EDID Override Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #61 of 3494 Old 12-06-2008, 11:19 AM
devoz's Avatar
Two months of waiting...for AMD ATI to do something!
and now thanks to people in this AVS forum a solution!
Another reason to support it...its great!
so to all those Onkyo SR606 owners ...a solution!?
devoz is offline
post #62 of 3494 Old 12-06-2008, 11:46 AM
bingobill's Avatar
Great news devoz, I would also like to thank RandomFoe, I studied the changes he made to your .inf and now I understand exactly which blocks to use from each of the 2 raw datas.
bingobill is offline
post #63 of 3494 Old 12-06-2008, 11:52 AM
kemac's Avatar
Quoted: 91 Post(s)
Liked: 74
Not sure if you knew but the 4XXX cards worked fine on the 606 prior to this workaround but only on HDMI port 1, the other ports should work now with this workaround.
The 806 didn't work with any ports prior to this workaround without using a DVI-Detective but know I can confirm it does work with this workaround.
kemac is online now
post #64 of 3494 Old 12-06-2008, 12:24 PM
devoz's Avatar
Yes kemac...I already have my main HTPC working with an ASUS 4650 via HDMI Port 1 on my Onkyo SR606.
This workaround hopefully will allow the rest of the ports to work(well it does for me...yahoo!) and also any problem Onkyo receivers to work as well!
It would be good to have success feedback regarding other Receiver brands as well?!
So tell us about any successes...
devoz is offline
post #65 of 3494 Old 12-06-2008, 01:48 PM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
I was considering an HDMI receiver known to need this fix (the Denon AVR1909) and a 4850 card. However, I've got 8GB of RAM and am therefore running in Vista x64. Does this work there, or does the mandatory driver signing stop this from working?
XBL/Steam: JHoff80
jhoff80 is offline
post #66 of 3494 Old 12-06-2008, 02:17 PM
bokis's Avatar
You can put the Onkyo 576 on the list of working avr´s
I´m on a Gigabyte 780g mb back tomorrow need to reinstall the drivers and then I put up the Edid, bedtime in Sweden AND THANK you guys
bokis is offline
post #67 of 3494 Old 12-06-2008, 02:44 PM
bugme's Avatar
I have the HDMI connected (Radeon 4870) to my 42" Panasonic plasma TV. I'm trying to get the sound working properly, and was directed to this thread. I don't have any receivers. What do I do about the receiver part?
bugme is offline
post #68 of 3494 Old 12-06-2008, 03:47 PM - Thread Starter
RandomFoe's Avatar
bugme,
This workaround may not be required in your case. Is your tv seen as a HDMI device in CCC?
RandomFoe is offline
post #69 of 3494 Old 12-06-2008, 04:13 PM
bugme's Avatar
Originally Posted by RandomFoe View Post
bugme,
OK here's my problem:
Vista Ultimate 64-bit
ASUS Rampage Formula motherboard
Catalyst 8.11
ATI Radeon 4870
I have two monitors connected to my graphics card. One is a 20" LCD, connected via DVI; the other is a 42" plasma TV, connected via HDMI (using the included DVI->HDMI adapter that came with the graphics card). The 20" LCD is my primary monitor, and the 42" plasma TV is my secondary monitor that I usually keep turned off when I'm using my computer; I only use it when I want to play games or watch video.
If I turn on my computer with the 42" TV already on, then the HDMI audio seems to work just fine. In CCC, it is detected as HDMI.
However, if I turn on my computer without the TV on, OR if I turn the TV off at any time (and then on again), it is then detected as DVI in CCC and I get no sound.
Also, I do have Realtek's ATI HDMI audio driver installed. It doesn't seem to make a difference.
bugme is offline
post #70 of 3494 Old 12-06-2008, 05:18 PM - Thread Starter
RandomFoe's Avatar
bugme
I think the process would still be the same. However instead of entering information from a receiver you can enter the second block from the tv (this holds the audio information).
If you are using a moninfo report lines 1-4 of raw data is the first block & lines 5-8 the second block.
