Compressing BD-50 blu ray's to fit on a BD-25 disc. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By wmcclain
post #1 of 27 Old 01-07-2009, 07:05 AM - Thread Starter
SiciliaYItalia's Avatar
Can anybody give me some advice on how to compress BD-50 blu ray's to fit onto a BD-25 disc? I used to use DVDShrink to take out the extra features and such on dvd's, is there any program similar to that for Blu Ray?
Thanks in advance!
SiciliaYItalia is offline
post #2 of 27 Old 01-07-2009, 10:43 AM
salacious's Avatar
I haven't looked at the software but one I have read about is BD Rebuilder
http://forum.doom9.org/showthread.php?t=143716
I'm not sure if the BD25 reduced size file is playable from standalone, PS3 or only from a PC
__________________________
Blu-Rays 100
HD DVDs 65
DVDs 300+
salacious is offline
post #3 of 27 Old 01-07-2009, 11:04 AM
rockytt's Avatar
IMHO, don't get involved with the whole compression thing -
Short answer, no there is no single program to strip out extras like DVDShrink, however, the process is VERY easy using 3 (or 4) programs:
http://forum.slysoft.com/showpost.ph...81&postcount=1
I repeat, it's VERY easy to do this (and I hate learning new things) - strip out everything except the main movie and you are almost always left with an iso smaller than 25 gb
rockytt is offline
post #4 of 27 Old 01-07-2009, 01:55 PM
YONEXSP's Avatar
BD Rebuilder is a 1-click process to do exactly that, will strip out everything if you so require & put the movie only on a BD-25 or even a BD9 (DVD+ RL).
YONEXSP is offline
post #5 of 27 Old 01-07-2009, 05:01 PM
rockytt's Avatar
What kind of time is required for this (curious, not challenging) - in reading the thread on this (beta) product is appears that folks were spending up to 24 hours simply re-encoding a single movie w/o extras-
Maybe it's gotten better?
rockytt is offline
post #6 of 27 Old 01-07-2009, 05:27 PM
YONEXSP's Avatar
for a 1.5hr movie on a dual core e2200 basic cpu it took 16 hrs on mine. The dark knight took 22hrs
Sone with good 3+ghz quad cores were doing it in 6-8 hrs
YONEXSP is offline
post #7 of 27 Old 01-07-2009, 06:45 PM - Thread Starter
I forgot to ask..will I be able to play the BD-25 in my PS3 or other standalones?
post #8 of 27 Old 01-07-2009, 07:12 PM
Max_Schreck's Avatar
Yes, you should have no problems as long as you stick to the BD specs. Heck, I re-encoded 2 movies to AVCHD ("home made" blu ray) on DVD5 and they play fine in my Panny BD35. MeGUI and tsMuxer truly are God sends
Max_Schreck is offline
post #9 of 27 Old 01-07-2009, 07:22 PM - Thread Starter
Do you use BD Rebuilder at all? I downloaded TSMuxer, but have no idea how to use it yet lol.
post #10 of 27 Old 01-07-2009, 07:42 PM
No, I heve never used it. I use DGAVCIndex to index the frames in the h264 file, AviSynth to resize and frameserve, MeGUI to reencode video with x264 and to transcode the audio if necessary, finally I use tsMuxer to create the BD structure which I burn onto a disc with ImgBurn. Of course you need AnyDVDHD to be able to copy the necessary files to the hard drive. My method probably takes longer than using BDrebuilder, but it works for me so I'll stick with it until I hear that BDRebuilder is past the beta stage.
post #11 of 27 Old 01-07-2009, 09:15 PM - Thread Starter
So when I use AnyDVDHD to copy the files to my PC, I dont copy it as an iso, but as Video files right? I am such a noob to this, it was much easier with Dvd's
post #12 of 27 Old 01-07-2009, 11:16 PM
rockytt's Avatar
Please read the link in post #3 - very easy to do and doesn't take 12 hours(!)
rockytt is offline
post #13 of 27 Old 01-08-2009, 04:03 AM - Thread Starter
Thanks, I learned a lot from reading that post. However, I have one more problem. The movie I am practicing this on is Next, and even if I only choose the main movie, it is still 30gb. What do I do to compress that to fit onto a BD-25?
post #14 of 27 Old 01-08-2009, 05:19 AM - Thread Starter
I took off everything but the main presentation of Next, and the audio..and it came out to be 27.3gb Looks like there will have to be a small amount of compression used..not sure how though...
post #15 of 27 Old 01-08-2009, 06:22 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I've tried BD-Rebuilder (also using The Dark Knight) and stripped out just the main movie and sized it to fit on a DVD-9 disc. The results were virtually indistinguishable from the original BD rip. There are options for compressing either the full disc or just the main movie to either BD-25, DVD-9, or DVD-5. You should have no problems getting your movie shrunk to fit on a BD-25 disc and the results will be fantastic.
