EDID Override Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #901 of 3494 Old 08-01-2010, 08:32 AM
Micke O's Avatar
Originally Posted by Tulli View Post
According to the 2807 EDID it has LPCM/2-channel up to 192khZ & LPCM/6-channel up to 96kHz capabilities.
(153-156) Audio Data Block
Audio Format #1 : LPCM, 8-Channel, 24-Bit, 20-Bit, 16-Bit
Sampling Frequency : 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
(157-160) Audio Data Block
Audio Format #1 : LPCM, 2-Channel, 24-Bit, 20-Bit, 16-Bit
Sampling Frequency : 192 kHz, 176.4 kHz, 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
(161-164) Audio Data Block
Audio Format #1 : DTS, 6-Channel, 1536 k Max bit rate
(165-168) Audio Data Block
Audio Format #1 : AC-3, 6-Channel, 648 k Max bit rate
FWIW, here's the modded EDID + 192khz for LPCM/6-channel
GREAT! Thanks a lot!!!
Edit: I'm, still only able to get 2CH (the AVR reports 2CH in and that's what I hear):-(
# I've set PDVD 9 Ultra to output PCM via HDMI.
# PDVD 9 reports the correct format output (LPCM in various flavours (bitrates, sampling freq. and #CH)) and not "compressed" or so as it does when using SPDIF.
# Tried different movies/concerts and different sound tracks on each.
# Tried to turn off the "auto" setting (soundformats) on the AVR
# Verified in the device manager that the override is installed and in use
Does anyone have any other ideas?
Micke O is offline
post #902 of 3494 Old 08-01-2010, 12:40 PM
erl
erl's Avatar
Tulli,
i was wondering if you could help me out as well... my HTPC was functioning perfectly up until the last few months, then i began to get random picture/system freezes and lost HDMI handshake after turning off the tv/receiver. at the time, i was using an onboard ATI HD4200 from a Windows 7 Home machine with the Xonar HDAV Slim and a Gefen HDMI Detective Plus (ATI > HDAV > Yamaha RX-V2700 > HDMI Detective > Pioneer PDP-5080HD). i removed the HDAV, but things haven't really gotten better (the machine runs fine as long as everything is left on... if i turn off the tv, i lose handshake; if i turn off the tv and receiver, the machine freezes). i've tried changing the arrangement of the HDMI Detective, but it will only pass signal if it is between the receiver and the tv.
i'm not sure if it was a Windows update or the change in Catalyst drivers, but now trying to keep my HTPC on with out actively using it has become and exercise in frustration.
reading this thread has made me wonder if a EDID override will help. i followed your directions on capturing the EDID data for both the Pioneer and the Yamaha and have attached both in the hope that you would be able to produce a custom .inf file that i could try. if you have the time, i would greatly appreciate the help!
pioneer_yamaha_infs.zip 2.41015625k . file
erl is offline
post #903 of 3494 Old 08-01-2010, 01:59 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Is the DENON HDMI set to "AMP" (no tv audio passthrough)?
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #904 of 3494 Old 08-01-2010, 03:13 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by erl View Post
Tulli,
Here's your mod.
Pioneer PDP-5080HD - YAMAHA RX-V2700.zip 1.2421875k . file
File Type: zip Pioneer PDP-5080HD - YAMAHA RX-V2700.zip (1.2 KB, 46 views)
Tulli is offline
post #905 of 3494 Old 08-01-2010, 08:53 PM
erl
erl's Avatar
Tulli,
many thanks!
i will post the results of your efforts once i've made the appropriate changes...
erl is offline
post #906 of 3494 Old 08-02-2010, 01:33 AM
Micke O's Avatar
Yes, I never use the TV's built-in sound.
Micke O is offline
post #907 of 3494 Old 08-11-2010, 09:13 AM
wyerd's Avatar
Hi Tulli,
You kindly created an override file for me a month or so ago, but I'm still having problems. My setup is:-
PC running 7MC & ATI 5450(10.7 cats) -> Onkyo TX-NR807 Receiver via HDMI -> Panasonic TH50PF20 Plasma via HDMI at 1080p
The problem I'm getting is:-
When I power on the receiver & plasma, every so often 7MC is displayed in what appears to be a 1024x768 resolution, even though going through the Media Center setup it still says 1080p. If I exit from 7MC, the desktop is still shown at 1080p and I can then run 7MC again without any problems for 5 or 6 days turning off (into standby) and on the receiver & plasma. Once I've had the desktop change to 1024x768 as well as 7MC and the overscan back to 15%....I hadn't changed it back.
