Media Browser: Great alternative to DVD Library/My Movies/Movie Collector - Page 83 - AVS Forum | Home Theater Discussions And Reviews
post #2461 of 4110 Old 11-01-2009, 10:22 AM
Paul E. Fox, II's Avatar
Originally Posted by ebr View Post
What is the format of your movies? Are they all in their own folders?
Do you get that message when you try to play something or right when MB starts up or when?
Everything is in a separate folder with the exception of two concert DVDs by the same band. They are in separate folders IN the main folder named for the band.
I get this error when I try to click on something and play it back.
Originally Posted by jrwalte View Post
It's possible your windows account doesn't have the permission it needs for the programdata folder. Did you setup your user account as administrator or user? Go to Windows Explorer, right click on programdata and select properties. Select Security tab and then advanced. Select Effective Permissions tab and then the 'select' button under Group or user name. Type in your user name and hit ok. What is the effective permissions listed? It should be full control.
My account is listed in the administrator's group. I just checked it's permissions and reset it to "full control" for my account just in case.
Paul
Paul E. Fox, II is offline
post #2462 of 4110 Old 11-01-2009, 07:53 PM
ebr
ebr's Avatar
What kind of files? avi, mkv, video_ts rips...?
ebr is offline
post #2463 of 4110 Old 11-01-2009, 08:52 PM
Demonseed64's Avatar
@Paul E. Fox, II
First answer ebr so its easier to find the root of the problem.
A few steps you can try to help trouble shoot. If one doesn't work go to the next, and post back what each one does.
1: You can create a Test folder, Drop like 6 movies in it. Show it to the config tool. Try to play a movie
2: Kill MB, Go to C:ProgramData\\MediaBrowser\\Cache + ImageCache and Delete everything inside. Run MB, try to play a movie
3: Open the config tool and remove the Rips VF , Go to C:ProgramData\\MediaBrowser\\Cache + ImageCache and Delete everything inside. Run MB, let it sit for 5 min, Kill it. Add you Rips folder back to the config tool. Open MB and retry playing a movie.
I also saw that you said your fonts were messed up. Do you have the Windows (DPI) turned up? I have seen others say that having it turned up was screwing up MB fonts. It shouldn't be doing that, if that is in fact the case.
Demonseed64 is offline
post #2464 of 4110 Old 11-02-2009, 06:32 AM
Only really using .iso rips thus far. I have two movies ripped as MKVs but since TMT3 doesn't want to deal with them, I've gone back to ripping ISOs.
Originally Posted by Demonseed64 View Post
@Paul E. Fox, II
I do think I have the DPI set to larger or whatever that actually says. I'll check when I get home.
Thanks for the help guys...really REALLY appreciate it.
Paul
post #2465 of 4110 Old 11-02-2009, 07:07 AM
ebr
ebr's Avatar
Aha. Do you have the external player setup properly in the Configurator?
Can I see a screen shot of that setup?
Also, what do you use to mount the .ISO or will TMT3 take care of that? Sorry, I don't use ISOs at all...
ebr is offline
post #2466 of 4110 Old 11-02-2009, 01:37 PM
Ximori's Avatar
Quoted: 136 Post(s)
Liked: 46
Whenever I start WMC, media browser shows all my movie selection with posters and backdrops. However, when I go to the main screen and then to video or movie library they are nowhere to be found. While I know how to direct all my movie files to show up in the video library section I can’t seem to get media browser recognized in there to show the same images and backdrops I'm getting upon startup. Does anyone have a tip? Thanks.
Ximori is offline
post #2467 of 4110 Old 11-02-2009, 02:08 PM
ebr
ebr's Avatar
Originally Posted by Ximori View Post
Whenever I start WMC, media browser shows all my movie selection with posters and backdrops. However, when I go to the main screen and then to video or movie library they are nowhere to be found. While I know how to direct all my movie files to show up in the video library section I can't seem to get media browser recognized in there to show the same images and backdrops I'm getting upon startup. Does anyone have a tip? Thanks.
The Video and Movie Library within MC are completely separate from MediaBrowser. Basically, MediaBrowser is a replacement for both of them (as well as other stuff). If you want to use the built-in Movie Library, you will need to run the routines to populate its own information (through the media center menus) but I recommend just using MB instead...
ebr is offline
post #2468 of 4110 Old 11-02-2009, 03:08 PM
Ximori's Avatar
Quoted: 136 Post(s)
Liked: 46
Well, that's a bummer. I tried media portal one time which worked within the video library, but presentation-wise wasn't as nice as media browser's (imo). I thought there was some way to, at least, go back to the media browser without having to keep re-starting 7MC.
Ximori is offline
post #2469 of 4110 Old 11-02-2009, 03:50 PM
ebr
ebr's Avatar
There is. When you install MB it should end up with its own icon on the start menu...
ebr is offline
post #2470 of 4110 Old 11-02-2009, 03:58 PM
Ximori's Avatar
Quoted: 136 Post(s)
Liked: 46
Thanks, I missed this somewhere.
Ximori is offline
post #2471 of 4110 Old 11-04-2009, 06:06 PM
smallhometheater's Avatar
Has anyone here tried to copy Transformers 2 Revenge of the fallen to computer? I have tried with two discs.. .1 purchased from the store and another rented from NetFlix and both do not allow me to copy like I've done with many other discs. when I open the movie with DVDFAB I only show a file with 356K and 4:3 format. I normally see a file with 16:9 format and hours worth of video. Is there something special about this movie that's not allowing me to copy?
smallhometheater is offline
post #2472 of 4110 Old 11-04-2009, 06:29 PM
ebr
ebr's Avatar
I don't have that disc but I was not under the impression that DVDFab could strip BD+ copy-protection...
