Arcsoft TMT 3 Platium is not working with Media Browser.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-23-2009, 11:44 PM - Thread Starter
96redformula's Avatar
Anybody having problems with Arcsoft and Media Browser. I redirected the link to the right file and it will open arcsoft total media theater 3 platinum, but WILL NOT start the movie. I am trying to play blu-ray folders via VMC using media browser, had been doing it for a long time with TMT 2 vanilla.
Should Run TMT3 Platinum from Media Browser to play Blu-Ray Folder Structure.
Here is my Config file for Media Browser.
false
1
1
1
0
0
0
0
false
220
220
0
0
0.05
true
.dvr-ms,.wmv
false
true
true
true
2
C:\\ProgramData\\MediaBrowser\\StartupFolder
true
true
C:\\Program Files\\DAEMON Tools Lite\\daemon.exe
E
true
false
LightSkyBlue
false
false
false
false
false
2007-01-01T00:00:00-07:00
true
Poster
true
false
2
the|a|an
true
false
470
false
true
0.1
en
BluRay
"C:\\Program Files\\ArcSoft\\TotalMedia Theatre 3\\uMCEDVDPlayer.exe"
"{0}"
Default
Default
false
false
false
false
true
Media Library
Default
true
50
false
96redformula is offline
post #2 of 15 Old 03-24-2009, 12:07 AM - Thread Starter
Upon further investigation it seems that the file playerloader.mcl is what is connecting the two together (VMC and TMT3) It seems they have a new way of doing it and it works completely different. I am no expert at this, but it sure seems like the culprit. Compare running playerloader.mcl from your TMT2 folder to the new playerloarder.mci from your TMT3 folder.
Tired, frustrated, going to bed .
post #3 of 15 Old 03-24-2009, 06:00 AM
cybrsage's Avatar
Liked: 154
TMT3 is no longer an external app, but it is now embedded into VMC (like the VMC DVD player is).
I wonder what will happen if no external apps are listed, but autoplay is used instead.
cybrsage is offline
post #4 of 15 Old 03-24-2009, 02:22 PM - Thread Starter
Bump for importance.
post #5 of 15 Old 03-24-2009, 02:37 PM
genro's Avatar
Yes, have you tried via autoplay and not defining an external app? That's how I currently have TMT2 working with Mediabrowser, but of course I'm only doing this for BD discs/isos.
genro is offline
post #6 of 15 Old 03-24-2009, 02:55 PM
cybrsage's Avatar
Liked: 154
Yes, it works perfectly with TMT 2.
TMT 3 uses a different type of program. They actually are fully integrated into VMC instead of being a seperate application. Not sure of the specifics, but it is very different from TMT 2.
cybrsage is offline
post #7 of 15 Old 03-25-2009, 12:16 PM
cybrsage's Avatar
Liked: 154
This is also being discussed here:
http://www.avsforum.com/avs-vb/showt...094009&page=32
cybrsage is offline
post #8 of 15 Old 03-26-2009, 03:04 PM
sh1ft3rDtCom's Avatar
Definitely not good, hope this gets fixed so I can purchase TMT3 w/ 30% off before end of tomorrow.
sh1ft3rDtCom is offline
post #9 of 15 Old 04-02-2009, 12:24 AM
TestLabMonkey's Avatar
Ok here is where I am at. If I do not modify the media browser xml file I get a black screen with audio which looks like MC attempting to play the file natively. The video time bar and functions all work perfectly but no video is being decoded.
Config the xml file to externally launch uMCEDVDPlayer.exe causes TMT3 to load but no start the movie due to the fact that the MCE player does not allow the playing of media folders.
Using uDigital Theatre.exe works in the fact that it loads TMT3 and starts playing the movie HOWEVER mc is kept open in front of the TMT3 window so not a lot of help there.
Has anyone had any more success using the two programs together?
This was done using W7 beta build 7068, Media Browser 2.0.11.0, TMT3 and AnyDvd HD
TestLabMonkey is offline
post #10 of 15 Old 04-02-2009, 09:10 AM
cybrsage's Avatar
Liked: 154
I should have updated my posts in this thread.
I did a complete reinstall of Vista 32 and installed TMT 3 on it. I did not install TMT 2 first. I installed MB last and it works perfectly.
I use ISOs, mounted by VCD.
cybrsage is offline
post #11 of 15 Old 04-02-2009, 09:22 AM - Thread Starter
Yeah, I saw that you all got a solution for the ISOs, but what about those of us with 100+ Blu-Ray folders already .....
post #12 of 15 Old 04-02-2009, 03:36 PM
cybrsage's Avatar
Liked: 154
I could not get it to work, it kept saying the file was missing.
cybrsage is offline
post #13 of 15 Old 04-02-2009, 05:40 PM
Damn thats a decent amount of data storage :P
post #14 of 15 Old 04-02-2009, 05:42 PM
Well my install is on Windows 7 beta build 7068 and it was a clean install with no TMT2 either and the results are what I posted earlier which seem to be different errors to the Vista ones.
post #15 of 15 Old 05-18-2009, 08:28 PM
Has this been resolved in TMT 3?
Reply Home Theater Computers
