Best video capture codec? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-29-2002, 02:27 AM - Thread Starter
d!abolic's Avatar
What codec should i use to capture video? Is there any way that i can make captures that look as good as regular satellite broadcast? Without using those 10gb/hr codecs that is :)
"Wake up number thirty seven!"
d!abolic is offline
post #2 of 9 Old 01-31-2002, 03:13 AM - Thread Starter
d!abolic's Avatar
Anyone care? :D
d!abolic is offline
post #3 of 9 Old 01-31-2002, 06:46 PM
Accooe's Avatar
well you could record in a 10/gb codec (MJPEG) and convert to a MPEG 2 or DIVX (both with 2 pass) to get the best results (IMO).
Accooe is offline
post #4 of 9 Old 01-31-2002, 07:11 PM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
Thats pretty much the best way to do it, unless you can use HuffYUV (lossless ~2:1 compression) for the first pass.
Compressing directly to MPEG2 or DIVX will not give you the best quality results.
Andy K.
kromkamp is offline
post #5 of 9 Old 01-31-2002, 07:29 PM
Namlemez's Avatar
Seconded.
I usually do HuffYUV for the initial capture then compress to DivX on a faster computer. If my current HTPC wasn't 400Mhz, I'd probably just do straight to DivX.
Namlemez is offline
post #6 of 9 Old 02-02-2002, 02:53 AM - Thread Starter
d!abolic's Avatar
Ok so once i capture in HuffYUV, how do i compress it further? Also, what will give me the best quality - DivX or MPEG2?
d!abolic is offline
post #7 of 9 Old 02-02-2002, 03:32 AM
yawnmoth's Avatar
So HuffYUV is better than uncompressed?
Is HuffyYUV a codec you have to install, or what?
Does the hardware have to support it??
yawnmoth is offline
post #8 of 9 Old 02-02-2002, 07:04 AM
BigAl's Avatar
I prefer Picvideo MJPeg quality 19 setting for the initial capture, but yes it is around 9gb/hr given a clean satellite signal at 640x480 and uncompressed audio. On my P4 1.4 I see about a 40-50% cpu utilization with no dropped frames during capture.
If you've got the harddrive space I'm sure that huffyuv would be preferrable since it's lossless... never used it though.
If I want to remove commercials I edit them out using Virtual Dub and it's directstream capture.
For recompression I get the best quality using Microsofts Windows Media 8 Encoding Utility with the Windows Media 8 Encoder GUI. 100% quality based encoding w 1 pass vbr, I use the inverse telecine processor on movies. It takes about 3 hours to encode an hour of video and when you play back the movie it takes a significant amount of cpu... approx 70% of my p4, I've heard you need at least a 1ghz to play a wmv8 file. Resulting files are approx 1.5gb/hr.
BigAl is offline
post #9 of 9 Old 02-03-2002, 02:10 PM
Accooe's Avatar
kromkamp did a nice walkthru on converting mjpeg to mpeg 2.
I might add, forget about de-interlacing. Encode your video with interlace enabled and let the software decoder (or hardware) worrying about the de-interlacing.
Accooe is offline
Closed Thread Home Theater Computers
