Media Browser: Great alternative to DVD Library/My Movies/Movie Collector - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 4110 Old 02-09-2009, 12:24 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Originally Posted by Mopar_Mudder View Post
I don't know how much time you gave it, but if you have alot of movies and they are on another server it does take Media Browser some time to pull them all up. I run ito the same thing when I clear my cache, nothing shows up in the movie window so I just leave it run for awhile and it all shows up.
Well, you were right. I wasn't giving it enough time to populate. Although it doesn't see my J:\\ HDD. Any ideas??
Xzener
xzener is offline
post #362 of 4110 Old 02-09-2009, 12:44 PM
staab29's Avatar
staab29, did you get it to work?? Do you choose a icon to use?? Could I use something like this...
http://images.google.com/imgres?imgu...ctive%26sa%3DN
or like this...
http://www.samsung.com/au/system/con...features01.png
Well, I suppose I could just use Photoshop.
it didnt work for me either, i am pretty new at this as well. i have figured most of my stuff out from trial and error and i have read this whole thread. sorry i couldn't help.
staab29 is offline
post #363 of 4110 Old 02-09-2009, 12:50 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
*FIXED* I'm a moron. I used a capitol F.... oops!!
Xzener
xzener is offline
post #364 of 4110 Old 02-09-2009, 01:23 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Ok, I think I'm ready to ****e can Movie Library. Is there a way to reverse the hack??
Can I just reverse the instructions...
The first thing you need to do is edit the Windows Vista registry so that Media Center displays a "gallery" view of your DVDs instead of just a "play DVD" button. To do this, run "regedit" and navigate to: HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrentVers ion\\Media Center\\Settings\\DvdSettings and change the "ShowGallery" value to "Gallery."
Like if I were to change "Gallery" back to "ShowGallery"?? Would that work??
Xzener
xzener is offline
post #365 of 4110 Old 02-09-2009, 02:12 PM
taz291819's Avatar
Originally Posted by shazo View Post
Does video quality and audio quality stay the same? Also I keep reading to get the files to play in WMC I will need TMT. Is their a demo some place I can get?
EDIT:
Now that I put the movies in their own folders it seems MB is getting the data on its own. Only issue is for one of my movies it is getting the wrong info. I have the 1989 version of The Punisher and it is geting the info and poster for the 2004 version. Also for Terminator The Sarah Connor Chronicles it is getting nothing.
You don't need TMT to play MKVs.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
post #366 of 4110 Old 02-09-2009, 03:02 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Yet another question....
Do I have to clear the cache everytime I add a movie??
Xzener
xzener is offline
post #367 of 4110 Old 02-09-2009, 03:08 PM
Mopar_Mudder's Avatar
Quoted: 25 Post(s)
Liked: 32
No, only if you change the cover art in the movie folder, or any folder for that mater
Mopar_Mudder is offline
post #368 of 4110 Old 02-09-2009, 03:31 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Thanks Mopar_Mudder.
Is there anyone who can answer this question??
Xzener
xzener is offline
post #369 of 4110 Old 02-09-2009, 04:04 PM
cybrsage's Avatar
Liked: 154
It should work. Give it a shot. If it does not (which I doubt) then simply change it back to gallery again.
cybrsage is offline
post #370 of 4110 Old 02-09-2009, 06:24 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
It worked. Now to get MediaMender to change MediaBrowser to My Movies. *DONE*
I also used photoshop to make a HD icon (thanks appleTV) on my .mkv folder.jpg's. Heres a pic...
Anyone know if you can change the icon of Media Browser on the VMC menu??
Xzener
xzener is offline
post #371 of 4110 Old 02-10-2009, 03:30 AM
shazo's Avatar
I was using SMO and I still can not find anything but the movie poster for my movies. Where can I get the picture or the case and cover art of the movie. It would be nice to know what ones are HD, BD and just SD DVDs.
shazo is offline
post #372 of 4110 Old 02-10-2009, 08:04 AM
cybrsage's Avatar
Liked: 154
Does Media Browser support playing ISOs of BR and HD-DVDs?
Does it support Virtual CloneDrive?
I have a full retail version of Arcsoft's TMT already, so that is my program of choice, and I would want to launch the VMC plugin version of TMT.
cybrsage is offline
post #373 of 4110 Old 02-10-2009, 08:12 AM
davdev's Avatar
You can try using the MyMovies collection manager, so you can just go to a site that sells DVD's and copy the cover art there. I find that Amazon typically (though not always) has decent quality images
davdev is offline
post #374 of 4110 Old 02-10-2009, 08:24 AM
genro's Avatar
The code has been added but I believe a build has not been released with this new support.
Specifically:
BD/HD-DVD ISO: The next build will allow you to check an option to say "Let Autoplay take over for mounted ISOs".
