6ch analog in? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-14-2009, 05:53 PM - Thread Starter
zryder's Avatar
So, do you guys know of any sound cards that deliver 6ch analog inputs, preferably somewhere close to 24bit 192khz? I would like to record my SACD's from my 6ch SADC player to multichannel, high bandwidth FLAC, if this is even possible.
Thanks in advance guys!
"The satisfaction of a great price will be overshadowed by the bitterness of poor quality."
Originally Posted by KO Abear
You still measure your TV in "inches"? Thats so cute! :D
zryder is offline
post #2 of 7 Old 03-15-2009, 10:04 AM - Thread Starter
zryder's Avatar
any ideas?
zryder is offline
post #3 of 7 Old 03-15-2009, 11:36 AM
Smitty2k1's Avatar
Afraid you are out of luck unless you look into professional solutions. It's pretty easy to copy DVD-A to you hard drive using a computer's DVD drive. I would figure SACD isn't too different.
Smitty2k1 is offline
post #4 of 7 Old 03-15-2009, 12:00 PM - Thread Starter
zryder's Avatar
Thanks.. I have found good ways of encoding DVD-A to Flac, for example... but it seems SACD is another beast all together. DVD-A's can be read by a DVD drive, but SACD's can not. they dont use the PCM architecture, they use Direct Stream Digital, wich aparently is a 1bit signal, and there are no computer drives in existance, that I am aware of, that can read SACD's. Nearly all SACD's are hybrid disks, in wich they store both the SACD and standard CD layers on the same disk, so when you put that in your drive, it only reads CD.
I wish there was a good way to do this...
zryder is offline
post #5 of 7 Old 03-15-2009, 06:08 PM
ROBSCIX's Avatar
The only type of card with that many inputs would be a pro grade recording card.
SACD's are a tricky beast and as you have found the drives are not avialable for the PC.
I haven't looked into this subject very much but if yor serious about it, perhpas some research is in order to find the most cost effective way to back up your SACD investments.
ROBSCIX is offline
post #6 of 7 Old 03-15-2009, 07:01 PM
phelmers's Avatar
I bought an M-Audio Firewire 1814 unit for under $300 not too long ago but haven't had time to try it with SACD's yet (even though its hooked up to a dedicated Pioneer DV-588A SACD player...). I wanted an external unit to avoid noise issues. It seemed to be the best deal at the time.
- Peter
phelmers is offline
post #7 of 7 Old 03-15-2009, 08:07 PM - Thread Starter
zryder's Avatar
let me know how those solutions work out for you guys, i would be curious. sad that there isnt anything under $300 that will do anything close to what I am looking for..
zryder is offline
Reply Home Theater Computers
