ATI Catalyst 9.2 RELEASED! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 71 Old 02-20-2009, 10:48 AM - Thread Starter
daMaster's Avatar
Well, the ATI Catalyst 9.2 drivers are out today.
Tried them yet? Post your findings here.
One of the items in the Release Notes that's crucial to most of us is:
- [...] component video pixel format settings are retained on system restart
I'm not sure if that refers only to the Y:Cb:Cr or also to the RGB 4:4:4 options.
daMaster is offline
post #2 of 71 Old 02-20-2009, 11:14 AM
Cetrian's Avatar
taking the plunge! will report back.
Pioneer lover: Elite TV and AVR | HTPC Masochist | Bit-perfect Audiophile | Networking Guru |
Cetrian is offline
post #3 of 71 Old 02-20-2009, 11:56 AM
DPlettner's Avatar
The release notes state that the Pixel Format will stick after a reboot. I was not having that problem with 9.1, but I know that others did.
I installed 9.2, and everything seems fine. I did notice a new option:
Anybody know what ITC Processing does?
-Dave
DPlettner is offline
post #4 of 71 Old 02-20-2009, 01:05 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
• Catalyst Control Center, some HDMI monitor are not longer incorrectly
reported back as DVI
• Resolved video displaying in black and white when playing back high bitrate
AVCHD files
• Playing back some Blu-ray content with video acceleration disabled on
Cyberlink Power DVD_Cinema no longer results in no video rendering
• Fixed H.264 videos not rendering (black video) when Closed Captioning was
enabled
• Overlay Theater Mode now enables with a component video or composite
video in extended modes
• Playing some Blu-ray DVD titles on PowerDVD no longer shows the lower
portion of the player window intermittently appear shaky when playing Special
Features
• Some video shake is no longer observed when fast forwarding with certain
Blue-ray titles
hifiaudio2 is online now
post #5 of 71 Old 02-20-2009, 01:57 PM
Nighthog's Avatar
Well DXVA seems still not working whit 9.2 for XP users as it was whit the 9.1 release.
I have a HD3200 and used DXVAChecker_1.10.1.0 and I plainly only get these two things listed in Decoder Device:
Code:
ModeMPEG2_IDCT DXVA NV12 720x480/1280x720/1920x1080
ModeVC1_VLD DXVA2 NV12 720x480/1280x720/1920x1080
This means I basically get no DXVA accelration on any videos whit MPC-HC... Found only a few that maybe worked, those could be counted on one half hand though...
The little I've used it now I see really no diffrence really from before.
Nighthog is offline
post #6 of 71 Old 02-20-2009, 03:08 PM
kkozma's Avatar
Have they fixed being able to turn hardware acceleration back on in TMT for the 2600 series cards yet? Kinda defeats the purpose of the GPU if you have to use software acceleration to get smooth playback.
- Keith
kkozma is offline
post #7 of 71 Old 02-20-2009, 03:24 PM
severian1967's Avatar
How about HDMI audio out, and the EDID issue, which was reportedly resolved in Catalyst 9.1, but which did not work on my 3450?
severian1967 is offline
post #8 of 71 Old 02-20-2009, 03:26 PM
mattpwill's Avatar
Does anyone else beside me find that the UseBT601CSC=1 setting doesn't work for this new driver?
mattpwill is offline
post #9 of 71 Old 02-20-2009, 04:01 PM
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
-Dave
I Too; also What do most of you set the "Scaling Option" to????
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
post #10 of 71 Old 02-20-2009, 04:19 PM
DPlettner's Avatar
Rew
According to the help file:
Under Image Scaling, select Enable GPU scaling, and then select the desired setting:
Maintain aspect ratioTurns on Ratiometric Expansion and scales the frame buffer horizontally and/or vertically up to the panel size while maintaining the wide-panel aspect ratio of the original mode.
Scale image to full panel sizeTurns on Ratiometric Expansion and scales the frame buffer to fill the panel.