[edit] oops, I guess I assumed you were talking about a BluRay.
ebr is offline
post #2473 of 4110 Old 11-04-2009, 06:36 PM
Not BR just the regular DVD
post #2474 of 4110 Old 11-04-2009, 07:44 PM
I think I may have found my answer in another thread here.
"regarding DVDFab HD, just my guess but that may be worst case scenario. transformers2 (and their new protection scheme) was released on the 22nd and a new build was up by the 27th to deal with it. so, even though updates may be slower than the paid version, you'd probably be good to go if you just waited a week before buying and ripping the dvd."
post #2475 of 4110 Old 11-04-2009, 08:44 PM
jman7's Avatar
Got one last issue I am dealing with. I am using the latest 2.1.3 version of Media Browser with Windows 7 Ultimate. I have two folders mapped - one with 300 movies and one with 394 movies. All my movies are on a network SMB share over gigabit nic. My HTPCs are running on a fast Solid state disks so the cache should be plenty fast. I am using the diamond theme with 3 rows of poster covers.
About 1 out of every 3 times I start up my HTPC and navigate to one of my folders when I get to the screen that shows all my movies the screen just freezes. It just dims and sits there showing my movie covers but not allowing me to do anything with my remote. I can hit the back button and and come back into the folder and it works fine. I have tried deleting my cache a few times but that didn't help. I even uninstalled the whole thing and and deleted the cache. I tried disabling every extra option in the configuration. Turned off the clock, viewing tracking, weather. I unchecked every check box in the configuration and still it persists. Anyone know what to do? I really like the Diamond theme with the 3 rows over covers.
jman7 is offline
post #2476 of 4110 Old 11-05-2009, 05:01 AM
CocheseUGA's Avatar
I've not had any luck with the themes. I'd have text overruns and other issues, so I just stick to the default theme.
CocheseUGA is offline
post #2477 of 4110 Old 11-05-2009, 06:21 AM
Thanks for the suggestion...I've been busy and haven't had time to get back in here until this morning.
I thought I did...I have chosen TMT3 as the program to use for these and have browsed to the path of the VCD app.
When I get home, I'll try to post a screen shot.
Paul
post #2478 of 4110 Old 11-05-2009, 07:08 AM
genro's Avatar
I had a similar issue and I believe it's related to Mediainfo. Do you have it installed? Basically the first time you go to the folder it takes a while because media info needs to get all the properties of the files. I think if you leave it there for a while it should eventually come into focus and not do it again once it's cached locally.
Otherwise try uninstalling mediainfo.
genro is offline
post #2479 of 4110 Old 11-05-2009, 11:43 AM
ebr
ebr's Avatar
This is a focus issue that we haven't nailed down yet. If you have a mouse attached, simply move it over the covers and they will light up.
I don't think it is related to MediaInfo, but, since we don't know exactly what it is, I suppose it could be. Somehow, the current selected index is ending up at zero (look at the counter on the page, it will say 0 | nn).
ebr is offline
post #2480 of 4110 Old 11-05-2009, 12:00 PM
Iteki's Avatar
I have a similar issue...I use the dinovo mini and just dpad over to the right and the covers show (mousing works too). It never actually freezes. It's not a huge issue, just a bit of an annoyance.
I'm no expert....so your mileage may vary
XboxLiveID: archie68
Iteki is offline
post #2481 of 4110 Old 11-05-2009, 01:01 PM
huskerpat's Avatar
It's not me going crazy then. I wondered why it was doing that.
Life is tough, but it's tougher when you're stupid. - John Wayne
huskerpat is offline
post #2482 of 4110 Old 11-10-2009, 06:16 PM
spillz564's Avatar
Is there any way to sort by series for Recorded TV. I'm using MB 2.1.3 with the Diamond Theme and using the DVR-MS plugin on Vista and Win 7.
It would be nice to have all the "60 minutes" and "Jay Leno Show" under one heading like it is the the native recorded TV in media center.
I tried sorting by Genre but the view freaks out under Recorded TV. Does anyone know if there is a way to do this?
Half-knowledgeable but fully dangerous.
spillz564 is offline
post #2483 of 4110 Old 11-10-2009, 08:05 PM
mike_311's Avatar
i guess you linked you recorded tv folder that windows uses?
you could get a batch file to move the recorded tv files to a different folder that MB looks at. and keep each show in its own folder.
like this:
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #2484 of 4110 Old 11-10-2009, 09:01 PM
tycoonheart's Avatar
like this:
How'd you get mediabrowser to look like that?
That looks very nice.
tycoonheart is offline
post #2485 of 4110 Old 11-10-2009, 09:05 PM
mike_311's Avatar
diamond theme, cover flow, stark covers...
mike_311 is offline
post #2486 of 4110 Old 11-10-2009, 09:16 PM
How'd you get the covers to spread out like that? Mine are like literally stuck to one another. Can't find the option to change that.
post #2487 of 4110 Old 11-11-2009, 04:04 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
In the configuration under the "General" option there are options under "Views" called Poster Grid Spacing. I assume this should allow to adjust the spacing between covers.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #2488 of 4110 Old 11-11-2009, 04:08 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Meant to post this here earlier, here is the writeup I did on the latest Media Browser release:
http://www.mediasmartserver.net/2009...1-3-0-phoenix/
Cheers,
Damian
post #2489 of 4110 Old 11-11-2009, 06:47 AM
Servicetech571's Avatar
It's a tough one for sure. I haven't found a Windows program that could crack it. K9copy (Free linux program) got it.
Servicetech571 is offline
post #2490 of 4110 Old 11-11-2009, 06:59 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Has anyone tried with AnyDVD? I had no problems using AnyDVD with the Blu Ray disc.
Cheers,
Damian
Reply Home Theater Computers
