EDID Override Thread - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1711 of 3493 Old 10-22-2011, 12:17 AM
Sebastiii's Avatar
Hi,
I would like help about EDID
All seems working but i didn't get DTS-HD HRA comes from Bluray or Sample.
I try to explain my installation :
HTPC Nvidia card is connected to a HDMI Splitter 1 input to 2 output.
(I use it that way because my Harman seems to lost Video when i do refresh rate)
So i have one output of splitter to input AVR (to get sound) and second output to Sanyo Z3000.
If i stay like this, i have no sound on my Win7 because (it seems) it detect a monitor device plug and play as monitor.
To get sound i replace this device by harman kardon EDID that i made a long time ago when i use ATI 5770.
All seems working except this DTS-HD HRA.
So i need help to figure out if i have to make it differently
AVR355TEST.zip 1.1865234375k . file
Sony VPL-HW40ES, HK AVR 355, Klipsch Synergy 2
Sebastiii is offline
post #1712 of 3493 Old 10-22-2011, 01:03 AM
Qaq
Qaq's Avatar
My Onkyo 1007 tends to loose the vsync for 50, 60Hz and TV has no such problem. What did I do? My ATI 5450 has DVI and HDMI ports. So I connected DVI to TV directly and HDMI to AVR (and avr 2 tv after that for any case). This way I keep any sound format in HDMI and any refresh rate in DVI. (Not sure if "chroma bug" still exist in DVI connection - to lazy to check and I know I can't make things better anyway).
Burned by the Audio Inquisition
Qaq is offline
post #1713 of 3493 Old 10-22-2011, 01:15 AM
Sebastiii's Avatar
I have try that way too but don't remember exactly what happen but didn't work very, but maybe i didn't setup it correctly.
Thanks for your feedback
post #1714 of 3493 Old 10-22-2011, 04:52 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The HK EDID is perfect. Whatever the issue is it's player/codec related, not an EDID detection problem.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #1715 of 3493 Old 10-22-2011, 05:29 AM
Sebastiii's Avatar
Thanks Tulli,
It's not a codec issue for sure, TMT didn't work too lol. (All is working except DTS-HD HRA) or maybe Harman didn't handle it (or Nvidia drivers ?)
So the attached file is correct ? if yes it's cool.
Because in my current setup i need to put that inf to enable/validate sound on PC.
Cheers.
post #1716 of 3493 Old 10-23-2011, 06:12 PM
LVNeptune's Avatar
This is my last hope, I have tried pretty much everything I can think of.
I am running a unique setup but the run down is this: I need to use a custom INF because NVIDIA sucks with their 3DTV lockdowns.
This works GREAT for 3D but I CAN NOT get any kind of surround sound out of it. It is showing 2ch http://blog.bagearon.com/downloads/NVIDIA-UN-3DTV.inf
My setup supports 7.1 ch and here's the INF from real-time. If you could copy over the AUDIO section to the modified NVIDIA one I WOULD GREATLY appreciate it ! This is the real-time inf http://www.sendspace.com/file/d19k1w
Thank you so much
EDIT:
Not even remotely sure how I found this post: http://www.avsforum.com/avs-vb/showp...postcount=2075
That works as perfectly as I can tell. I would still like mine modified if possible though Just so I can see how it is done. I tried myself but failed
LVNeptune is offline
post #1717 of 3493 Old 10-23-2011, 07:15 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Post your native EDIDs (Display Device & AVR) and I'll help you with the merge ...
Tulli is offline
post #1718 of 3493 Old 10-24-2011, 10:26 PM
Sebastiii's Avatar
The HK EDID is perfect <<-- it's about the file i have attached or in general ?
Also i think i need help to merge Z3000 + AVR-355 to make one for my use
post #1719 of 3493 Old 10-25-2011, 02:44 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
I meant your attached file. Sure, post the Z3000 native EDID and I'll help you with the merge.
Tulli is offline
post #1720 of 3493 Old 10-25-2011, 11:19 AM
Sebastiii's Avatar
Thanks will get EDID for Z3000
post #1721 of 3493 Old 10-25-2011, 10:11 PM
Sebastiii's Avatar
Hi
This is 2 inf made with moninfo with Z3000 (Sanyo) and Harman AVR-355.
Tulli can you merge both please ?
Thanks a lot,
Seb.
EDiD Sanyo-Harman.zip 2.412109375k . file
post #1722 of 3493 Old 10-26-2011, 12:13 AM
Sebastiii's Avatar
1- Actual connection
Output of Nvidia 460 GTX goes to the splitter (input) and 2 outputs goes to :
output1 -> AVR 355
output2 -> Sanyo Z3000
2-
When i made moninfo : EDiD Sanyo-Harman.zip
For Harman AVR-355-1.inf :
I disconnect output2 to connect to output of my AVR-355
For Sanyo Z3000-1.inf :
I just remove my override inf and monitor pnp generic was detected and set.
