Media Browser: Great alternative to DVD Library/My Movies/Movie Collector - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 4110 Old 01-26-2009, 11:49 AM
joikd's Avatar
Originally Posted by hifiaudio2 View Post
For iso files to work in MB / TMT, I didnt have to adjust any config changes. Accept the default address in MB for Daemon tools lite, and it launched the BD movie and TMT flawlessly. its getting BD folder structure to work that I have issues with - although it sounds like its working now with the exception of the error it throws up even though the video is playing.
I'm glad to hear that iso & TMT work. Do you get any error messages when you play an iso through MB? Which version of MB are you using?
joikd is online now
post #272 of 4110 Old 01-26-2009, 12:07 PM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
using version 2.0.6 - 2.0.7 is now out.. will change to that tonight
I had ISOs working with 2.0.5 - when .6 came out I started trying out native folders.
I got no errors with the iso - although when I stopped it I noticed MB was on a "nonsupported video" page - but it wasnt an error to click. The back button cleared it.
hifiaudio2 is offline
post #273 of 4110 Old 01-26-2009, 12:14 PM
staab29's Avatar
i see that some people have TMT working with ISO's. how about powerDVD? it also looks like i need to switch from VCD to daemon tools
staab29 is offline
post #274 of 4110 Old 01-26-2009, 02:07 PM
MoNkLorD's Avatar
over the weekend i installed TMT back onto my machine, and now i no longer have MB icon, i have to go to the programs page and launch it from there, how can i get it back to its normal location?
MoNkLorD is offline
post #275 of 4110 Old 01-26-2009, 02:30 PM
sudo4re's Avatar
Has anyone successfully launch MPC-HC for Mkv files using the config commands? I have tried all possible configs that I could think of but MB just will not launch the external player. I ripped my BD's to Mkv and FLAC then remuxing them and got a .Mka file so that might be the difference... Please post your code snippet here if you successfully launch MPC from MB. Thanks
sudo4re is offline
post #276 of 4110 Old 01-26-2009, 02:39 PM
ebr
ebr's Avatar
This error (playing folders) is fixed in the latest SVN. Folder playback now works seamlessly again.
ebr is offline
post #277 of 4110 Old 01-26-2009, 02:42 PM
ebr
ebr's Avatar
by the way, i cannot get the mediabrowser forums to send me registration confirmation. Did you get in?
I had a lot of trouble with this too. Took three or four days before the thing would send me a registration confirmation email. Keep telling it to re-send it...
ebr is offline
post #278 of 4110 Old 01-26-2009, 03:10 PM
tman247's Avatar
Quoted: 58 Post(s)
Liked: 53
Your not the only one. Same problem here. VMC will play the file rather than MB launching MPC-HC. It should work, but I guess there's a bug in there somewhere!
tman247 is offline
post #279 of 4110 Old 01-26-2009, 05:12 PM
sudo4re's Avatar
I can't even get VMC to play the Mkv files. I can play them in VMC if I manually open the files with VMC but MB does not launch VMC for me. I have associated the Mkv files with both VMC and MPC (at different times) but MB does not launch either one. Guess we'll have to wait until the next release to see if Sam fixed this bug.
sudo4re is offline
post #280 of 4110 Old 01-26-2009, 06:32 PM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
So I am noticing an odd thing with the video - it seems to "tear" in fast motion. So this might be a post for another thread... not sure. Is this a known issue with TMT? The bottom and top of the picture seem the most prone to this.
This is on my "non htpc" system that I am testing with that has and ATI x1900 and core2 quad 2.66 proc. Latest catalyst drivers..... sorry if it belongs in another thread. Getting MB to work has been my top priority, then perfecting playback on my real htpc, which is the Gigabyte 9400 integrated chipset with core2 quad 2.5.
post #281 of 4110 Old 01-26-2009, 06:45 PM
ebr
ebr's Avatar
Yeah, the tearing has nothing to do with MB. Related to the player, hardware, config, codecs, etc.
ebr is offline
post #282 of 4110 Old 01-27-2009, 08:45 AM - Thread Starter
politby's Avatar
Quoted: 78 Post(s)
Liked: 77
I would love to be able to do this as well (with TMT, though, not MPC-HC). I have some .mkvs that I for some reason only can play back in TMT because of audio issues, so would love to have MB start TMT when I start playing an .mkv file.
politby is offline
post #283 of 4110 Old 01-27-2009, 10:53 AM
ebr
ebr's Avatar
The config setup is case sensitive. Have you guys entered the MediaType as "Mkv" exactly...?
ebr is offline
post #284 of 4110 Old 01-27-2009, 12:20 PM
taz291819's Avatar
Quoted: 88 Post(s)
Liked: 63
I believe it's a bug, that will be fixed in the next release. Supposedly, if you have a single MKV in a folder, MB doesn't see it as a MKV, but as a video folder. This is a known bug and is being fixed, from what I've read.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is offline
post #285 of 4110 Old 01-27-2009, 05:02 PM
ebr
ebr's Avatar
Ah, that's right. I remember that caveat now. However, I don't remember them saying they were fixing it, but I might have just missed that conversation.
ebr is offline
post #286 of 4110 Old 01-27-2009, 05:24 PM
sudo4re's Avatar
paul777 wrote:I think the problem you are having is down to one of the original caveats. At the moment movies that exists in a folder of there own are recognised as movie folders, rather than mkv or avi files, and we "play" the folder using playlists if necessary. As such any configuration you try for Avi/Mkv external players will be ignored. Once I get to it we will extend it to cope with folders that contain single movie files, support for external applications using playlists probably won't happen.
