TotalMedia Theatre 3 Platinum - Page 114 - AVS Forum | Home Theater Discussions And Reviews
Old 12-11-2010, 01:42 AM
Chalupacabra's Avatar
Rechecked the e-mail from ArcSoft. Missed the message at the bottom. Since I'm deleting it before I leave, it's all good. Thanks again Samuri for the reply.
Chalupacabra is offline
Old 12-26-2010, 07:39 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 56
I am new to TMT3. Is there a way to playback HDTV MPEG2 transport stream files(.ts) seamlessly if the movie is across several smaller files. At the moment the player returns to the beginning of the same file instead of moving on to the next file.
Thank you!
Alan Gouger is offline
Old 12-26-2010, 04:58 PM
Davinleeds's Avatar
A few years ago my Autumn Wave Gt recorded in small files. I was recording the remastered Star Trek. I had your issue. Changed settings to not cut to small files (ts) and TMT played my remastered recordings fine.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
Old 12-28-2010, 08:13 AM
jimwhite's Avatar
you can concatenate all the small files into one with a DOS copy command or there is a utility that would do it, but I can't remember the name...
Jim White
St. Petersburg, FL
jimwhite is offline
Old 12-28-2010, 08:50 AM
salacious's Avatar
do you mean
copy /B inputfile1+inputfile2+inputfile3 outputfilename
__________________________
Blu-Rays 100
HD DVDs 65
DVDs 300+
salacious is offline
Old 12-28-2010, 08:54 AM
SamuriHL's Avatar
Originally Posted by salacious View Post
do you mean
Yes, but, I would HIGHLY recommend using eac3to to extract seamless branched titles and "stitch" them together correctly. Otherwise you may run into issues even with the single file.
SamuriHL is offline
Old 12-28-2010, 10:13 AM
vladd's Avatar
Liked: 39
You've been messing with Bluray too long. Alan asked about "HDTV MPEG2 transport stream files(.ts)"
copy /b should work fine.
vladd is offline
Old 12-28-2010, 10:14 AM
SamuriHL's Avatar
WOOPS! Yea, I was definitely thinking blu-ray. My bad.
SamuriHL is offline
Old 01-14-2011, 05:37 PM
jrolmstd's Avatar
Having some problems with the TMT 5 and the Media Center plug-in. TMT 5 starts up and plays the movie file just fine but when I stop/exit/return out of the movie, it takes me back to the WMC TMT load page where for some reason the MCE return will not take me back the the previous page (works ever where else).
Any suggestions?
thanks
jrolmstd is offline
Old 01-14-2011, 06:07 PM
tehowell's Avatar
Any suggestions?
thanks
There is a known problem with the "back" button. You can use the "green" button as a temporary workaround.
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
Old 01-14-2011, 06:12 PM
adidino's Avatar
Quoted: 309 Post(s)
Liked: 238
It's not exactly an issue with the back button. It's an issue with TMT5 playing native dvd (video_ts) format and a couple of formats TMT attempts to play. The back button works fine when playing actual discs or ISO files.
adidino is online now
Old 04-30-2011, 09:52 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
Anyone else having problems playing DVD folder rips (VIDEO_TS) is TMT3 with the .190 update? It all works fine in .185, but after the update, if I try and play a DVD folder, after a couple of seconds, the program crashes. I'm using SIMHD as normal.
I've just checked, and DVD discs also crash the program. MKV's play fine though.
tman247 is offline
Old 04-30-2011, 03:41 PM
pbo
pbo's Avatar
It works on mine.
Paul O'Neal
International Networking, Inc
pbo is offline
Old 06-27-2011, 05:13 AM
facepalm's Avatar
Hello.
Can somebody tell me what are the correct ati drivers + tmt3 version so i dont get video stutter / audio popping?
facepalm is offline
Old 06-27-2011, 04:06 PM
Davinleeds's Avatar
Which card? I have 6450/11.4 driver/TMT3.190 working well.
Old 07-11-2011, 04:23 AM
facepalm's Avatar
oh my. this must be the only setup i havent tried yet. tmt working and silent stream bug / pops / distortion is gone. using 5770. thank you man!
facepalm is offline
