EDID Override Thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 05-07-2012, 12:41 PM
seelesscacti's Avatar
Mentioned my my configuration problems on a different thread and was told a HDMI Detective may work, but want to find out first before I make a decent investment. Anyone with any input?
I am unable to get a connection from my Toshiba Thrive tablet (HDMI out at 720p) to my Optoma EP910 projector (HDCP compliant, native resolution 1400 x 1050, with supported 720p resolution) via HDMI to DVI cable. And also not able to do this with a Denon AVR391 receiver added in the desired chain (tablet - HDMI cable - receiver - HDMI to DVI cable - projector).
The HDMI port works fine on the Toshiba Thrive outputting to receiver and display set-ups when only HDMI is used, and will output audio to my receiver if the projector is not being output. But, as soon as the projector is plugged in, all audio is lost and no video is displayed. Point is I can output video to HDMI displays, but have never once been able to output video to this DVI display.
I have a laptop existing in the set-up and have no issues outputting via HDMI to the receiver to the projector at 1600x900; if the projector is off, the audio still will play through the receiver. If the receiver is off, the audio will play through the laptop speakers.
My question is, is if I add the HDMI Detective to the chain for the tablet (tablet - HDMI cable - HDMI Detective - HDMI cable - receiver - HDMI to DVI cable - projector) will this solve my issue of sending audio and video to the HDMI receiver and DVI projector?
seelesscacti is offline
Old 05-07-2012, 12:50 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The tablet will only accept standard resolutions, so it seems. So the HDMI Detective should be set to 720p (1280x720). Will the proj. sync at that resolution?
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 05-07-2012, 01:04 PM
Originally Posted by Tulli View Post
The tablet will only accept standard resolutions, so it seems. So the HDMI Detective should be set to 720p (1280x720) ... or 1080p of course. Will the proj. sync at that resolution?
Thanks for the quick reply.
First, I'm no expert at these things. There are no options that I can see on the tablet to change resolutions, so I think I can only output 1280x720. But, I am able to output from my laptop to the projector at that resolution, so I think it's okay.
I may not really understand the HDMI Detective, but it seemed to me it's use was to keep an output source constant to prevent problems from awakening sleeping HTPCs. I've never got a handshake from the projector, so worried that they are just not compatible.
Also, it seemed like you plug in the HDMI Detective to the receiver that the projector is connected through and then it automatically programs the EDID information onto it -- is it complicated to manually set a resolution on it?
Old 05-07-2012, 01:27 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Yes, that's right. Scratch my previous question. It's already answered by the proj. not syncing with the tablet at 720p. In sum, the detective won't help.
Tulli is offline
Old 05-07-2012, 01:30 PM
That's a shame. I was hoping to have a solution. Is there anything else that might work?
Old 05-07-2012, 01:36 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Not IMO, I'm afraid. You have one device that only accepts 720p and the other that won't take 720p. So they can't handshake. Unless there's a way to manually set the resolution for the tablet, but I don't know ...
Tulli is offline
Old 05-07-2012, 01:45 PM
Thanks, anyway. I like that projector a lot, but might convince me to upgrade.
From your response, it got me to thinking that I may as well try this when I get home: Set laptop output resolution to 720p, and then switch HDMI cable to tablet. Probably pretty naive, but about the only thing I haven't tried yet, and worth a try.
Old 05-07-2012, 07:33 PM
trex2010's Avatar
Hello everyone. I need help editing the EDID for my Planar PX2611W monitor. The native resolution is 1920x1200 but about 2 months ago the EDID became corrupted and most of the resolutions vanished, leaving only some low res options. I know that it is possible to fix this because I used an *.ini file for a different Planar monitor and it allowed me to use the resolutions specified in that file. Unfortunately they are not the native resolutions for my monitor.
I just need to edit the actual data to allow a 1920x1200 resolution, but I have no idea how.
