Open Media Library (OML) - Fantastic VMC plugin for DVD/Blu-Ray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-22-2009, 09:05 AM - Thread Starter
I'd like to point out to everyone a fantastic project for another front end for your HTPCs. I know some people around here are using this already, but things are really progressing along nicely with the OML project, and its the only solution I've found that works perfectly for my needs.
The front end is integrated with VMC, and is just for movies. A new icon is added to the TV + Movies strip in VMC, and you can select your coverart for whatever movie you would like to watch. The plugin supports both daemon tools and Virtual Clone Drive perfectly, and can also launch into any external player for Blu-Ray playback. The plugin even monitors when the external application (like TMT) is running, and upon exiting the player will automatically revert back into VMC.
Personally, I find this plugin to be the perfect front end application for movie selection because it blends in so perfectly with the rest of VMC and supports fantastic Blu-Ray playback (with external player). I highly recommend it, and suggest checking out the main page and the discussion forum:
http://code.google.com/p/open-media-library/ - Main Google code page
http://www.ornskov.dk/forum/index.php - Discussion Forum
jdubbs23 is offline
post #2 of 10 Old 01-22-2009, 09:38 PM
Neo541's Avatar
Does it work with Windows 7?
Living Each Day Well Above My Means...
Neo541 is offline
post #3 of 10 Old 01-23-2009, 01:22 AM
pastishe's Avatar
while oml is nice, i would recommed media browser if you don't need to worry about blu-ray (though that is in the process of being supported).
To the op, it's worth checking out media browser, i was sold on oml a few weeks back before i checked it out. The automation of metadata and art downloading and the centralization of all the video media is what got me.
pastishe is offline
post #4 of 10 Old 01-23-2009, 12:54 PM - Thread Starter
I have read a lot about Video/Media Browser on these forums, but as far as I know it currently does not mount with Virtual Clone Drive. I'm not sure about the ability to launch into an external application (TMT) either, which is also essential for me.
jdubbs23 is offline
post #5 of 10 Old 01-23-2009, 01:29 PM
Youg's Avatar
All of these things are plan for future release. But these guys work so fast that it should not be very long before it's done.
Give it a try and choose what best fit you.
Youg is offline
post #6 of 10 Old 01-23-2009, 01:50 PM
DraZtiK's Avatar
There is one thing I hated about my movies and that was the size of the program with its additional components. mymovies requires 70 meg download, OML is 10 megs now but...installs its own database, is a server required or in the future going to implement one?
As far as Media Browser it is an 840KB download that runs extremely fast for me looks better than OML judging from the screenshots from both and has talks for Blu-ray and HD DVD. Why would I want to try OML?
DraZtiK is offline
post #7 of 10 Old 01-24-2009, 06:15 AM
cybrsage's Avatar
Liked: 154
Because media browser does NOT have BR and HD-DVD support.
If you need support for these two items, you cannot use media browser. If you do, you will not get support for these two items.
That is the point of OML. It provides support for everything.
Note that I do not use either one. I tried out mb, but it does not add enough extras to have me switch from the VMC media library hack. I also tried out OML, but it is not polished enough for me. I stayed with the VMC media library hack.
cybrsage is offline
post #8 of 10 Old 01-24-2009, 06:44 AM
DraZtiK's Avatar
I have yet to try it but according to the change list it does.
* Fix so external players mark the watched flag
* Fix spelling of BluRay
* Ensure we recognise folders with BDMV and HVDVD_TS folders in as movies
* Ensure we only try external player if we are not on an extender
* External player support, add section to config file for
Avi
wmplayer.exe
"{0}"
Where ExternalPlayer element is repeated for each required mediaType.
Valid MediaType values (case sensitive)are Avi, Mkv, DVD, BlueRay, HDDVD
DraZtiK is offline
post #9 of 10 Old 02-18-2009, 08:12 AM - Thread Starter
I thought I would get some pictures up in here so people had an idea of what OML looks like right now.
jdubbs23 is offline
post #10 of 10 Old 02-20-2009, 07:24 AM
el Filou's Avatar
OK, so it's just yet another movie library with option to launch an external player.
What would actually be fantastic is Blu-ray and HD DVD playback inside VMC/MediaPortal or something else without having to launch an external player.
el Filou is offline
Reply Home Theater Computers
