Multiple Monitors Separate Refresh Rates - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-12-2009, 09:15 PM - Thread Starter
KevinMRoach's Avatar
I have a HTPC set up with two TVs(Same image at the same time). My big TV in the entertainment room supports 24p and the smaller Kitchen TV doesn't. both support 1080p/60.
What I would LIKE to do is set up the entertainment room TV to use 1080p/24 and the kitchen at 1080p/60. I can't for the life of me figure out how to do this. Has anybody does this before? Do I need separate video cards for each monitor? Right now I'm using one card with two DVI outputs.
KevinMRoach is offline
post #2 of 12 Old 01-13-2009, 02:14 AM
whymeintrouble's Avatar
need more info, post the specs of everything you are trying to get to work together
whymeintrouble is offline
post #3 of 12 Old 01-13-2009, 09:02 AM - Thread Starter
HTPC:
Intel Core 2 Duo 3.0
4 Gigs Ram
Video card ATI Radeon 3850 Dual DVI
Windows XP
Media Portal as my front end/Media Player
My two TVs are a Panasonic TH46PZ80 and a Sharp LC32D62U input through HDMI
post #4 of 12 Old 01-13-2009, 09:59 AM
walford's Avatar
Does your big TV support 120Hz refresh and also the ability to select 5:5 pulldown when receiving 1080p/24 to eliminate judder?
If not the TV will just upscale your 1080p/24 to 1080p/60 which is the native resoloution and refresh rate of your TV.
If not there is not any real benefit to sending it 1080p/24 when playing Blu Ray DVDs since all other movement on your desktop such as cursor movement will be slower then normal.
walford is offline
post #5 of 12 Old 01-13-2009, 10:27 AM - Thread Starter
On my TV Box is said it supports 480hz but I can't find anything about 5:5 pulldown.
post #6 of 12 Old 01-13-2009, 11:44 AM
Calcvictim's Avatar
is the tv a plasma(maybe Panasonic) if so then it's internal refresh and has nothing to do with it accepting 24/48/120 hz
Calcvictim is offline
post #7 of 12 Old 01-13-2009, 12:35 PM - Thread Starter
Ah ok well its a Plasma Panasonic so never mind about the refresh rate.
I have other reasons besides the refresh rates. I would like the resolution for the Kitchen TV to be different than the Big TV. I have to run the PC in Clone mode so I can get the same image on both TVs(Media portal on both). Is there any way to do that?
post #8 of 12 Old 01-13-2009, 12:43 PM
rockytt's Avatar
Nope - can't run clone mode with different resolutions/refresh rates
rockytt is offline
post #9 of 12 Old 01-13-2009, 04:37 PM - Thread Starter
Any advice then on how to run a front end(I.E. Media Portal) on two screens different resolutions without using clone mode?
post #10 of 12 Old 01-13-2009, 05:35 PM
walford's Avatar
At the san time or at different times.
If at different times just have a Icon for the application on both the primary and secondary displays by copying the Icon from the primary to the secondary.
walford is offline
post #11 of 12 Old 01-14-2009, 04:09 PM - Thread Starter
They don't "need" to be at the same time, but using a mouse to double click an icon is acceptable. Both of these TVs are controlled with Harmony Remotes as if it is a regular TV. It's geared towards non-techy people who can turn it on and watch entire collections of videos or pause/record live TV.
post #12 of 12 Old 01-17-2009, 01:15 PM
Eiffel's Avatar
Quoted: 13 Post(s)
It's possible to run the same resolution with different refresh rates in clone mode. I'm running a monitor using 1080p @ 60Hz over DVI while driving my analog projector with a 1080i (30Hz) signal.
Results may vary with video cards and drivers, but my Nvidia 8600GT does work fine.
Eiffel is offline
Reply Home Theater Computers
