Can someone clear up QAM for me - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-29-2009, 02:36 PM - Thread Starter
mattintx's Avatar
Hi
I understand that QAM goes through your local cable provider for unencrypted broadcasting. To recieve QAM channels do you need to have digital cable or will basic analog have it?
thanks
Matt
mattintx is offline
post #2 of 2 Old 01-29-2009, 02:51 PM
grittree's Avatar
Quoted: 260 Post(s)
Liked: 148
All the cable signals are on the wire(*). The plan you subscribe to just determines which channels are enabled on any "cable box" that you have inside.
Without a box, it just depends on which channels your tuner can decode. Modern TVs and other tuners can decode analog and unencrypted QAM.
(*) They can put a "trap" at your house to prevent certain frequencies, most frequently for HBO on Ch2 analog.
grittree is offline
Reply Home Theater Computers