This is what one of the developers over at MB forums is saying. May be it's just me but the message I get from this excerpt is playing mkv files using an external player is not a priority and they'll get around to it eventually.
sudo4re is offline
post #287 of 4110 Old 01-27-2009, 05:32 PM
sudo4re's Avatar
ebr,
Nice Home Theater set up you've got there... when my HT grows up I want it to be just like yours. Very impressive!
sudo4re is offline
post #288 of 4110 Old 01-27-2009, 07:14 PM
ebr
ebr's Avatar
ebr,
thx.
I'm still hacking on my copy of MB. Probably really making a mess of things but now, in addition to having sort titles working, I'm on my way to parental controls...
ebr is offline
post #289 of 4110 Old 01-27-2009, 09:34 PM
ka6tya's Avatar
I rip them to .mkv files with flac audio and original VC-1/H.264 video. It seems to be able to play anything recognized by Vista as a video file - so you need to have made the registry changes to make it understand .mkv extensions and you need a matroska splitter and the required codecs.
I would like to know how to rip to mkv do the registry changes. Can you help?
ka6tya is offline
post #290 of 4110 Old 01-28-2009, 05:36 PM
pclausen's Avatar
Quoted: 138 Post(s)
Liked: 105
Search this forum for "eac3to".
pclausen is offline
post #291 of 4110 Old 01-28-2009, 10:40 PM
yelnatsch517's Avatar
Liked: 24
Originally Posted by pclausen View Post
I'm currently using MM and have a total of about 1400 movies. Of those, about 400 are Blu-ray or HD-DVDs ripped to MKVs w/ flac audio. All my DVDs are ripped to folder structures.
My directories are setup as follows:
Z:\\\\SD Movies\\Alien\\VIDEO_TS\\
Z:\\\\SD Movies\\Aliens\\VIDEO_TS\\
Z:\\\\HD Movies\\AVP.mkv
Z:\\\\HD Movies\\AVP2.mkv
So I only have metadata for the DVD rips within each folder. All my .MKVs are individual files within the HD Movies folder. So all the metadata with residing in the MM database.
Would I need to place each .MKV within its own folder, and then use the utilities mentioned in order to re-create the metadata?
MM is slow with a large collection and I have been waiting for version 3 for I don't know how long now, so this sounds like it might be the way to go.
How are you ripping the blu rays into mkv and what versions of MKB/BD+ can you decrypt?
Edit: Nevermind, just read your post above.
yelnatsch517 is offline
post #292 of 4110 Old 01-29-2009, 12:22 AM - Thread Starter
politby's Avatar
Quoted: 78 Post(s)
Liked: 77
Here's a little registry edit file that sets up the most common video formats so that Windows recognizes them.
I suspect Mediabrowser doesn't need this though, I think it has its own list of supported file formats so assuming you have the correct codec, they will play fine. ffdshow and Haali Media Splitter is all you need.
/politby
video-extensions.zip 0.4150390625k . file
File Type: zip video-extensions.zip (425 Bytes, 36 views)
politby is offline
post #293 of 4110 Old 01-29-2009, 01:01 PM
I've noticed some of the change log reporting VCD support. This hasn't been checked out to an official installer yet, but is there way to download the source?
EBR,
Seems you have downloaded the source and made modifications to it, how did you get the source code?
jdubbs23 is offline
post #294 of 4110 Old 01-29-2009, 01:13 PM
DraZtiK's Avatar
EBR,
http://code.google.com/p/videobrowser/source/checkout
DraZtiK is offline
post #295 of 4110 Old 01-29-2009, 10:27 PM
nownot's Avatar
can someone please build the msi with the line change for vcd and upload that? i hate to have to install visual studio on my htpc just for this, thanks.
nownot is offline
post #296 of 4110 Old 01-30-2009, 07:47 AM
ebr
ebr's Avatar
I just grabbed the latest trunk and built it. Didn't do any testing or anything so proceed at your own risk... MB Rev 478
ebr is offline
post #297 of 4110 Old 01-31-2009, 06:10 AM
shazo's Avatar
Does this work with Virtual CloneDrive for iso files? I know it has been asked but i didn't see an answere for it.
shazo is offline
post #298 of 4110 Old 01-31-2009, 06:51 AM
stanglx's Avatar
Not out of the box.. grab the file above your post.. someone was nice enough to compile a trunked version that does support it
stanglx is offline
post #299 of 4110 Old 01-31-2009, 04:23 PM
shazo's Avatar
Thanks would I need both versions or just the one that was posted?
shazo is offline
post #300 of 4110 Old 01-31-2009, 04:55 PM
staab29's Avatar
just the one posted, but it didnt work for me.
staab29 is offline
Reply Home Theater Computers