Keep in mind that BD-Rebuilder is still just a beta release so expect to encounter an occasional bug. I did get an error message during the process but it didn't seem to affect the overall processing or results.
I'm a long-time user of DVD-Rebuilder (also developed by jDobbs) and it's by far the best app available for compressing standard DVDs. Lots of people like DVD Shrink but DVD-RB blows it out of the water with respect to picture quality. I would expect nothing less than the best from BD-Rebuilder. It may be time consuming, but you have to realize what you're dealing with. The amount of data being processed is massive so expect the time involved to reflect the task at hand.
captain_video is online now
post #16 of 27 Old 01-09-2009, 05:41 AM - Thread Starter
How long do you guys think it will take for BD-50's to drop in price? How long did it take DVD-9's to drop?
post #17 of 27 Old 01-09-2009, 06:24 AM
DVD9s are still expensive if you want to buy the good stuff. Hit and miss cheap off a spindle discs can be had for little less than a buck. But my guess is that it will be a long long time before even 25GB discs are affordable.
post #18 of 27 Old 01-09-2009, 06:43 AM
MHoefler's Avatar
Originally Posted by captain_video View Post
I'm a long-time user of DVD-Rebuilder (also developed by jDobbs) and it's by far the best app available for compressing standard DVDs. Lots of people like DVD Shrink but DVD-RB blows it out of the water with respect to picture quality...
From my experience, this is not true! If you enable the 2-pass encoding in DVD Shrink, the results are equal (and some times better) than with DVD Rebuilder. Also, DVD SHrink is a 100 times faster...
Furthermore, the new BR Rebuilder lacks the option to rebuild to BD-50. Why would I need that? Because I don't want any recoding to keep the image at the best possible level, but still I need to strip all the extras, unneeded languages, etc. to save space on my media server.
I'm putting all my hopes into SlySofts CloneBR, which is apparently under development!
Regards!
MHoefler is offline
post #19 of 27 Old 01-09-2009, 08:56 AM
Quoted: 510 Post(s)
Liked: 336
That all depends on which encoder you're using with DVD-RB. If you're using the freeware QuEnc that comes with DVD-RB then I'd be inclined to agree with you. I'm using CCE (CinemaCraft Encoder) and the results are noticeably better than DVD Shrink, at least with the movies I tried it with. I haven't used DVD Shrink in a very long time so I have no idea if they've made improvements to it.
DVD Shrink is definitely much faster than DVD-RB, but then DVD-RB does a much better job at re-encoding the data than DVD Shrink, IMHO. I'd rather use an app that takes the time to do the job right than give me a quick and dirty fix in less time.
post #20 of 27 Old 01-09-2009, 09:13 PM - Thread Starter
25gb discs are affordable? I just bought 25 of them for only $2.99 a piece..I think thats affordable. Much better than they were a year ago...
post #21 of 27 Old 01-10-2009, 05:23 AM
Please tell where you bought them from, the cheapest I have seen is $11.00 a piece.
post #22 of 27 Old 01-10-2009, 04:04 PM - Thread Starter
Newegg.com
http://www.newegg.com/Product/Produc...82E16817132051
Looks like they went back up to $4.99 a piece...they did this before, but quickly went back down to $2.99...
post #23 of 27 Old 01-10-2009, 07:33 PM
Quoted: 21 Post(s)
IME DVD Shrink does an OK job if you're not too picky and if you're not compressing to less than about 75% of the original program size. Any more compression than that and DVD Shrink can look pretty awful.
I have always used the free HC encoder (Hank's encoder) with DVD-RB and it is excellent. DVD-RB is an excellent product and one can expect that BD-RB will become one too (it is still in the early beta stage of development).
Laserfan is offline
post #24 of 27 Old 01-10-2009, 07:49 PM
Quoted: 510 Post(s)
Liked: 336
Newegg has the 10-pk Verbatim 25GB BD-R discs for $49.99 and only $6.99 shipping.
http://www.newegg.com/Product/Produc...82E16817130047
post #25 of 27 Old 01-12-2009, 05:11 PM - Thread Starter
I just want the price of BD50's to go down, so I dont have to bother with compressing blu rays
post #26 of 27 Old 03-30-2015, 06:36 PM
Grendel007's Avatar
Quoted: 33 Post(s)
Hello Guys
I would like to update this thread.
Has anyone tested any commercial software that could enable compress BD-50 blu ray's to fit on a BD-25 disc?
Is there any software that is faster and much more convenient than BD-Rebuilder?
Grendel007 is offline
post #27 of 27 Old 03-30-2015, 07:34 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Originally Posted by Grendel007 View Post
Hello Guys
Try this thread: Ripping Blu-Rays II
-Bill
Grendel007 likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Reply Home Theater Computers