Use centered timingsTurns off Ratiometric Expansion. If you are using a smaller frame buffer image (800 x 600 resolution) than the native panel resolution, the image displays centered on the panel with black bars around it.
It seems to me that if I had a 1920x1080 display, and selected 1280x720, GPU scaling would scale up to and output 1920x1080. Therefore, GPU scaling should not matter if you are outputting at the native resolution of the panel.
However, I read a post that stated the GPU scaling is also used if the GPU is fed an SD stream, with the GPU upscaling the stream to the window size (or the panel size in full screen). The poster maintained that the quality of upscaling was better if GPU scaling was enable.
Frankly, I don't see much difference, but I leave it enabled.
-Dave
post #11 of 71 Old 02-20-2009, 04:24 PM
jeffreydeng's Avatar
'Tropical Thunder'(BD) still only shows blinking white when playing with PDVD Ultra. I go back to 8.12.
jeffreydeng is offline
post #12 of 71 Old 02-20-2009, 04:31 PM
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
-Dave
Thanks; but..
I always thought GPU did all the scaling if necessary.
Still not sure what setting is the better?
Rew
post #13 of 71 Old 02-20-2009, 05:17 PM
DPlettner's Avatar
Thanks; but..
I did some more searching, and it looks like ATI added this option for digital panels so that the GPU could do the scaling instead of the display, since the GPU can do scaling better than a typical display. For example, if you play a video game at 1024x768 to get a decent frame rate, the GPU would then upscale to the resolution of the panel, instead of the panel.
The setting probably makes no difference if you are outputting at the native resolution of the panel.
-Dave
post #14 of 71 Old 02-20-2009, 07:37 PM
nijel8's Avatar
-Dave
Found something:
Enabling ITC Processing for DTVs
ITC processing is a feature that enables display processors to use the appropriate pixel data processing algorithms based on specific content type to ensure video quality.
With ITC processing, the graphics driver enables the display to use its own video quality processing algorithms for movies played in full-screen mode on HDMI™ displays.
Note: This feature is available only for DTVs connected with HDMI cables and may not be available for all systems.
From the Graphics Settings tree, expand DTV.
Click Attributes.
Select or clear Enable ITC Processing as appropriate.
Select—Enables ITC processing for HDMI displays that are capable of the feature. When movies are played in full-screen mode, the display’s processors can be used to ensure video quality.
Clear—Disables ITC processing. Video quality is ensured by the graphics driver for all types of contents displayed.
nijel8 is offline
post #15 of 71 Old 02-20-2009, 07:43 PM
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
Thanks Guys. That seems to make sense,
Rew
Rew
post #16 of 71 Old 02-20-2009, 11:26 PM
sdheda's Avatar
I cannot seem to get multi-channel audio over HDMI. I have a 4670 and installed the latest ATI HDMI drivers (2.13) from Realtek's website.
Does anyone know how to fix this?
sdheda is offline
post #17 of 71 Old 02-21-2009, 02:36 AM - Thread Starter
daMaster's Avatar
Just tried 9.2 on a 780G chipset (onboard Radeon HD 3200) and the Pixel Format does indeed seem to stick on restarts.
Still gotta test on my Radeon HD 3470 discrete graphics card though.
daMaster is offline
post #18 of 71 Old 02-21-2009, 03:33 AM
underzone's Avatar
...me too. I havent found a fix....http://forums.guru3d.com/showthread.php?t=288140
I will try the Vista driver on my Win7 x64 install though
underzone is offline
post #19 of 71 Old 02-21-2009, 06:40 AM
soulrider4ever's Avatar
Is anyone else having an issue with using 24HZ and the pixel format settings are always acting as Full - even when Limited is selected? IE - I am getting crushed blacks on HD content with 24hz enabled and I'm set to limited.
soulrider4ever is offline
post #20 of 71 Old 02-21-2009, 08:37 AM
djp952's Avatar
Indeed. Hate to cross-post, so I'll link instead:
http://thegreenbutton.com/forums/thread/337337.aspx
If you happen to be using Media Center, I corrected the black level issues on my PC (0-255/DVI) with a VMC-specific registry hack.