This is the file I'm using now:
Monitor
Model name............... PlanarPX2611W
Windows description...... Generic PnP Monitor PlanarPX2611W
Manufacturer............. PNR
Plug and Play ID......... PNR888D
Serial number............ n/a
Manufacture date......... 2007, ISO week 34
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 550 x 340 mm (25.5 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (Unknown - 0x00)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.658 - Ry 0.324
Green chromaticity....... Gx 0.210 - Gy 0.665
Blue chromaticity........ Bx 0.146 - By 0.065
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-83kHz
Vertical scan range...... 49-75Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:10)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1920x1200p at 60Hz (16:10)
Modeline............... "1920x1200" 154.000 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 960p at 75Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1360 x 765p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1400 x 1050p at 75Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
Report information
Date generated........... 5/7/2012
Software revision........ 2.60.0.972
Data source.............. Registry
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,41,D2,8D,88,01,01,01,01,22,11,01,03, 80,37,22,78,2A,8D,B5,A8,53,35,AA,25,
10,50,54,BF,EF,80,71,4F,81,4F,81,80,8B,C0,95,00,90,4F,B3,00, A9,40,01,1D,80,18,71,1C,16,20,58,2C,
25,00,26,58,21,00,00,9E,28,3C,80,A0,70,B0,23,40,30,20,36,00, 26,58,21,00,00,1A,00,00,00,FD,00,31,
4B,1E,53,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,50,6C,61, 6E,61,72,50,58,32,36,31,31,57,01,8C
If anyone can help me add my native resolution to that list, that would be much appreciated.
trex2010 is offline
Old 05-07-2012, 08:44 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
monitor.zip 1.1474609375k . file
Tulli is offline
Old 05-07-2012, 09:52 PM
trex2010's Avatar
Thank you for your reply. I've tried updating my driver using the *.inf file you provided, however it didn't seem to work. I am still stuck at 1920x1080 as the max resolution. =/
MonInfo sees the correct information, but windows doesn't.
I just noticed that if I click List All Modes in my graphics adapter settings, it only goes up to 1920x1080. I have a Nvidia gtx 460 SE, and it worked just fine before...could this be a problem with my video card?
trex2010 is offline
Old 05-08-2012, 05:11 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Did you reboot after applying the EDID override? I doesn't look like it was installed at all. Try cleaning up all registry leftovers of monitor drivers (see proc. in my sig in section 4).
Tulli is offline
Old 05-08-2012, 08:28 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Sorry, I read the first five pages of this thread and I'm still confused. This is the EDID with my TV connected directly to my HTPC:
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x34,0xA9,0xDA,0xA0, 0x01,0x01,0x01,0x01,0x00,0x16,0x01,0x03,0x80,0x00,0x00,0x78, 0x0A,0xDA,0xFF,0xA3,0x58,0x4A,0xA2,0x29,0x17,0x49,0x4B,0x00, 0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38, 0x2D,0x40,0x58,0x2C,0x45,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E, 0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00, 0xBA,0x88,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0xFC,0x00,0x50, 0x61,0x6E,0x61,0x73,0x6F,0x6E,0x69,0x63,0x54,0x56,0x30,0x0A, 0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x44,0x0F,0x00,0x0A, 0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x9A,0x02,0x03,0x2A,0x71, 0x49,0x90,0x05,0x20,0x04,0x03,0x02,0x07,0x06,0x01,0x23,0x09, 0x07,0x01,0x73,0x03,0x0C,0x00,0x10,0x00,0xB8,0x2D,0x2F,0xC0, 0x07,0x81,0x49,0x01,0xFE,0x06,0x08,0x00,0x00,0x00,0xE3,0x05, 0x1F,0x01,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28, 0x55,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x8A, 0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xBA,0x88,0x21,0x00, 0x00,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E, 0x96,0x00,0x0B,0x88,0x21,0x00,0x00,0x18,0x8C,0x0A,0xA0,0x14, 0x51,0xF0,0x16,0x00,0x26,0x7C,0x43,0x00,0xBA,0x88,0x21,0x00, 0x00,0x98,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x86
And here's the EDID with the TV going through the receiver:
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x41,0x2F,0x00,0x00, 0x01,0x01,0x01,0x01,0x00,0x14,0x01,0x03,0x80,0x00,0x00,0x78, 0x0A,0xDA,0xFF,0xA3,0x58,0x4A,0xA2,0x29,0x17,0x49,0x4B,0x00, 0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38, 0x2D,0x40,0x58,0x2C,0x45,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E, 0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00, 0xBA,0x88,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0xFD,0x00,0x17, 0x3D,0x0F,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20, 0x00,0x00,0x00,0xFC,0x00,0x56,0x53,0x58,0x2D,0x31,0x30,0x32, 0x30,0x0A,0x20,0x20,0x20,0x20,0x01,0x88,0x02,0x03,0x43,0x71, 0x4F,0x90,0x05,0x20,0x04,0x03,0x02,0x07,0x06,0x01,0x0F,0x24, 0x0E,0x23,0x0B,0x0A,0x3B,0x09,0x7F,0x07,0x0F,0x7F,0x07,0x15, 0x07,0x50,0x3E,0x1E,0xC0,0x4D,0x02,0x00,0x57,0x06,0x00,0x5F, 0x7E,0x01,0x67,0x7E,0x00,0x77,0x1F,0x03,0x83,0x4F,0x00,0x00, 0x6A,0x03,0x0C,0x00,0x12,0x00,0xB8,0x2D,0x2F,0x80,0x00,0xE3, 0x05,0x1F,0x01,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E, 0x28,0x55,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E,0x8C,0x0A,0xD0, 0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xBA,0x88,0x21, 0x00,0x00,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10, 0x3E,0x96,0x00,0x0B,0x88,0x21,0x00,0x00,0x18,0x00,0x00,0x00, 0x00,0x00,0x00,0x07
Which am I suppose to use for the TV portion, and how do I split it up?