It would be interesting to see if this helps, I have read others having this problem but have not had it myself before or after using the override method.
post #71 of 3494 Old 12-06-2008, 05:40 PM
bugme's Avatar
Will the moninfo report be different depending on whether it's currently being detected as HDMI or DVI? If so, should I restart my computer (with the TV on) so that it is detected as HDMI?
Also, by lines 1-4 and 5-8 you're talking about here, right? This is the data for my TV (currently being detected as DVI):
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,34,A9,62,A0,71,72,03,84,19,11,01,03, 80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
......................... 17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
......................... 45,00,98,06,32,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, 98,06,32,00,00,9E,00,00,00,FC,00,50,
......................... 41,4E,41,53,4F,4E,49,43,2D,54,56,0A,00,00,00,FD,00,3B,3D,0F, 44,0F,00,0A,20,20,20,20,20,20,01,9D,
......................... 02,03,18,71,48,90,05,04,03,02,07,06,01,23,09,07,01,66,03,0C, 00,10,00,80,01,1D,00,72,51,D0,1E,20,
......................... 6E,28,55,00,98,06,32,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E, 96,00,98,06,32,00,00,18,8C,0A,D0,8A,
......................... 20,E0,2D,10,10,3E,96,00,B2,06,22,00,00,18,8C,0A,A0,14,51,F0, 16,00,26,7C,43,00,98,06,32,00,00,98,
......................... 8C,0A,A0,14,51,F0,16,00,26,7C,43,00,B2,06,22,00,00,98,00,00, 00,00,00,00,00,00,00,00,00,00,00,9B
I did notice that when I look at my monitor (not the TV), there are only four lines.
EDIT: Here's the full report:
Code:
Monitor
  Model name............... PANASONIC-TV
  Manufacturer............. Panasonic
  Plug and Play ID......... MEIA062
  Serial number............ -2080148879
  Manufacture date......... 2007, ISO week 25
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. Undefined or variable
  Power management......... Not supported
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2.20
  Red chromaticity......... Rx 0.640 - Ry 0.345
  Green chromaticity....... Gx 0.291 - Gy 0.635
  Blue chromaticity........ Bx 0.163 - By 0.093
  White point (default).... Wx 0.288 - Wy 0.296
  Additional descriptors... None
Timing characteristics
  Horizontal scan range.... 15-68kHz
  Vertical scan range...... 59-61Hz
  Video bandwidth.......... 150MHz
  CVT standard............. Not supported
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #1....... 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
EIA/CEA-861 Information
  Revision number.......... 3
  DTV underscan............ Not supported
  Basic audio.............. Supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 1
  Detailed timing #1....... 1280x720p at 60Hz (16:9)
    Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
  Detailed timing #2....... 720x480p at 60Hz (16:9)
    Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
  Detailed timing #3....... 720x480p at 60Hz (4:3)
  Detailed timing #4....... 1440x480i at 60Hz (16:9)
    Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
  Detailed timing #5....... 1440x480i at 60Hz (4:3)
CE video data (timings supported)
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1)
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  480p at  60Hz - EDTV (4:3, 8:9)
     720 x  480i at  60Hz - Doublescan (16:9, 32:27)
     720 x  480i at  60Hz - Doublescan (4:3, 8:9)
     640 x  480p at  60Hz - Default (4:3, 1:1)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
  LPCM    2-channel, 16-bit              at 32/44/48 kHz
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 0.1.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... No
  Supports 30bpp........... No
  Supports YCbCr 4:4:4..... No
  Supports dual-link DVI... No
  Maximum TMDS clock....... 165MHz
Report information
  Date generated........... 12/6/2008
  Software revision........ 2.11.0.760
  Raw data................. 00,FF,FF,FF,FF,FF,FF,00,34,A9,62,A0,71,72,03,84,19,11,01,03,80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
  ......................... 17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
  ......................... 45,00,98,06,32,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,98,06,32,00,00,9E,00,00,00,FC,00,50,
  ......................... 41,4E,41,53,4F,4E,49,43,2D,54,56,0A,00,00,00,FD,00,3B,3D,0F,44,0F,00,0A,20,20,20,20,20,20,01,9D,
  ......................... 02,03,18,71,48,90,05,04,03,02,07,06,01,23,09,07,01,66,03,0C,00,10,00,80,01,1D,00,72,51,D0,1E,20,
  ......................... 6E,28,55,00,98,06,32,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,98,06,32,00,00,18,8C,0A,D0,8A,
  ......................... 20,E0,2D,10,10,3E,96,00,B2,06,22,00,00,18,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,98,06,32,00,00,98,
  ......................... 8C,0A,A0,14,51,F0,16,00,26,7C,43,00,B2,06,22,00,00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,9B
bugme is offline
post #72 of 3494 Old 12-06-2008, 05:53 PM - Thread Starter
RandomFoe's Avatar
Yeah give the data you posted a go.