After post my EDiD Sanyo-Harman.zip
I reconnect like above "1- Actual connection" and this time an harman was detected (not the same as before) and this one give me "Harman AVR-355-Detected_Boot.inf"
I have attached it and i think maybe it detected this one because AVR was online when the reboot occurs.
3-
I see that there is a diff between Harman AVR-355-Detected_Boot.inf and Harman AVR-355-1.inf but i don't know what.
Also i have retry DTS-HD HRA with TMT or LAV and no sound It's possible that Harman didn't handle DTS HRA sound ? all other format is working.
But i will make test with the merged inf when you have time to do it ?
And my last question how do you merge it ?
Seb.
Harman AVR-355-Detected_Boot.zip 1.234375k . file
post #1723 of 3493 Old 10-26-2011, 04:38 AM
Stefan25's Avatar
Hello,
i have a HTPC with Asus P8H67-M Evo with an Intel I3 (2.Generation sandy bridge) and an Ati HD 6450. The HTPC is connected with HDMI to an Onkyo TX-NR 3007 and from the Receiver with HDMI to an Samsung 37C650 LCD. My problem is that i can only play DTS-HD Master with 1536kbps, so only the Core. My Onkyo shows me DTS-HD Master. I have already the Ati HDMI and the last Catalyst Driver installed. In Windows i have configured an 7.1 System. I play DTS-HD Streams with MPC HC with LVA Audio Decoder with DTS-HD passtrough. Is this in EDID Problem? Can anyone help me and check my inf's?
Greetings from Germany
Stefan
3xinf.zip 3.787109375k . file
Stefan25 is offline
post #1724 of 3493 Old 10-26-2011, 06:24 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
output1 -> AVR 355
2-
3-
Seb.
I only found 2 hex fields that were different in the HK EDIDs, one in each block in a video timings descriptor. Can't explain the difference but I don't think it's relevant.
I attach the EDID override, but with a standard 1-block audio descriptor (the HK has 2). Maybe this will help with the EDID parsing by the driver (if this is really the cause of of your issue).
For general information about a how-to procedure for doing the merge see here.
Sanyo Z3000 - HK AVR-355.zip 1.2666015625k . file
Tulli is offline
post #1725 of 3493 Old 10-26-2011, 06:30 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by Stefan25 View Post
Hello,
Stefan
It's not a problem at all! AFAIK the bitrate displayed is only nominal, so if the AVR is detecting a DTS-HD stream there's no issue. In any event there's no EDID detection problem either.
See here for more info.
Tulli is offline
post #1726 of 3493 Old 10-26-2011, 08:27 AM
Dan@SI's Avatar
I have a Denon AVR-4311CI which has HDMI 1.4a connections. However, when I do an EDID capture using Moninfo it appears to show HDMI 1.3. Is this correct or does this indicate that the cable between the NVIDIA GTX 460 card and the AVR is not 1.4 compliant?? See attached screen clips.
Dan@SI
Dan@SI is offline
post #1727 of 3493 Old 10-26-2011, 08:42 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
That's the EDID Version and Revision number (1.3), not the HDMI specification version. Are you having issues with 3D in your setup?
Tulli is offline
post #1728 of 3493 Old 10-26-2011, 09:02 AM
Dan@SI's Avatar
Yes, I can only manage 3D at 720P, not 1080P. Have tried compliant AMD and NVIDIA vidcards, both PDVD11 and TMT5, have Quad Core AMD cpu which barely registers usage with the vidcards (HD6850 or GTX460). The setup is: vid card to AVR 4311CI via 6' bettercables.com Silver Serpent High Speed hdmi cable; AVR to Panasonic PT AE-7000U via 50' high quality DVI-D cable (I think 24ga conductors..about 1/2 inch in diameter) with MonsterCable brand DVI/HDMI adapters each end.
Dan@SI
Dan@SI is offline
post #1729 of 3493 Old 10-26-2011, 09:26 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Post the native PT AE-7000U EDID for an EDID Override. It could fix your problem (which I guess it's not happening when connecting directly to the Panasonic?). Otherwise it could be a driver problem.