lockdown571 is offline
Old 05-08-2012, 08:58 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The EDID from your TV through the AVR is fine, so your issue, whatever it is, shouldn't be EDID-related.
If you still wan't to override the EDID use exactly this one.
Tulli is offline
Old 05-08-2012, 10:09 AM
thehobster's Avatar
I have a Radeon 5770 that has been in use on a 26" desktop monitor for about 2 years. About a month ago, I replaced the gaming rig and turned the old gaming rig into a media center after a fresh install (wiped the hard drive) of Win 7 Ult.
I leave the HTPC on 24x7 and do not use power management. It's connected to a Vizio 47" LCD (about 5 years old) over HDMI. When I turn the TV on first thing in the morning, I often have a green screen. Note that if I power the TV off during the day and back on again a few hours later I don't get the green screen problem.
I ran across this thread and installed moninfo package thinking it might solve the green screen problem. About the same time, I upgraded my Radeon drivers to the latest as that seems to be a common suggestion for just about any video problem I run across.
Now, I still see the green screen from time to time, so moninfo doesn't seem to have fixed the green screen. Further, it seems I've introduced a new problem regarding audio. If I don't get the green screen, I get a Media Center error about no audio device. When I open the Playback devices, the Vizio HDMI is listed as an audio playback option but it's disabled. I am using the TV for sound, ie, no AVR.
I can log out and log in again (not reboot), and the HDMI audio is back.
Can anyone speculate on if the moninfo is causing the audio problem, or is it the Radeon driver? Second, I know if I rollback to an older Radeon and remove moninfo, I'm back to green screen. Should moninfo fix that or not?
thehobster is offline
Old 05-08-2012, 11:47 AM
So, I had posted my question to the Gefen forum also, and the administrator said it should work if you fool the tablet that there is a tv with sound on the other end instead of a dvi projector -- does this make any sense?
http://forum.gefen.com/topic.asp?TOPIC_ID=11874
When I output from my computer to the projector at 720p, it says briefly that it's outputting at 1280x1024 60, because it is 4:3 native that is then cropped to 720. Is the issue not about the resolutions, but rather about the sound?
Are there less expensive devices that do the same thing that I could try this with?
Old 05-08-2012, 11:59 AM
Ricanmeng's Avatar
Hello,
I was wondering if anyone could help me add 120Hz timing option @ 720p to the following data: First is 3D VIP Theater with Marantz Receiver, 2nd is Panasonic 3D Plasma and Marantz Receiver, I use an Integra but that does not matter, it passes 120Hz just fine.
