is offline
post #733 of 3494 Old 04-12-2010, 07:47 AM
p750mmx's Avatar
Ok, to let you know.
5.1 HDMI audio is working now.
With TotalMedia Theatre 3, I get DTS and Dolby Digital (DD) on my RX-V465 display. The same with PowerDVD 10.
Under MediaPortal, when using Win7codecs v247, I get 5.1 PCM audio on my display when playing MKV's and Divx but no sound when playing media containing DD sound. I've used SAF 4.00 before the Win7codecs but couldn't get any sound at all under MP, whatever setting or codec I've tried. So de-installing SAF and installing Win7codecs give a better result but still no complete solution. I keep trying though.
When HDMI was still 2-channel I had no issues with hearing the sound at all, even with SAF 4.00, and I could see and hear every media under MP but just with 2 channel audio.
Oh, one thing more. In my HDMI config under Windows 7 it shows only "Dolby Digital" and not the list Encoded formats showing in the picture below. Could this be correct?
p750mmx is offline
post #734 of 3494 Old 04-12-2010, 01:35 PM
vladd's Avatar
Liked: 39
Post a screenshot of what you see on your machine.
vladd is offline
post #735 of 3494 Old 04-13-2010, 02:28 AM
p750mmx's Avatar
Here it is..
p750mmx is offline
post #736 of 3494 Old 04-13-2010, 03:47 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
You can passthrough 5.1 DTS (and DD of course) so ignore that info window.
Tulli is offline
post #737 of 3494 Old 04-14-2010, 12:28 AM
loza's Avatar
Hi, I have such a situation, the maximum number of channels 2.
You can do something like the number of channels 6 or 8?
loza is offline
post #738 of 3494 Old 04-19-2010, 10:14 AM
p750mmx's Avatar
That's correct but still no DTS-HD / TrueHD even when the source has that stream. Could this still be a handshake problem?
Why there is only DD in my picture and why is there a whole list of encoded formats in the other picture?
How and by what does Windows (7) fills that info?
p750mmx is offline
post #739 of 3494 Old 04-19-2010, 10:23 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
The Nvidia ION chipset does not have TrueHD nor DTS HD audio capabilities. Right now only IGP capable of bitstreaming those is Intel Clarkdale.
Tulli is offline
post #740 of 3494 Old 04-19-2010, 12:11 PM
p750mmx's Avatar
That's not nice info but ex-planes it all.
p750mmx is offline
post #741 of 3494 Old 04-28-2010, 10:00 AM
Aironxp's Avatar
HY all..
Ich tested 2 days to make this work.. but it wont ..
Can somebody make me a working *.inf for me ?...
Ich Have a POV-Atom330-ION with a LG 50PK760
Ich have 2 file: once is from active regsitry and once is from realtime...
In the realtime EDID it shows that the tv supports AC3 but it dont work ...
plz plz Thanks a lot...
active.zip 0.98046875k . file
realtime.zip 1.1708984375k . file
File Type: zip active.zip (1,004 Bytes, 48 views)
Aironxp is offline
post #742 of 3494 Old 04-28-2010, 10:45 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by Aironxp View Post
HY all..
The realtime EDID is just fine. It has 2 AUDIO SADs: 6-AC3 and 2-LPCM. Whatever your problem is, it's not EDID related. Also, I'm not sure that the ION chipset can be EDID overriden.
Tulli is offline
post #743 of 3494 Old 04-29-2010, 12:23 AM
Aironxp's Avatar
Yes it works on ION..
But i dont now why its not work for me ....
Aironxp is offline
post #744 of 3494 Old 04-29-2010, 04:13 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
What is exactly your issue and why do you need an EDID override?
Tulli is offline
post #745 of 3494 Old 04-29-2010, 07:41 AM
Aironxp's Avatar
Ich cant here AC3 over my TV..
I dont understand why the realtime shows Ac3 but the active not...
So its not a Problem with the EDID ?
This is not Lost ?:
Channel configuration.... 5.1
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Sorry for my bad englisch
Aironxp is offline
post #746 of 3494 Old 04-29-2010, 07:52 AM
p750mmx's Avatar
Maybe by asking you direct questions your setup will be clearer.
You have your POV ION connected directly on your TV, not on a separate audio receiver, and with HDMI only?
What software are you using for video playback (which OS and media_player) and do you have your OS configured that audio must be played back trough HDMI?
p750mmx is offline
post #747 of 3494 Old 04-29-2010, 08:03 AM
Aironxp's Avatar
I have Windows 7 32bit with Windows Mediacenter, Ac3-Filter...
My HTPC is directly connectet over HDMI to my LGPK760 and prom there to my Harman-Kardon with toslink
The Sound comes only in Stereo.. No Dolby..
I cant configure Dolby when i klick on the Symbol of the HDMI Device..
Theres only Option to configure Stereo...
I Selected my HDMI Device is my Standard Sound Device
Aironxp is offline
post #748 of 3494 Old 04-29-2010, 08:05 AM
vladd's Avatar
Liked: 39
TV's normally only support AC-3 audio through the tuner. I have never seen one that supports AC-3 on an HDMI input.
vladd is offline
post #749 of 3494 Old 04-29-2010, 08:29 AM
p750mmx's Avatar
Why don't you connect the POV by toslink audio direct to the amp and let AC3/DTS audio run that way?
p750mmx is offline
post #750 of 3494 Old 04-29-2010, 08:32 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
This is not Lost ?:
The registry-active is only 128-bytes so you won't see the audio block there, which is in the next 128-bytes (extension block).
Tulli is offline
Reply Home Theater Computers
