In search of a MEDIA PLAYER - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-12-2009, 02:47 AM - Thread Starter
G-Returner's Avatar
Hello all,
I'm looking for an external Media Player in order to play my Avi/DivX files on my TV.
My requirements are:
- Able to play Avi/DivX files. The more formats supported, the better.
- Able to play subtitle .srt files
- Hard drive of 100 gigabytes or more
- Reasonable price
Do you know of such a player?
G-Returner is offline
post #2 of 6 Old 01-12-2009, 03:30 AM
ApexHack's Avatar
Popcorn Hour, although you'll have to add your own HDD.
Cheers
ApexHack is offline
post #3 of 6 Old 01-12-2009, 04:52 AM - Thread Starter
G-Returner's Avatar
Thanks but I don't have an external HDD and I'm looking to buy it in a single package with the media player.
post #4 of 6 Old 01-12-2009, 05:09 AM
ApexHack's Avatar
It'll take an internal too.
I really don't think there's anything like it out there. I sure wouldn't let the fact that you can't order a hdd with it from stopping you. How long does it take to put a hdd in it, what, 5 minutes?
ApexHack is offline
post #5 of 6 Old 01-12-2009, 06:55 AM
vfortier's Avatar
Put in a second vote for PopCorn Hour
Putting an internal HD is really easy.
The interface is not up to par with an AppleTV but it plays everything I wanted (including MKV and divx)
vfortier is offline
post #6 of 6 Old 01-12-2009, 08:13 AM
sneals2000's Avatar
Quoted: 255 Post(s)
Liked: 131
Popcorn Hour - internal HD very easy to fit. I've got one and it does a good job - plays nearly every format, and has good subtitle support for SRT files. Does a good job with HD - but has composite, S-video, component and HDMI outputs from 480i to 1080p resolutions.
Also the AppleTV hacked to run XBMC is worth looking at - though is SD and low-end HD only really.
Some of the other low-end media players have basic SRT support - you have to ensure a common filename for the AVI and SRT file with the only naming difference being the SRT or AVI extension on many of them otherwise it won't see the file.
sneals2000 is offline
Reply Home Theater Computers