Yep thats where I split it up into blocks, it will need the prefix 0x added to each value and should end up being 1 clean line for each block.
post #73 of 3494 Old 12-06-2008, 06:24 PM
bugme's Avatar
Doesn't seem to work. I changed the .inf file so that the part looks like this:
Code:
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x34,0xA9,0x62,0xA0,0x71,0x72,0x03,0x84,0x19,0x11,0x01,0x03,0x80,0x00,0x00,0x78,0x0A,0xDA,0xFF,0xA3,0x58,0x4A,0xA2,0x29,0x17,0x49,0x4B,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x98,0x06,0x32,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0x98,0x06,0x32,0x00,0x00,0x9E,0x00,0x00,0x00,0xFC,0x00,0x50,0x41,0x4E,0x41,0x53,0x4F,0x4E,0x49,0x43,0x2D,0x54,0x56,0x0A,0x00,0x00,0x00,0xFD,0x00,0x3B,0x3D,0x0F,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x9D
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x18,0x71,0x48,0x90,0x05,0x04,0x03,0x02,0x07,0x06,0x01,0x23,0x09,0x07,0x01,0x66,0x03,0x0C,0x00,0x10,0x00,0x80,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0x98,0x06,0x32,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0x98,0x06,0x32,0x00,0x00,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xB2,0x06,0x22,0x00,0x00,0x18,0x8C,0x0A,0xA0,0x14,0x51,0xF0,0x16,0x00,0x26,0x7C,0x43,0x00,0x98,0x06,0x32,0x00,0x00,0x98,0x8C,0x0A,0xA0,0x14,0x51,0xF0,0x16,0x00,0x26,0x7C,0x43,0x00,0xB2,0x06,0x22,0x00,0x00,0x98,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9B
Then to went to install it. I noticed that, after the part with "Have Disk..", there are two options for the EDID Override (they both say the same thing). I chose the first one, installed it, restarted my computer, turned the TV off and on again, and the problem of no audio is still there (again, it went from being detected as HDMI to being detected as DVI). Then I tried the second option in the Have Disk part, restarted, etc., no change.
Anyways, thanks a ton for the help so far.
bugme is offline
post #74 of 3494 Old 12-06-2008, 06:30 PM - Thread Starter
RandomFoe's Avatar
ok, I had this problem when i first started to play around with things I got around it by removing one of the inf files to a different location so you only have the file you want to use in options.
post #75 of 3494 Old 12-06-2008, 06:34 PM
bugme's Avatar
Ah, I see. I had the original (before I edited it with my TV's info) on my desktop as well. That would explain why the first time when I restarted my computer it was detected as a Samsung instead of a Panasonic.
Still, it's using the correct driver now and still not working.
bugme is offline
post #76 of 3494 Old 12-06-2008, 08:37 PM
devoz's Avatar
bugme...
From what I have read you dont have a receiver or external speakers connected?
So when you have your 42inch TV connected you are using the 42inch TV's speakers to play sound?
The sound is reaching your TV because you have the special DVI/HDMI adapter connected.
Your 20inch is connected via a DVI connection. Does your 20inch monitor have speakers?
This DVI connection will not allow sound to work even if your 20inch does have speakers.
Unless you have a special dongle which allows your video card to pass audio to your 20inch monitor(assuming it has speakers), then you wont get sound.
devoz is offline
post #77 of 3494 Old 12-06-2008, 08:40 PM
bugme's Avatar
bugme...
