What is "Clear QAM" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-16-2008, 05:30 PM - Thread Starter
rbmcgee's Avatar
Hi all,
I've had directv forever but I'm trying to help someone with cable TV. I have some questions, this is the first one.
Bob
rbmcgee is offline
post #2 of 13 Old 12-16-2008, 05:34 PM
chris5977's Avatar
Read this and let us know if you have any questions:
http://en.wikipedia.org/wiki/QAM_tuner
PSN Gamertag: chris5977
In War: Resolution
In Defeat: Defiance
In Victory: Magnanimity
In Peace: Good Will
Winston Spencer Churchill
chris5977 is offline
post #3 of 13 Old 12-16-2008, 05:38 PM - Thread Starter
rbmcgee's Avatar
Is the opposite of "Clear QAM" encrypted QAM?
Bob
rbmcgee is offline
post #4 of 13 Old 12-16-2008, 05:53 PM
chris5977's Avatar
Correct. To get the encrypted stuff you need:
1. A cable box from the cable company; or
2. A TV with cableCARD; or
3. A DVR with cableCARD; or
4. A pre-built HTPC with cableCARD.
There was talk of allowing consumers to buy their own cable box and put a cableCARD in it, but I don't know if this has happened.
See here for more info:
http://en.wikipedia.org/wiki/CableCARD
Typically the cable companies broadcast the main networks (ABC, NBC, FOX, etc.) in the clear.
In War: Resolution
In Defeat: Defiance
In Peace: Good Will
post #5 of 13 Old 12-16-2008, 05:58 PM - Thread Starter
rbmcgee's Avatar
My friend can hook a digital TV to the raw cable outlet (gets Charter Digital) with no cable box in the mix and receive channels. Does that mean that all those channels that can be tuned are clear QAM?
Bob
rbmcgee is offline
post #6 of 13 Old 12-16-2008, 06:00 PM
sneals2000's Avatar
Quoted: 253 Post(s)
Liked: 131
Yes - Clear QAM broadcasts are unencrypted.
sneals2000 is offline
post #7 of 13 Old 12-16-2008, 06:04 PM
chris5977's Avatar
That's not necessarily true. Your friend could be looking analog content. How to tell the difference?
Digital channels have a decimal: 5.1 instead of 5
Digital looks better.
In War: Resolution
In Defeat: Defiance
In Peace: Good Will
post #8 of 13 Old 12-16-2008, 06:14 PM - Thread Starter
rbmcgee's Avatar
This is where I get confused. The relevants:
Subscribes to Charter Digital cable
Hooks up a digital tuner TV to the raw cable and receives channels, tuned by the TV. No channels are .1 channels however many, many of them are "cable" channels (ESPN, etc).
Looks like analog to me.
Question, if they are analog, will those channels go away after 2/09? Or, do cable companies grab the digital signals, convert them to analog and then still pump it to your house? The cable company claims no problem getting the signals after the conversion date. Seems odd to me.
Bob
rbmcgee is offline
post #9 of 13 Old 12-16-2008, 06:30 PM
sneals2000's Avatar
Quoted: 253 Post(s)
Liked: 131
It is only analogue OTA channels that are legislated to disappear in the US after 2/09.
Analogue cable channels can continue as apart from rebroadcasts of OTA channels (which if sourced from analogue currently will need to switch to a digital received version if to continue), almost everything else on analogue cable (including pay-TV stuff like ESPN) is distributed to the cable companies via a digital distribution system (off-air satellite or fibre AIUI)
However the OP was asking about QAM - which is the digital modulation system used for digital cable - with clear QAM being unencrypted, and pay-TV cable using encryptio. Analogue cable uses NTSC-M modulation AIUI.
post #10 of 13 Old 12-16-2008, 06:32 PM
sneals2000's Avatar
Quoted: 253 Post(s)
Liked: 131
??? Analogue broadcasts use NTSC not QAM. The OP was asking about Clear QAM (which is a digital standard) not NTSC (which is analogue)?
post #11 of 13 Old 12-16-2008, 06:32 PM
vladd's Avatar
Liked: 39
sneals2000 is correct. All clear QAM broadcasts are unencrypted. If they are encrypted, then they are not "clear".
vladd is offline
post #12 of 13 Old 01-13-2009, 08:50 PM
ryoushi's Avatar
This is Clear QAM. Then Charter is clear QAM, at least in central MN. My parents recently bought a 32' HDTV and a 23' HDTV/Monitor and when I auto programmed the channels, the extended basic cable included these channels.
ryoushi is offline
post #13 of 13 Old 01-13-2009, 09:23 PM
vladd's Avatar
Liked: 39
A cable company can have both clear and encrypted channels on their system. "Clear" QAM is a per digital channel designation. It is possible to have 5.1 in clear QAM (unencrypted) and have 5.2 encrypted (not clear).
Channel 5 would be analog but the 5.1, 5.2, etc would be QAM. If your TV can pick them up without a cable box, then they are Clear QAM. Also, channel 5.1 could actually be on the frequency for physical channel 71. The reason this is possible is due in part to the Digital Transition. Broadcasters needed to keep transmitting their analog and you couldn't have a digital and analog channel on the same frequency. So your analog channel 5 could be broadcast on physical channel 17. They used the digital virtual channel to reassign the number that everyone would recognize (5.1).
vladd is offline
Reply Home Theater Computers
