The Inconvenient Truth about SPDIF Input! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 193 Old 04-05-2016, 10:29 AM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
Yeah, I was only processing audio on the HTPC (unless the HTPC was the video source).
-tm
millst is offline
post #182 of 193 Old 04-07-2016, 02:19 AM
GrandeBoma's Avatar
Quoted: 17 Post(s)
millst did you use graphstudio tu create these wasapi input to jriver program? could you be more specific? I am trying to get the spdif input of a lynx to communicate with jriver
GrandeBoma is offline
post #183 of 193 Old 04-07-2016, 10:43 PM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
No, from what I remember, the Directshow filters have large buffers and it's difficult (impossible?) to get less than 500ms delay. That's fine for conversion, but I needed something near real-time. I was creating a C++ app based on the liba52 library, WASAPI API, and ASIO SDK.
-tm
millst is offline
post #184 of 193 Old 04-08-2016, 01:04 AM
GrandeBoma's Avatar
Quoted: 17 Post(s)
any chance you could share this nice program? I would like to test it with my lynx. Can it be made compatible with another soundcard? I would be very interested in such a workaround.
post #185 of 193 Old 04-08-2016, 11:20 AM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
It's been over a year since I looked at it and only in a prototype phase. It was targeted to the JRiver ASIO input and a console application with a text menu...not ready for integration into a HTPC setup. It just wasn't worth the time and money to put everything together. It wasn't going to compete with a pre-pro. I was only considering that solution in the first place because I had some unique requirements for driving three zones digitally.
-tm
millst is offline
post #186 of 193 Old 04-09-2016, 08:54 AM
GrandeBoma's Avatar
Quoted: 17 Post(s)
If I wanted to set up something similar, how would I open an spdif input with wasapi? which console program?
post #187 of 193 Old 04-11-2016, 11:42 AM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
I don't know of any software that does it, which is why I was writing code.
-tm
millst is offline
post #188 of 193 Old 04-11-2016, 11:34 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
do you mind if I test your software on my system?
post #189 of 193 Old 04-13-2016, 02:26 PM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
Sorry, it's not in distributable form and I'm not interested in spending time on it as I've already moved on from the concept. Just buy a pre-pro...it's cheaper and involves many less headaches.
-tm
millst is offline
post #190 of 193 Unread 03-04-2017, 01:06 AM
Liked: 0
Originally Posted by dadudster View Post
...even though the Realtek chipset is able to recognize that the signal it is receiving IS, in fact, an AC3 signal.
You can verify this on your own by simply plugging a device that is outputting Dolby Digital directly into the SPDIF input and goto the Realtek HD Audio Manager ---> Digital Input tab ---> Digital Audio Input tab. You will see under Sample Rate: "AC3 48Khz"....
WHAT IS NOT POSSIBLE:[LIST][*]Source outputting an AC3 stream ---> SPDIF input on your computer ---> 5.1 speakers connected to your computer.[*]Source outputting an AC3 stream ---> SPDIF input on your computer ---> AC3 Software Decoder ---> 5.1 speakers connected to your computer.
The problem, I think, is mostly legal.
I know this post is years old, but for what it's worth I just want to thank you for going through this work. I started working on the same idea this weekend, and ran into the same dead end. This post came up in a search result and I was glad to find it. Now I know the Realtek ALC889 on my Gigabyte UD9 motherboard with onboard Optical SPDIF Input, is only usable with 2ch PCM. I was not able to confirm this with anything I read, and the mere fact that the management application can tell that I am sending it AC3, really made me question the dead end. Optical SPDIF Input worked great when I sent it 2ch PCM.
I did some testing with a Playstation 2 and games that do DTS live, as well as a PS3 playing a DVD with both DTS and DD5.1 tracks. (Stargate).
I was hoping to record some video game play, and include the DTS or DD 5.1 audio. Have any sound cards come out in the market since 2009, that will now do this from Optical?
bytesaber is offline
post #191 of 193 Unread 03-04-2017, 10:26 PM
Worf's Avatar
Quoted: 475 Post(s)
Liked: 231
There are capture cards that can accept Dolby digital from optical and they're also popular with the game streaming crowd. Cards like the HD-PVR2 from Hauppage and others.
And yes, they capture in HD as well.
Worf is offline
post #192 of 193 Unread 03-06-2017, 03:48 PM
millst's Avatar
Quoted: 124 Post(s)
Liked: 79
At one point, I played around with one of those, but gave up because the latency was horrible. The device was great for capture since you don't care about the latency. It's not so great when you're trying to fast forward on your TiVo and everything is off by half a second or so.
-tm
millst is offline
post #193 of 193 Unread Today, 08:40 AM
sebus's Avatar
ESI - U24 XL with 2.6 drivers on Windows 7 x64 do great direct recording of DTS/AC3 5.1 directly with ASIO drivers in ie Audacity 2 ASIO build
sebus is online now
Reply Home Theater Computers