I'm not trying to get sound to my 20inch. That's simply my primary monitor.
I'm trying to get sound to STAY on my TV (I AM using the DVI->HDMI dongle that carries sound). My problem is that if I turn my TV off at any time, then turn it back on, my computer will refuse to carry sound to it unless I restart my computer.
bugme is offline
post #78 of 3494 Old 12-06-2008, 09:01 PM
devoz's Avatar
bugme... just wanted to make sure of a few points.
So if you can get a good .inf file or driver for your 42inch TV from this process
that RandomFoe has written about(and is helping you with)....and then instal it as the 42inch TV driver, it should be retained.
So that each time the 42inch TV is seen by your computer it should use that 42 inch TV new driver and should allow sound to work.
Hopefully you will have as much success as I have, with the connection to my Onkyo receiver! Goodluck!
devoz is offline
post #79 of 3494 Old 12-06-2008, 10:34 PM
bugme's Avatar
I might be doing something wrong. What's the driver supposed to do, exactly?
bugme is offline
post #80 of 3494 Old 12-06-2008, 11:23 PM
tmsmith124's Avatar
Well I've about had it. I've been trying and trying and still can't get any sound at all.
Currently I am trying to get sound from my 4870 to my Denon 1909, hooked up to a Samsung Ln40a650. I've tried everything in the thread with no luck.
Any help or suggestion would be appreciated. I will be the first to admit that the audio stuff is new to me, but computers maybe my thing.
Replaced both of the original post with the following:
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4C,0x2D,0x57 ,0x03,0x00,0x00,0x00,0x00,0x22,0x11,0x01,0x03,0x80,0x10,0x09 ,0x78,0x0A,0x1D,0xED,0xA7,0x53,0x34,0xAC,0x25,0x12,0x47,0x4A ,0x21,0x08,0x00,0x81,0x80,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71 ,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA0,0x5A,0x00,0x00,0x00 ,0x1E,0x66,0x21,0x50,0xB0,0x51,0x00,0x1B,0x30,0x40,0x70,0x36 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00 ,0x17,0x3D,0x1A,0x44,0x17,0x00,0x0A,0x20,0x20,0x20,0x20,0x20 ,0x20,0x00,0x00,0x00,0xFC,0x00,0x53,0x41,0x4D,0x53,0x55,0x4E ,0x47,0x0A,0x20,0x20,0x20,0x20,0x20,0x01,0xBC,0x02,0x03,0x22 ,0xF1,0x46,0x90,0x04,0x05,0x03,0x20,0x22,0x23,0x09,0x07,0x07 ,0x83,0x01,0x00,0x00,0xE2,0x00,0x0F,0xE3,0x05,0x03,0x01,0x67 ,0x03,0x0C,0x00,0x20,0x00,0xB8,0x2D,0x01,0x1D,0x00,0x72,0x51 ,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xA0,0x5A,0x00,0x00,0x00 ,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x8C,0x0A,0xD0,0x8A,0x20 ,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x5A,0x00,0x00,0x00 ,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0xDF
HKR,EDID_OVERRIDE,"1",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x11,0xEE,0x12 ,0x00,0x01,0x01,0x01,0x01,0x00,0x12,0x01,0x03,0x80,0x10,0x09 ,0x78,0x0A,0x1D,0xED,0xA7,0x53,0x34,0xAC,0x25,0x12,0x47,0x4A ,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71 ,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA0,0x5A,0x00,0x00,0x00 ,0x1E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00 ,0x17,0x3D,0x1A,0x44,0x17,0x00,0x0A,0x20,0x20,0x20,0x20,0x20 ,0x20,0x00,0x00,0x00,0xFC,0x00,0x44,0x45,0x4E,0x4F,0x4E,0x2D ,0x41,0x56,0x41,0x4D,0x50,0x0A,0x20,0x01,0x5A,0x02,0x03,0x33 ,0x71,0x48,0x90,0x04,0x05,0x03,0x20,0x22,0x0F,0x24,0x35,0x0F ,0x7F,0x07,0x3D,0x1E,0xC0,0x15,0x07,0x50,0x5F,0x7E,0x01,0x57 ,0x06,0x00,0x65,0x7E,0x00,0x67,0x1E,0x00,0x83,0x5F,0x00,0x00 ,0xE3,0x05,0x03,0x01,0x67,0x03,0x0C,0x00,0x13,0x00,0xB8,0x2D ,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00 ,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x8C,0x0A,0xD0,0x8A,0x20,0xE0 ,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x5A,0x00,0x00,0x00,0x18 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0xF1
Supposedly corresponding with the models of my TV and receiver using the previous app mentioned.