I've installed RealVMC to see what is happening when I put the plasma & receiver into standby. It appears that when the receiver is put into standby, the Monitor device "OnkyoTX-NR807 (EDID Override)" disappears from the device list. When this happens, the resolution then changes to 1024x768 60hz.....every time. Once the receiver is brought out of standby, the "Onkyo TX-NR807 (EDID Override)" Monitor reappears in the list and the resolution is then set back to 1080p.............but this doesn't always happen in 7MC.
Is there anyway that I can set to stop this from happening, or is the Gefen HDMI Detective at over $120 the only answer?
Many thanks for any help that you can give.
wyerd is offline
post #908 of 3494 Old 08-15-2010, 07:53 PM
rmclaren's Avatar
Anyone else having problems with softMCCS? It was working yesterday, but today on two machines it brings up error messages, then closes when clicked.
The first message says that you have the latest version, the next message that the program has expired.
rmclaren is offline
post #909 of 3494 Old 08-22-2010, 03:09 AM
KOROR's Avatar
I am having trouple wrapping my head around this, my setup is as follows:
Asrock ION 330-BD running Windows 7 Ultimate 64-bit (dualboot with Linux Ubuntu option)
connected with HDMI only directly to my
Phillips 42PFL5604H LCD
I am getting no sound whatsoever, having tried all sorts driver updates, I stumpled upon this thread.
Will I be able to use this EDID workaround on my setuo or is it only usable for people with standalone sound receivers?
God I hope this can also work for me, the only way I've been able to get sound over HDMI is if I boot into Linux instead of Windows, but really sucking at Linux does that I really need to get the sound working in Windows.
KOROR is offline
post #910 of 3494 Old 08-22-2010, 06:38 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Yes, you can use it on your setup (AFAIK the ION accepts an EDID override). Capture the real-time Philips EDID with latest version of Moninfo. Make sure your Windows user is an administrator or, if UAC is activated run moninfo as admin. It's possible that the EDID doesn't have an extension block (where the audio descriptor is stored).
It it has the extension block (2nd row of 128 hex numbers on moninfo .inf file) you can use that same .inf file to do the override. Otherwise it will need merging with an extension block with an audio descriptor.
Tulli is offline
post #911 of 3494 Old 08-22-2010, 10:02 AM
KOROR's Avatar
Thanks for a very fast reply Tulli
This is the info I get from Moninfo, I'm guessing the second row of hex numbers isn't there?
How do I proceed with "Otherwise it will need merging with an extension block with an audio descriptor."
Detailed timing #4....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Video latency (p)........ 31ms
Audio latency (p)........ 31ms
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 030C001000382D801010
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
Report information
Date generated........... 22-08-2010
Software revision........ 2.52.0.857
Data source.............. Real-time 0x0031
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,41,0C,00,00,01,01,01,01,08,13,01,03, 80,80,48,78,0A,E6,92,A3,54,4A,99,26,
0F,4A,4C,21,08,00,8B,C0,81,80,A9,40,01,01,01,01,01,01,01,01, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,00,D0,52,00,00,1E,02,3A,80,D0,72,38,2D,40,10,2C,45,80, 00,D0,52,00,00,1E,00,00,00,FC,00,50,
68,69,6C,69,70,73,20,46,54,56,0A,20,00,00,00,FD,00,30,3E,0F, 46,0F,00,0A,20,20,20,20,20,20,01,C7,
02,03,31,F1,52,1F,10,20,21,22,14,05,13,04,12,03,11,02,16,07, 15,06,01,26,09,1F,07,15,07,50,83,01,
00,00,6A,03,0C,00,10,00,38,2D,80,10,10,E3,05,03,01,01,1D,80, 3E,73,38,2D,40,7E,2C,45,80,00,D0,52,
00,00,1E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,00,D0,52,00,00, 9E,01,1D,00,BC,52,D0,1E,20,B8,28,55,
40,00,D0,52,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,00, D0,52,00,00,9E,00,00,00,00,00,00,5E
KOROR is offline
post #912 of 3494 Old 08-22-2010, 10:30 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Yeah, it's there. Audio descriptor shows LPCM 2-channel and AC-3 6-Channel capabilities:
(151-157) Audio Data Block
Audio Format #2 : AC-3, 6-Channel, 640 k Max bit rate
Sampling Frequency : 48 kHz, 44.1 kHz, 32 kHz
They should appear as available formats on the audio device properties. Make sure they show up there. If not then try to override the EDID with the same .inf that you've captured.
