Need help connecting PC to an old CRT TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-08-2009, 01:50 PM - Thread Starter
zippydan99's Avatar
Not sure if I'm posting in the right section, but here goes.
I'm trying to connect my PC to an old CRT TV via S-Video. The connection displays just fine, but the problem is a DVD player and Satelite tv is connected to the TV too. When I plug the S-Video at the TV, I can't view my satelite tv and all I got is only audio.
Here is a photo of the CRT TV's back panel.
Is there a cheap solution or workaround for this problem? Any ideas?
zippydan99 is offline
post #2 of 15 Old 04-08-2009, 04:41 PM
walford's Avatar
I can not get the picture on my PC.
So how is the satellite STB connecte to the TV? If it is using a comnposite connection then the TV can most likely not have both an S_video and a composite video connecton connected at the same time. How do you tell your TV which one to use?
walford is offline
post #3 of 15 Old 04-08-2009, 05:22 PM - Thread Starter
zippydan99's Avatar
Sorry here's the photo again
post #4 of 15 Old 04-08-2009, 05:34 PM
Davinleeds's Avatar
I think it's either/or for the AV1 connection.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #5 of 15 Old 04-08-2009, 06:23 PM
walford's Avatar
Certainly makes sense since composite is actually a subset of S-video and the S-video connector is labled AV1 in the picture.
walford is offline
post #6 of 15 Old 04-08-2009, 06:32 PM
DJWikiera's Avatar
You can always move your satelite to AV2 then use your PC to play DVD's on AV1. Time to upgrade your TV.
DJWikiera is offline
post #7 of 15 Old 04-08-2009, 06:32 PM - Thread Starter
zippydan99's Avatar
ok will it be possible for the DVD player and satelite TV to share AV2 through a twin RCA jack like the photo below?
post #8 of 15 Old 04-08-2009, 06:33 PM
blue_z's Avatar
Quoted: 12 Post(s)
No, that's for audio, and does not have the 75-ohm characteristic impedance for video. You would need a video selector switch.
blue_z is offline
post #9 of 15 Old 04-08-2009, 06:34 PM
DJWikiera's Avatar
Yes, as long as they aren't powered up at the same time. You'll need to get a couple more to supply audio going that route, but it all won't fit. Get a switch.
post #10 of 15 Old 04-08-2009, 06:48 PM - Thread Starter
zippydan99's Avatar
That component jack is colored yellow, is it still considered audio?
Yup that's what i intend to do.Turn off dvd player to watch satelite TV and etc. Satelite TV audio will be connected to the composite audio and audio for the DVD player will be connected to a AV receiver.
I was worried I couldn't get the video right.
Alright will try that when I get home, thanks for the help!
post #11 of 15 Old 04-08-2009, 08:12 PM
rockytt's Avatar
Get a switch.
Hook the switch up to AV2 with the DVD player and the Sat STB-
Hook up the HTPC to AV1 (audio and Video cables)
rockytt is offline
post #12 of 15 Old 04-08-2009, 08:26 PM - Thread Starter
zippydan99's Avatar
ok now I'm getting a distortion on the DVD player even when the sat TV is turned off. Sat TV works fine when I turn off DVD player. Is there a possibility that the twin jack is faulty( i find the plug to be abit loose) or the jack just wouldn't do it for this case?
So getting a switch selector is the only way?
ps. i've found an old manual switch in my junk store room so that solves my problem! Thanks for all the help and replies
post #13 of 15 Old 04-08-2009, 08:33 PM
DJWikiera's Avatar
Just use your PC to play DVD's, then you don't have to spend any money.
post #14 of 15 Old 04-08-2009, 08:37 PM
walford's Avatar
The RCA jack in your picture is for splitting a composite connection to 2 different displays concurently. It is not for merging two composite inputs to a single display.
walford is offline
post #15 of 15 Old 04-08-2009, 09:30 PM - Thread Starter
zippydan99's Avatar
Just an old manual switch in my store room thanks for your help
Appreciate the explaination, cos i'm still very new to stuff like these. Thanks guys , keep rocking!
Reply Home Theater Computers