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x59,0x30,0x05 ,0x00,0x01,0x01,0x01,0x01,0x01,0x14,0x01,0x03,0x80,0x00,0x00 ,0x78,0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,0x12,0x48,0x4C ,0x21,0x08,0x00,0x81,0x80,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x00,0x72,0x51 ,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00 ,0x1E,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFC,0x00 ,0x33,0x44,0x2D,0x54,0x68,0x65,0x61,0x74,0x72,0x65,0x20,0x20 ,0x20,0x00,0x00,0x00,0xFD,0x00,0x17,0xC0,0x0F,0x79,0x17,0x00 ,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x67
;Extension bloc #1, e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x4F,0x72,0x50,0x9F,0x90,0x14,0x05,0x20,0x13 ,0x04,0x12,0x03,0x11,0x02,0x16,0x07,0x15,0x06,0x01,0x38,0x09 ,0x7F,0x07,0x0F,0x7F,0x07,0x17,0x07,0x50,0x3F,0x06,0xC0,0x4D ,0x02,0x00,0x57,0x06,0x00,0x5F,0x7E,0x01,0x67,0x54,0x00,0x83 ,0x0F,0x00,0x00,0x78,0x03,0x0C,0x00,0x10,0x00,0xB8,0x26,0x2F ,0xC0,0x0A,0x81,0x49,0xFF,0xFC,0x06,0x16,0x08,0x00,0x18,0x00 ,0x00,0x00,0x00,0x00,0xE3,0x05,0x1F,0x01,0x01,0x1D,0x80,0xD0 ,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0xBA,0x88,0x21,0x00 ,0x00,0x9E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C ,0x25,0x00,0xBA,0x88,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xB6
and this one:
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x34,0xA9,0xC9 ,0xA0,0x01,0x01,0x01,0x01,0x00,0x15,0x01,0x03,0x80,0x00,0x00 ,0x78,0x0A,0xDA,0xFF,0xA3,0x58,0x4A,0xA2,0x29,0x17,0x49,0x4B ,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01 ,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0xD0,0x72 ,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0xBA,0x88,0x21,0x00,0x00 ,0x1E,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45 ,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0xFC,0x00 ,0x50,0x61,0x6E,0x61,0x73,0x6F,0x6E,0x69,0x63,0x2D,0x54,0x56 ,0x0A,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x44,0x0F,0x00 ,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xAD
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x3C,0xF1,0x48,0x84,0x10,0x05,0x03,0x20,0x29 ,0x2F,0x3C,0x2C,0x09,0x2E,0x07,0x14,0x04,0x80,0x3C,0x04,0xC0 ,0x34,0x04,0x20,0x83,0x01,0x00,0x00,0xE2,0x00,0x0F,0xE3,0x05 ,0x03,0x01,0x76,0x03,0x0C,0x00,0x40,0x00,0x00,0x2D,0x20,0xC0 ,0x0C,0x00,0x01,0x00,0x11,0x08,0x10,0x28,0x10,0x38,0x10,0x48 ,0x10,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25 ,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x8C,0x0A,0xD0,0x8A,0x20 ,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x2A,0x53,0x00,0x00 ,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96 ,0x00,0x38,0x2A,0x43,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xCD
Ricanmeng is offline
Old 05-08-2012, 12:00 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
What is exactly doing that "Moninfo package"? Do you mean an EDID override?
The problem with sound is driver related and cannot be solved with an EDID override. I have it myself with my 5750.
Tulli is offline
Old 05-08-2012, 12:03 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Well, that could work indeed and it could be tried. Post the native EDID of the proj. and I'll add an extension block (you could do it yourself if you want).
Tulli is offline
Old 05-08-2012, 12:10 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by Ricanmeng View Post
Hello,
;Base EDID
and this one:
;Base EDID
What is your issue, exactly?
Tulli is offline
Old 05-08-2012, 12:40 PM
Ricanmeng's Avatar
I currently have all my sources running into an Integra DTR-30.3 (3D, 120Hz capable) going into a VIP 3D Theater then to an Acer H5360. Without a custom edid with 3D enabled, the VIP Theater would not be triggered in 3D mode and I would end up getting eye swaps every 5 minutes due to the AMD HD3D driver using quad buffer without HDMI 1.4 signaling. So I used the Panasonic 3D TV driver with Marantz edid from you list and got the VIP Theater to recognize HDMI 1.4 signaling. Also games with built in native 3D functions for AMD such as Battlefield 3 and Crysis 2 would start working because they recognized the edid as 3D capable with HDMI 1.4 instead of just seeing my Acer through a receiver. With the Panasonic edid, I lost the ability to do 720p 120Hz for when I game in 2D on the projector, or watch movies and want to eliminate 2:3 pulldown without running 24Hz options. It would be awesome to be able to use the VIP Theater edid with proper surround options and HDMI 1.4 signaling flagged.
Old 05-08-2012, 01:14 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
So what is needed is a custom EDID for your setup, i. e. the merged EDID of the Acer H5360 + Audio Block of the Integra.
Tulli is offline
Old 05-08-2012, 01:26 PM
thehobster's Avatar
Yes, moninfo is an EDID override application from Entech. It seemed that the green screen problem is supposedly solved by an EDID override. Based on current experience, I'm not so sure.
What sounds driver do I need to look into? Can I assume it's provided by ATI/AMD? Since it just started it seems like it has to be related to either the EDID override or the latest Radeon package I downloaded. And if EDID override isn't the cause, it seems like it must be new Radeon driver.
Do you ever solve the problem? What driver package are you using?