Tulli is offline
post #913 of 3494 Old 08-22-2010, 11:21 AM
KOROR's Avatar
Sorry for being daft when it comes to this, but when looking under NVIDIA HDMI OUT in the playback devices I see these options, I tried them all, still no sound:
What am I doing wrong?
KOROR is offline
post #914 of 3494 Old 08-22-2010, 01:23 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
No, look at the "Supported Formats" tab above. It will show the audio capabilities of the HDMI audio devices detected by Windows. If it corresponds to the EDID info, then the problem is not EDID related.
Tulli is offline
post #915 of 3494 Old 08-22-2010, 01:38 PM
KOROR's Avatar
Here is a screenshot of supported format tab:
KOROR is offline
post #916 of 3494 Old 08-22-2010, 02:00 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, except for 88.2kHz not being supported, which could be due to a driver limitation, there's no EDID detection problem, so no need of an EDID override.
Your problem should be driver related. Do you have the latest version installed?
Tulli is offline
post #917 of 3494 Old 08-22-2010, 02:17 PM
KOROR's Avatar
I found this forum post:
http://www.ionbased.com/forum/topic/...-hdmi-no-sound
and have tried this:
Hie
I finally found a issue for this config :
- Windows Seven Ultimate
- ASRock Ion 330
- Phillips LCD TV
1. Windows Install
2. VIA HD Audio Driver Install for Win7 (from ASRock Website) + Restart
3. HDMI Audio Driver Install for Win7 (from ASRock Website)
4. All-in-one NVidia Install for Win7 (from ASRock Website) + Restart
5. NVidia GeForce/Ion Driver Release 191 not beta !! (from NVidia Website) + Restart
http://www.nvidia.com/object/win7_wi...1.07_whql.html
and I finally have sound with HDMI support ...it's a great day !!
Except the last driver I used one for 64 bit Windows.
God this sucks, there must be a way to get this working :-(
This was actually in the forum post I linked to, is this a possibility?
since NVIDIA disables sound when detecting a Philips TV, Win 7 must be tricked in thinking another brand of TV is attached. This can be done with "EDID override", i.e. supplying a monitor.inf file with video & audio information from another TV or monitor. avsforum has a lengthy thread about this, just google. Works for me, with the usual problems though (first seconds of sound missing, video blank/reappearing when sound kicks in, no sound when Win 7 disables monitor).
KOROR is offline
post #918 of 3494 Old 08-22-2010, 03:03 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Unbelievable. Anyway I changed the Philips descriptors of the original EDID to Samsung's, so hope it'll work now. You should have no video issues as it's the exact original EDID of your Philips TV but with Samsung ID descriptors.
See instructions on link in my sig. for proper installation.
Phillips 42PFL5604H_MOD.zip 1.1943359375k . file
Tulli is offline
post #919 of 3494 Old 08-22-2010, 04:06 PM
KOROR's Avatar
Thx Tulli, will try tomorrow, my bed is calling :-)
KOROR is offline
post #920 of 3494 Old 08-23-2010, 02:05 AM
robin64's Avatar
Hello
First, sorry for my english, it's hard for me to learn technics and language at the same moment !!!
I'm using seven 64 bits premium, whit graphic card HD 5450
My receiver is ONKYO SR 606 whit en 5.1 speakers system
And SAMSUNG LE37S67BD TV LCD
My problem first was the bistream dont work normaly. I works only when the TV was out...
After using override with a ONKYO SR 606 data AND Samsung Data, it was a same.
It is only when I brought out the information of the amplifier That the systeme finally worked...