I have also tried Realtek with no luck. Someone shine some light on this as its going to bug me until I get some sound! Even at this point, stero would sound good.
tmsmith124 is offline
post #81 of 3494 Old 12-06-2008, 11:43 PM - Thread Starter
RandomFoe's Avatar
Have a try using to info below, it will need to be cleaned up in the inf file so it only uses 1 line each. it looks like you might be trying to uses to much information for each block.
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xF F,0x00,0x4C,0x2D,0x57,0x03,0x00,0x00,0x00,0x00,0x22,0x11,0x0 1,0x03,0x80,0x10,0x09,0x78,0x0A,0x1D,0xED,0xA7,0x53,0x34,0xA C,0x25,0x12,0x47,0x4A,0x21,0x08,0x00,0x81,0x80,0x01,0x01,0x0 1,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x0 2,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA 0,0x5A,0x00,0x00,0x00,0x1E,0x66,0x21,0x50,0xB0,0x51,0x00,0x1 B,0x30,0x40,0x70,0x36,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x0 0,0x00,0x00,0xFD,0x00,0x17,0x3D,0x1A,0x44,0x17,0x00,0x0A,0x2 0,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x53,0x4 1,0x4D,0x53,0x55,0x4E,0x47,0x0A,0x20,0x20,0x20,0x20,0x20,0x0 1,0xBC
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x33,0x71,0x48,0x90,0x04,0x05,0x03,0x20,0x2 2,0x0F,0x24,0x35,0x0F,0x7F,0x07,0x3D,0x1E,0xC0,0x15,0x07,0x5 0,0x5F,0x7E,0x01,0x57,0x06,0x00,0x65,0x7E,0x00,0x67,0x1E,0x0 0,0x83,0x5F,0x00,0x00,0xE3,0x05,0x03,0x01,0x67,0x03,0x0C,0x0 0,0x13,0x00,0xB8,0x2D,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x2 0,0x58,0x2C,0x25,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x8C,0x0 A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x5 A,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF1
post #82 of 3494 Old 12-07-2008, 07:16 AM
kemac's Avatar
Quoted: 91 Post(s)
Liked: 74
You might want to give a a program called HDMIon a try to see if that helps, if forces a reread of the EDID. I have not tried it yet but I ran into a condition yesterday waking from standby where I had no Video/sound and had to reboot. I need to do some more testing when I have time...
kemac is online now
post #83 of 3494 Old 12-07-2008, 08:33 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Thanks RandomFoe. I finally got HDMI audio from Radeon HD 4xxx via any of IN2-IN4 of ONKYO 606.
I found 24Hz was lost, but it's not a big problem because I can add it manually in CCC. Perhaps it's related to the lost second block?