Tulli is offline
post #1730 of 3493 Old 10-26-2011, 10:17 AM
Golitzbt's Avatar
Hello,
I just finished a new build using an Intel i3 2100 and iGPU and TMT5 as my player. As with any blu-ray, I can not get any video once selecting "play", nor the DTS-HD option. DVD's play fine after solving the video driver issue. I have used one of your other overrides for another HTPC and worked perfectly for the same issue, but I was wondering about selecting an override for this setup. I am using an HC-4000 mits projector with a Denon AVR-2310. There is an override similar in the DB, but not an exact merged file. (Mits HC-5500 & Denon 1909). Can I give that one a shot or will it muck things up even worse? I am currently at work and can't provide the original proj and AVR EDID until later tonight, if needed.
Thanks for your assistance.
Golitzbt is offline
post #1731 of 3493 Old 10-26-2011, 10:55 AM
Dan@SI's Avatar
OK, here is the inf for PT-AE7000U and the inf for the AVR-4311 that I used for the override. I actually loaded the AVR-4311 override file to the generic monitor in device manager for the override, not the AE7000U; is that correct?
PT-AE7000U.zip 1.228515625k . file
denon4311.zip 1.2421875k . file
Dan@SI
Dan@SI is offline
post #1732 of 3493 Old 10-26-2011, 11:55 AM
Sebastiii's Avatar
Going to try
I look the inf in moninfo and it seems that there is less audio available compared to both inf detected.
It's maybe because 2 to 1 block audio descriptor
Report my result later
post #1733 of 3493 Old 10-26-2011, 01:15 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Try the attached EDID override.
Panasonic PT-AE7000U - DENON 4311.zip 1.2734375k . file
Tulli is offline
post #1734 of 3493 Old 10-26-2011, 01:21 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by Golitzbt View Post
Hello,
Unfortunately Intel IGPs don't accept EDID overrides. Try playback with a different player (e.g MPC-HC) to narrow down the issue to either TMT5 or driver setup.
Tulli is offline
post #1735 of 3493 Old 10-26-2011, 05:56 PM
Dan@SI's Avatar
TULLI FOR USA PRESIDENT!!
Tulli,
Thanks very much; your edid override worked perfectly as far as I have tested so far. I tried a couple of 3d bds and they did in fact work at 1080p/24 and regular bds still work and sd dvds still work.
I did have to move back to the AMD 6850 for the HD Audio to work easily when I got your genius code installed. I am delighted to have everything working perfectly again and with the bonus of Full Scale 3D. All I had to do was set the resolution to 1080p/24 after loading your edid to the monitor driver file.
Thank you!!
Dan
Dan@SI
Dan@SI is offline
post #1736 of 3493 Old 10-26-2011, 09:01 PM
tepoloco's Avatar
Hello everyone!!:
I have a problem with my sound, prob someone here can help me out.
My setup is : laptop (nvidia gtx 460m)>>hdmi>>samsung tv (UN40D6050)>>home teather
The problem is that control panel in Windows 7 shows only 2.1 channels... from what I've read I need to override the EDID to get 5.1 channels. Am I correct? Can anyone help me please?
SAMSUNG_info.txt 9.810546875k . file
tepoloco is offline
post #1737 of 3493 Old 10-26-2011, 09:46 PM
tepoloco's Avatar
Originally Posted by tepoloco View Post
Hello everyone!!:
Here its the .inf file
SAMSUNG_UN40D6050.zip 1.2275390625k . file
tepoloco is offline
post #1738 of 3493 Old 10-26-2011, 10:24 PM
Sebastiii's Avatar
Hi Tulli,
This one works like the one i have, so i mean DTS-HR didn't work
It's really weird, maybe my AVR didn't handle that after all.
Thanks for your help
post #1739 of 3493 Old 10-27-2011, 08:45 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Mod attached. Note that uncompressed 6-LPCM is not possible over S/PDIF, only 2-LPCM & compressed 5.1 AC3 & DTS. Not sure that your Samsung will accept DTS passthrough.
Samsung UN40D6050+6LPCM+5.1AC3+5.1DTS.zip 1.2783203125k . file
File Type: zip Samsung UN40D6050+6LPCM+5.1AC3+5.1DTS.zip (1.3 KB, 50 views)
Tulli is offline
post #1740 of 3493 Old 10-27-2011, 09:51 AM
Orta's Avatar
Hey guys, I have a GTX460 + 3DTVPlay that I'm trying to feed through a non-3D Pioneer VSX919. This AVR actually seems to handle frame packed 720p/60 and MPCM just fine (3D PS3 games work flawlessly), but since Nvidia uses their EDID whitelist with 3DTVPlay obviously it does not. Will it be possible for me to use the EDID of a newer 3D compliant AVR to get 3DTVPlay to work as well?
Orta is offline
Reply Home Theater Computers