Old 05-08-2012, 01:28 PM
Ricanmeng's Avatar
I have already created that custom edid, the problem arises when I am reading the edid via Monitor Assest Manager, the 3D flags are saying not supported even though the VIP Theater is 3D and HDMI 1.4 capable. I didn't have these issues with the mold Nvidia 560 TI reading HDMI 1.4 capability & 3D along with the 120 Hz with nothing special regarding the edid other than the my receiver's name showing up as the dispaly device (Integra DTR-30.3) Here is my raw data of my receiver, Vip theater, and Acer directly from Monitor Asset Manager.
Raw data
00,FF,FF,FF,FF,FF,FF,00,04,72,01,07,AF,09,00,00,2B,14,01,03, 80,00,00,78,0A,A4,9A,A3,58,53,9C,24,
0F,4B,57,3F,CF,80,D1,C0,31,7C,95,00,45,7C,81,C0,61,7C,81,00, 81,FC,1A,1D,00,80,51,D0,1C,20,40,80,
35,00,00,00,00,00,00,1C,00,00,00,FD,00,32,78,1E,64,11,00,0A, 20,20,20,20,20,20,00,00,00,FC,00,41,
63,65,72,20,48,35,33,36,30,0A,20,20,00,00,00,FF,00,4B,30,37, 30,31,30,32,30,35,39,30,31,0A,01,B2,
02,03,50,F1,4C,84,10,05,03,20,29,2F,3C,06,0F,0A,24,38,09,7F, 07,0F,7F,07,17,07,50,3F,06,C0,4D,02,
00,57,06,00,5F,7E,01,67,54,00,83,4F,00,00,7A,03,0C,00,45,00, 80,2D,E0,00,00,00,00,C0,0C,00,01,00,
11,08,10,28,10,38,10,48,10,E3,05,03,01,E2,00,0F,01,1D,80,18, 71,1C,16,20,58,2C,25,00,A0,5A,00,00,
00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,A0,2A,53,00,00,18, 00,00,00,00,00,00,00,00,00,00,00,EF
Old 05-08-2012, 01:43 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Tried different driver versions including latest without success. The problem happens with the disconnection (power off) of the display device, after which the audio device is disabled and doesn't fully re-enable after power on.
Don't know about your green screen problem but I presume that it's a driver problem too.
Tulli is offline
Old 05-08-2012, 01:49 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Raw data
Looks fine to me, and from what you say the problem is not the EDID but the graphic driver perhaps. Not much to add really ...
Tulli is offline
Old 05-08-2012, 06:37 PM
thehobster's Avatar
Well that sux. What kind of monitor are you seeing this on? It's weird that it just started. Maybe I should revert to an older driver and see if it goes away - the audio problem that is.
Old 05-10-2012, 10:16 AM
thehobster's Avatar
No green screen since EDID override. And no audio errors since downgrading the video driver (Radeon 5770). Hoping it holds...
Old 05-10-2012, 05:31 PM
timmyotule's Avatar
Hopefully someone can help me with my current issue.
My HTPC is setup to two displays as follows:
HTPC -> HDMI -> Denon 2309 -> HDMI -> Panasonic AE2000U Projector
HTPC -> DVI -> Dell 2405FWP Monitor
My HTPC is using the integrated graphics of the Intel i5-661 processor.
When everything is powered up it works just fine. However if I try to have on just the monitor and the Denon the monitor flickers a "Can Not Display This Mode" message. If I turn off the Denon or turn on the projetor the monitor will show the computer desktop.
I'd like to be able to listen to music off of the computer while working on it while having the projector off. I've had it working like this in the past where turning on the Denon didn't mess up the monitor's display. I don't know what has changed to stop this from working properly.
It seems like when the Denon is being brought online the HTPC changes the video output to a mode that isn't compatible with the monitor. However there isn't a monitor attached that is able to display anything so I can see what signal it is sending or change it.
Let me know if you have any ideas on how to fix this. Also let me know if this likely isn't an EDID issue and I can start a new thread for this issue.
timmyotule is offline
Old 05-11-2012, 04:09 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Try cleaning up registry entries for monitor drivers by following procedure outlined in section 4 in my sig. (removing registry leftovers). Then reboot.
Tulli is offline
Old 05-11-2012, 11:02 AM
timmyotule's Avatar
Thanks for the tip. I did that and cleared up quite a few items but it didn't solve the issue.
I did get it fixed though using 'Print Screen's and setting up pens to know where to move the mouse on my phantom display. It was set to 'Single Display' with the Denon Amp as the only monitor.
I've got it back so that the monitor is the main display with Denon as a the secondary.