I can only speak for my own setups, but I prefer hacking VMC for 0-255 levels than messing with everything else. YMMV.
djp952 is offline
post #21 of 71 Old 02-21-2009, 09:34 AM
sdheda's Avatar
I reverted back to a previous catalyst version which I installed when I first got my card. I don't remember the number, but it solved the multi-channel audio problem. The UseBT601CSC=1 registry entry also started working again.
sdheda is offline
post #22 of 71 Old 02-21-2009, 10:03 AM
thiruvil's Avatar
Quoted: 16 Post(s)
I have the same problem with the pixel format always sticking to full RGB when I select Limited RGB. Think Limited RGB is broken in this release.
thiruvil is offline
post #23 of 71 Old 02-21-2009, 01:32 PM - Thread Starter
daMaster's Avatar
24Hz? Because Limited RGB works fine for me and sticks @ 60Hz.
daMaster is offline
post #24 of 71 Old 02-21-2009, 04:21 PM
fast---'s Avatar
installed 9.2 and still no fix for hdmi edid issues w/ HD4670, Denon 1909 and WinXP. continues to show up as DVI connection in CCC.
fast--- is offline
post #25 of 71 Old 02-21-2009, 05:11 PM
Ingram's Avatar
What resolution are you using?
Ingram is offline
post #26 of 71 Old 02-22-2009, 07:06 AM
I went back to 9.1 - my RGB limited / Full issues are gone > seems like they fix 1 thing - break 3 others :>
post #27 of 71 Old 02-22-2009, 07:17 AM
mpgxsvcd's Avatar
Quoted: 2473 Post(s)
Liked: 2221
They fixed it for Yamaha receivers in 9.1. So maybe Denon users are out of luck for now. We yelled pretty loudly about the problems for Yamaha receivers. Maybe you should do the same for the Denon receivers?
mpgxsvcd is offline
post #28 of 71 Old 02-22-2009, 08:50 AM
mattpwill's Avatar
Using the new level expansion method in Vista Media Center and ATI 9.2 driver, does it also convert 601 colorspace to 709 (as well as 16-135 to 0-255) to provide accurate color?
Thanks for any help
post #29 of 71 Old 02-22-2009, 09:08 AM
Riptide_NVN's Avatar
Quoted: 68 Post(s)
Liked: 38
Looks like ATI did something to the way the card outputs it's signal and man has it totally freaked out my Sony XBR6.
I am not the only one having the problem. First my post, then the other.
http://www.avsforum.com/avs-vb/showt...5#post15874465
I installed the new Catalyst 9.2 driver that just came out. Now the 37XBR6 is stuck in some weird video mode. When I go into the settings under picture adjustments and try to change the picture mode I only have two choices. "Text" or "Video".
If I go down to Video/Photo optimizer the display still says "Photo" - but it's grayed out and I can't change it.
What the hell?
"Vivid", "Photo-Standard", "Photo-Custom", and "Photo-Original" are all gone!
http://www.avsforum.com/avs-vb/showt...3#post15883293
yep, same result here. the tv is now detecting the signal as a PC, it used to be detected as 16:9 1080p/60.
now the only Picture Mode profiles are Text or Video. All the video processing is disabled. The Home -> Screen menu does show the signal correctly as 1920x1080/60Hz.
ATI must have changed the way the signal is output.
Riptide_NVN is offline
post #30 of 71 Old 02-22-2009, 11:10 AM
DPlettner's Avatar
Does enabling/disabling ITC Processing make any difference? Based on the description posted above by Nijel8, it sounds like it might signal the display whether or not to make certian display processing modes availble.
-Dave
Click Attributes.
Reply Home Theater Computers