renethx is offline
post #84 of 3494 Old 12-07-2008, 08:42 AM
bokis's Avatar
Philips 9551 (L06HD v1) Crt
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x41,0x0C,0x51,0x95, 0x01,0x01,0x01,0x01,0x06,0x10,0x01,0x03,0x80,0x42,0x25,0x78, 0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,
0x12,0x48,0x4C,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D, 0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,
0x25,0x80,0x94,0x72,0x21,0x00,0x00,0x9E,0x01,0x1D,0x00,0x72, 0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0x94,0x72,0x21,0x00, 0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x31,
0x3D,0x1C,0x2E,0x08,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20, 0x00,0x00,0x00,0xFC,0x00,0x4C,0x30,0x36,0x48,0x44,0x20,0x76, 0x31,0x20,0x31,0x36,0x3A,0x39,0x01,0x29
Onkyo 576
0x02,0x03,0x35,0x72,0x55,0x85,0x04,0x03,0x02,0x0E,0x0F,0x07, 0x23,0x24,0x10,0x94,0x13,0x12,0x11,0x1D,0x1E,0x16,0x25,0x26, 0x01,0x1F,0x2F,0x09,0x7F,0x07,0x0F,0x7F,
0x07,0x17,0x07,0x50,0x3F,0x06,0xC0,0x57,0x06,0x00,0x83,0x4F, 0x00,0x00,0x66,0x03,0x0C,0x00,0x10,0x00,0x80,0x8C,0x0A,0xD0, 0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,
0x00,0xC4,0x8E,0x21,0x00,0x00,0x18,0x8C,0x0A,0xD0,0x90,0x20, 0x40,0x31,0x20,0x0C,0x40,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00, 0x18,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,
0x20,0x6E,0x28,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x01, 0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xC4, 0x8E,0x21,0x00,0x00,0x1E,0x00,0x00,0x5C
Why is thier a diffrens between Hdmi and the optical output, I reinstalled 2.09Hdmi Audio driver from Realtek and the latest 2.10 HD audio driver after a good cleaning this is on a Gigabyte HD3200 mb
bokis is offline
post #85 of 3494 Old 12-07-2008, 08:55 AM
Mikl1984's Avatar
Quoted: 18 Post(s)
24p live in second 128 bytes.
You may try to make perfect EDID (all video from TV, audio + CEC address from AVR).
Don't forget to recalculate control sum.
Mikl1984 is offline
post #86 of 3494 Old 12-07-2008, 09:57 AM
bingobill's Avatar
This fix here solved the same problem for me Click me
post #87 of 3494 Old 12-07-2008, 01:33 PM
bugme's Avatar
This fixed it! It also fixed the main monitor going crazy problem I had as well (only lasted a few seconds though, so that it wasn't a big annoyance to me.)
Thank you so much!
bugme is offline
post #88 of 3494 Old 12-07-2008, 01:49 PM
bingobill's Avatar
Thank you so much!
Cool don't you just love these forums
post #89 of 3494 Old 12-07-2008, 06:10 PM
skidoo1's Avatar
As I said earlier thanks to RandomFoe, I've got my setup working fine.
But on reading this forum, I've been pondering a question.
How to put it, I was never really worrying about what the HTPC thought of the TV EDID. I'm happy to be wrong, just wondering. Isn't it really the business of the receiver to know the EDID of the TV, why should the HTPC care about the TV EDID, since the HTPC is connected to the receiver, so it really only needs to know the EDID or more correctly the E-EDID of the receiver.
As long as the HTPC knows all the E_EDID info of the receiver, it can output any audio format and any video format that the receiver can cope with, what happens after that is a 'negotiation' between the receiver and the TV. My assumption is that the receiver enquires the EDID of the TV and then outputs the video in a format the TV can interpret.
Isn't that how it works (just asking), this only makes sense of course if the receiver can convert the video format coming in from the HTPC into a format that the TV can interpret, my receiver does this (I think anyway).
From a nerd point of view (ie my point of view ) I think of the receiver as a server, it takes the data in (any it can understand, by telling all the upstream devices ie HTPC what it can receive, or the XBOX or PS3 or whatever) then it sends that data out (downstream) in any format the receiving device (ie the TV) can understand.
Anyway just wondering, since my understanding is the HTPC doesn't have to care what the TV can interpret, that's the receivers problem. The HTPC only has to care what the receiver can interpret. So my thoughts are that the HTPC only needs to E-EDID of the receiver and nothing else.
just thoughts
ps of course this only makes sense if it's an AV receiver (ie audio and video)
skidoo1 is offline
post #90 of 3494 Old 12-07-2008, 06:31 PM
kemac's Avatar
Quoted: 91 Post(s)
Liked: 74
Onkyo's have the option of passing the audio through to the TV via HDMI si I assume others do as well...
kemac is online now
Reply Home Theater Computers
