ArcSoft TotalMedia Theatre & sleep on inactivity? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2009, 05:29 AM - Thread Starter
vinomarky's Avatar
Hi All,
While watching HDDVD movies with the Vista MCE plugin launched TotalMedia Theatre I have my machine go to sleep periodically.
It's not the software crashing, the machine simply goes to sleep. I can re-power it up no problems
I do have a sleep on inactivity period set, but while playing DVD's through the native MCE interface it seems to be smart enough to detect that even though I am not pressing any buttons, the system is not 'inactive'.
I am guessing that the TotalMedia plugin somehow loses these smarts....
Has anyone else had this issue? are there any suggestions out there beside simply removing my sleep on inactivity setup?
vinomarky is offline
post #2 of 5 Old 01-27-2009, 06:09 AM
cybrsage's Avatar
Liked: 154
What version of TMT are you running?
Are you using the MCE Standby Tool?
cybrsage is offline
post #3 of 5 Old 01-27-2009, 01:42 PM - Thread Starter
vinomarky's Avatar
Thanks - am using TMT v2.1.6.128, and yes I am using MCE Standby tool
post #4 of 5 Old 10-22-2009, 06:31 PM
flic3d's Avatar
Has there been any resolution to this? I am experiencing the same thing. Thanks.
flic3d is offline
post #5 of 5 Old 10-23-2009, 01:55 AM
fraggermcg's Avatar
Can't you just adjust your MCE Standby system idle settings so that the system usage is above the threshold where it starts counting down going into standby?
fraggermcg is offline
Reply Home Theater Computers