VCD: They will support VCD explicitly, however the latest VCD beta also supports daemontool commands and has a "dummy" daemon.exe so technically would work right now.
genro is offline
post #375 of 4110 Old 02-10-2009, 09:58 AM
ericwe's Avatar
See my post here for a method that works for me.
ericwe is offline
post #376 of 4110 Old 02-10-2009, 04:09 PM
MoNkLorD's Avatar
Originally Posted by MoNkLorD View Post
I have a new problem
I refreshed the cache, now my movies have a space between then, i reset everything back to default and same thing. my tv shows are not affected just my movies (MKVs) i checked the settings and the grid is set to (0) . i can't figure out what went wrong?
anyone? i still can't find a solution for this
MoNkLorD is offline
post #377 of 4110 Old 02-10-2009, 04:18 PM
staab29's Avatar
i would like to see BD and HD DVD frames as well. i have seen pics earlier in the thread that someone had, but i cant figure out how to add the frames.
staab29 is offline
post #378 of 4110 Old 02-10-2009, 05:15 PM
ebr
ebr's Avatar
I did it in my own copy of MB. It requires modifying the source code.
Most users of MB at this time are not interested in this feature because they use full-sized poster art for their thumbs.
ebr is offline
post #379 of 4110 Old 02-10-2009, 06:38 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Try using Photoshop to resize a bluray cover. I'll try one and get back to you guys.
I'll also try the frame too.
Xzener
xzener is offline
post #380 of 4110 Old 02-10-2009, 07:05 PM
staab29's Avatar
what are you doing? modifying the image in each folder?
staab29 is offline
post #381 of 4110 Old 02-10-2009, 07:59 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Well it took some toying around, but I got it to work. I made a bluray frame, and resized it to a normal DVD .jpg size. Then I resized a DVD .jpg to fit in the frame. Resizing a bluray to a DVD would work also. Tell me what you think. I like playing with photoshop, so go easy on me HAHA!!
Xzener
xzener is offline
post #382 of 4110 Old 02-10-2009, 08:03 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Yes, I originally modified all my HD movies to have an HD logo on the bottom right of the cover. It didn't take long. But I never thought about resizing a bluray cover to fit until you mentioned it.
Xzener
xzener is offline
post #383 of 4110 Old 02-10-2009, 08:06 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Why not try and uninstall MB and do a reinstall?? It couldn't hurt.
Xzener
xzener is offline
post #384 of 4110 Old 02-11-2009, 03:39 AM
shazo's Avatar
I really don't want to have both MyMovies and MB seeing how they do the same thing and MB seems a little nicer then MyMovies. I guess I will just live with just having the movie posters.
shazo is offline
post #385 of 4110 Old 02-11-2009, 05:51 AM
cybrsage's Avatar
Liked: 154
Funny thing is that I did not realize I skipped a few pages. I found your method later on, copied all the files to a USB stick, put your post into Word, and am going to try it out tonight.
cybrsage is offline
post #386 of 4110 Old 02-11-2009, 06:17 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
Thought I'd add something here, as I've been using MB for a while and think it's such a cool app.
Anyway, I have DVD's ripped to a media server in there native VIDEO_TS/VOB format, which VMC plays fine. I also have HD movies ripped to MKV format in another location, which means I keep DVD's and HD movies in seperate root folders. I created .vf's for each folder that MB can use, with a graphic saying 'DVD Movies' and 'HD Movies' on the frontend, so I know which are which. I'm using standard movie poster images for each film (not BD covers, or Photoshop creations), and it works fine. The icing on the cake is to use the mediainfo trick in MB, so the format of the HD .mkv file is detected, and I automatically get an icon displayed in the bottom right corner of the poster image saying 'HD 1080P' or HD 720P' depending on the format. I don't have to change anything, or mess around in Photoshop.
I'm happy with this, as it works really well with no other work required.
I've also registered the MPC-HC video decoder in VMC, so I can playback 1080P mkv's WITHIN VMC with full acceleration. This works ok, although I'm really waiting for MB to allow 3rd party apps (such as MPC-HC) to automatically load and play the mkv file. This should be coming soon.
tman247 is offline
post #387 of 4110 Old 02-11-2009, 06:32 AM
lakaw's Avatar
Beta 2.0.8.0 of Media Browser is out
If you've got Beta Updates checked, you'll be prompted to upgrade. After setting up VCD to mount iso's and checking autoplay, MB launches PowerDvd to play my iso's. Hit the Green button, PowerDvd closes and you are returned to the MB interface. "Cover Flow" is a very sleek interface.
I wanted to configure MB to use Theatertek for my sd DVD's, but I can't seem to locate the mediabrowserxml.config file for my x64 install. I turned on hidden files and looked in C:\\Program Files (x64)\\ Media Browser\\Media Browser\\. There were only three files there, an icon, a registration file, and one other file (not the config file).
Am I missing something?
This could very well be the death of My Movies. I'm still currently using it to retrieve my metadata, but I might try Meta Browser to see how well it works. On a side note if I decide to uninstall My Movies, I assume I can safely remove database software (SQL?) as well. Any thoughts on that?
lakaw is offline
post #388 of 4110 Old 02-11-2009, 06:47 AM
gplasky's Avatar
If you'e running Vista with UAC enabled those settings files are probably in the Virtual Store.
Gerry
Big Gerr
gplasky is offline
post #389 of 4110 Old 02-11-2009, 07:42 AM
ebr
ebr's Avatar
The config file (as well as the cache, the logs and the custom images and styles) is in (systemdrive):\\programdata\\mediabrowser.
ebr is offline
post #390 of 4110 Old 02-11-2009, 07:44 AM
ebr
ebr's Avatar
Unfortunately, mediainfo doesn't work if you have your HD movies ripped to folders.
ebr is offline
Reply Home Theater Computers
