Buy LG Blu-ray OEM or Retail and case Q - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-06-2009, 07:47 AM - Thread Starter
Rabbits's Avatar
I am putting a LG GGC-H20L in the following build and plan on using ANYDVD on the system. Does it make sense to buy the LG's retail version w/ PowerDVD 8 OEM to be able to play blu-ray discs? I am using ANYDVD will I still need to run PDVD 8 (and possibly upgrade to Ultra from OEM) for BD play.
Also, does anyone see a problem using a IN WIN Mt. Jade BK623 for this build?
Here is the build:
GIGABYTE GA-E7AUM-DS2H Micro ATX Intel Motherboard
Intel Pentium E5200 2.5GHz LGA 775 65W Dual-Core Processor
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 TWIN2X4096-6400C5 (great deal $27/us after $30/us rebate)
IN WIN IW-BL631.300BLP Black Computer Case
LG Black Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner SATA Model GGC-H20L
Sony Bravia 46z4100
Tks for all your help
Rabbits is offline
post #2 of 8 Old 02-06-2009, 11:57 AM - Thread Starter
Rabbits's Avatar
er Bump?
Rabbits is offline
post #3 of 8 Old 02-06-2009, 12:39 PM
DanITMan's Avatar
Here is the build:
Sony Bravia 46z4100
When I purchased my LG Blu-ray/HD-DVD combo drive from NewEgg I got the OEM version. It came with a copy of PowerDVD 7.3 It seems that both the retail and the OEM versions come with the software. The only thing missing is the box.
DanITMan is offline
post #4 of 8 Old 02-06-2009, 05:57 PM
rdunnill's Avatar
Here is the build:
Sony Bravia 46z4100
I use PDVD 7.X with the same drive and a lesser CPU. Works great.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #5 of 8 Old 02-06-2009, 08:14 PM
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
There is only a diff between the LG writable drive packages other then the box. The OEM comes with PDVD and a burning suit of SW and the retail comes with the same but also a blank 25gb BD-RE. There is no diff between the OEM and retail BD only LG readers.
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
post #6 of 8 Old 02-06-2009, 08:38 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
Well.... I just purchased the LG GGC-H20L retail @ my local frys for 99.00
It plays both Blu and HD-dvd. It came with free Cyberlink software to play both formats.
I don't own much of either movie formats, but I played them both on it w/ Cyberlink and I do-not have any issues. It is very, very quite and simple install my Win XP sp3.
It also plays and burn dvd & CD-r +/-/RW
I like the LG over my recently purchased SAMSUNG SH-S223Q; which is 2x Winner of Customer Choice Award - CD / DVD Burners from NEWEGG. Since I can compare the Samsung is much louder when playing dvd movies. The LG is like S-T-E-A-L-T-H
Oh as for the OEM vs. Retail.
OEM is just the drive (at least that's what it was when I got my samsung) no hardware / sata cable ect..ect.
The retail comes with all the goodies. I would get the retail if I was you, well...... as long as your not going to pay over $10-$20 more over OEM.
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
post #7 of 8 Old 02-07-2009, 05:57 PM - Thread Starter
Rabbits's Avatar
Thanks for the advice, I ended up buying the retail version of the BD player.
I also ended up ordering a InWin BK636, 12.7" x 5.5" x 10.8". We will see how the build goes (assuming they actually ship the case).
Rabbits is offline
post #8 of 8 Old 02-07-2009, 10:25 PM
PhillipH's Avatar
I bought my LG GGC-H20L OEM version from Newegg last month. I received the drive, a sata cable & Powerdvd 7.3 6 channel version. Plays everything I've thrown at it.
SageTV v7 WHS + 2 HD200s
Windows Home Server PP3 - Dual Xeon 2.8ghz
23 Drives - 26 Terabytes
Blu-ray Titles 251
HD-DVD Titles 166
DVD Titles - Too Many To Count..
PhillipH is offline
Reply Home Theater Computers
