Forcing Resolutions on TV through HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-29-2009, 12:22 PM - Thread Starter
PainlessProd's Avatar
I have a custom HTPC running vista Ultimate with a radeon 2600 Pro with latest drivers and caatalyst suite out to hdmi via dvi and optical out running to a Yamaha RX-V1800 AV Receiver then from there to a Samsung LN-T4661F TV. I constantly switch inputs on the amp to switch between my pvr and other devices like xbox etc via channels on the amp.
Heres the problem, whenver i switch away from the pc to another signal such as the pvr adn then switch back to my pc i lose my desired resolution. I run the pc at 1080i and it always wants to go back to some crappy resolution. Has anyone found a way within vista or radeon in general to keep resolutions at the desired level. For debugging sake whenever i switch back my pc makes the new device found noise like when you plug in a usb cable which i guess is to be expected since the amp cuts the line to the tv every time i switch inputs.
Any suggestions or links in the right direction would be appreciated
PainlessProd is offline
post #2 of 3 Old 03-29-2009, 12:27 PM
vice1986's Avatar
Check out this sticky thread. May be of some help.
http://www.avsforum.com/avs-vb/showthread.php?t=206854
vice1986 is offline
post #3 of 3 Old 03-30-2009, 10:38 AM - Thread Starter
that seems a lil different than the issue im xp'ing
Reply Home Theater Computers