And now, i can use my PCHD normaly with bitstream song.
I someone use this samsung, i join mi personal file
I want to thank all the persons having participated in this thread which enormously helped me...
Thanks a lot
Fred
SAMSUNG LE37S67BD.zip 0.98828125k . file
File Type: zip SAMSUNG LE37S67BD.zip (1,012 Bytes, 36 views)
robin64 is offline
post #921 of 3494 Old 08-23-2010, 05:24 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
The problem is your 606. See here.
Tulli is offline
post #922 of 3494 Old 08-23-2010, 10:16 AM
KOROR's Avatar
I tried installing the file you posted Tulli, to no luck, there is still no sound :-(
The filename was Samsung, but I think the drivername was Onkyo, is this correct?
I really really appreciate you taking your time to helping me out and really would be grateful if my sound issue could be solved. But if you're all out of ideas I would understand? :-(
EDIT: The HDMI option does no longer appear in the sound manager?
KOROR is offline
post #923 of 3494 Old 08-23-2010, 10:53 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Go to Device Manager, and under the Monitors tab there should be a Monitor labeled:
SAMSUNG (EDID Override)
No way for an Onkyo description as I took your Philips EDID and only changed the Monitor descriptors.
Maybe you need to clean up any Monitor drivers leftovers in your system. Follow the uninstall section from link in my sig. to remove any monitor drivers leftovers. The install the EDID Override again, reboot and try.
Tulli is offline
post #924 of 3494 Old 08-23-2010, 10:54 AM
robin64's Avatar
Thanks Tulli answer me.
Now, my ONKYO work perfectly with this file, i hope it will be a long time...
Fred
robin64 is offline
post #925 of 3494 Old 08-23-2010, 01:00 PM
KOROR's Avatar
@Tulli
I somehow downloaded the Samsung posted by robin64 below your post, I will try with your zipfile, my bad :-)
KOROR is offline
post #926 of 3494 Old 08-24-2010, 07:56 AM
KOROR's Avatar
I uninstalled the Onkyo driver and installed the Phillips from you Tulli.
HDMI is now again an option under sound manager, but still no sound.
I've read about loads of people with this problem with sound from computer over hdmi to Phillips flat screens, but no solution. So if we are able to figure out a solution many many people would benefit.
I hope you can help figure out other stuff to try out Tulli?
KOROR is offline
post #927 of 3494 Old 08-24-2010, 08:40 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Should be the driver then. Try playing with different driver versions.
Tulli is offline
post #928 of 3494 Old 08-24-2010, 05:45 PM
tai1spin's Avatar
Tulli,
I have frequent handshake problems with my Onkyo HT-R580 and Panny Plasma TC-42G10. Especially if I try to use the sleep feature. How about it?
Luis
OnkyoHT-R580.0.2.zip 1.4677734375k . file
tai1spin is offline
post #929 of 3494 Old 08-24-2010, 06:22 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by tai1spin View Post
Tulli,
Luis
Here you go ...
Panny-TCP42G10 - ONKYO HT-R580.zip 1.189453125k . file
Tulli is offline
post #930 of 3494 Old 09-05-2010, 01:41 AM
crs.one's Avatar
hey guys!
after reading all this stuff now for days and starting to understand the core essence of all I still got some major problem with editing the edid of my tv.
my config looks like this:
win7 x64 ultimate / gtx470 (259.32) -> hdmi -> philips 37pfl9603D -> coaxial -> co² coaxial/optical converter -> optical -> technics sa-da8
now my problem is that I can't get MonInf to read the RealTime EDID of the 37pf9603D. it's not even shown by it, only my regular screen with all data.
even the EDID information inside registry for the 37pfl9603D is totally messed up. but using it as a screen or watching movies works without a problem, just not the sound. it's always limited to 2-channels.
and that's why I want to alter the EDID info for the TV but without a proper original EDID file read from the device itself. I guess that this is the main reason for this situation not to work proper, that the driver can't get the correct EDID info.
I already tried to connect the screen alone with hdmi/hdmi and dvi/hdmi but the results are the same. no RealTime EDID info shown.
maybe some advice or hint how to get the EDID info?
thanks for your time and patience!
so long, crs
crs.one is offline
Reply Home Theater Computers
